View Full Version : Honda Prelude
- 5th rear upper control arm in 4th??
- JDM vs. USDM Crank pulley?
- I have an LSD question?
- JDM H22A questions
- H22 Swap no spark!
- H22A injectors
- 5th Gen Maint. Help
- Bypass Valve
- Honda Car Care Days, April 1 - April 30, 2006.
- Noname Header from good seller
- 89 prelude parts?
- local ny prelude owners
- wich axles shafts are needed... ?s need help!!!!!!!!!!!!!!
- which to buy?
- speed sensor?
- Keep tripping code 12
- directionals interchagable?
- acl or stock bearing for the h22
- When to change Cap/Rotor/Plugs
- Vtec messing up
- Winter Tire Size
- p28 vs p13
- .: Swaybar Issues :.
- sh and base suspension (searched)
- Lower Rad Hose not getting warm/pressurized
- type s cams intall problmes
- Tein HA
- DIY Fuel Pump Install ?
- Just purchased a 97 Lude Sportshift. A few questions...
- prelude with euro-r rims
- Help Shocks and Coils on 95 Prelude
- 4th gen honda oem accessory lacing kit
- cleaning intake manifold
- is this an ABS sensor?
- weird cold start problem
- individual throtle bodies
- where would i find 4 gen 1pc head lights
- Motor company? (tigerjapanese.com)
- drop/lower control arms
- alternator belt, no AC still has alternator and power steering what belt?
- Now i am scared and looking for help.
- Misfire,.... HELP PLEASE!!
- Rotora Rotors
- Lower Ball Joint Removal
- 1986 honda prelude trying to remove the fuel tank
- car revs to 7k on startup and wont stop, Idea's?
- h22 driver side knocking noise in first what is it??
- AC compressor
- Electrical Problem?
- steering wheel install
- Autotensioner question
- M2S4 tranny mount
- Turbo Help
- Attack of the ball-joints
- vtec oil pressure switch
- Stolen Prelude??
- How do you remove the window from door?
- Quiet 3" exhaust & resonator combos.
- Help bad compression numbers
- 1992 Prelude engine questions
- help ! 92 prelude won't start help!
- 4th gen prelude SE wheels
- vtec vs LSD vs Atts
- difference WHP with LSD or no LSD
- Knock Sensor INSTALL advice
- H23 bottom end and H22 top end
- HELP: Possible Problem
- Best 5th Gen Manual
- can a ps pump cause leaks?????
- jr supercharger???? (searched)
- base or sh?
- these wheels on a 'lude?
- 4th gen intercooler placement.
- RSX Wheels Rub Or Not?
- shocks on sh 5th gen
- SRS light (cant reset it)
- build done for now... no low end power...at all
- H23 to H22 swap
- Best Alarm for my 98 Lude..Yes I searched...
- 92-95 civic lowering springs fit on an 89 prelude?
- Grinding when I turn my wheels
- Rear main seal for 92 prelude si?
- Prelude might be f/s
- clutch...
- Help!!!
- few questions
- DIY O2 Simulator
- Hi-Flow Cat
- JDM headlights
- Fix one thing, break another
- getting pissed trying to run power wire through firewall
- tach jumps around and car cuts out?-searched
- Quick Help!!!! Toque value for wheels and calipers
- How do I tell: JDM H22A swap is OBD1 or OBD2?
- Anyone sucessfully install an Accord lip on a 5th gen?
- AEM CAI question.
- VFAC Tuning help H22a Prelude
- What is this?
- my cousins prelude has its MIL light on.
- Installing sidemarkers on the BB6 Prelude
- h23 in s model
- baring h22a with aftermarket pistons??
- revhard turbo kit
- drag kit on 5th gen
- Syncromesh in H23 tranny (already searched)
- 4th gen Vtec floormats where to buy???
- H22 Turbo
- Compression check done...now which is bad, block or head
- jdm h22a fuel pressure
- my block NO. 1?
- jdm h22a running lean = /
- 4th gen JDM Value Bodykit? Anyone know what im talking about?
- request pics of the temp/gas relocated to the far right side
- Anyone know of this shop or had work done by them?
- h22 radiator
- Camber ball joints? anchor bolts?
- Can't Get Caliper Bracket Bolt Off
- Weird noise .....help
- New stage II REV HARD Turbo Kit 97+ preludes / sh included
- what will an aliminum flywheel do?
- CV boot busted - change whole axle?
- JDM H22 civic making noise around timing belt area
- quick question about prelude climate controls
- mugen rear?
- *Searched* Already tried everything I foud; Overheating
- Question on Vtec Killer Cams
- ? on the resistor box
- few questions...
- Header Glow Problems
- clutch pedal assembly
- fog relay required?
- OaksRacing Prelude featured in D-Sport magazine
- JDM Climate Control
- Roll back electronic odometer?
- need some help
- Can't remover head! Best way to get it off?
- What would a Stage III clutch do?
- motor help !!!!
- Clutch recommendations (searched)
- magnaflow cat
- help with h22 parts asap
- h23a dohc vtec (jdm)
- Useful information about Braille batteries
- what do i need to do before i can install a turbo
- Help with Body Kit
- 1991 prelude speed sensor PLEASE HELP
- i need the torque spec on pressure plate and clutch for a h22
- Prelude SI Head Gasket Kit Question ...
- Honda Civic Type R stearing wheel on Prelude 4 gen ???
- jdm h22 operating temp?
- Tanabe SMH or Apex WS2?
- what rear is this??
- h22 JDM header heat shield!!
- Crank bolt question
- 4th Gen Hood Pin Pic PLEASE! Searched.
- tranny whirling sound - weird clutch engagement - what's new
- 15's on a lude
- 99 Prelude Stalling
- Digital temp control/rota slip stream that are 17"s...hmmm?????
- Alternator?
- p14 question
- VSS failure after looping lines & manual rack conversion
- f20b in bb6?
- h22a advancing ignition timing, how far can u go??
- 95 Prelude AC Problem
- Who makes this front air dam?
- Hondata V's DTA
- 92-96 lude rims
- 4th gen...taking back panel off
- helm manuel ???
- replacing the Throttle Body-searched
- Fast Idle Control Valve
- 2000 prelude auto transmission.. is shot
- hiding exhaust
- Service connector local
- shit points
- turbo help
- ES trail arm bush kit (mods for some reason cant create a new topic)
- !!Transmission Hell-p!!
- NGK wires question
- Is this article legit and true?
- K series in 4th gen.
- just did a compression test after mishifted, need help :(
- Engine lag when hitting the gas question
- need help with jdm h23a swap on 92 prelude si
- p13 chipped ecu by ericks racing
- jdm h22 or h23
- yet again a vibration question
- wat would be the best route
- What kind of OEM prelude wheels are these?
- H22a8 on m2k4? bolton?
- gonna need a transmission soon...advise/tips
- What price should i sell my spoiler for?
- How Do You take the Amber out of the tail lights
- Loud H23 Engine
- Shock Knock
- Prelude shifter and cable question
- need help with a part number
- question for guys with hoodpins
- Toyota 2 Honda Turbo Adapter
- need help on some info about rebuilding my motor.
- type s camshafts
- Engine swap tips
- Stock Climate Control gone bad!
- relay is clicking
- JDMCARBOY twin loop mufflers
- Clutch and flywheel change, 1 man job?
- What's the difference between SH and non-SH blocks?
- Symptom of cracked head or bottom block, and knockiing rods.
- No Speed Limiter & Vtec Question
- Nitrous again. . .
- Installing A Toyota Turbo To A Prelude
- new to honda & honda tech
- Fuel Mileage?
- Weatherstripping / windows (help)
- 84 and 88 lude taillight problems
- Huge Oil Leak!!!
- Need help w/ Crank pulley set up (running without balance shafts)
- overheating question
- Nology wires
- Euro R head
- transmission bolt torque spec and pattern
- ATTS Disabling Question
- 3rd Gen Prelude with 4th gen accord front clip?
- Help on which piston size to choose
- i need the torque specs for arp head studs and the torque specs for the main bolts
- how do u degreeing overhead camshifts for dohc prleude
- Help with Climate control.... bad!!!!!!!
- Car Went Completely Dead
- 4th gen prelude seats in da?
- wiring ecu for h22 type-s into a 92 prelude?
- Problems with new H22A swap...
- front bumper gap help
- Questions from H22 Newb
- quick conversion harness question
- Dual N1
- 4th gen half switch. how to wire.
- H22a Vent prob?
- help me out with my cel....
- Need help with interior. . .please
- jdm integra dc fog lights? Will Fit 4th gen lude
- DIY cleaning injectors?
- Signs of bad rings??
- 96 prelude timing belt
- JDM H22A won' t hEAT up!!!!!
- E46 projector retrofit done... I need help with the wiring badly
- ATTS Noob
- fully built turbo lude, with continuous tranny/clutch problems
- 4WS gremlins... help required
- tranny help...
