PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 [102] 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. H22a Won't go into 2nd gear. HELP!!!
  2. won't go into first gear?
  3. injectors for f22a1
  4. Interesting intake manifold design (directed towards those of you who make custom headers)
  5. Im going to venture yes, but is 245 tires too wide for the lude?
  6. Questions about h23a
  7. Fuel Injectors
  8. How to remove heater core/ac under dash?
  9. help please
  10. Buying a prelude. Advise before I buy it.
  11. aftermarket fuel rail gains?
  12. Spring Cleaning....what all newcomers and tuners should know!!!!!
  13. does a high flow cat hurt you
  14. VTEC not working
  15. anybody running 16x7" 43 offset wheels?
  16. Manley Valvetrain?
  17. supercharged 5th gen
  18. Front bumper problems
  19. can i swap my usdm h22 for a jdm h22
  20. Where to Dyno, and Tune
  21. Removing IM bracket on SH
  22. Trying to remove wiring harness
  23. BB6 and Handling
  24. injector bushing problem
  25. Power Steering Removal
  26. h22a1 redline??
  27. Auto H22 Vs Manual H22
  28. clock color
  29. Balance Shafts belt
  30. idel problem
  31. 88-89 FOGLIGHTS - How Do You Get To The Bulbs? Lights aint workin!
  32. f20 valve cover
  33. Vacuum system hose sizes?
  34. Need Horsepower Increase on my 99 Prelude
  35. Jdm side Markers
  36. JDM Knock off headlights - 4th gen
  37. question for those with Big....
  38. dyno charts - jrsc :)
  39. Ground control Install problems *searched*
  40. burning oil on 5th gen
  41. ..::: 5th Gen Newbie - Q&A Thread :::.. (New Members, PLEASE CLICK HERE)
  42. Changed BMC and still a mushy pedal
  43. dash light
  44. Trans swap help
  45. h23 vtec spark plug problem....
  46. Heat Sheild
  47. Removing head bolts
  48. USDM vs. JDM Stock Exhaust Manifold Downpipe
  49. Help with front brakes
  50. h22 vs. 06 civic si.
  51. Which sidemarker is for a bb6?
  52. stage 2 cam ?
  53. Spring compressor
  54. '97 a bad Prelude year to buy?
  55. f23 crank in an 98 h22a4
  56. stupid bolt
  57. oil in radiator! help!
  58. h23--h22 head
  59. h22 automatic to manual help
  60. Fan not working?
  61. How do I find out what year my motor is?
  62. Help me decide: Straight pipe or high flow cat?
  63. hesitation bogging when warm
  64. Sea Foam, improved idling and my car does not stall as much.
  65. tail lamp gaskets
  66. where to connect gauge to dim with interior
  67. -High flow, or straight pipe the cat?-
  68. trans help
  69. annoying squeak from front of vehicle
  70. High Flow Catalytic Converter
  71. RHD Conversions
  72. exhaust situation
  73. can you use any h series oil pan gaskets on an h22a4
  74. Review eBay Twin Loop Muffler
  75. KSport fullcoilovers on 5th gen
  76. ecu for turbo setup?
  77. Clutch and Flywheel.
  78. 18's with 45 tires on 5th gen?
  79. Another Intake thread, Clear this up for everyone (who doesn't know)
  80. Deck CODE !
  81. h22 or h23vtec
  82. Rattle from belts & how to purge power steering.
  83. Megan headers
  84. clutch noise at idle
  85. calling out all h22a aftermarket cam gear owners
  86. f23a1 exhaust manifold
  87. Dash harness question
  88. Jdm head on a UK 97+ bottom end
  89. CEL No code
  90. Flywheel Weight?
  91. Draining Fluidyne Radiator ???
  92. CEL/ATTS lights after oil change
  93. wheel size
  94. Balljoint Removal
  95. RSR Ex-Mag for SH
  96. Wedge brackets for Sparcos Install
  97. need some help!
  98. Tires sizes
  99. code 43????(4th gen)
  100. Any 3g 4w steering fans/buyers out there?
  101. Low Idle, unplugged EGR valve connector and nothing happerned?
  102. just swapped jdm h22a - got cel 22, help!
  103. steering problem
  104. Return of the Shock Knock
  105. wats better for lude sh...vafc 2 or afc neo
  106. speed restricted on jdm import 2.2 vtec
  107. honing question
  108. Popping sound when turning/going over large bumps
  109. H22a dyno and pictures
  110. h22 injectors? identifying ?
  111. att or not?
  112. h22 flywheel turque specs.
  113. help auto to manual conversion
  114. Valve job
  115. coils in front of rad.
  116. i want to put new speaker in my 92 lude
  117. HELP!!!!H22 auto tranny JDM vs. USDM need info
  118. Honda MTF
  119. ABS Code
  120. Cold Air intake vs. Short Ram intake systems.
  121. head light
  122. What the? My clutch engagement changed over night.....
  123. H23 to a H22 Vtec conversion
  124. Balance shaft Removal??????s
  125. found leak in IACV, could that cause bad idling?
  126. 98prelude-changing my brake pads
  127. please help: i need to get rear camber fixed.
  128. Front Blinker Wiring Setup...
  129. top hat
  130. Switching to Synthetic
  131. quick question
  132. Balance shaft Removal
  133. Timing Belt ?
  134. pulling an engine
  135. Blown ecu??? or main relay??
  136. Service Plug?
  137. timing belt, how tight?
  138. dash conversion for 94 prelude
  139. Need help balance shalf
  140. H22a ITB - Individual throttle bodies needed
  141. tune a 97 prelude SH...need help..
  142. looking for a five lug swap for an accord wagon 91
  143. Running Rich..
  144. Shift linkage with plastic base instead of metal??
  145. DIY Lower Ball Joint Change
  146. Think I may have broke my timing belt...advice needed.
  147. 5 lug swap axle question
  148. Adjusting lifters?
  149. Misfire, getting tired of it! HELP!
  150. H22 PCV Valve bracket/relocator
  151. 5w30?
  152. Manufacturer oil rating
  153. Diagnostic Port
  154. type SH ecu/upgrade ?
  155. What function does a MAP sensor perform?
  156. H22 with F23 tranny? 6th gen Accord, swap question.
  157. ignition problem, wierd..
  158. This i a noob question but how do you time the balance shafts on a H23
  159. need a quick answer for fuse box
  160. HID PROBLEM HELP!!!
  161. Would 97-01 sun visors fit 92-96?
  162. Quick h22 automatic question
  163. Prelude Keep missing on all for cylinders. Also it is idling a like 200RPM's.
  164. throttle bodies
  165. Headlights??
  166. Camp1320 header for the H22
  167. Running H23A Vtec W/ pics
  168. Idle problems, please help! 4th inquiry!
  169. 1 bolt on my thermo housing?
  170. Does a 1997 Auto prelude have a seperate computer for triptronic
  171. alternator removal and install HELMS/HAYNES/CHILTON/etc. PICS
  172. How do i check ABS code???
  173. 4th gen owners lets see some Roll Cages!!
  174. good deal or no?
  175. is this the right clutch?
  176. Ok Line to use?
  177. 98 prelude with data system vtec controller?
  178. ebrake conversion
  179. SOHC VTEC
  180. Uneven brake wear
  181. subframe braces
  182. Nuts for the header
  183. turbo lude
  184. wtf is wrong???
  185. Dual Exhaust
  186. i read the rule
  187. Prelude, H22A, with Idle problems. Please help!
  188. Idle problems, please help!
  189. Bad master cylinder???
  190. Knock Sensor problem?
  191. 7 Year old Battery...need new one?
  192. vtec question
  193. h22a parts
  194. h22a 6 speed manual transmission
  195. EGR VALVE??can it cause harsh idling
  196. b18b into a prelude
  197. Broken VSS
  198. LED on top of the steering column?
  199. h22a stock header: usdm vs. jdm
  200. time to replace clutch?
  201. Strange problem
  202. SeaFoam on a Jdm H22a?
  203. Need Help ASAP!!!! JDM H22 OBD1 swap into a 97 Prelude non SH w/ auto
  204. Necessary Ground Wires?
  205. ---Iddle Problem----
  206. Replacing Ground Wires????
  207. :::Common Prelude Problems:::
  208. Vtec cel code 22
  209. H22 OBD2 wierd timing.... HELP!!!
  210. el cluster conversion
  211. Cams for H22a
  212. GTECH PRO
  213. ABS Need Help!!!!!!
  214. Injen's instructions suck! Noob here could use some advice.
  215. Removing valve seals ?
  216. what do you think?
  217. main relay?
  218. Intermediate shaft replacement
  219. I'm looking for Prelude type S grill!!!
  220. Engine in 94' si?
  221. 93-95 vs 96-01 transmission
  222. gauge cluster help
  223. in accedent key stuck
  224. BB6 Prelude, idle problems, please help!
  225. Time for brakes whats yalls input on pads?
  226. Type SH Adjustable Suspension
  227. SoCal Engine Swaps....
  228. Looking for a good set of adjustable coils and struts.
  229. Compression Tested Today :(
  230. tanabe gf210 springs
  231. compressor and radiator fan problems
  232. 12:1.1 compression with 91 octane gas?
  233. Help wit h23 vtec plz!!?
  234. Problem with my H22 build!
  235. H22a4 Bearings
  236. Help identify this h22 turbo manifold pics included
  237. H22A: hydraulic lifter?
  238. usdm climate control
  239. FLY>>>>WHEEL
  240. 5th gen swap
  241. Adjusting Cam gears.... whats to far?
  242. Cooling Systems Probelms....
  243. ::::National Prelude Meet 2008 Ohio::::
  244. Need New Catalytic Converter for 00 SH
  245. jdm h22 swap
  246. Prelude Meet - North East - May 12th....
  247. Just picked up an 87 lude for a daily, got some issues that I need help on.
  248. Odd moonroof leak?!?!
  249. F22a1
  250. h22a4 questions.
