AEM CAI question
Old Oct 16, 2003 | 07:39 PM
Wiseguy619's Avatar
Default AEM CAI question
what can i put around the opening for the filter so that the frame and intake do not scrape.
thanks
Old Oct 16, 2003 | 07:43 PM
PrecisionH23a's Avatar
Default Re: AEM CAI question (ProjectPenny)
Stan-Pro. It seals it off quite nicely. A local auto-parts store should have some of this trim, it is used mainly for door trim.
Old Oct 16, 2003 | 07:47 PM
Gabe's Avatar
Any type of rubber hose. Slit it lengthwise and put it over the opening, works great and it's dirt cheap.
Gabe
Old Oct 16, 2003 | 07:49 PM
Default Re: AEM CAI question (Gabe)
Another good idea. Keep in mind the jagged metal will most likely cut the rubber hose sooner or later depending on your clearance issues. This is why stan-pro was invtented
Old Oct 16, 2003 | 07:51 PM
Wiseguy619's Avatar
yeah, i could probably find some hose for it, thanks. does that Stan-Pro come in different quantities becuase i wouldn't need a lot.
Old Oct 16, 2003 | 07:53 PM
Wiseguy619's Avatar
Gudeh23a ,i have a shifting problem also, wont shift into reverse. any ideas?
Old Oct 16, 2003 | 08:28 PM
rjr162's Avatar
Default Re: (ProjectPenny)
I just used some ABS plastic. Cut two squares, and then dremeled them to the shape of the intake tube into the one edge. Placed it around the intake tubing, screwed it in, and viola. Holds the intake tubing in place, helps seal the filter are from the engine bay, and keeps metal to metal contact at nill.
Old Oct 18, 2003 | 10:12 PM
EK22Tim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectPenny &raquo;</TD></TR><TR><TD CLASS="quote">Gudeh23a ,i have a shifting problem also, wont shift into reverse. any ideas? </TD></TR></TABLE>
Try changing the fluid- It sounds crazy, but change it with GM Synchromesh (from any GM dealer parts counter) and it may clear it up. Mine did after about 500 Miles.
rj_vitec
May 14, 2006 01:09 AM
H22AKrazy
Aug 17, 2004 10:17 AM
Starrman85
Dec 17, 2002 08:45 PM
97ITR
Dec 4, 2001 02:30 PM
