View Full Version : Honda Prelude
- got oil beneath my car, don't know where it's coming from. Help
- What turbo cams are you running on your turbo H22A????
- Swapping H22a gears with Accord?????
- Emissions Help: Hondata+test pipe
- Buddy Club V Con VTEC controller
- TYPE s pistons in stock jdm h22a block?
- Poly Motor Mount Inserts
- H22A P30 WIRING
- will 92 si side mirror fit 93 si side mirror?
- stainless steel brake lines
- pulling motor
- What have you paid to have your block sleeved?
- headlights going out
- Replaced cam seal and distributor o-ring, but there are still leaks??!!!
- 5th gen prelude, how do you get the fuel pump relay out?
- VTEC pins on Euro-R ecu?
- Prelude VTEC performance upgrade advice
- a lil advice about preludes
- Location question. *searched*
- Need opinions about ECUs, valvetrains, fuel rails, etc.
- Replace this distributor rotor and cap ?
- right hand drive
- swap?
- camber kit woes
- stupid me mishift today, i think i bend a valve, how can u tell?
- loud preludes
- IACV going bad. . .searched
- what would you guys do?
- 4th gen s model radiator good for an si?
- Dyno/tune results.....
- Cam lift and Duration of JDM '94 H22A, not Type S though?????
- will this radiator fit H22?
- help with cleaning jdm headlights!!!
- H22A Engine and Tranny Swap
- 4th Gen Side Parking Light Replacement. Help
- H22 quad throttle body
- Alexlude, anyone got his e-mail address??
- Is there a way to drain all the atf yourself?
- H22 oil and coolant capacity
- 15) Ignition Output Signal - Missing or defective ignition output signal ????? need help
- Intake Manifold help (top portion)
- What is this connection on my fuel rail? Pic included!
- Which valves? Ferea Competiton Plus/Sodium Fill hollow stem or Manley
- Prelue + ITR = ?
- JDM weekend :)
- p13 chipped ecu
- Aftermarket timing belts -vs- OEM? Thoughts
- Free 40 point inspection from honda. (no charge) anyone gone/heard of it yet?
- Info on All OEM F/H Series Piston/Rod/Crank Combos
- Just 4th Gen Lude PICS (**56K Warned**)
- Two important questions H22a turbo and nitrous intercooler sprayer
- type sh exhaust on 4th gen vtec?
- Couple of wheel questions...
- h22 rods on a h23 engine
- 1992 Si Wiring Harness and Knock Sensor?
- issue with idle and idle control on a h22... need input please
- Timing Belt Change, 2 quick questions
- world sport I vs. world sport 2
- JDM H22a has no thermostat?! Help me out.
- vtec cuts out...
- wtf why doesnt it work? aHHH
- No signal to injector#3 only weird.. HELP!! Code 9 & 16
- How To: Replace VC gasket and O-Rings?
- Rocket Cams?
- strut bars
- USDM El glow cluster and JDM inverter quastion ????
- JDM styled headlights
- Stealth Hitch 01 Prelude for bike carrier
- buying a prelude
- msd ignition...
- Gas in the oil Please Help quick
- ebay p13 spoon chip ????????
- Vtec Controller INstall Help
- have spark and fuel comming but car won't start
- H22A - Fuel but No Spark....
- Hit a pothole, now suspension squeak on front passenger side
- Jdm pwer folding mirrors
- tach is jumping all over the place
- 1990 Prelude question... Please help.
- 4th Gen Intercooler and Charge piping
- Anyone tried the Weapon R coilover kits?
- Help... I have a short somewhere! =(
- h22 LOW PROFILE OIL PAN
- h22 needs to be fully built
- Re-Charging Air Conditioner
- Do you have to remove the spindle nut to get the brake rotor off?
- CEL - H22A - Knock Sensor
- H23A1 / H22A exhaust...HELP!!!
- LS cams into a b20a5?????
- wierd noise coming from timing belt
- H23A1 / H22A Belts....
- swap complete.. first drive!!
- jdm password magnetic drainplug
- question on itr boot and knob installed in 4th gen
- type S pistons in h23 non-vtec
- Type S pistons
- Recaro Seats in 5th Gen Prelude: WHAT BRACKETS/SLIDERS?
- F22 valve cover stem broken...
- are there yellow bulbs that fit in the highbeam spot on jdm headlights?
- 93 ac
- 98 prelude rpm
- 97-02 honda prelude headlamps for sale!
- 4th GEN Mugen experiment.... need your help
- just aquired an 84 prelude, looking for info
- where to dyno tune in nj-pa-del area??
- Snaped Rear Sway Bar
- Bolt on turbo kit
- Valve Lash or Clearence on H22a Shunk2
- how do you remove this sunroof switch bulb
- Frog pod guage installation. Need help please
- Irratic idle, bogging, slight over heat (swap)
- 1 piece lights
- vtec console conversion for 4th gen...
- No Tengo VTEC!
- 5th Gen. Prelude Retrofit (TSX projectors w/lots of pics)
- mugen headers and exhaust
- 4th gen bumper removal
- For the love of god I need more headroom!
- hit a crazy pot hole
- another h22 issue need fast help please.
- AEM fuel rail question
- car dies
- ATTS light came on... *HELP*
- Fron turn-signals don't work, its not the bulbs.
- Considering a 94 prelude
- Difference between SH and Type-S
- opinions on xtd clutches and flywheels???????
- need help cant find type s long block
- H22 ramhorn style manifolds
- prelude bumper help
- a/c removal
- High Stall TQ Converter-H22a Auto
- OEM knock off lip kit on ebay
- vent selector light
- prelude vetc controller instal.
- coolant bypass
- cel code 43: what to do?
- Opinions on engine bay color...
- o2 sensor
- 4th gen yellow JDM fog question...
- *SEARCHED* 5th gen JDM fogs into replica Mugen bumper?
- Car cant seem to find idle speed
- Small problem just going to get worse? White smoke/ Raspy engine noise
- GREEN cams!!
- Will 5th gen brake lines fit 4th gen?
- Noisy hi flow cat exhaust sound
- 93 AC problem
- 4th gen JDM DSP Sterio
- 1997 H22A Type S LSD tranny
- .:SMSP Installation:.
- Euro-R manifold: Compatible Honda Throttle Bodies?
- I want to buy inverter(silver box) foк 94-96 El cluster!!!
- Brakes
- which prelude?
- Wierd Idle at Start Up
- Cruise in honor of Ryan Foley who died 4-11-06 in a car accident
- Coilovers ?
- i did search but i don't know how to do it right...?
- brakes.. again. help
- injectors question???
- emissions help please
- What shop to look for?
- Prelude intake manifold question! Ebay?!?
- links to download 4g prelude service manual???
- shift cables can you...
- LCA ball joint problem
- h22 stutters when i turn ignition off??
- Turbo Lude Running Lean - Diagnosis??
- 350+WHP
- Hi-flow cat options
- interesting sway bar idea...
- f20b vs g23
- getting a 01 lude
- looking for prelude lips
- Polyurethane exhaust bushings
- i found a post on how to install a lsd will it work for h22 tranny
- Brake Light
- Oil Viscousity: Synthetic vs. Conventional
- Highest HP N/A?
- Suspension install gone wrong :(
- Fiber-tuned Carbon Manifold makes power NA
- H23 Deal?
- Unofficial CAI Poll
- Flywheels
- help!!!92 si h23a1 5spd intermentant shut off while driving
- turbo prelude tuning help. hondata.
- Question on aftermarket intake manifold!
- lca bolt question
- 5th gen headlight wiring harness for retrofit
- 5th gen prelude camber question (searched)
- Car stalling Already searched all the archived content --PLEASE help
- how f'd is my prelude
- Replaced clutch/flywheel and now have clutch chatter in 1st/Reverse??
- Need Detail Pictures of H22 header
- obd2 harness & h22a distributor
- Need An EGR Valve For A 1998 Honda Prelude...
- 4th Gen JDM Climate Control Problem
- my little setup
- vibration after clutch and flywheel
- h22a1 h22a4 question (searched)
- how do i tell if my oil pump is working or not???
- auto tensioner help??
- AC Autotechnic S72 El Gauge getting stuck
- Radiator Question
- Steering wheel vibrates after heavy acceleration and hard turns
- changing rev limiter - will rsm or vafcII work?
- Is it my auto tensioner?
- Pulling h22 from 4th gen.
- Prelude 97 RPM too high?
- can't find my obd port
- Having trouble starting a 99 prelude
- Timing Belt Problems
- Clutch has no pressure
- Baer Brake Kit
- who knows???
- Funny noise
- Performance Valves, Springs, Cams H22A
- Symptoms of a seized caliper?
- High theft rates on 97+ Preludes???
- fuses for car radio
- need h22 diagram (layout) and need crash course on vafc tuning
- Removing Intake Manifold on a 5th gen. SH
- DIY steps to painting fiberglass lip or bumper
- Help me identify this part from my vague description!! H22a inlet mani
- H22 Swap, Accesories Related
- how to run speaker wires through door jamb?
- What is the 5th gen wheel offset: Stock and 17x7.5
- Im looking for a big brake kit
- Using premium fluids
- Hondata question
- KYB AGX adjustables on a 5th gen prelude
- 5th gen prelude ABS
- rev limiter
- How did you wire your power for an amp in a 4th gen prelude??
- H23 Stroker?
- Extreme Jerkiness in 1st/2nd H22A
- what kinda lips????????? (searched)
- i searched...what's the size of a USDM 1999 Prelude Throttle Body?
- getting a new slave, ever heard of these companies?
- using to much oil
- 2 different h22 crank pully bolt sizes?
- Accord P/S question, Need this settled once and for all
- oem fog light installation 4th gen
- JDM door controls
- brake rotor remove 1997 base
- Quick Question(Tanabe Exhaust)
- windshield..
- Doing Cam Plus install on 95 Prelude...
- 1992 paint code.
