PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. honda prelude insurance
  2. Bad Power Steering Pump or...?
  3. 00 h22a4 high performance build
  4. Can this h22a4 be used?
  5. h23 92 prelude build help
  6. 92 Prelude S f22a
  7. LEGIT h22a specs
  8. Any nice looking Preludes?
  9. car dies and sputters just replaced the fuel pump
  10. Help, engine wont start!
  11. New to the prelude community
  12. transmission m2s4 help
  13. VTEC vs No VTEC
  14. need help
  15. EMS Issue
  16. thinking of buying a prelude
  17. 99 SH spun rod
  18. Official first post and introduction.
  19. 93 prelude blower fan turns on/off by itself ?
  20. 89 Honda Prelude 2.0 S Carb No Fire From Coil
  21. Possible Changes to FAQ
  22. Low Oil Pressure
  23. How much power can I run safely?
  24. 92 lude h23 to h22 swap issues!?!?
  25. Very odd crank position sensor problem
  26. swaping fuel pump out question??
  27. Radiator Fan is not working
  28. Prelude problem
  29. Best headgasket? 89 mm
  30. H22 Prelude not starting
  31. H22 transmission swap
  32. H22a1 head gasket replacement
  33. Honda Prelude 2000 Stuck In Park
  34. H22 issues. Misfire!
  35. Transmission question
  36. Transmission Installation Problems
  37. Mugen Exhaust
  38. 3G Prelude Speedormeter and Temp Gauge Issues
  39. Transmission question jdm H23a
  40. Dynocom
  41. H23 head
  42. 5th Gen F20B swap troubles
  43. header and downpipe question
  44. H22 Prelude Race Car
  45. h22a questions
  46. V2V clearance
  47. Cam cap bolts keep snapping when I try to torque them?
  48. Steering wheel just spins and wheels don't move
  49. atts swap to LSD
  50. Piss poor gas mileage
  51. engine shaking
  52. help
  53. Starting problems now with swap
  54. I need help with my prelude
  55. Seattle area projector retrofit
  56. what injectors do i need
  57. Engine shuts off while driving
  58. 4th gen midori green
  59. For those who have gone though a wild goose chase chasing vacuum leaks
  60. H22a4 front crankshaft seal replacement????
  61. h22 Throttle body vacuum hose-Where to go after 70mm TB?
  62. japspeed performance parts? :)
  63. Russian 4th gen 95' build
  64. Gonna buy a prelude soon
  65. H22 Engine Knock
  66. h22a rebuild. low oil pressure?
  67. Engine type
  68. New to Forum
  69. A20A3 motor
  70. 3rd Gen Prelude suspension question!!
  71. h22a swap. motor is bogging down.
  72. need help with idle
  73. Are there any differences between H22 and H23 bearings.../
  74. FUEL LEVEL SENSOR NOT WORKING 4TH GEN
  75. Honda Prelude '84 '85 URGENT please help
  76. engine almost stalling after revs. need help
  77. is fuel level in a 4th gen vtec prelude regulated by pressure or floating sensor?
  78. 91 prelude Si code 9....
  79. H22a4 SH with a H22a1 usdm block swap. Mixed information is killing me.
  80. 1995 prelude brakes binding :(
  81. Low oil Pressure H22A4 Prelude SH
  82. NEED HELP!! 5th gen transmission/shifter troubles
  83. 5th gen transmission removal problems
  84. Timing Belt Troubles after 500 miles
  85. H22 transmission problem
  86. Rear Brakes locking
  87. 1996 Prelude Brake Going to Floor at low RPM
  88. need help!!! after replacin the distributor it wont start it just cranks
  89. exhaust systems help :)
  90. swapping trannys
  91. Prelude f22a6 block, h23 head, timing issues?
  92. 92 prelude shutting itself off.
  93. jdm h23 install
  94. what gear oil
  95. 5th gen drag car?
  96. Need help with pricing!
  97. 4th gen prelude gear box...
  98. My 93 Lude project!
  99. 01 Type SH Coil Over install?
  100. 92 SI eingine harness issues.
  101. H22a1 what cranks can i use?
  102. Header/downpipe
  103. Can I use accord parts to swap a 98 base prelude to a manual tranny?
  104. where does the vacuum line on top of the rear radiator mount go?!?!!?!?
  105. What do I need ????
  106. Reving Issues afer auto to manual trans swap
  107. No start/ No spark Need help.
  108. 1997 Prelude - Oil pan Leak
  109. 5th Gen Prelude Exhaust help
  110. abs light and buzzing noise
  111. CVs and Motor Mounts advice
  112. AC fan will not shut off after HOURS of sitting
  113. 92 Prelude cosmetic questions!
  114. h22 question
  115. h22a questions? someone point me in right direction
  116. unknown engine?
  117. H22a4- knocking?
  118. Clutch question
  119. AEm digital oil pressure gauge install....
  120. Prelude Build Question
  121. 1998 prelude H22A (138,XXX)
  122. Running Rich - Bad Fuel Pressure Regulator?
  123. Finally it lives....
  124. Weird noises in prelude
  125. Hey Brodudes, is this part need?!? (PICS)
  126. oil change help asap!!!
  127. 4th gen detailed rebuild!
  128. H23A Transmission Question 96 Si/ 92S
  129. Prelude build.
  130. NEWB QUESTIONS- b20a '86 SI 'lude
  131. Coolant Question
  132. Console version 1992 Help!
  133. Car dies out after re-torquing headsteads
  134. h22a oil pan needed
  135. Honda Prelude 01
  136. F20B DC2
  137. FUEL / COOLANT GAUGE NOT LIGHTING UP
  138. ? about h22
  139. prelude 1998 axle noise with LSD tranny
  140. H22A5 ATTS rebuild?
  141. Question on my Try-Y header
  142. Dizzy confusion
  143. h23 vtec check off list and info !
  144. H22a4 SH swapped to H22a1. Issues.... but can be done.
  145. vtec light question.
  146. Koni Yellow + GC Eibach
  147. blue top vs non blue top
  148. h22 vtec $$$$$$
  149. H22a Swap Please Help
  150. final drive, what 5th gear
  151. Machine main journal or buy a new crankshaft?
  152. 5th gen jtc shifter question
  153. Prelude throttle issues
  154. no start
  155. steering wheel size/shape question.
  156. what else will i need?
  157. Might buy a 01 base manual
  158. what pistons and ratios do i need for my h23a1
  159. 4WS Dash Light U/S
  160. Sticky Buttons on Remote
  161. Chaning sway bar end links
  162. f22a1 build
  163. 1995 Si Starting Problem
  164. best place for prelude parts?
  165. spoon calipers fit 4th gen lude?
  166. trade for prelude carfax question???
  167. P0172 Code - '98 Type SH
  168. H23a vtec HELP!!!
  169. 92 prelude wheel / lug adapter
  170. Is this part needed?(PIC)
  171. dropping prelude (4th gen) h22 transmission/engine for paint...
  172. Intro thread
  173. Power antenna question??
  174. Need recommendations for brake issue on 95 prelude
  175. h22 help
  176. Oil Pan Leak
  177. need to do something about my H22a short block !!!
  178. h23block h22 head ? need help
  179. cutting out at 3k
  180. Im About to Buy a 93' Prelude, need help!!
  181. lower timing cover removal.
  182. 95 2.2 vtec, clutch issues
  183. H-Series Spark plug cover with k coils
  184. H22A1 block to H23 block (internals)
  185. JDM headlight Q
  186. out with the old in with the new
  187. 5th Gen Prelude 1997... 3 problems in the last 48 hours...
  188. wont start?
  189. Cam Angle Sensor
  190. stock 4th gen intake part needed or not? (PIC)
  191. Chirping VTEC?
  192. 98 sh jumped few teeth is it over?
  193. new rear side window moldings?
  194. Clutch issue?
  195. 4g vs. 5g - axle length differences ? -- (drivers side)
  196. n00bert with some questions
  197. tranny ?
  198. is the h22 auto tensioner hyped up?
  199. 99' Lude Logic header question
  200. Aftermarket H22A Header downpipe hitting oil pan.
  201. 98 base prelude, jdm h22
  202. Prelude Tranny Swap....What Axles?
  203. H23A/EK hatch NEED HELP
  204. what is the sensor directly above the oil filter that bolts into the block?
  205. 4th Gen Prelude Build.
  206. Misfire at cold start up.
  207. Guess this A/C Compressor!!!!???!!?!!
  208. Automatic transmission problem.
  209. lsd clunking noise???
  210. '85 Prelude Si refuses to charge
  211. problems with my 1990 Honda prelude
  212. OEM or Aftermarket Control arm for DD?
  213. Prelude A/C effecting idle. Common problem, but what is the solution?
  214. Axle binding .. after 5-lug swap ?
  215. h22a hks sld
  216. timing help
  217. Prelude bulkhead parts?
  218. ATTS code 73 fix it or swap it?
  219. h22 resistor plugs?
  220. Koni Yellows + GC coilover sleeves
  221. ecu question odb1
  222. Pic request?? Photoshop?? Seen somewhere?? Thoughts??
  223. SH transmission confusion?
  224. Suspension systems for a 4th gen
  225. 92 prelude h23a VTEC DYNO
  226. MAP. Best location? TB or IM
  227. Will these seats fit?
  228. 91 Prelude Si snapped timing belt
  229. 93 prelude - NO DASH OR TAIL LIGHTS
  230. Main Relay Fuel Pump
  231. H22 JDM engine swap guide
  232. Which h22 intake maifold would you pick?
  233. Honda sounds like a subaru
  234. 3rd gen ecu upgrade
  235. 89 prelude Si b20 2.0 bouncy idle issue help!!!
  236. 99 honda prelude auto transmission issues
  237. VTEC vs No VTEC
  238. 96 honda prelude ac blower not coming on at all
  239. bouncing idle and wont rev past 4k
  240. H23a Timing HELP!!!
  241. h23a1 head on a f22b2 block questions.
  242. Where to buy motor
  243. friend got into an accident need some advice.
  244. HELP! Problems with oil on H22a head.
  245. Hondata intake gasket, loose nuts?
  246. obd2 obd1 conversion h23a blue top
  247. 4th gen front bumper
  248. Prelude ride height help!
  249. prelude sounds like subaru
  250. some one please help.
