PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 [188] 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. No spark on JDM H22 in Accord HELP!
  2. Gas mileage???? (prelude SH)
  3. Oil leak from hell?
  4. got a leak from hell?
  5. 5th Gen. Gas Mileage
  6. What's the best sleeper exhaust for 4th gens?
  7. Electrical problem on 92 gen4 lude SI.... help
  8. Sporatic idle problem?!
  9. Fuel pressure
  10. Code DRL
  11. Swapping windows?
  12. question about 92 si and 92 si 4ws
  13. 4th gen and aftmrkt seats?
  14. check out the f20 set up ..
  15. how to replace h1 bulbS?
  16. Pulled codes for CEL and found out ABS flashed one too. Is this a problem?
  17. Dc header Stainless Steel on Ebaay, worth buying?
  18. help needed
  19. 92-93 integra harness same as 94-95 harness?
  20. h-23 crank swap
  21. coolant drain plug location
  22. rev problem
  23. Prelude Repair Manual
  24. crower stage 2 cams h23....good for turbo?
  25. H22 Exedy Twin Disc Clutch?
  26. 4th GEN HEADLIGHT REMOVAL
  27. Quick Question?
  28. strut bar question
  29. cam question
  30. 97 ecu no a 96?
  31. trans. gear swap. read.
  32. Hayame exhaust
  33. what tranny has the shorter gears with lsd???
  34. 5G H22A4 > H22A Swap Notes v2
  35. Swap : H22a4 into 92 SI
  36. Clutch install help. -> shift linkage
  37. How to pull codes on a 1999 prelude?
  38. 15w30 in my H23... why shouldn't I?
  39. help on 4th gen work
  40. 1989 Honda Air Conditioning Trouble
  41. h22 and h23 valve cover interchangable?
  42. For those with JRSC water injection option
  43. IMPORTANT!
  44. a/f gauge stopped working when converted my car to obd1
  45. trying to find out what cooler this is
  46. been gone a while, noticing new things....
  47. should i buy it?
  48. oil pan gasket ?
  49. best chip for p13?
  50. which seats can i put in my 5 gen lude??
  51. h22a with type-s cams?
  52. chipped P13 + nitrous? bad idea?
  53. H22 UNDER PRESSURE!!!!!!!!!!!!
  54. head gssket
  55. need help.plzzzzzzz
  56. springs
  57. turn signal housing
  58. Stock Headunit ques??? cd player!
  59. Oil Pump Assembly? H22A1
  60. Should I install a JRSC myself? need advice from those running a JRSC.
  61. idle air control valve and fast idle valve location???
  62. Accord Euro-R or Type-R Tranny
  63. Snapped timing belt with fully built head
  64. jackson racing fuel rail having problems with fuel pressure regulator
  65. jdm h22a in a 5th gen...
  66. help
  67. Engine Harness: White/Yellow wire leading to FPR
  68. HID fitment question
  69. any review or feedback on Prostreet's timing belt kit?
  70. help changing front light bulb.
  71. Buying a 5th gen, need advice. Common problems?
  72. Problems Galore. Misfiring. Fire!
  73. h22a4 block question
  74. switching ECUs...
  75. failed emissions by a nose
  76. 5th Gen SS Automatic to 5 Speed Swap Wiring Information
  77. starter?
  78. F series vs. H series
  79. header advice
  80. Tuning with Microtech units...
  81. anyone have flooding problems with their prelude?
  82. Pillar Bar
  83. NO A/C DIODE IN MY 97 PRELUDE?? 97-99 Honda service manual says there is, Honda Dealership says NO??
  84. 4th gen power locks **security breach bitches**
  85. Greddy turbo 5th gen prelude
  86. C/F weight savings
  87. Headers for SH Model
  88. digital climate control
  89. Will an Exedy Organic Clutch hold?
  90. external or internal coil???????
  91. Odometer problem
  92. Tokico ILK Kit and Rota Circuit 8s
  93. EM Racing C-Pillar Bar Length?
  94. just picked up a 96 a1...some questions
  95. 1992 si swap info
  96. Good website for 5th gen body kits/skirts??
  97. DRL and headlight question
  98. tranny help; those who've built their own
  99. aem ems 5th gen?
  100. 5th Gen Parts for sale
  101. 92-96 owners: For people with seatbelt issues...lifetime warranty
  102. Front upper A-arm bushing question
  103. Civic rad in 4th gen: Here's how...
  104. 91 Si lude worth bringing it back
  105. In car shower initiation
  106. 3rd gen lude
  107. What kind of gains can I expect with Type S Pistons + cams on a 97 Sh?
  108. 376 horse h22 turbo
  109. dtc 19?????
  110. ABS pump making noise at startup om 2000 lude
  111. Will this DIY catch can/blow by can set-up work?
  112. Slipping clutch or bad flywheel?
  113. Spark Plug Shot out and dented hood
  114. oil catch can install..
  115. Tenzo Overdose rims!! tight
  116. SH tranny and Base lude
  117. Racing store in so CAL
  118. jdm type-s pistons PART NUMBER needed!
  119. HELP?? Distributor cap shows corrosion on the firing pins?? Replace? Wipe off? 97 Prelude... HELP PL
  120. Oaks Racing Prelude Update
  121. Brake Problem. Already searched.
  122. Honda MTF...can be replaced by MT-1 fluid?
  123. Catalytic Converter Review with Pictures.... Where?
  124. Having clutch pressure issues, any ideas?
  125. 4WS production numbers?
  126. Replacing wheel bearing on gen 4 lude
  127. ok help with steering and wheels
  128. Air cleaner box size
  129. Whining noises as the rpm climbs : normal or not? (5th gen)
  130. Jay's racing carbon fiber intake, 2.2l group buy!!!
  131. Question about 3rd Gen Ludes. HELP PLEASE
  132. 5w-30/0w-30 question
  133. Pros and Cons of H22
  134. H23 to H23a VTEC
  135. H23 auto tensioner? (searched)
  136. f22 head gasket help!!!
  137. whats goin on with prelude hp numbers???
  138. New code (10)...IAT
  139. H23 Removal Question
  140. stock lsd
  141. intake manifold question
  142. Need to buy EGR Block off plate
  143. My prelude is dying..!!!
  144. Anyone need a couple valve spring retainers for an H22A?
  145. Idle Question (searched)
  146. just curious
  147. Upper control arms, etc replaced - now back end feels loose
  148. VTEC radiator
  149. 1997 PRELUDE radiator & condensor fans do NOT engage?? Have done numerous tests with NO AVAIL!
  150. Thinking of purchasing a 3rd Gen
  151. Removing 94 prelude seats
  152. weapon r header?????????/
  153. Headlight question
  154. Hondata Datalogging Question (searched)
  155. Prostreet FLywheel any good?
  156. Header's & JRSC question
  157. whats up guys
  158. newbie question about brakes. Pedal pushing too far down.
  159. Minor taillight problem
  160. How to remove brake booster on 92 prelude?
  161. no pressure in clutch pedal HELP!!
  162. Where to buy an O2 sim
  163. NEED HELP with Reving problems
  164. Smog questions
  165. H22 exhaust port spacing
  166. Removing Axle
  167. Which wire is the A/f on the 5th gen stock ecu?
  168. TPS question for SH
  169. Looking at a 01 Prelude...advice please!!!
  170. Just an Idea about the Flapper valves in the intake manifold of the H series
  171. does your lude do this? Vtec malfunction-heat?
  172. Replacing synchros in my JDM H22 transmission.... HELP!!!
  173. Does the 2004 model S2000 steering wheel still fit the Prelude? (searched to no avail)
  174. Oil Pump Breaking?
  175. Comparing 4th and 5th gen exhaust routings
  176. Ticking noise in car when idle
  177. Removing Cats
  178. High Compression Turbo App
  179. JDM foglight bulbs modifying the H3 *Tried searching already*
  180. need tips on anti theft
  181. Reverse Light Woes
  182. cheap stock clutch kit?
  183. flywheel for 91 prelude
  184. M2A4 transmission question....
  185. H22 gauge installation question....
  186. honda prelude 97-01 test pipe *searched
  187. victim of theft... where can i find this?
  188. best theft deterrent system (does more than return ur car) *funny
  189. where do you get type s stuff?
  190. Enjo Mounts
  191. My prelude stambles when lunching ????????? help
  192. h22a or jdm h22 preferred?
  193. Motor Mounts Un-install
  194. Tuning with uberdata, ecu/obd question
  195. Axles - Base vs. SH
  196. Interested in buying a Prelude.
  197. CEL code 16 what the?
  198. F22 TPS on H23 manifold?
  199. vafc or hondata
  200. 12.721 @ 108.30 pass at NOPI Phoenix (more hope for the NA guys)
  201. axhaust for turbo
  202. 92 h23 rods what year h22 pistons?
  203. Help w/supercharger Installation
  204. Can you use this ecu????
  205. guage cluster quit working
  206. 4G rear camber adjustment needed to compensate stock setup
  207. hondata ecu question?
  208. 00' Lude, 12 sec car project
  209. Stock fuel pressure???
  210. suspension problem
  211. tech HELP
  212. cant find . need help
  213. sputtering before vtec...
  214. H22 drop from F22 in '94
  215. Exhaust for 92' Lude
  216. Custom Exhaust Piping
  217. which stage two clutch is good
  218. check engine light on.. help
  219. Exhaust sound clips?
  220. Synthetic vs. Conventional - comparison
  221. Transmission won't go into any gears...
  222. f22a1 vs h23a
  223. What's the engine code?
  224. Should i buy this PRELUDE???????
  225. Tach Problem
  226. How much do these things weigh?
  227. Which pulley is this?
  228. remove main gauge assembly w/o disabling SRS?
  229. 1980 prelude project, is it worth it?
  230. Where to buy a ATR tranny?
  231. Secondary O2 Pinouts
  232. does anyones car do this to?
  233. Where to get Samco radiator hoses?
  234. Im thinking of buying a 93 prelude, what do you guys think about 1800?
  235. For Sale New Greddy Type S BOV and Clutch Masters Flywheel
  236. will SH rims fit a base 5th gen?
  237. fuel pressure reg...
  238. Requesting some advice.
  239. Spoon strut bars for 5th gen
  240. who has measured their h-series deck hight?
  241. 4th Gen balljoints or bushings first?
  242. Solution to creaky suspension
  243. side motor mount inserts
  244. 5G ECU Q: Can you use a 97/98 ECU in a 99+ model Prelude?
  245. Borla Exhaust???
  246. Stock air boxes. would 92-96 fit 97-01?
  247. O2 Sensor no good, which one?
  248. Type-s pistons
  249. FITV Idle Surge problem..
  250. Cracked water pump :(
