PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. My new BB6 = cel after cel...lol
  2. koni+gc spring rates?
  3. Unknown Part
  4. kinda new
  5. Things never seem to work out for me.
  6. prelude problems
  7. what comes after I/H/E ?
  8. low rpm stutter
  9. HELP!! H23A1 Engine won't Spark!!
  10. !!!!!Whats up with this!!!!!!!!!CLOCK!!!!!!!!!!!!!!!!!
  11. Need Help getting motor running right!
  12. H22a Code 1! Help, I'm stumped.
  13. 95 prelude h23 5 speed trany with h22a4 sh
  14. Euro R Prelude Front End (Hubs/Spindles/Rotor/Calipers/Etc)
  15. H22a1 main cap problem
  16. Walbro 255 and fuel pressure
  17. Clutch won't disengage
  18. Found a Honda Prelude 1993.
  19. 97 SH multiplex system fail
  20. WANTED TO BUY ONLY :: NO TRIAL USERS, NO PICTURES - Oct-Dec 2012
  21. FOR SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, PICS REQURED (as links) -Oct-Dec 2012
  22. newbie -- owner of 1988 prelude 2.0 Si 4Ws
  23. wiring diagram for a 4th gen jdm prelude climate control
  24. help finding a beaks bar for a 5th gen prelude!
  25. p13 code 13
  26. Stock 5g Injector Size/Response Time?
  27. dyno numbers for a stock h22a4
  28. my 1993 honda prelude wont start and no fire to the plugs
  29. H23 AUTO! performance ideas?
  30. Considering purchasing a 1982 Prelude and have a few questions.
  31. h22a allmotor
  32. 97 prelude cel code and low idle help!
  33. Are Clevite main/rod bearings any good...?
  34. 1996 JDM H22A Swap Help!! Im Stuck
  35. H23a vtec blue top misfire!!!!HELP!!!
  36. '97 Prelude SH, Clutch issue?
  37. How do I get A V-TEC in a Honda
  38. 93 prelude h22 won't start
  39. Red key wtf
  40. Brake pad questions
  41. 98 prelude automatic transmission issue
  42. Loose h22 timing belt?
  43. Cat or Vacuum leak?
  44. help a n00b out RHD prelude
  45. 97+ p.s. bracket needed
  46. What trim level?
  47. '92 Prelude Si Help
  48. VTEC not kickin in YO!
  49. 2000 Prelude Lost keys
  50. tps adjustment help
  51. What should come first when fixing up my car?
  52. identify this box, 1993 prelude.
  53. Honda Prelude '85
  54. vacuum hoses jackson racing
  55. alright honda techers... heres one
  56. Noob Question! Whats Hondata?
  57. 94 Prelude swap help
  58. just wanna know for sure, exhaust question
  59. Buying an H22a and need help!
  60. Newbie
  61. s2k or rsx seats in 5th gen?
  62. h22a4 rebuild help
  63. Clutch acting up.. + Engine heat question
  64. help please no start has spark no ground to injectors
  65. NEED HELP!
  66. why doesnt my a/c condenser fan turn on??
  67. Pic Request: 5th gen lude with basket roof rack??
  68. oil pump issues.
  69. Cams all stock on H22a4
  70. Rod knock
  71. 5 lug conversion (Yes I've read FAQ)
  72. engine question
  73. Power steering leak!?
  74. balance shaft and tps broke
  75. got new clutch, question now
  76. 5th gen ABS Motor Stuck ON - code 53. Please help!
  77. 92 prelude help
  78. BB4 93 prelude Si on LS Meshes??
  79. Why JDM F22B??
  80. H22a1 Idling @1500rpm -_-
  81. h22 idle problem. Tps?
  82. 4th gen lude transmission acting weird...
  83. Help me diagnose my clunking. VIDEO INSIDE
  84. just some swap questions
  85. Quick question!
  86. AC turbo car options.....or ideas
  87. NEED HELP FIRST LUDE
  88. Please help identify h22a
  89. JDM F22B dohc NON VTEC block / H22 dohc VTEC head???
  90. H22a charade-Only one in the world!
  91. 97 H22 to H23 Blue top Swap
  92. I NEED SOME HELP!! my a/t trans is shifting late and backwards.....
  93. Dry or Wet Sleeves for H22?
  94. photoshop request
  95. h22 cam gears. Need a little help..
  96. H22A4 w/atts ej1 motor swap problem !!!! help!!!!!
  97. h23 blue top injector size
  98. Honda Prelude 94 - 4WS Light goes on after battery change
  99. New clutch question
  100. Quick question?
  101. 93 prelude battery cables
  102. k2h qsd adpter
  103. wat sensor is this
  104. 16x22 dowel pin instead of 1/8npt plug for balance shaft removal?
  105. flash codes.. help
  106. 4th gen h22a obd1 swap and exaust
  107. 99 Prelude SH parts for SALE! (or trade)
  108. Stage 1 H22a1
  109. Honda Accord TypeR camshafts - gain HP & torque
  110. obd2 to obd 1 jumper, turns on and dies
  111. Restoring the lude
  112. Prelude smog help needed
  113. Could you retrofit 03-05 350z projectors on a BB4
  114. 92 prelude si stalls when hot
  115. Strange stutter problem
  116. HELP!!! 92 Prelude si blowing main ECU fuse: wont start: Solid check engine light
  117. Rod Knock on 1997 H22A4 ~ HELP!
  118. HELP just got a turbo project im tryn to get running
  119. ignition switch or main relay
  120. 98 prelude CEl p1491
  121. ecu in limp mode!!! help asap!!!
  122. b20 vtec or h22 swap 3rd gen
  123. Sorry going to bitch alittle
  124. Trying to tune/find a basemap for an H23?
  125. time for new muffler
  126. 92 prelude SI 2.3l torque spec question
  127. Fan Cfm
  128. 96 prelude si crank sensor bypass wiring
  129. Easiest place to fill tranny?
  130. cam identity need help.
  131. USDM 4G Fog Light Switch vs. USDM 5G Fog Light Switch
  132. CEL, Missfire in Cylinder 1, help please.
  133. 93 Prelude S, F22A4, No Fuel, No Spark...
  134. H23 vtec distributor pic of plug help!!!
  135. H22A 1/4 mile: Rpm needle going backwards in third - Odd rpm dependent issue (w/vids)
  136. Wheel wobble
  137. Backup lights wont turn on not the relay or bulbs
  138. 97 Prelude with JDM h23A Vtec Need help..
  139. Engine managment system
  140. 2001 Honda Prelude SH NO POWER HELP!
  141. Honda Prelude Transaxle.
  142. h23 automatic wiring
  143. 97 prelude looses power when hot out
  144. Super High Idle After Rebuild
  145. H22A type- S, Prelude Sh; J.R. Supercharger
  146. Have two gas lines & I need help!!!
  147. automatic transmission question
  148. Water pipe leak. What is the trick?
  149. Golden Eagle scatter shield HELP please.
  150. removing head off 94 prelude vtec quick quesiton..
  151. 97+ Bolt on dyno?
  152. downpipe help!!
  153. ls civic hatch or jdm b20 prelude
  154. 92 prelude brake line tuck
  155. Valve timing oil pressure
  156. Need help from the Gurus: H22a4 bogs after several miles.
  157. '98 FR Lower Control Arm Bushes
  158. Do different h22s require different tunes?
  159. 2000 Auto prelude
  160. h22a1 to h22a4 questions
  161. H22 Not Running Right
  162. Suspension recommendations?
  163. 93 prelude parts into civic?
  164. .014" copper headgasket
  165. 1997 Honda Prelude codes
  166. I could use a little help here.
  167. Battery question
  168. What oil weight do I use?
  169. Piston ring question
  170. Yet another WHICH BRAND gasket, rings, bearings topic..
  171. VSS question? H22/f22
  172. Stay away from Kittler's Auto Machine Shop in Shreveport LA!!!!
  173. Help with H23 engine noises - sound clips!
  174. Pros and Cons of an H22 Prelude
  175. 98 prelude dizzy wiring?
  176. H22a no power
  177. climate control
  178. h22 loosing ignition?
  179. H22 Running Rich!!
  180. power folding mirrors not folding
  181. jdm j22 not running right
  182. f20b???
  183. Will these fit?
  184. what lip kit is this?
  185. wiring schematic help
  186. Fresh up my prelude, bushing kit
  187. people i got questions can u help
  188. 88 prelude .40 how much horse power
  189. motor mounts on a DD
  190. H23 HELP!!!!!!!!
  191. h22a4 wont turn on
  192. Can I convert lambo doors to regulars doors?
  193. Help!! h23 to h22a4 swap problem
  194. 94 VTEC Overheating? Or not?
  195. ATTS is broken. any ideas?
  196. 205/60/15 on 4th gen
  197. 88 4WS Fuel Tank Swap-Which tanks fit?
  198. Cruise Control delete on 5th Gen (pics!) question
  199. 96 Prelude new a/c compressor not engaging
  200. H22 knock sensor symptoms?
  201. Knock sensor
  202. Getting a tune vs getting new motor
  203. Code 9 on H22
  204. inspection fail.
  205. What could possibly make this leak? Dartons sleeves with pictures
  206. OBD1 CAR TO OBD2 H22A SWAP
  207. Fuel Issues? Help please.
  208. Rare 4th gen fog light covers?
  209. H22a bogging at low rpms
  210. I put diesel oil in my h22
  211. power steering ?
  212. 95 Prelude VTEC Heater / AC Blower Question
  213. 98 sh- crankshaft pulley belt/ac belt replacement
  214. 98 prelude tuning questions
  215. Rev limiter kicking in way too early.
  216. H22A Can i replace my own Piston rings?
  217. vibration when off gas
  218. Acceleration suffering after new oil pan gasket
  219. cost to clean head/replace valve seals?
  220. H22 injector question
  221. H23a1 Rebuild
  222. H22 header question
  223. looking for prelude guys
  224. '89 Keeps bouncing "cool"
  225. Small problem with overheating...
  226. wiring H22 question
  227. h22 swap help plz!!!!
  228. 1993 prelude HELP?
  229. ECU Diffrence?
  230. will all h22 downpipes interchange
  231. what half radiator fits 93 si lude
  232. what half radiator fits 93 si lude
  233. Cracking open the old 'lude... Can't remember a few things...
  234. Crushed oil pan: Flickering/flashing oil light
  235. check engine light on after fueling
  236. Carbon fiber for my maaaan, help?
  237. H23a1... Compatable with F22 ?
  238. Automatic Shift Cable, '92 Prelude
  239. Which ecu to tune an auto 00' prelude?
  240. H22a boosting questions
  241. 92 Prelude SI F22b JDM swap stall out when at op temp
  242. EGR question
  243. 98 prelude oil light issue and engine problems
  244. installing hytech rep headers bb4?
  245. Coolant leaking
  246. H23A1 aftermarket coolant temp port?
  247. H22 Idle problem *Video Inside*
  248. new turbo'd engine build
  249. glasspack help!
  250. Suspension upgrade and rebuild
