View Full Version : Honda Prelude
- is this the evap solenoid?
- anyone know what after martket fuel rail will fit euro r intake manifold to make it fit right in?
- Quietest exhuast?
- The differences in power betweek Short Ram and CAI: Why?
- 92-96 Carbon Fiber "F1" style mirrors? where to find?
- abs swap?
- AEM Big Brake Fitment (Si/VTEC)
- anyone use a Venom IM??
- think I blew a front strut
- is it bad to unbolt your muffler?
- turning distributor to advance/retard timing??
- CRV Steelies?
- How to remove vehicle specific MOMO shift knob and boot...
- greddy evo 2 vid, rainy launch
- Does a 92-95 prelude s/si catalytic converter fit a prelude vtec?
- removing heatshild/ adding heat wrap ???
- Brakes - Ceramic or Semi-Metallic?
- Pick my exhaust for me Honda-tech
- egr help i did search first
- Injector question??
- dc header gasket size
- Bored throttle body + blower
- 99 Type SH...Oil usage issues
- Power antenna
- Oxygen sensor problems
- Bounce Shift
- Hesitation ????
- Problem with 3rd Gen Prelude....
- Clutch Issues
- ABS Light
- Can I use a JDM VSS?
- Help Wut timing belt do i get?
- HID Kit on 5th Gen Prelude Problem???
- why the constant (personal) battle of na/vs f/i ( my poor head is gonna explode )
- Checking Cell 4th Gen
- Hose Kit
- Suspension options for a 98 SH
- 95 J-spec H22 in 5th gen?
- Does the Euro R Have an Aluminum front A/C Mount?
- Quality headers...
- Help!!! automatic won't shift or do anything.
- sh tranny in a h22a1
- Dead Battery Problem!!!
- Anyone have Instructions on Camshaft Changing?
- Stress: Uber noob question
- 4th gen SunRoof
- how to set timing on aftermarket flywheel
- weird electrical lights problems
- anyone know how to install the euro r intake manafold into the h22a?
- removing rear seats in 5th gen sh
- 1995 Si Prelude - 4WS & Cruise Control Problem
- cam gear adjustments
- srs light blinks while trying to check cels
- Any Difference between JDM and USDM injectors (OBD-1 for VTEC)
- egr block off question (searched)
- Advice/Suggestion Please
- Has anyone tried this lsd...?
- Reusing H22 Head Bolts
- winter tires or CRV 15" steelies w/ winter tires?
- NationalPreludeMeet.com / NPM06.com now up and running!
- Need help finding a starter for a prelude srv
- Transmission grind problem
- stock prelude camber kit
- I wrecked it. What should I do? Part it out, or sell it?
- 00 SH Alignment Problem
- Skunk2 intake Manifold for H2 Whats next?
- meter fuse broke.. no signals, dash lights, tach or speedo (93 Si)
- alternator
- which swap axels???
- Shopping for a header
- does anyone know darkfx im getting worried
- Euro-R manifold parts
- question about goo under emblems
- WTB:
- H23VTEC w/ H22 connecting rods/pistons
- Some performance to JDM B20A7
- problem with ATTS and leaking oil????
- gague swap?(searched)
- h22 and h23 frm?
- butterfly valve for h22
- Twin Loop muffler 2.25 inlet on 2.5 exhaust
- turbo kit
- Brembo blanks or powerslot
- Cable Tranny Swap/conversion
- head gasket Questions h22
- Getting a 4th gen
- can i run obd2 ecu with obd1 h22 and obd1 dizzy
- Osaka Motors
- h23 - h22 swap. green plug by radiator hose
- Circle or square plug for an OBD 2 alt?
- F22A - H22A Swap - IAB System pics needed
- transmission problems HELP
- Replacing Rear Wheel Bearing(s) WRITE-UP
- knock sensor from a 99 prelude work on a jdm h22?
- Yes another h22/h23 manual tensioner thread
- 4th on 5th gen p/S pump ???? would it work
- Tbelt wont loosen up ....
- How to figure out bolt pattern on my wheels.
- Prelude kicks out of gear and check engine light cuts on.
- b-series in a 5th gen
- H22 Swap
- OBD1 H22 Dizzy fit H22a4?
- A/C questions
- 1992 Honda Prelude Si 156K
- 99 SH oil consumption
- A/F Ratio
- crank pullie removal? (i searched)
- h22a h22a1 water pump
- belt configueration 1985 prelude carbuerated
- door speakers not working
- Should I sell the prelude?
- Oil orifices in the head- question
- air filter, where to buy
- Quick Question...
- Check engine light
- (searched) 5th gen headlight assembly
- WTB 5th H22 gen parts
- HELP GAUGES!!!
- JDM Type-S Sat Nav/TV/DVD screen help
- Evil coolant leak.
- RMF vs.......H22 header
- Anybody know of a place to get axel back exhausts??
- Code 9 (CYP sensor) - on 96 prelude!
- Racer Design Mufflers
- 4WS
- VTEC Solenoid - OBD1 vs. OBD2
- Prelude running cold?
- My car keeps dying. WTF?!?! Need help ASAP
- anyone have a 98 prelude DOCH V-tech cyllynoy (spelling) ?
- CF radiator shroud
- which is better?
- 2nd gen help
- brake lines out of master cylinder
- THERMOFLEX VALVE?????
- FS:AEM cold air
- My engine LIGHT is Still on, on my 98 prelude, how can i fix it?
- T belt change and tdc question.
- What size throttlebody is good for an all-motor setup?
- h22 bearing clearance
- is a F22 tranny weaker?
- How do i check my compression?
- proper method to fill antifreeze
- Can you help me?
- '93 VTEC overheating problems
- Turbo & Traction
- I broke this...what does it do?
- Knocking axle....ripped boot.
- Is a little too much oil bad?
- Electrical Issues: Help please...
- Good short shifters???
- Ticking sound inside the head...
- type s quarter mile
- HONDA PRELUDE OWNERS: Have you had this problem
- could someone tell me what this is?
- what do you guys think of this turbo kit? is it worth it?
- Gas Fumes coming out of shirt ram intake.
- USDM H22a1 OBDI-OBDII
- prelude ecu
- tire question
- H23 build suggestions
- Euro R cams, and IM question...( searched)
- Oil Pump installation
- installing headlight help
- head gasket problem
- BASE exhaust to a SH?
- where does JDM higher compression come from, nothing after 2002 with search
- Thin Head Gasket Dilemma
- f22
- 5th gen sunroof visor acident
- Difference between B20A1 and B20A5
- 4WS light - resoldering relay points may fix my problem??
- is there any other trans I could use for a h22
- 4th Gen door speakers...tweeter/crossover wiring help
- 5th gen prelude with rims have 35 offset, rubbing?
- JDM H22 92-96 swap
- cam advice please
- part number
- LOOKIN FOR USER: KDoGx504
- help
- Exaust is it true
- Ansa Exhaust
- For those with Koni sports....
- type of tranny problems owners 5th gen have/had
- F.S 5 gen Eibach sportlines
- H22a4 Piston Ring gap size
- what is the differnce?
- h22
- 4th gen kaminari quality?
- killing the d4 light
- F22A1 swap for H22 need help
- question about the 5th gen ecus
- Flsuhing the cooling system. Now a question about refilling
- balance shafts
- limiter at 5k
- Protecting your Carbon Fiber Hood
- 215/45/17
- H23 downpipe
- 1987 Prelude stereo wiring diagram
- no spark?
- where are all the VIN's located on a 92-96 prelude
- valve adjustment now my idles lower??
- vecco turbokits
- Header Problems
- i need a new ECU!!!!
- getting rid of wheel hop
- Idle problem - searched
- H22 engine..engine build up
- Question about P14 ECU
- Motor oil leaking in my H22 distributor again
- Honda screwed me
- Antifreeze leak under car
- My Cylinder to Piston Clearance
- Civic Idle Air Control on H22?
- Available swaps for 93 lude with F22A1
- H22 OR H22A ENGINE BUILD UP?
- OBD-1 or OBD-2
- A question about the 1988 Prelide Si
- enough space to do this.
- ATTS UNit
- Are there any 92-96 mugen front bumper replicas being made?
- Hesitation with no check engine light ... try this
- power issues
- 02 sensor... why so much??
- A/T to Manual Conversion Question
- weird prob., when you let off the gas... help me out
- MagnaFlow muffler?
- cam timing off, any noticable noises
- Skunk 2 Intake Manifold
- Do 96+ JDM H22 motor swaps Exist???
- Help me out~~~
- Blown Shocks!! How to prevent?
- Results of the Royal Purple Dyno!!
- finding the switch
- Search down like always but overheating issues.....
- why is my h22 eating so much oil?
- 93-96 cross drilled and slotted rotors
- jdmpassword intake
- What is the best tranny fluid for the Fifth Generation Prelude.
- overheating problem
- Coilovers
- prices for engine rebuild
- will the 00 si msd distributor cap fir the jdm h22a?
- what is the deal??
- h22 fuel rail
- I'm Hearing a strange noise
- 93 Si issues.....motor is struggling to turn over.
- H23 to F22B swap (search is down)...
- Choice of upgrade....need opinions
- Pic's Koni w/ OEM springs (before and after)
