View Full Version : Honda Prelude
- 1993 prelude ac acting kinda whack..
- Give me detailed instructions on how to replace my alternator
- Valve cover screw.
- Steering wheel
- I have H22A, what can I get rid of to make this car run the way it wants to.
- SRS Light
- problems reading/adjusting TPS
- light conversion
- Airbags Blown
- h22a4 acl bearings large or small main bearings?
- Transmission/gear engagement problem
- bolt pattern for a 4th gen lude
- hid kit for jdm one peice???????????
- i am doing a h23 vtec need help
- 2001 SH into a 97?
- dose newers prelude engine fix 91's prelude
- Whta is the difference between the JDM F20B and the stock prelude engine in a 99 Prelude?
- Crank Pulley Holder Tool
- what is the point of a valve adjustment?
- 2.2 VTec engine oil?
- Quick questio nabout throttle body
- long arm VS short arm air intake
- Prelude dies at idle. Need help.
- Steel Braided Brake Lines?
- CV axle problems with my prelude
- Dumb question but....
- f20b swap in for h23
- OEM custom grill?
- new lude owner, need info on oil changes...
- H22A redline and fuel cut?
- 99 Prelude SH oil leak questions.
- Intake Poll:
- Upgrading the whole prelude....got some questions!
- H22 Turbo vitals
- distributor problem? video
- Unplugged EGR Valve and no check engine light.
- clutch problem
- I can not locate my Intake Control Valve Solenoid. Help please asap.
- bad radiator?
- need to find a replacement part
- 5th Gen injectors
- Car bogs under full throttle after swap....???
- 98/Automatic - electrical problems maybe? Check engine light
- Loose Wheels
- Has anyone used SH springs with aftermarket shocks?
- jdm ecu
- has anyone used the new kteller header?
- I think my transmission is going...help?
- Power Steering Removal 4th gen
- Spring's installed incorrectly..???
- Rota wheel size 5th gen
- spun a main
- HeadStuds
- Valve adjustment question
- 94-96 VTEC Console E-brake Question
- M2B4 - can I use a USDM 4th gear?
- HELP!
- how do you keep your head lights clean from exterior oxidation?
- 1990 Prelude Overheating
- SHift boot fitting
- '92 Dome Light....
- Automatic to maual conversion
- CUP HOLDERS!?!?!?!? 1992 prelude
- Need advise on getting my H22 Lude started again
- Harness
- ECU
- o2 sensor
- QUESTION ABOUT SHIFTLINKAGE
- Collective Racing site!
- 1987 1.8 carb, alternator problem?
- quick question on the gauge cluster
- 1997 Prelude Semi Automatic VSS location?
- Caliper Problems
- Radiator replacement
- Need Help!!!!!!!!!!!ASAP
- h22a (powersteering, ac, cruise)
- 4th gen, what lip kit is that?
- Help with fuel issue
- f22b?
- wiring harness? 1999 honda civic dx TO 98 H22A4?
- Internal Coil Dizzy - External Coil Engine Harness?
- Prelude Front Collision repair :)
- Lightweight battery and civic alt
- This sucks !!! Idle fluctuates, and doesn't want to go below 1200 rpm. WTF !!
- valve cover problem
- IF u got the cash 4 MUGEN
- H22 Water Pump replacement - gasket maker?
- Who has the RED 4th gen w/ the Jackson racing supercharger
- Flywheel Dust Shield? (searched)
- 1992 honda prelude si turbo
- h23 dilemma
- Please help, loss of power steering/poss timing belt break?
- steering wheel shakes
- skunk 2 coilovers...front hella higher and back low
- gasket
- 1994 Honda Prelude SOHC with iridium plugs
- No matter what I do my Lude continues to stall.
- My quest to fix the speedometer
- Bleeder valve where is it ?
- convertion auto to stick 5th gen
- camber kits
- bumper clips
- i need help with my turbo!!!
- ecu question (iab) 12 volt or negative
- good tires
- Possible H23 Turbo Project
- Aftermarket valve spring on a stock cam... problems eh???
- My 5th Gen 2001 Mugen Honda Prelude!
- Taking off a fender
- Removal of an ac line
- Start up and Idle issues
- 92 Dash Harness questions?
- changover Question
- Turning Steering Wheel = RPM Loss?
- H23 disaster
- Help !!!!!!!
- Lookin for Picture of 4th Gen with Sportmax 501 or 002 rims...
- 97+ wheel bearing info
- Stock catalytic converter length for 92 H23
- f22b2 block with f20b head and pistons build question
- Aftermarket manifold vacumm researve tank use ?
- obd2 to obd1
- NOOB question can you use the h22a wire harness for a f22?
- h22 swap
- Wiring Harness Question?
- ATTS question
- Denso K20PR-L11 ND
- Prelude Turbo
- Bottom end rebuild! Cost?
- 98 H22 M/T engine wiring harness
- WANTED ASAP...Shifter and Cables 89-91 Prelude
- Parts help
- Need some info!!!
- Rebuilding H22 Questions About What Pistons
- Low idle when AC is on...
- surging idle to 2500rpm?
- Looking for a member...
- Good headers to put on.....
- Aftermarket Steering Wheel question.
- LUK Gold Pro prelude clutch
- Air box
- what is the most you rev an h22a on its stock crank with blowing it?
- Rods for the F20B
- Distributor Problems
- auto to manual questions
- Total loss of power
- Old school HondaPrelude.com members Check in!!!
- where do i find camber kit for a 98 prelude?? help plz!!!
- which O2 sensor to get?
- crank pos senser
- Exhaust Flange from Header to Cat
- help with installing skunk 2 IM
- Help for removing Rotors.
- 4thgen spring rates
- Look Prelude Owners (Plexi glass roof) PIcs
- 5th Gen Mugen rear spoiler
- 5th Gen Turbo Help
- Hondaautomotiveparts.com
- new oil pump?
- Cant get the girdle off if my life depended on it? HELP!!?
- Does exhaust material affect exhaust tone ?
- 4th gen rear windshield wiper
- Strut Mounts
- 95 Prelude brake lights/fuse box
- Blue Tinted Mirrors
- need help w/ 97 prelude....timing and leaking oil
- Gearbox question
- Installing A/C in the lude ----- NEED Advice
- -SRS question-
- checking code for my CEL
- h22 block F22 block, parts needed...
- front main seal install, does this look right to you? *PIX*
- ground control lowering
- Anyone know how to contact Randy at RMF?
- Spark plugs, FPR, and Nitrous
- h22 no compression
- Aeromotive FPR + H22 = ??? (searched)
- h22a idling (searched)
- clutch
- Help finding FULL H22A swap
- no more reverse
- some quick help please??
- 97 Prelude Service Manual (rewiring engine harness)
- Anybody rebuild h22a in the honda forums
- About new car
- whats the problem blue smoke coming out
- H22A1 weight?
- 4th gen front motor mount question
- Where to tap oil pan (searched)
- Lude Runs Like CRAP!!!!
- 1997 Honda Prelude MK5 2.2 ltr Triptronic transmission troubleshooting
- In desperate need of help
- skunk 2 coilovers for civics on 97 prelude?
- El Conversion
- alternatives for clutch master cyl. hard line?
- H22A got tooooned
- pulled trans out to do clutch install, now 4ws light will not go out?? anyone???
- MSD blaster coil and Hondata
- pic of intake mani plz
- Air intake Wrap
- Fogged JDM headlights (cleaning them, clearing them)
- pic request: H22 ignition coil
- one more dum question b4 i hit the sack. mr2 turbo retro fit to prelude
- Installing EL gauges.
- m2l4 trans?
- New England Meet? MA NH ME 5/19/07
- im just learning about materials of headers but what material is the best?
- anybody coat inside of header (4-2-1) with axle grease?
- lock noises
- h22 IAC
- power steering gone...:(
- which ngk spark plugs are good?
- h22 h23 cheap built parts
- h23 h22 cheaappppppppp
- TPS, IAT, IACV wire colors? OBD1 Harness!
- all motor intake manifolds for h22a4
- Timing belt help
- block EGR and get rid of CEL?
- 93 lude idle screw
- Brand of upper control arm...
- rad fluid drain and refill
- Prelude alternator bracket?
- s2k start button (searched)
- steering wheel shakes like an earthquake...
- 5th gen headlight/sidemarker issues
- CROWER OR SKUNK 2
- Compression test #s.. 3rd Gen, 1991 Si Prelude 2.0L
- Stock wheel offset
- Hondata Intake Manifold Gasket! Problems!
- Oversized pulleys
- Vtech prob
- 1990 Prelude 2.0 SI Blue Paint Code
- Front Lower Ball-Joint Install?
- Camp1320 Header
- Wierd Problem, PLEASE HELP!!!
- My 1998 SH, start to... not quite finished (pics)
- m2B4 or m2F4 trans
- Where's all the pics gone to?
- High Idle Problem need help
- injectors how many cc's
- 5th gen Fan which is the ground wire?
- H22 parts
- 92 Prelude Si H23 Idle Problems
- 4th GEN fogs without the covers? what did you do?
- Fast idle valve or something else
- Not for Prelude but need Help
- prelude turbo set up?
- H22 prelude
- Checking to see how much I can get for my lude.
- Tein S-tech problem??
