PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 [221] 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. H22 with H23 5spd?
  2. 89 prelude si
  3. H22 Teg ..... NA or Boost?
  4. CUTTING THE SHIFTER!
  5. H22 Injector Info Requested
  6. CODE 12........Help locate please!!!!!!!!!!!!!!!!!
  7. h22a1 swap ecu question
  8. need help on power steering problem
  9. JDM Transformation
  10. intake question
  11. Anyone have plans for constructing a homemade H23 header?
  12. Prelude vs. ITR
  13. Prototype CF Lip
  14. Turbo size question???
  15. best short shifter for 5th gen lude
  16. Looking for a hole to get under the hood
  17. 1990 Prelude Si Question.
  18. H22 Vaccum box wiring
  19. H22a4 in 4th gen OBDI car
  20. ATTS on 97 Prelude Type SH
  21. MAin realy location?
  22. Engine surging at high rpms...
  23. ?I gotta question about my idle?
  24. why is it so hard to find a manual tranny for 5th gen lude?
  25. 97+ Prelude Parts for sale
  26. Will Euro-R Intake Manifold fit on a H22A cylinder head?
  27. H23a lower compression headgasket
  28. h22 header, help!
  29. Exhaust question
  30. Jdm H22 block
  31. Still problems with jdm H22 turbo
  32. new car, clutch pedal too hard, strange axle noises
  33. upgrading my prelude
  34. Cylinder#1 not firing properly?!?
  35. 1990 si.....b21
  36. i'm new and would appreciate input on....
  37. Oaks Racing Prelude 11.2 in Vegas
  38. Will 5gen shocks work on a 4th gen?
  39. STR throttle body vs bbk
  40. Type SH
  41. manual tranny change by mechanic?
  42. NEED HELP! H22 swap (what is this solenoid, where does it go?)!!!!!!!!!!!!!!!
  43. http://www.polepositionproducts.com
  44. *SQEEEAKING WHILE STEERING*
  45. need some help
  46. In need of JDM H22 downpipe!!!!!*HELP*
  47. re: prelude vtec ecu
  48. h23 side engine pic??
  49. Track Times?
  50. Individual Throttle Bodies...
  51. electrical question
  52. H22A build-up questions
  53. hot weather+crower cams=running lean which causes my car to overheat intermediately?(long)
  54. I can't get my cf hood lined up!
  55. Question about RC cleaned injectors
  56. manual tranny items?
  57. 128K too old? to race?
  58. AWS preludes?
  59. Overheating Question
  60. Free carfax?
  61. '87 lude swap
  62. shift knob stuck ?
  63. modifying stock collector
  64. 1986 Prelude, New to me, issues.
  65. slooow ass H23a
  66. wheel fell off
  67. I quit......... For a while anyways
  68. M2A8 Tranny...what engine does it belong to?
  69. 93 prelude si auto
  70. '92 Prelude
  71. all motor h23 dyno results ( kinda sad)
  72. Wheel hub
  73. feilds vtec controller
  74. wheel studs
  75. Dyno'ed
  76. aem v2 question?
  77. down pipe/header 01 Prelude
  78. what type of hondata should i go with help please
  79. why am i running rich???
  80. what shocks can i use?
  81. Anyone Ever Screwed w/ an Automatic Tranny On the Prelude?
  82. Which helms?
  83. Supposedly H22A B18C GSR Throttle Bodies on H22A
  84. Front end maintenance
  85. prelude fuel filter question (idling)
  86. 92-96 Fuel Filter Same as 97-01?
  87. Motor Break in for Turbo?
  88. motor needed
  89. what are you guys running for fuel filter with high hp applications
  90. H22 down pipe???????
  91. Mahle Pistons
  92. what should ido to my 93 prelude
  93. TEIN EDFC, why not?
  94. hondata or vafc-II?
  95. Speedware Stainless Harness Bar
  96. squeaky belt
  97. M2B4 with Quaife LSD? JDM H22 LSD tranny transmission
  98. service request light
  99. '00 Canadian Prelude Gauge/ODO swap to US Spec
  100. H22A tranny question
  101. my h22 del sol is not sparking???
  102. ebay cat's
  103. engine doggish
  104. '91 Prelude 2.0 SI For Sale
  105. H22 belt size in 97 Accord????????
  106. Top Speed....
  107. Throwing a 4ws cel - code 29
  108. resinator
  109. what are good light wheels to put on a 4th gen?
  110. s200 hondata ecu for 2000 prelude?
  111. h23a1 turbo project
  112. selling car..where??
  113. Straight Pipe Exhaust
  114. Friend about to buy Prelude
  115. 93 SI engine specs?
  116. RIM sizing question help !
  117. axle help!!
  118. Any ideas for a setup on a 3rd gen
  119. thinkin of buying a prelude
  120. Would a PGM-FI (mec. Fuel Injec.) do any good.
  121. JDM H22a Valve Clearances
  122. 97-01 prelude springs
  123. vafc?
  124. wiring help please
  125. Finally my H22 turbo dyno in my 93 civic 4dr!!!!!!!!
  126. LSD gone wrong it looks like
  127. where do I find the error code?
  128. H22 transmission mounting issues. Please help!
  129. NEED HELP! Clutch problem!
  130. is my H23 shot or what
  131. help spring compatiability
  132. JDM Service mannual
  133. would a this be worth doing on my h22
  134. tapping in the engine causing blue smoke?
  135. Quick Question
  136. What is better Exhaust Apexi N1 or Greddy Evo ll
  137. how much power can stock setup handle?
  138. need help =/
  139. Need Prelude help with mystery hose
  140. Adj cam gears.
  141. Axle compatibility - h22 vs h23a
  142. suspension
  143. ABS system shot... brake mods or help plz
  144. f20c
  145. NEED HELP! NEED FINAL DRIVE GEARING INFO
  146. how mUCHH??!?
  147. help my car keeps shutting off !?!?!?!?
  148. any aftermarket drive shafts ?
  149. Prelude intermediate shaft installation help!!
  150. Have Stock Vtec 93 Need help on The Best MODS
  151. 93 VTEC redlining at 6500 RPM's
  152. Removing Oiil Cooler.......
  153. Brake lights
  154. what do you guys think of stromung exaust??
  155. str intake manifold and iavc
  156. Prelude intake
  157. 3200 RPM's at 60MPH???
  158. What Is the Best Exhaust For 93 Vtec
  159. installing air fuel ratio gauge in 96 si ?????
  160. Balance Shaft Bearings
  161. Just got back from dyno
  162. M2B4 Swap into a 98 type SH
  163. removed cat....CEL
  164. idle problem 1990 prelude
  165. oil problems
  166. 1992 prelude si=53k? is the miles right???
  167. VTEC gauge cluster?
  168. not sure what is wrong, please help!
  169. Engine mods...?
  170. 96 jdm swap
  171. 4th gen stock wheels weights
  172. EFI PMS any good?
  173. can i throw a h22a in 91 prelude
  174. What to do next..and headers?!?!?!?
  175. 8 pd. flywheel or lightin up factory flywheel?
  176. anybody going to poughkeepsie ny? vision of speed meet tomorrow?
  177. Honda / Acura Knock Sensors interchangeable?
  178. Swap problem
  179. starving for torque!!!!
  180. vtec,ecotec, or mivec
  181. where to get the spoon tinted mirrors
  182. sluggish fifth gear?
  183. Turbo and Supercharger
  184. cltuch pressure plate bolts!!!!!
  185. Gen 5 lug nut specs
  186. Different Size Oil Filters That Will Fit The Prelude?
  187. to turbo or to not turbo
  188. P13 manual ecu and clutch switch
  189. new to prelude.
  190. Flip Up Head Lights wont stay closed?!
  191. back to stock?
  192. question on dizzy??
  193. H23 tranny problems
  194. my graduation gift
  195. Timing the flywheel with the distributer
  196. modified distributors???
  197. Need some 4'th gen buying help...
  198. what would you do?
  199. greddy header
  200. ECU questions?
  201. H22 into 95 eg civic coupe
  202. Specs on a B21
  203. adapter for an intermediate shaft to fit on sh block?
  204. interior question?
  205. Which Would you choose 93 Prelude Vtec or 94 Prelude Vtech.
  206. ATTS fuse?
  207. removed a/c what size belt?
  208. Engine Block Mathmatics
  209. Car died AGAIN
  210. H-series Fidanza flywheel problems.
  211. Question concerning Tein suspension install?
  212. H23A1 Turbo, anybody here have it too?
  213. H22A inside USA
  214. got my h22 running right but....
  215. LSD from auto in to a manual
  216. how to remove my balancer shafts??
  217. Where can i get the Honda Factory bodykit for 97+ preludes?
  218. can't figure out why 88 si won't start
  219. Pic of AEM V2 intake??
  220. ANOTHER F22B DOHC QUESTION
  221. what next..??!?
  222. f22 vtec
  223. Just Installed Tein Basics in My 99 Prelude
  224. putting my h22 together in my lude few questions
  225. 2001 Prelude or 2001 Accord V6 Coupe
  226. auto?..manual?
  227. 92 SI LEATHER INTERIOR
  228. prelude will start but wont move
  229. Looking to buy a 93 Prelude Vtec. Need Some help.
  230. JDM headlight installation
  231. 97 honda prelude gauge cluster glass piece
  232. Should I buy my old (wrecked) prelude back and fix it?
  233. 2000 auto tranny locked up
  234. Where to buy Fidanza friction plate?
  235. Anyone located in the Orange County area?
  236. Fidanza Flywheel
  237. OT : Prelude Trunklids & VIN Tag Question
  238. vibration noise when shifting at high rpms, something loose
  239. SRS airbags deployed - how to repair?
  240. 1995 H23 engine question
  241. SRS light on after replugging?
  242. obx intake manifold...
  243. Surging idle on h22 turbo
  244. which provider has springs for 5 gen lude that lower more than 2 inches?
  245. putting at idol?
  246. 5th gen JDM climate control Digital BB6
  247. 15 inch wheels on 5th gen?
  248. 2nd gear grinds
  249. 1988 prelude. worth anything?
  250. h22 head on h23 block
