View Full Version : Honda Prelude
- H22/F22 Fuel rail question
- H23Block W/ H22Crank?
- badd gas mileage
- jun/cosworth pistons
- New prelude member
- 92 to 93 center console conversion question
- MyCar! I finally figured out how...
- What size tires is best for Rota Slipstream 16inch????For a 93 prelude.
- ABS light turned on
- accord intake and prelude intake
- Timing... HELP
- Install new block
- Extreme Valve clicking noise
- removing fender(need help)
- Putting in an ECU chip
- Check out my timming belt
- 4th gen. 2.3 non vtec parts
- plugs for f20b
- rpm's drop when i push the clutch in
- Confused about Weight of Cars
- jdm h22 pistons in h23a1
- crower stage 2 cams with stock valvetrain and pistons?
- just got done with swap but car wont move
- 4th gen won't go into reverse
- Which camber with h&r race???
- 4th gen. 2.3 ltr automatic parts
- any way to clean carbon deposits from exhaust pipes??
- H22 ITBs sound clip
- h22 jdm distributor
- h22 to h23 tensioner... should I?
- which cams to go with and do i need valve springs?
- ECU cause valve clatter?
- JDM H22 valve adjustments
- question for people that have looped their power streering lines
- wet distributor?
- wut motor to go with
- whats more expensive
- JDM rack&pinion same as USDM?
- Prelude Springs
- How can I check the oil pressure to the head?
- Input anyone!!!!!!!!!!!!!!
- My GF's 92' Lude is overheating!?
- Need a huge favor from the luders...
- What should i do?
- Final Purchase Decision
- h23 vs. h22 oil pump
- pics of 97-01 stock radio please
- JDM/USDM Tranny and Clutch
- Curb Weight?
- Smoke problems..........?
- how to install a header
- Crower Valve Springs Question?
- The official H/F piston/rod/crank/block specs and CR thread
- H22 in EK with H22 axles, springs, shocks, rotors, brakes etc...?
- Prelude Engine
- 17x8, +35mm offset -> OK for 4th gen?
- O2 Sims on 2000 SH Lude?
- JDM type S vs. crower stage 1!!
- prelude SH question:
- Need help finding wings west lip
- H22a prelude running like crap...
- Prelude on tunerzine.com a few quections
- JDM H22 swap or build USDM H22?
- H22 VS H23 gear ratios?
- 5th gen radiator question
- VSS sensor in 98 lude
- Dirty oil questions...
- jdm vs aftermarket headers
- VTEC question
- '93 prelude wiring ?????
- h22 vs f22 exhaust manifold gasket
- Exhaust diameter
- All axle-back exhausts..
- Civic Radiator install cant find the article
- Where can I get thrust washers??????
- Lee from Koni?
- ???Cleaning up the engine bay, what can be removed with out throwing a CEL???
- trouble with starting new h22
- clicking in the rear axle?
- CEL stays off, fuel pump not getting juice
- exhaust tone..no more rice
- vtec question for my 99ludeSH
- what would cause a balancer belt to do this?
- Best H23a sleeves(turbo)?
- 92 JDM H22A 5-speed, hoses on tranny?
- My car keeps getting hit!
- H22 Engine decoder How do tell if I have a JDM motor?
- Limp mode with no CEL?
- 4gen with eibach pro kit
- Compression Test Q
- Modding my prelude
- Pulleys: AEM vs. OBX
- Blue Dash Light Conversion Tip
- rear bumper marker?
- h22a4 valves and valve spring
- h22 question
- Smog Test Failure Help
- dumb header question
- H23 Timing...Searched, No answer...
- 4th Gen climate control light issue. Have to tap it to make it work
- Vehicle Speed Sensor. help
- Need vafc help!
- Any other lips fit the 5th gen prelude?
- 4th gen rear cross member
- trying to find out how much and where to put the oil for the compressor
- Electrical Problems
- 4th gen spoiler
- redline on a 97 base?
- I have a IDLE Problem???
- how do i bleed my clutch system?
- Greddy EVO TT 70mm piping
- Another gas mileage thread...
- honda tech meet night cruise seattle
- p13 ecu
- some wire tucking
- need info
- Car rocks from side to side @ high speeds, what's wrong?
- h22 smog
- Pulley belt size with A/C removed! help...
- What Color ???????
- Need help with radio harness
- My Prelude needs something??? Its playing with me
- H22 oil pan same as H23/F22/F23?
- Intake manifold is out of my car, What should I do to it while its out?
- Help on wiring Fog Lights, 4th gen...
- rod and piston combo
- Need a transmission......
- Nitrous kit
- Dyno Results(Rage header/exhaust)
- h22a distributor Q
- Fuel Injector Problem.....I'm stumped!? Please help.
- 4th gen H23 inner cv boots leaking (Searched)
- 92-93 to 94-96 interior change over?
- Will 90 SI Head Fit on 89 S block?
- Flex pipe broke
- prelude oil bolt
- power loss after accidnet
- 4th gen suspension.
- Need help winning the "Is the Gen 5 prelude ricey or not" argument..
- Computer Tuning software??
- Rebuild or type S engine swap?
- 93 H22 with OBD2 P72 ?
- 2000 prelude tranny
- Camber Kit Question
- Megan Racing SS Cat-bak exhaust, awrsome
- H22 Head O Ring???
- How can I change the mileage when installing EL gauges
- Spring rate question (searched)
- Integra Type R Vs. Prelude SH
- code 22 oil pressure switch
- Flat spot
- throttle bodies for Euro R intake Manifold
- Okay to run 225/50/15 on a 4g?
- Deck burn wire
- 4th gen radar mounting question
- whats the best/most reliable place to order your jdm H22 online?
- Frame bend to the left?
- clutch going out?
- ACT vs. Centerforce clutch
- h23 main cap torque specs
- Intake Air Temperature
- engine management
- No spark after cam install
- quick question,nitto drag tires
- Factory H23 rod strength...How much Power can they handle?
- Hondata/Uberdata for turbo Lude?
- h22a1 head and h22a4 block
- NGK plug question
- TD60U and TD61U distrbutors?
- o'rileys or honda?
- h22a jdm euro r
- Car and Driver Prelude articles
- Black smoke
- Removing an H23 head.
- honeing sleeves yourself....
- should i gut My cat converter?
- nepTUNED
- just got a 93 prelude vtec
- running rich at idle, read...
- Fixing turn signal harness???
- b20a mounts question
- please help
- Please help my H22!
- Where to find after market seats (preferably in stock/in town)
- h22 without shifter cableS?
- car ran so lean, fail smog, need more fuel
- Know of any good bodyshops? the new prelude can opener!
- Timing belt - Anything better than OEM?
- Grill vents and grill
- OBD2 to OBD1 Conversion
- Axles
- Whats the mesurements for the corner
- h23 to 86 prelude swap
- getting a car
- I am confused, some crazy Celica?
- taking out windshield
- Video of me racing at CMI few weeks ago...
- Sunrise JDM Motors Vouch?
- SPEEDOMETER GAUGE
- AEM cold air or AEM V2 for nitrous?
- 90-93 accord radiator and a/c fan
- my clutch is depressed. (98 Sh)
- Felt good at 135mph
- Momo wheel with quick release
- dsm 450 injectors with oem h22 resistor box???
- do i have to do bleed again?
- Prelude Gen. 4 EFI problem
- stipid question dash swap
- how do u take out speed gov jdm p13
- Greddy Evo Cat Back Exaust for 5th gen. Prelude
- worn out shocks?
- Throttle bodies for Euro R intake?
- Stock 92 radio problem
- h22 prelude swap ?'s
- Worth it to rebuilt?---H23a1
- Updates on "where i've been"
- H22 TYPE S IN 96EK
- Changing the belts anything else I should do?
- What did i do to my clutch/tranny??
- h23 to h22 swap (hmotorsonline)
- Skunk2 Intake Manifold Idle Problems!
- Question about Redline
- Funny noises from under the hood.help
- NEED HELP FINDING GOOD PRICE ON SPOON LIP
- top speed 118
- ecu and fuel management
- stock base map
- ALL 5th Gn Prelude owners, **RECALL** on your car!!
- mounting hood pins
- 1994 Prelude Vtec, how much is it worth??
- Sunroof, cruise, fog light switch, gauge cluster lights not working?
- Problems that make you want to set the car on fire...
- 92 si, engine hot, needle cold, white smoke out exhaust some under hood
- prelude 3g 91 si with a b21a
- Steering rack worn out?
- Valvetrain upgrade...
- How heavey is the stock prelude hood? 5th gen related...
- JDM 1 piece headlight
- electricity turns off when i try to start?
- Yellow top optima battery. which one??
- OEM alarm Question Disarm button??? car not starting
- MYStiff Clutch Pedal
- ok guys quick easy question
- undifined noise in h23
- Honda Japan Links
- how to gut a catalytic tech fourm wont anwser
- ???Missing one of the two ECU fuses in the kick panel???
- Difference in JDM Prelude and USDM Prelude (97-01).
- Hubs?
- People who have done auto-manual swap 4th gen, searched. About firewall.
