PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. h22 jumping idle
  2. Valve Adjustment
  3. b21a1 INFO NEEDED~~!
  4. I havent been on here in years
  5. Will a f22a1 oil pan fit?
  6. problematic prelude
  7. H22 and f22 what about f20c?
  8. XTD fly wheel question
  9. stuck coilover collar
  10. Replacing power window hardware problem
  11. lobes on intake and exhuast?
  12. intake?
  13. ► WANTED TO BUY ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Feb/Mar 2011
  14. ► FOR SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Feb/Mar 2011
  15. Second gear problem
  16. 2.0i BB3 F20A4 - hoping to buy!!
  17. Prelude f22a/h22
  18. 18" TE 37 wheel hop/, smaller wheels w/ bigger tires? heavier wheels? Suspension?
  19. Grommet for CC delete?
  20. Removing rear seat?
  21. newb help
  22. JDM BB4 calipers same as USDM vtec?
  23. 93 Prelude Si w/ h22a4 ALTERNATOR CHARGING ISSUE
  24. P13 Obd2 Ecu
  25. show me some anti trailor queen 98+ preludes
  26. vtec problems after build
  27. gears grinding in cold weather...
  28. p28
  29. Prelude CEL P0136, P0138
  30. How to bleed 95 honda prelude shift line?
  31. HELP!?!? 2000 Prelude clutch destroyed!!
  32. Megan EZ Street Coilovers
  33. crazy idle
  34. Tein HA or Zeals b6
  35. 95 prelude si color
  36. Random misfire- only at idle, please help.
  37. clutch question
  38. P0135 O2 sensor heater wire malfunction
  39. Euro-R Header on Ebay, Is it legit???
  40. 1994 Honda Prelude
  41. h22 to f22b
  42. turbo H22 questions HELP!!!!!!
  43. Suggestions for Crank dampner and pulley replacement
  44. Won't start, cranks, new batt, smell fuel.
  45. Tri-y replica header.
  46. 1G Prelude Facebook Page...JOIN
  47. SH lude to base
  48. f22a1 question
  49. F20b Cam set up
  50. H23a1 Block Question.
  51. OBD1 to OBD2 ECU
  52. Intermittent starting problem!
  53. exhaust question
  54. Boosted 92 Prelude overheating Problem
  55. what is the best exhaust for a lowered lude
  56. Head work done
  57. 96 prelude front driver side fender needed
  58. H22a4 valve rebuild
  59. Passenger rear hub assembly question...
  60. where to get spoon lip that's not ebay too many fakes
  61. want your opinion
  62. prelude engine sway
  63. looking to use bigger valves on my h22?
  64. Whats the stock size mm for H22 Throttle Body
  65. 1995 Prelude ABS code
  66. 1980 Honda Prelude Build Thread
  67. vss on tranny?
  68. steering issue
  69. rough start when cold
  70. help! dropped something into gas tank
  71. Hello. Forum n00b. Honda n00b. New 5th Gen Lude owner here.
  72. Making H tranny as Competitive as H2b
  73. Cold Weather - No Oil - Engine Blew Up
  74. balance shaft Q
  75. Need some help...
  76. Hey everyone is this worth the price? help a brother out thanks!
  77. a question about the fan.
  78. Will a F20B fit in a 95 prelude?
  79. h23 rich,knocking and shaking engine HELP!
  80. Seafoaming the Lude
  81. boost
  82. 2000 prelude clutch problems
  83. 98 prelude h22a4 cable clutch?
  84. Need part numbers for Multiplex Control Unit
  85. Quick question
  86. jdm h22a help????????
  87. Injectors on h22's this loud? or is it the lma?
  88. Bellow dust boot
  89. 95 Prelude VTEC - starts, rough idle, dies shortly after, ...fuel issue?
  90. H22 to F22 swap
  91. Car Jerks when coming to a stop...
  92. headlights wont dim 96 prelude
  93. h23 to h23 vtech
  94. 3rd gren prelude rev limiter Q
  95. back from the desert and time to start the build.
  96. need help with spring
  97. **H22a4 Fully built-sleeved-low compresion** VALVE QUESTION!!
  98. Opinion on a '93 vtec 4thgen with a blown motor
  99. h22 fully built turbo will these cams hurt me
  100. What are the best Pistons to use for H23 Sleeve blocked?
  101. Whats the max i can sleeve my H23 Block?
  102. h23a1 cams
  103. cabin air filter
  104. New Tranny
  105. Still smoking Oil!!!! whats the deal...
  106. P1382 Cylinder position sensor
  107. h23 turbo build question??
  108. 91 prelude taking off the unneeded
  109. 95 prelude stuck in third gear.
  110. Blackstone Labs Oil Analysis
  111. ball joints ???
  112. Misfire when cold?
  113. ?Yet another Question dealing with my engine?
  114. 87 Honda prelude si
  115. prelude
  116. Vtec Question
  117. 97 lude h22a4 cuts off while driving
  118. Car wont start?
  119. Parts question?
  120. vss ?????
  121. s2000 steering wheel help
  122. Camber Kit
  123. Question: VTEC's
  124. Prelude 2001 not starting and low compression
  125. 98 prelude engine noise
  126. Can Ecu's go bad???
  127. Need Some More Opinions
  128. HELP! BUYIING A 5th GEN w *AUTO TRANNY
  129. :( 5th gen Wheel fitment Question
  130. H22A CONNECTING RODS?
  131. Help, problems with my lude, need opinions please...
  132. my clutch
  133. Need help with 3rd gen Trans swap!
  134. Sway Bar Endlinks
  135. Who's running nitrous??I need help on how to tap in the fuel.PLEASE
  136. 89 prelude si (4ws) B20A5 to B20A
  137. tripometer
  138. Water pump = FAIL
  139. Not that it matters, but it might help someone..
  140. three VSS still nothing
  141. day running lights
  142. oil cooler removal
  143. 1993 honda prelude vtec I want to get rid of the big brakes
  144. 1993 prelude camber options
  145. DIY: 4gp Air Condition removal
  146. TPS censor problem help please
  147. 91' Si w/b21, swap?
  148. Need help picking cams Tuner 2 vs pro1 (H2B)
  149. New to HT and new H22a build
  150. h22a4 distributor wiring?
  151. Knock Sensor Question
  152. 93 Prelude NO SPEEDO NO VTEC ??????
  153. 94 Preude heater?
  154. exact rim size please!!!
  155. difference b/w a '93 and '94 h22a1
  156. H22a1 vs H22a4
  157. D4 blinking and CEL with no speedo
  158. h22a4 swap no fuel
  159. Manual conversion on 99 prelude
  160. Air Condition delete help
  161. Bulbs for Instrument Cluster.
  162. 1997 Prelude Tip Tronic?
  163. driver and passenger seats
  164. How does the Vtec work?
  165. Clogged EGR ports
  166. Coolant problems? h22a eg
  167. 2001 Honda Prelude Oil Filter Housing oil leak
  168. Idle Surging When Cold - H23
  169. H22A1 issues....p13 ECU might not work
  170. 89 prelude won't engage in reverse.
  171. 92 prelude, HEATER control issue HELP pls
  172. Oil sensor
  173. M2S4 tranny hoses?
  174. h22 cams
  175. needs a wiring genius..LOL
  176. speedo only works when it warms up
  177. Wantin to boost my h22a
  178. H22 swap help
  179. h22 rebuild
  180. Wheel Fitment Question
  181. sunroof
  182. 4 to 5 lug conversion?
  183. Best 5th gen replica Mugen bumper?
  184. egr ports...
  185. Clutch or trans problem?
  186. Cruise control wont work in 92 prelude
  187. Prelude H22a No spark at all spark plug.
  188. prelude revs up and down
  189. h22a swap started fine but died after a few minutes
  190. h22a4 to h22a misfire
  191. plx dm-200 on 99 type s
  192. Help with Prelude Head Swap???
  193. sensor wire diagram
  194. My Ride: Jdm prelude type s
  195. need h22 part# flywheel cover
  196. Prelude = accord?
  197. Brake Force Distribution
  198. question about exhaust manifold
  199. h22 tube?
  200. H23A1 headache
  201. p13 swap pins a6 a11?
  202. h22 porting im tb
  203. quick question on left and right oil pressure sensors for atts
  204. Honda Accord Transmission Codes & Ratios
  205. H22A JDM
  206. Seals Needed!
  207. new to hondas
  208. Alarm System Acting Weird
  209. Iac valve issue
  210. HID Kit
  211. Alternator/Battery Light on HELP...
  212. Ran for two days after replacing battery.
  213. h22a swap from 91 accord ac compressor pulley doesn't line up ?
  214. Spoiler choices with CF trunk, many options
  215. car bogging at 3k rpm
  216. car dying while running? need suggestions please!
  217. Is my clutch going out?
  218. Making a Bet
  219. Turbo Gearing?
  220. H22A tcu help?
  221. How do i take the headlight out of my 94 honda prelude?
  222. I'd like to know if I can use H22 stock pistons/rods on an H23 stock crank.
  223. GT5 lude meets.
  224. Sk2 stage 2 camshafts h22
  225. New to autocross
  226. h22 and b series trans?
  227. With H22 (H2b) 11.1 compression how high can i rev?
  228. NEED HELP with a 1992 honda prelude
  229. Distributor Conversion
  230. hmmm, can this even be done?
  231. New Prelude
  232. Noob blew motor, need help please
  233. Aem v2 question
  234. saving a prelude
  235. 92-96 Honda prelude heated mirror switch?option in the states as well?
  236. H22 feels sluggish
  237. Replaced head gasket
  238. 94 honda prelude s
  239. 96 accord h22 brackets?????
  240. 4th Gen Clutch Problems
  241. oil control orifice on h22a4 block
  242. my new fuel system, ss clutch line kit
  243. performance parts?
  244. 4th gen climate control
  245. Replacing Piston Rings On H22a1
  246. F20B Intake Manifold/ H22 head
  247. Oh God Help Me... Engine Prob...Plz Read
  248. where is the abs module on 96 si lude?
  249. 5th gen - Koni + GC question
  250. trying to make it work
