View Full Version : Honda Prelude
- Power loss
- JRSC & Fuel rail
- a/c WON"T shut off please HELP!!!!
- 260 psi compression test!!!
- wtf is in my coolant overflow?
- any site better then Hondaautomotiveparts.com for exploded views?
- h22a timing belt problem...sliding off....
- where teh heck is the oil filter
- anyone have reviews on the aem wideband?
- Clutch Pedal Height
- window probs!!
- Harmonic Balancer, can I remove?
- Increase lift and durration on stock cams?
- which ecu for jdm h22
- ARP wheel lug studs
- "spiky" a/f
- euro-r spec obd-II
- auto to manuel swap around mid-west area
- Amber Turn Signals
- Car is overheating after radiator install!!! Need help fast!!
- back from dyno with modded im
- my 5th gen prelude wont go into reverse
- Clutch Install DIY or PAY
- h22 euro-R installed into an EK , having problems with the IACV
- Engine size
- SkidPad
- JDM H22A Problems
- Fixing syncros?
- strange.. strange power door lock issues..
- whats the best mod youve ever done...
- Question for sleeved closed deck h-series guys???
- Turbo or All Motor
- Did a search, few extra questions on p13 obd1 / 2 questions
- H23 diff in a H22
- Odb2 pi3 auto for sale
- I need some help....
- MSD modified cap & external coil hookup???
- CKP Sensor....
- Turbo Prelude on Ebay
- KYB AGX adjustment knob is smashed. Can it be repaired??
- Jdm Fog Lights Vs USDM Fog Lights
- 5-speed swap worth this much
- signal and windshield wiper levers
- Too poor to buy JDM fogs
- Motor swap question ...
- crane cams/roller rocker arms
- usdm h22 transmission specs/codes
- Symptoms of a bad distributor
- 92-95 usdm prelude h22 tranni specs
- what motor came in the 88 lude?
- H23 Crank vs. H22 Crank - The Truth Comes Out...
- JG ENGINE EYNAMICS
- you guys really need to check this out..
- Need help to lower my oil pressure
- total-boost.com is for real!!!! just did my swap
- 4th gen prelude axles
- Buying a Prelude
- Wastegate question...
- BS or real?
- high miles
- For all you turbo prelude's help
- need help with cel
- Trouble Code #4 HELP!!!!
- Question on 4th Gen JDM head lights??
- need help !!!! cel code 20
- How many of you have removed the stock IM with motor still in the car (4th/5th Gen)
- Eagle Intake Manifold for our H22 motors
- Good Deal? or No?
- Where to buy Greddy Gracer Lip
- Anyone stock header/exhaust they want to sell???
- auto to 5 speed swap - if you have all the parts, how hard is it?
- Callin out all 96-up JRSC'ed ludes! pics needed!!!
- which msd ignition coil for 5th gen lude??
- s2000 rims?
- removing ABS - need help/advice
- Turbo Question
- Engine sputtering under 2.5k RPM???
- HONDATA
- Too much oil?!
- Change spark plugs for a turbo setup?
- Whats that light mean again
- Prelude SH OEM headunit same as Civic Si and ITR?
- Chassi set up for Prelude gen.4
- problem on start engine
- Need Help rebuilding H22a block
- Valves/Springs/Retainers for H23
- I was told something. About the H22 and H23 Parts.
- Skunk2 Valves
- 4WS and wheel size
- prelude trannies
- AEM or Iceman?????
- valve cover?
- Spoiler Functionality on '97-up Preludes
- Jackson Racing Supercharger on 4th gen Prelude
- h23 vtec wont start---distributor problems
- going all motor
- o2 sensor problem
- test pipe problems ! car stalling and bogging
- INSTALLED: AEM V2 on 5th Gen
- 4-speed Auto Phenomenon on my 86 Prelude Si
- Speed governor on a JDM H22A with P13??
- FS: Bride Zeta 2 and Schroth Harness
- VAFc VTM
- Free Mods
- question about door locks on 4th gens
- coilovers and camber kits????
- aem pulley kit
- base maps hondata or aem
- Rear strut bar for 5th gen worth it?
- B20 Vtec or Turbo Auto
- ac dont work...
- abs and 4ws lights
- help - sunroof
- wierd question...
- any 1 got pics of a 97-01 lude with Mugen MF10 wheels?
- H22A4 Turbo KIT
- Custom turbo
- Looking for 5th gen. R&D-car in northern NJ for P/S removal kits
- how do you access the intank fuel pump on 4G prelude ?
- how can you tell a 4th gen prelude si or vtec apart????
- battery not charging, how do i check for a short??
- going h22 to h23, a few questions? tia
- jdm 1 piece healights
- Tire Size Help For My 5th Gen 'Lude
- How 'bout this set up?
- CUSTOM 3" 4th gen lude downpipe
- Such a NOOb question but are h22 trannies cable or hydro, i need to know asap
- Revving to 8000RPM on stock internals in a del Sol
- h22 and h23 head bolts same size ?
- Nitrous
- Camber Kit Question???
- Lowering Spring Install Question???
- Interesting TSB on Emissions
- tighten/adjust e-brake on 4th gen???
- New Auto-Tensioner kit for the H22a
- JRSC power?
- JDM Type S Prelude strut bar installation... need suspension guru's input
- you think RS*R lowering springs would go well with koni yellows?
- 13second time slips
- 97lude turbo questions please HELP...please serious advice needed...!
- OEM Clutch w/ ACT HDPP ?
- DC sports Short Shift adapter
- Need info on camber kits
- 98 H22 USDM OS Pistons in my 95 H22..?
- clutch problem
- JR h22 powered ludes
- Hi all, need sum tips, please help
- Tires
- turboed lude
- Cars finally back...pistons, cams and all!
- 4gen radiators
- h22 still running lean
- valve adj time? pinging / tink noise comming in very low rpms
- JDM sidemarkers
- are all cheap rims heavy?
- How to wire JDM fog lights without a wiring harness
- H22 Compression???
- Golden Eagle fuel rail install question
- Illuminted door sill??
- IAC not working.
- Seriously confused with my exhaust
- Dust collector
- aem no bypass aem w/bypass ingen cia?
- 5th gen bumper "damper". In front of the hood latch. WTF is it.
- if you have a 5th gen with oem shocks/springs, please read and help me. regards to my type s strut
- Accord Euro Type R Intake Manifold into a 99 Prelude VTEC
- Automatic h23 and mods
- 4th Gen Targa Top
- local prelude runs 26 psi
- 4th GEN or 5thGEN
- prelude got side swiped!!!!
- Automatic Transmissions....For a 1986 prelude Si...Any suggestions?
- does h22 headers fit on to a h23? noob question..
- 00 suspension on 92 lude?
- turbo question....please help
- getting caliper off ...
- hmm what to do......1985 prelude.......
- need suggestions on h22 valvetrain upgrade
- Converting a carbureted 2.0S to fuel injection to receive JDM B20A
- Compression Numbers
- when to rebuild?
- N/A Build Up ? please
- VAFC 2 Installation instruction for Accord with H22A OBD1
- Question about weight transfer compared to Integra
- Hi, where is the IAC located?
- ...cold air or short ram???
- Clutch replacement
- need help oil pressure ???
- Help Removing an IM off and 86 Prelude....
- aem cold air help
- wheel feels and sounds like it's coming off
- SMSP Exhaust
- Continual CV problems
- 1st gear vtec problem
- Longevity of the Thermal R&D?
- JDM Type S BB6 Strut Bar technical question....... *ahhhh you are kidding me!
- Not tech related but funny, kind of
- Some one who has ordered Konis from Ground Control....
- Adjustment Throttlebody
- help! where to buy good camber kit?(4th gen)
- Swap Question?
- Question about Mugen
- motor mounts
- 4 wheel steering issue. Just heard back from the dealer
- h22 tensioner problem.... HELP!
- how much does a vtec head weigh?
- arias pistons
- Just got my JDM H22 in the del Sol...now I have a couple questions
- Taking stock bottom end H22a4 to 8500
- what size turbo
- SEVERAL PROBLEMS WITH 4th GEN, PLEASE HELP!
- decah (lambo) door kit
- out with the altezza's, in with the custom's(pics)
- h22 turbo mani on a 4thgen f22a1
- h22 with h23 trans
- Egr question
- cheapest place to aquire a clutch masters clutch?
- Blue/Red Top H22a Catalog F20B, Type-S, SiR S-Spec, H23A VTEC, Type-R, Euro-R
- Reliability of 92 Si 4WS
- h22 type s for 4th gen?
- SERIOUS h22 turbo manifold problem!!!
- ---2 Moderators Added
- H23 Build up
- Two mufflers?
- ¿Were can I get a OJM complete bumper kit for my Prelude 99?
- About the ATTS Computer...
- Last minute and future items?
- Help with turbo choice
- 4th gen instrument panel bulbs (searched)
- Looking for a ECU
- Just made a website....Check out Prelude pics!!
- So Cal alignment shops
- whats bad about this
- best all motor rods for h22a (daily driver reliability) please post.....
- wont to put h22 head on h23 block
- Question about Prelude specs
- GT turbo help
- Exhaust
- Best Headers for a 4th gen lude vtec
- Proven Methods To 200+ WHP NA
- stock hp/tq
- nitrous bottle pressure
- Who would be interested in traction bars for a preludes?
- How do you drain the PS wrack of a 5th gen? (4th gen was easy, this is not)
- fuel pressure too high
- wanted:post PICS of 5gen with R33 body kit
- DOES ANYONE MAKE LSD FOR 2001 PRELUDE SH
- how fast can a lude go?
- orlando body kit retailer?
- Anyone have tires that are 245 wide???
