PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 [186] 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. exhaust not sounding right!
  2. what are some chippable ECUs for the Honda Prelude SI H23 besides p28 and p72?
  3. Best short Shifter for 5th gen lude?
  4. forbidden shortshifter setting
  5. HELP- grinding going into first please help
  6. JDM H22 PROBLEMS PLEASE HELP!! TIERED OF THIS MOTOR!
  7. a vid of my 93h22a accord
  8. JDM Hayame CatBack Exhaust
  9. Map sensor...where the plug goes on the harness.
  10. prelude track times.
  11. Bearing on top of the mainshaft
  12. Alternator problem
  13. 600cc CBR ITB's, DIY question for my 5th gen
  14. my new ride
  15. How to open hood without using latch?
  16. Golden Eagle Intake Manifold - Please answer....
  17. Need AEM EMS info (searched)
  18. please help, car cranks but not starting, back up fuse keeps blowing
  19. idle problem
  20. auto tensioner problem..HELP
  21. so i just spent a day replacing the throw out bearing
  22. Help Injectors not firing
  23. h22 crank in a h23a1
  24. need help lowering my car
  25. Smoking Engine
  26. H22 Cl, Anyone have a skunk2 intake manifold, or AEM fuel rail and pressure reg on their H22?
  27. NEED HELP with this ASAP
  28. did i do this right?
  29. My continuing progress
  30. I Need Some Help
  31. H22A Head w/ 1mm Oversized Valves too much?
  32. coolant problem
  33. zip tie your shifter cables?
  34. A/C problem
  35. IACV - Idle Air Control Valve - Woes
  36. NEED HELP on making decision of my "Base Model S 4th gen Prelude" (Searched)
  37. wheres the ecu
  38. dynos in so. cali...
  39. Skunk2 Intake Manifold now CARB Exempt?
  40. Head Lights
  41. crank pully tight?
  42. Question to those who are supercharged
  43. PLEASSSSEEEEEE HELP!!!!!!!!!
  44. changed spark plugs...
  45. High Idle
  46. Thermostat install gone bad, bolt broke and got stuck
  47. H22 Base Map
  48. 5th Gen "Blueprints?"
  49. Very, Very New!!!!
  50. HKS Exhaust Clips
  51. Water in the trunk wheel well
  52. car dead, constant CEL
  53. overfill bottle
  54. skunk 2 shocks
  55. 92-93 4th Gen owners: Speedometer removal question
  56. BB6 Koni Neuspeed(fronts), Neuspeed Sport Springs, Eibach Sportline, SH Tranny
  57. 4th gen fender, hood, radiator support
  58. problem with jdm prelude abs please help
  59. need to find auto tensioner kit
  60. SRS light (searched)
  61. exhaust setup
  62. H22A4: Weird startup idling and shutdown problem, need input
  63. Help need a turbo Mani...
  64. FS: JDM Type S Steering Wheel w/ SRS Airbag
  65. 1/2nd generation parts
  66. JDM Header collector diameter? (H22a)
  67. Cant figure out whats wrong?????
  68. ATTS again.
  69. 4th gen supercharger
  70. problem with locks
  71. How much time for break in?
  72. fan Q
  73. Mugen Thermostat + Fanswitch
  74. 9003 for 5 gen bulbs
  75. Alternator Schematic
  76. Size for catalytic converter in a 4th gen? Also, where to get cheap Honda parts online?
  77. Is it possible to make the 4ws not 4ws anymore?
  78. Why is the h22a4 slow at accelerating on the 4th gen
  79. Greddy SP sound (searched)
  80. I have 3 serious car issues I need help with
  81. 97 Prelude
  82. Clutch Install Question
  83. Fan on Prelude
  84. h23 vtec info
  85. anyone have a teeth count for m2f4 5th gear
  86. vacuum tank?
  87. Tanabe Ultra Medallion question
  88. Need help on deciding on a coil
  89. !!!Help wiring a GM horn to my prelude, keeps blowing fuses!!!
  90. FS: Apex'i WS 5th gen Base
  91. Valve Adjustment Clearence SPecs HELP!
  92. new clutch....break in procedure?
  93. easiest way to tell if i have type s cams?
  94. Fix or part out?
  95. Possibly Scammed by Lude2fast88
  96. Knocking in rear suspension
  97. Aftermarket Exhaust Sound Clips
  98. wont start?
  99. Anyone use Crane Cams Fireball Hi-6R Race Ignitions? will it fit?
  100. Installing JDM sidemarkers (searched)
  101. what are the signs of auto-tensioner failuer (i already searched)
  102. Compression Test
  103. h23 distributor...??HELP
  104. How do you tell the difference between pistons?
  105. How to build a stronger H22 Tranmission?
  106. 12.72 @ 108 Video FINALLY! Let the doubting cease...
  107. H23 -> JDM H22 swap: JDM engines OK out of box?
  108. Compression test result......Crazy High???
  109. 99 Prelude Wiring Harness
  110. Problems w/ dash
  111. Car won't start
  112. would this be all that i need?
  113. Short "RAM AIR" Intake Suggestions
  114. Will this Manual tensioner work?
  115. need help
  116. Mahle pistons
  117. How reliable is VTEC prelude
  118. stupid opossums...
  119. pgmfi??? whats it mean
  120. FS: 1993 Prelude VTEC (N/A built engine) (Moderator Approved E. Nick M)
  121. idle problem
  122. /valve Adjustment question
  123. Engine question
  124. advice needed 92 si swapping to h22a
  125. help with type s install
  126. LSD pulling to the left?
  127. progess kit
  128. Euro-R Engine/tranny swap
  129. P13 ECU and 4WS
  130. check engine 5th gen
  131. JDM LSD from M2B4 Tranny into M2Y4 USDM 5G Base Tranny?
  132. Installing 90-97 Accord Springs on a 97-01 Prelude
  133. aftermarket exhuast
  134. Oil Leak, Where is it coming from?
  135. 02 sensor: Slow response
  136. tranny cooler
  137. Damn, have some wierd electrical problem
  138. idle surge until warm bogging after that
  139. help me i'm a noob
  140. !!Prelude Damper!!
  141. supercharging a 4th gen?
  142. post pics of ur sh painted rims
  143. JDM , Stock VTEC Exhaust
  144. 24.5 on my first tank
  145. transmission that would fit a fifth gen lude
  146. Where to buy 02 sensor for 97 sh?????
  147. got my allign. now what?
  148. spoon sports products for the 4th gen prelude?????
  149. i have a timing belt question please help
  150. Starting/ide issues
  151. A few issues with my euroR swap
  152. F22a to H23 already searched no answer
  153. electroluminescent guage cluster wiring from 93 prelude analog
  154. octane mixing experience and question
  155. replacement auto tranny's (TOPEND motorsports)
  156. H22a4 questions help
  157. Loss of top end, VTEC works -secondary butterflies?
  158. Whuz good?
  159. 4th gen prelude wiring....HELP
  160. why do i keep spinning bearings
  161. Rough Idle Question
  162. 92 Si, Wont warm up, low idle, shaky. Thermostat stuck open?
  163. Post a pic of your VAFC where its installed
  164. Need Help Picking Different Exhaust... Opinions Please...
  165. Blown Motor.
  166. is this turbokit good or bad?
  167. Quick question on Auto tensioner
  168. what IM do i have
  169. H22a1 question
  170. Autozone Balljoints ok?
  171. 92-96 Prelude Firewall question!
  172. Would someone kindly host a pic that I would like to post here.
  173. Putting on new rotors
  174. Love for our Preludes
  175. Thermal R & D (Research & Development) Exhaust
  176. whats wrong with my lude
  177. 1989 Honda Parts
  178. Official Prelude Weight Thread
  179. Secondary O2 Probs(H22a)
  180. crankshaft and cam in line??
  181. H22a acting up again...question about what is wrong need help
  182. water leak, searched
  183. Engine question
  184. oxidized front headlight
  185. 3rd brake light
  186. Overheating - Thermostat or Water pump?
  187. Screeching sound from distributor
  188. Could a bad alternator cause bogging or poor/insufficient spark?
  189. A question for all the H22 owners out there.....
  190. DIY Black Housing Headlight 5th gen
  191. SMSP header stats
  192. how much performance can you get from a 1990 prelude ?
  193. prelude exhaust qustion
  194. Anything special about SH Valve Springs?
  195. Effects of Front Strut Bar on 4WS Handling
  196. Difficult 4th gen electrical problem...HELP!
  197. Free: obx header for h23
  198. wheelhop
  199. help....4th gen prelude
  200. Shifter slop on 4th gen prelude
  201. Prelude on rated r's?
  202. Anyone have probs. with rust around the trunk keyhole? (*Pic*)
  203. Clunking noise from rear
  204. Compression test numbers?? UH OH h22a blower
  205. what to replace with timing belt?
  206. IAT on 4th Gen - The problem?
  207. prelude mufflers!
  208. install cam gears and pullys h23a1
  209. Rusted Axle?
  210. Selling my 1997 prelude Turbo... check it out and tell me what you think
  211. Do all H22's use oil?!
  212. Prelude tranny won't shift in to reverse HELP!!
  213. Unknown plug on block
  214. clutch advice
  215. Will a 99' civic Si arm rest fit in a 4th gen with a little modification?
  216. Normal oil pressure
  217. How do I open the rear light clusters to change a brake sidelight?
  218. NOS and h22's
  219. lude 1/4 time
  220. 97 Prelude auto slipping when cold only
  221. h22a1 head bolts, h22a4 arp head studs
  222. Tein suspension
  223. went to the track today
  224. can anyone vouch for Mahle h22 NA pistons? gold series
  225. Car won't start? 1993 Si with JDM h22
  226. does anyone no bout 4ws
  227. picking a h22a
  228. Do OBD1 ECUs in OBD2 cars give up AC and the Gast light??
  229. How much boost can a stock h22 handle?
  230. slowin down after exhaust noise
  231. need help deciding on rim size
  232. squeek springs
  233. 92 prelude si parts?
  234. Brake Lamp light????
  235. h23 help!!!!!!!
  236. A few problems (idle and studder)
  237. Oil sending unit leaks.. help?
  238. Axle Popping
  239. Which Plugs? JRSC
  240. h23 vtec
  241. Accord Tranny/h22 motor (cons)
  242. box above transmission mount
  243. *sigh*-car wont start, bad gas....
  244. my new prelude
  245. Timing maps
  246. Trying to work on inside of the car, where should I start?
  247. Pics of 4th Gen?
  248. FUEL FILTER REPLACEMENT... HELP
  249. Removing and Painting Interior Panels
  250. GAS issue: how long till you refill your gas tank?
