View Full Version : Honda Prelude
- Battery not being charged
- auto tensioner failer
- My Honda Prelude - BB6 - Misty
- Custom 5th Gen Type S.
- 92 prelude si h23 tranny issues
- ABS delete ?
- Common Problems over the years
- DIY: 4th Gen EL Cluster step by step conversion (9 pictures)
- Clutch adjustment.
- Compatible Timing assemblies?
- Max tire size
- Alternator Nut, Removing valve cover
- Adding More To A Finished Show Prelude "Motor First"
- Need advice - lost car keys.
- First Prelude First Honda - Concern's on Refreshing Engine
- 92 , 95 prelude body
- H22 in 3rd generation honda prelude
- Looking for a motor for my prelude
- Help! prelude running rich
- Disconnected EVAP purge solenoid car runs better?
- 96 Prelude - Accord Manual Compatibility?
- 98 prelude wiring help
- Building n/a bb6
- Went into limp mode during the race
- Ecu question for turbo f20b
- piston pin question =)
- 5g Lude diagonal cut eyelids ?!
- 4g prelude electrical help!!
- 2001 honda prelude patch panels
- Logic-defying non-starter!
- Info
- Active torque transfer, h22a4,m2u4 parts
- Anyone hear from John at ESP?
- BC Racing BR Series Coilovers
- H22 rebuild
- Someone please identify b20a5 1990 prelude
- Whirring Noise from Manual Transmission
- Venting block from BS alignment hole.
- H22A4 turbo build.
- Exhaust leak?
- H22a4 to h22a swap help
- Help
- 98 Honda Prelude automatic base model hesitates
- Car won't start. What could it be?
- A real head scratcher.. Any ideas?
- Engine Revving up / Clutch not grabbing
- Hard start when hot, and idle issues
- If I'm missing a fuse let me know
- smog questions
- My $100 5g Prelude
- Recommended_H22A4 Gasket kit
- HVAC control
- H23a Bluetop Vacuum Leak...please help
- prelude trans question.
- 15s on a 5th gen
- mchef's slow daily build
- 97 h22a4 oil leak
- Type S Swap into 1997 SH Prelude Help
- 1987 Prelude 2.0 si won't start - intermittent
- 93 honda prelude HELP!!
- CA Smog help
- Amp not receiving power
- B20a5 exhaust ideas???
- Removal of underhood fuse box
- Oil in spark plug well, 2 plugs wont come out
- Pulsating vibration
- How do i reduce my exhaust noise?
- Euro R swap done no spark rywire distributor adapter problem? Please help
- 1990 Prelude Fan Issue
- Knock Sensor (P0325): Car Shut Off, Wouldn't Turn Back On. Please, HELP!
- energy suspension
- poor mans h22 build
- How to remove?? Prelude driver seat rail.
- H22 Turbo Integra build
- H22 skunk2 or EuroR Intake Mani (MY SETUP)
- Best Full Exhaust Systems for bb6
- Advice on ecu for my 5th gen
- Anyone wanna sell me P5M ecu Manual for 2000 Lude
- Code 8 CEL, top dead center/crankshaft position sensor? Help !
- f22b jdm dohc over rev... cheapest quickest fix?
- Help please to identify extra pugs
- H22A OBD1 Swap Mystery
- Auto Trans Prelude- Do or Don't?
- electrical wiring diagram
- Check Engine No Link OBD2 Scanner on H22 Motor Swap, help!
- 1999 honda prelude base CV axle question
- Rattling sound when accelerating
- Sh tranny with h23
- Honda prelude idle problem
- new prelude owner! 2001 question pls help
- 1999 H22A to H23A engine swap
- Identify this suspension :: mystery coilovers..
- Trunk Release fix bb6
- Power window problem
- BB6 Gang!
- No-start after misfire code, fuel and spark
- H22 limp mode
- clutch hydraulic/fork problem
- 99 prelude smoking- A LOT of oil going in from pcv valve.
- H22a valve cover stud size?
- 93 Honda prelude vtec kills car ?
- prelude: a litle high HC Smog failed
- Just picked up a Type S h22a Swap a few questions
- Rear End Link Fitment
- cannot get clutch pedal!! HELP!!!
- H23 throttle body spacer?
- Thermostat housing
- 2001 prelude cam/crank pos sensors
- Quick question
- fresh headgasket, white smoke. help?
- Sputtering in low rpm after vtec engagement.
- Prelude h22 crank pulley fell off. No compression?
- Need help fixing cruise control
- 4th Gen Two Seater Conversion Project (with pictures)
- Fly wheel
- Bouncy Idle and overheating.
- Max boost for stock h23 block
- Is my Axle All The Way In?
- H series noob needs community help!
- Stupid Code 43!!!!!
- f20b madness
- 98 Prelude type SH, thinking about selling
- Drivers side front bumper side marker losing power
- prelude w/f20b question
- 3rd gen.2.0 so low idle cut-out
- Bare essentials
- To swap or not to swap?
- 5th Gen Project Car - Oil leak
- Looking to get a Prelude. Couple options I found!
- 4th gen foglights. Projector?
- What Do You Think ???
- Prelude check ups
- TD-61U H22a4 Firing order
- No fuel after Engine swap
- Have an issue with my car lossing power
- egr delete cel
- P13 HF-1 HEAD?
- f20b oil filter
- Cylinder Head Identification
- Need help with TPS, closed voltage at 4.9v
- Auto Trans Advice from folks who have done it
- I think I need an engine H23A1 to H23A3
- stuck!!
- turn signal indicator issue. need assistance please!
- SENSOR HELP!!!
- ecu cabin wiring harness issue
- VTEC problems after timing belt replacement
- transmission question
- 4th gen question about Mirimoto Mini HIDs
- TD-94U distributor F20B/H23AV/EuroR OBD2 Intenal Coil Dizzy same as OBD1 inside?
- H23 vtec swap distributor wiring
- help please!!!
- Noob needs assistance with idle
- H22 Throttle Body fit H23? (Auto)
- Abs light
- Engine swap
- Is buying a new distributor from China a good idea?
- Misfire was fixed by increasing fuel pressure?
- what are these seats?
- honda prelude 98 turbo build
- Professional product 68mm with Fitv?
- FTP sensor vs Evap purge switch.
- H23a1 to H22 conversion
- spark ignition issue
- Power steering issue
- HELP with 1996 Auto ECU 37820-P12-A70
- Dizzy Internal Coil JDM Type S/Euro R/F20B/H23AV OBD1/2 JDM H22 Coil & Igniter Same?
- Just got some new suspension
- Old Timers, Come in here and update us!
- coolant drip can't find
- Request for facts of a 91 H22A out of a prelude si vtec
- Ignition switch won't turn over after swap 1998 Prelude MT
- Prelude crank & tdc position sensors
- 700hp Texas prelude - whos car is this?
- is my timing belt on correct timing
- f20b balancer belt
- Help, I can't figure out where thos vacuumn line goes
- Clutch issues
- Shaking while accelerating
- m2l5 gears
- Sunroof seal on a '92
- f20b timing belt issua
- 98 Prelude Auto Trans
- Prelude 2000 need help
- Loud clicking at 3k rpm and up
- ABS light...
- Tie rods
- G22 build
- 4gen front sway bar
- need help with dizzy
- I'm trying to find the exact body color code for a Honda Prelude 2.0i 1998 (BB3)
- 92 prelude si pro needed
- '93 Prelude misfire on acceleration
- Steering wheel shake while driving
- 92 prelude won't idle at all
- AC Delete belt Size Nightmare
- oil catch can or breather or breather catch can?
- P1361 Code After Swap H22A to H22A4
- Stolen vehicle recovered, now car won't start
- Hard water stains on 94 Si rims, any suggestions?
- crank no start
- h23a3 motor hesitation
- Genuine leather steering wheel?
- Tuning my Prelude
- Timing Belt Help
- 2001 Prelude momentary loss of power/check engine light.
- Options for 5th gen Prelude Power Steering Rack
- H22a questions
- I want a header like this! Don't we all?
- what to do next on the car?
- Year determination on swapped parts
- 4th gen prelude bogging
- motor swap ecu /vtec issue please help.
- 5th gen manual starter
- Prelude Start-up Issue
- 15% lower compression in cyl 2+3..head gasket?
- size of 93 prelude shift knob?
- Greddy SP2 on a 92 Prelude Si
- 1999 Honda Prelude Massive Oil Leak
- Water over flow
- 98 Prelude Cooling Fan Issue
- 2001 Prelude Vacuum diagram and vacuum box problem please help
- 3rd Gen S4 light flashing, speedometer intermettent
- cluster swap
- Hard wiring Vtec Solenoid?
- 92 h22a prelude misfire plz help...
- opinions please - f20b gt35 ball bearing turbo.
- F22 crank in 97 H22a4
- Could I still pass smog with this engine? (California)
- JRSC H22 guys, I need your help!
- Anybody using a Borg Warner S372 Turbo?
- Help needed!!! looked everywhere and can not find
- Best Internal Mods To Increase Low End Torque On An H22A4
- Help identify plug
- how can I fit 13" circle track racing wheels on to 94 si
- what is the price range?
- ATTS lines disconnected and dont know where they go
- 98-02 accord trans( P2A8 )into 94 prelude question
- 01 Prelude clutch problem
- 93-96 bb1 Value?
- Supercharged H22A vs Turbo'd H23A
- Help me play "NAME THAT SENSOR!", aka, car is stalling, hard to start after it's warm
- h22 transmission
- td-60u internal coil distributor.help
- 01 prelude issue. please help
- Water leak bad weep hole?!?
- 92-96 steering wheel hubs?
- 1995 honda prelude radiator fan problem
- Spongy Brakes????
- New engine burning oil, thoughts?
