PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 [271] 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. sick and tired of babying 3rd gear...
  2. h22a eng.
  3. Manual Transmission Swap. Good or Bad?
  4. Any way to disengage the antenna?
  5. Engine Done!
  6. I got F*cked...valves...
  7. Type R throttle body can be used on H22's to increase hp, True/False
  8. What am I missing?
  9. Need advice on which engine to put in my 1990 Prelude Si, and where to find it.
  10. New to manual trans. tips plz
  11. FS: 97-up prelude tanabe super medalion hyper spec catback exhaust
  12. I was quoted 1500 parts and labor for lambo doors on the lude, by a respectable shop.
  13. EL cluster harness
  14. Skunk2 Exhaust
  15. FS (Free actually) OEM 5th gen stuff:
  16. H23 Header?
  17. Hey everone
  18. What color Berrings to use for H23
  19. ps pump belt removal
  20. JDM h22 type-s
  21. Looking for a H22a OEM crank pulley
  22. True or False EG civic with H22 can run with GSR ecu
  23. Doing a Compression test: NEED HELP QUICK
  24. prelude 3rd gen website
  25. Who wants to test a header?
  26. Looking for reputable seller - P13 ECU
  27. Selling taillights with yellow turn signals
  28. Is the Apexi N1 for 4. gen cat back?
  29. H23 and H22 Fuel Pump's the same?
  30. wiring harness h22a
  31. ecu help
  32. Question about Tein super sports
  33. are H motor fuel rails and B motors the same???
  34. where to get ome doors for cheap for 92-96 prelude
  35. ahhhhh, finally.......
  36. type s cams
  37. "quadrasteer" in a prelude???
  38. 97+ Prelude OEM Kit
  39. tech help!
  40. Any thoughts about the new REV-HARD bolt on turbo kit for th 4th & 5th Gen Preludes?
  41. SS Brake line install
  42. exhaust
  43. 98 Prelude making an odd noise when downshifting
  44. gRinding...
  45. How much will this cost to fix?
  46. someone wanna doublecheck my rebuild?Am i missing anything?
  47. Wiring harness
  48. getto gasket leak
  49. where in my engine bay is my EGR located? I threw a CEL!!!
  50. OUCH The Word is in....HONDA said I blew my....
  51. H23 Fuel Pump relay same as Main relay?
  52. FS: Arias Custom Forged H22a pistons
  53. WTB:4th gen mudflaps
  54. Wiring diagrams for OBD2 to OBD1 conversion harness?
  55. Who wants to wait for Skunk2? What about this. Anyone give it a try yet...
  56. Ok, PROOF! Balance shafts eliminated properly, cleanly, EFFECTIVELY!
  57. please help
  58. Introducing our newest moderator: Boosted97Lude... aka... Big Sam
  59. AEM cold air question
  60. New rod bearings
  61. JDM Install
  62. Alternator Problems
  63. anygood 2nd generation prelude sites?
  64. More Intake Talk
  65. price for 96 stock sawblade rims with tires?
  66. 5th gen prelude
  67. Opinions of EBAY "Spoon Spec" or "Mugen chips for P13 OBD1 Ecus?
  68. H&R Red Springs ?
  69. Tempest Racing
  70. how do you change tranny fluid?
  71. Crank Pulley
  72. H22 Direct port installation, where did you do it?
  73. Best 18" wheel size without scraping on your 5th gen
  74. Need help with parts...anyone selling these i will buy..
  75. Anyone need any parts...trying to get rid of these
  76. Cup holder holes ?
  77. Presenting your 2nd place Prelude!!!!!
  78. starting air valve
  79. Top Speed?
  80. Shaking
  81. H22 Power Increase
  82. computer chips jet ecu???? any response on power?
  83. need help with a short shifter for 5th gener
  84. Piston Questions
  85. 4th & 5th gen header differences
  86. People with 4th Gen Prelude Si with Carsound cats and aftermarket exhausts. I need your help
  87. VAFC in a 5th gen
  88. which relay is the flasher relay??
  89. Digital 6 Install Help (po.com member needed)!
  90. WTB: ANyone of you guys have a stock prelude shift knob?
  91. FS: Unorthodox Ultra SS pulleys (red)
  92. i got a tranny problem that i need help on!
  93. Assembling motor! Need engine bay pics ASAP!!
  94. rsx shiftknob into a 4th gen (***pics inside 56k warning***)
  95. serious motor problems
  96. compression equation
  97. H23 block vs. H22 block
  98. Can anyone help me find this? (Steering wheel)
  99. need help finding parts
  100. compression loss in three cylinders
  101. to engine swap, or move on?
  102. Firing order
  103. who had prodrive oil gear?? im thinking about getting one
  104. knockin high rpms when clutch is all they way end help
  105. STR intake manifold
  106. N2O question
  107. Looking for a h22 head.
  108. Do you have a good H23 tranny lying around?
  109. Help! spark plug flies out-breaking wire cover...
  110. 1st to 2nd Problems
  111. first time at the track last night
  112. Help me out guys... Racing hart question
  113. what header to get???
  114. OBDI-OBDII harness??
  115. Beefing Up Transmission?
  116. Broke into the 13's today!!
  117. Compretion Question!!!
  118. any one know the aint theft code for the prelude tape player?
  119. lip kit..
  120. hole in piston
  121. I'm retarded...Seafoam help pls.
  122. WTB 97-01 prelude injectors
  123. h22 vs. JDM h22
  124. Tranny/Clutch issue. Up again
  125. Got car back from gettin tuned.....10 mins later..
  126. gauge pod
  127. Hi 2 all LUDE fans from Russia
  128. if i blew the rings/ringlands, would i have crap in my oil pan?
  129. awhat other aig bags fit in a 92-96 prelude??
  130. Online Performance Shops?
  131. how to modify an Euro-R manifold for maximum power!
  132. Holy shit i just shat myself!
  133. Compression test
  134. The Classifieds Forum moves way to fast....
  135. Tech Help Needed (Limited to $3K)
  136. What's this worth... rebuilt H23A1
  137. h23 vtec??
  138. STR throttle body fixed.
  139. STR problem fixed. Thanks STR !
  140. part number on cams...
  141. still looking for...
  142. Help with some Prelude questions please...
  143. h22 stroker kit
  144. Crower cams - again
  145. check oil light on
  146. Supercharger problem please help
  147. Manual Tensioner
  148. Removing Rear Bumper Support - Quick Help!
  149. someone offered to sell me a Mugen style wing a while back.....
  150. Streetable H22A....Need Advice
  151. h-22 swap from new prelude typr SH to 95 accord
  152. Why is the Sh heavier than the S?
  153. I bought Prelude - old oil question
  154. stock head gasket thickness h22a1
  155. OBD2 -> OBD1 harness
  156. Spoon throttle body for prelude?
  157. Steering wheel adapter question...
  158. low speed throttle lag
  159. STR throttle body problem. Please help
  160. Just purchased Mickey Thompson ET's...Any suggestions?
  161. does the H22 have a block gridle?
  162. H22A2 vs. H22A4
  163. main&rod bearing colors on h23?
  164. question about intake for 4th gen ludes
  165. Unorthodox pulley kit
  166. H23 with 400+hp ..main bearing concerns
  167. how can you do this??
  168. For those of us who have some FPR tuning experience..
  169. Header Wrap worth it?...DC 4-2-1 CC
  170. Skunk2 H22 dyno plots and tech
  171. Dyno sheets
  172. 97+ Lude Interior
  173. fuel pump
  174. Prelude Exhaust
  175. Is it really worth it???
  176. Spent an hour on the hoist trying to locate my oil leak today
  177. fifth generation short shifter/adapt
  178. jet ecu chips
  179. help wit my 4gen
  180. Do performance spark plugs make a difference?
  181. FS h22 six puck clutch and lighten flywheel
  182. What's Wrong With My RPM? Why Is My RPM So LOW at Any Speed?
  183. ball joints question
  184. What's Wrong With My RPM? Running out of Options & Ideas... Is there a Honda God?
  185. FS: Tein HA....need to sell asap..only 3k miles
  186. what do you guys run
  187. different size Tein spirngs
  188. well...more problems
  189. struts and Type sh
  190. Trimming Bumpstops?
  191. shift kit
  192. n00b over size pistons question
  193. sunroof
  194. Prelude
  195. where can i get 4 gen airbags?
  196. prelude 01 headlight
  197. quick ? on legend calipers
  198. dropped my lude, one little detail
  199. need help quick, please read
  200. EuroR vs. spec-S?
  201. Switching Si -> VTEC brakes...
  202. knockin at high rpm h23a
  203. Prokit or Sportlines?
  204. ever seen a venom intake manifold up close?
  205. Super Street
  206. Just got my 98 Lude... Time to start my project... Help!!!
  207. Slave Cylinder
  208. Value of a 92 prelude si
  209. Want to confrim oil capacity for H22 in a 1998 prelude...
  210. Need Help !! (Source for Exaust manifold Flanges in Stainless) i know he's here in the prelude forum
  211. Tons of coolant pressure....why?
  212. Kosei K-1 15X7 5X114.3 1 rim needed
  213. Exhaust piping from KTeller8 - reviews wanted.
  214. Pulley kit???
  215. Skunk2 Manifold
  216. shift gate question
  217. I thought this wasnt supposed to exist???
  218. OBD2 walkaround?
  219. a good a/f ratio gauge???
  220. OK, I need an OFFICIAL typed article on two things. All my Tech heads are needed...
  221. h22a in a 92 lude si
  222. Wheels, Rota...Spoon...Mugen...Volk...?
  223. AC Vent Vibration
  224. F4 Gearbox Installation
  225. >>>WTB: Red Type S valve cover before this weekend!!!!!!
  226. torque specs??
  227. Aiming for mid 12s...thoughts?
  228. Where can I find the DIY for clearing 4th gen stock tail lights?
  229. b21a w/ gsr head? need advice!
  230. 4G headlight disassembly
  231. carbon fiber trunk?!?
  232. MOD please
  233. just a few questions for my friend
  234. Differnce between Si and VTEC exhaust systems.
  235. 2001 prelude
  236. boost creep w/ drag 4 h22 manifold
  237. Whos ridin on 16's?
  238. aftermarket shiftboot
  239. will VAFC help with alreadyI/H/E on a 00lude
  240. h22 wiring harness
  241. Where to find an H22 LSD tranny?
  242. jerk off?
  243. vibrations b/w 1-2k rpm
  244. replacing bushings
  245. H22 Intake and TB ?'s
  246. Free rotors...
  247. Ok just got some new wheels for the lude will 16x8 rub with low pros/////// on stock ride height
  248. removign axel, slight problem
  249. Is this worth it?
  250. Dyno tuning
