PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 [132] 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. parking break adjustment?
  2. what to pull/disconnect for compression test
  3. 98 prelude h22a problem with oil consumption
  4. What should I get next?
  5. What do you guys think? Should i get this prelude?
  6. Odd electrical problem....
  7. help with my hesitation problem when car is warm!
  8. 98 honda prelude problem
  9. help with 5th gen rear speakers
  10. this might be a stupid question
  11. Can the greddy evo exhaust fit the si??
  12. Very strange and troubling cooling problems
  13. h22 timing drive pulley
  14. accord~prelude swap
  15. 4th Gen SC + poll
  16. Misfire Problem
  17. Engine restore with csl Review
  18. Suspension parts from other cars...
  19. how much longer is the 5th gen cat compared to the 4th gen cat?
  20. 92 Prelude, not cranking..
  21. oil filter question
  22. hondata....again.
  23. scratchy sound at 2800 RPMs
  24. my car is bogging down and vtec is not kicking in
  25. taking my 96 lude out of storage
  26. H22 Eagle rod bolts torque
  27. 4th gen + mods + CA Smog
  28. still Idle problem(IACV, FACV, EGR cleaned)searched..............
  29. obx short shifter???
  30. header for vtec prelude - not a honda guy need help for the GF's car
  31. whats it worth?
  32. <<<<<< 93 Lude - JDM Headlights, wiring harness's are melting >>>>>
  33. tire wear
  34. Where the main relay located at? plz help
  35. 5 speed conversion on a 92-96 lude
  36. greddy evo on si
  37. 94-96 El gauge cluster install help into a 92 lude
  38. HOnda prelude needs help
  39. HOnda prelude needs
  40. cooling system question
  41. Single Row VS. Dual Row Radiator
  42. How Can I put 5*100 wheels on my 97 Prelude (5*114.3)? Please help me~
  43. Oil recommendation
  44. Questions/ideas about bone yard boost (G23) .. cheaper the better.
  45. Turn singnals don't work
  46. 5th Gen Eyebrows
  47. Squealing clutch
  48. What are the (driving) symptoms of bent valves?
  49. 98 prelude shifting problem
  50. Help H22Vtec will not work!~
  51. Shift/Transmission Problem
  52. Question About Milling Head to Gain Compression. (searched)
  53. Need a new radiator for my 93 VTEC
  54. I did a bad bad thing
  55. 97 5th gen - how to drop a s2000 head in?
  56. 92 prelude vtech and non-vtech headers
  57. Rev limiter, what is yours set at?
  58. greddy kit 5th gen hp? quarter mile times
  59. skunk2 manifold and cruise control
  60. Strange cel problem
  61. trouble with installtion rear brake pads
  62. wipers come on without me turning them on
  63. f22 Help
  64. EGR valve...
  65. Dead shock so i got some kyb agxs, spring problem (didnt know what to search for)
  66. state ref with stock muffler w/upgraded 2.5" piping
  67. Hood Heat Shielding?
  68. Burning oil?
  69. h22 swap help in 4th. gen.
  70. Opened up my tranny and...WTF
  71. hinda civic obd2 ecu
  72. Broken throttle cable?!?
  73. Turbo H23???
  74. Frustrating prob with 91 SI Lude
  75. Why cant I sell my prelude?
  76. h23 tranny
  77. Will these fit?
  78. Aftermarket shift knob + boot
  79. Tranny Noise
  80. HOnDATA
  81. engine not turning over
  82. aftermarket suspension for type sh
  83. F22 headers fit h23's.....?
  84. 5th gen knocking in stop-n-go traffic (suspension? brakes?)
  85. HelP! AEM Cold Air Intake Installation
  86. O-ring + Hondabond or just O-ring on a waterpump?
  87. Font suspension clicking noise.
  88. cluster problem
  89. denso oil cooler
  90. electrical diagram needed
  91. Initial dyno of the new h22 / f20b turbo setup
  92. where to find H22a4?
  93. covert ecu from auto to standard
  94. EGR question combined with jdm p13
  95. ATTS question
  96. Stock Rods and High Compression Pistons?
  97. pass power wire through firewall
  98. Exhaust Kit, and other related ideas.
  99. 89 prelude.......suggestions???
  100. Correct size/model Optima RedTop (95 VTEC)
  101. HOnda prelude
  102. Putting Nitrous on my 98 H22???
  103. need your help on decision. selling lude.
  104. Audio Problem
  105. sandwich filter adapter
  106. Looking for a motor swap in Los Angeles Area
  107. Looking for a new Oil Pump
  108. H22A4 with LSD. Life Span?
  109. How can i check if a engine is legit?
  110. Seeking Information on 1992 Prelude with H22A engine
  111. 4th gen vss
  112. drive conversion
  113. Headlight removal
  114. h22 wont rev past 6500
  115. base prelude and Type Sh cluster the same?
  116. CEL
  117. draining my fuel tank
  118. Cutting my CAI
  119. HOW TO "H3C to H3 conversion for 5th gen fogs"??
  120. vtec not engaging bogs out like i'm hitting the barkes
  121. Prelude LSD????
  122. H22A4 professional rebuilder Needed!
  123. help getting main caps off
  124. F1 Flywheels
  125. engine won't start?
  126. Prelude A/C charged but still hot!
  127. lights coming on for no reason....
  128. So i want to add some new headers to my h22a
  129. can't get transmission apart..
  130. Installing coilovers
  131. h22a4 head
  132. Air/Fuel gauge
  133. 5th gear grind - updated part number?
  134. Sleeper gauges behind 4G dash glass install---
  135. accord O2 sensor
  136. JDM H22A... Compatible with ATTS or no?
  137. Flywheel Upgrade 12lbs or 8lbs?
  138. My 4ws is now non-functional...question.
  139. wanted h22a4 oil pan
  140. Soon to be in the market...
  141. what engine to swap into a 1997 SH
  142. 4th gen - hooking the clock up to the dimmer switch.....?
  143. JDM fog lights 5th gen Prelude
  144. having trouble getting into gear???
  145. Sway bar bushings for 1994 prelude? which size in mm
  146. PSPEC Short Shifter Question
  147. 5th gen headlight working/not working.
  148. wtb h22a4 oilpan asap
  149. How will my car look? (pictures)
  150. 89 auto tranny
  151. '94 Prelude VTEC: Rev Limiter Engaging @ 6500 RPM
  152. Engine Swap 2000 accord to 92 prelude
  153. K24/K20 Prelude Questions
  154. 4th gen fog light cut out
  155. ARP Head Stud Question
  156. H22 with H23 tranny?
  157. What kind of shock?
  158. h22a swap questions
  159. Brakes
  160. ?? more power with little fuel left
  161. Help with an auto to manual swap
  162. ECU Reset Radio Question
  163. 93 prelude
  164. BB Squad link
  165. Ohlins
  166. help!! problem after testing compression
  167. h22 type S turbo wat is needed
  168. Check it out guys!!!
  169. Suspension issue / looseness
  170. Need Help Please!!!, OBD1 JDM H22A swap into 97 prelude and didn't swap the oil pump for CKP sensor.
  171. Help after B20 swap, PLEASE im stuck
  172. too much play in the shifter..cant find gears sometimes...shitfer linkage?
  173. Need help forgot how to re assemble alternator
  174. car random dies in neutral ... why?
  175. H22a Experts help!
  176. koni yellow - which coilovers work best
  177. throttlebody bypass
  178. (Searched) Car just died and the brake seems tighter. Need some advices...
  179. Difference between an h22a1 and h22a4?
  180. srs question
  181. Euro R primaries
  182. Flywheel bolts loose again. 3rd F*($ing time. Any aftermarket h22a flywheel bolts?
  183. 95 VTEC. Belts broke, Crankshaft pulley came loose. Now car wont start!! HELP!!!
  184. JDM H22a Block And Type S Piston Quick Question (Searched)
  185. OE SAFC numbers
  186. EGR removal
  187. viper alarm 771xv help
  188. my first post and question
  189. Is the evaporator necessary?
  190. Camber on H&R + Koni's
  191. h23a1 belts
  192. ECU options while doing auto -> 5spd
  193. Dealer says I need 4 new struts
  194. 2001 Lude won't start - need some suggestions please!
  195. Few pictures of my prelude in the Honda Challenge race last weekend.
  196. doing 5 speed swap on friends lude need help
  197. oil relocation..is this any good?
  198. H23/H22 crank pulley compatability
  199. Axles the same for SR and SRv?
  200. Interior Swap
  201. 5th gear just cuts off at 6000 rpms?????
  202. 93 Prelude w/ EURO-R H22 SWAP. BYE BYE H23...advise needed
  203. My H22T/nos fed Thread. Got questions???
  204. ignition install
  205. h22a speed sensor question
  206. Prelude Tranny + ECU ?
  207. 1992 Prelude Si - build up worth it?
  208. What hose is this?
  209. sidemarker help
  210. Prelude Type S *tried searching*
  211. 96 F22a OBDII ecu pinout?
  212. Manual Gearbox Hose??
  213. Hondata seller on here??
  214. i searched!!!
  215. My prelude is revving from 1200 to 3000, constantly, HELP!
  216. .:OFFICIAL:. Suspension Thread
  217. h22 guys with water temp gauges
  218. d series IAC on h22 mani
  219. Compression Test Results
  220. H22, H22A1-A4
  221. Motor not what it used to be
  222. quaife lsd question
  223. Does this look like a jdm p13 ecu?
  224. Opinions on Vecco Turbo Kit
  225. TDC question
  226. 4th Gen Prelude; vacuum diagram?
  227. world sport 2 + test pipe/hi flow cat?
  228. Killed my h23....too much happy feet!!!!!!!!!
  229. Cylinder compression on S/C Prelude
  230. Speed and RPMs Look Right?
  231. need to know the color code
  232. Searched, Replacing Fuel filter ona 5th Gen?
  233. ATTS Light
  234. KMS EGR Block Off or Hondata Intake Manifold Gasket ?
  235. strange 4ws code
  236. F20B and power steering
  237. Prelude stuff that I have for sale
  238. please help my car wont start after i fixed my timing belt ( snaped at around 30 mph 3rd gear )
  239. Number 1 cylinder head keep smashing my spark plug??!!!!!!
  240. 89 Prelude SI, 2nd gear problems :(
  241. hey i need help in knowing what's up with my lude
  242. Opinions on headers......
  243. help!! paint wont stick to wheel
  244. My Tube chassis lude for sale on ebay!
  245. Help with CEL after installing engine. Video included
  246. 89 Prelude
  247. Limp mode and no code. Then nothing. WTF?
  248. prelude starter
  249. performance tires
  250. h22 93 civic coupe driver side shaft axel problem
