PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 [227] 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. question about JDM H22 need help quick
  2. is my clutch out?! (symptoms inside)
  3. Drag instructions prelude
  4. Turbo exhaust??
  5. Head work and compression
  6. Problem with A/C, 1989 Prelude 2.0 SI
  7. turn signals, front and rear
  8. tranny or shifter cable problem?
  9. JDM h22a
  10. aftermarket h23 intake manifold???
  11. climate control
  12. Forged Pistons in Stock h22 block??
  13. My axles popped out while installing some suspension...
  14. Shift knobs
  15. Sound-deadening in a 5th gen?
  16. Help.. Big Manual Transmission Problem
  17. coil over drop?
  18. ABS problem, just changed clutch, axle problem...? 92 si
  19. euro Accord intake mani... a few questions
  20. Battery died, just found out I have an alarm...
  21. oil in the plugs?
  22. WTF! my car is 1/2 accord?!
  23. 4th Gen Sunroof Panel in 5th Gen Sunroof (56K Careful!)
  24. Need your opinion, on selling one of my ludes.
  25. F22a boosting day 2
  26. Bulbs for jdm prelude lights.
  27. Automatic Transmission fluid filter
  28. short shifter
  29. 4ws error codes - What next??
  30. New member to the club finally
  31. Header/Rotor Install
  32. throttle body question
  33. NAJOR CUSTOM BODY WORK
  34. motor mount bushings
  35. 92 prelude headlight assembly
  36. i just can't figure it out
  37. H22 question ( really quick )
  38. gauge(s) priorities?
  39. my car at the brink of overheating
  40. What's wrong w/ this pos now.. could it be the wrong t/o bearing?
  41. H23 v-tech
  42. Are Honda/Acura MAP sensors interchangable?
  43. Boosting F22a Need help
  44. car slanted
  45. anyone have pics of accord rims on a lude?
  46. Rear sway bar help
  47. vtec solenoid question...
  48. vtec problems...
  49. high compression
  50. help me buy a used prelude please
  51. Help Diagnosing Code 3 (MAP).....
  52. Installing Axle after balls-up. Please can I get some advice?
  53. AEM cam gear troubles....
  54. What would be the best clutch/flywheel setup for the street
  55. What is VAFC? (sorry if i sound dumb)
  56. does the phantom grip lsd werk? and wheres the cheapest place to get 1???
  57. need help!
  58. i am trying to find out what this part is called
  59. are axles all the same?
  60. Universal O2 Sensor
  61. it's time, but turbo or supercharger?
  62. which intake
  63. Vtec
  64. now a code 9 on 94 H22a
  65. Ok I just got my Jdm H22a and I have a couple of questions for u honda-techers out there wit the sam
  66. Fidanza owners............
  67. how can you tell if they are real type s cams ?
  68. question about flexpipe replaced..
  69. what does RETARDING timing do!?
  70. prelude help
  71. help me post this into FI..... please..... DOWN PIPE..
  72. vtec cutoff at 6500
  73. Finally I'm in the club, but need help!!!
  74. Thinking about a tranny swap, need opinions
  75. Sheet metal hood for a 92 Honda Prelude.
  76. Any good shops near me in NC?
  77. Installing Tail Light
  78. ES motor mounts
  79. Changing from 1st to 2nd
  80. Anyone try the turtle wax color car cure?
  81. sensor problem...
  82. h22 i/m on ebay
  83. battery troubles/no start.. please help!!
  84. JDM H22A Head chamber volume
  85. how big is h22 throttlebody
  86. header and exhaust, but what cat?
  87. motor swap for gen 2
  88. 88 lude si radio wiring?
  89. engine light
  90. Has anybody had any success mounting oil squirters in H blocks with the 95mm crank?
  91. 5th gen Prelude vs MkII MR2 Turbo
  92. 14.6 1/4 mile STOCK prelude. Did i just see something rare?
  93. problem on brake light
  94. Big mistake need help
  95. Where can someone buy a fully built h22a? partially built? etc...
  96. Voltage Question: Would this cause a problem with my ECU??
  97. Strange Lack of Power Problem - Can Any1 plz help?
  98. trunk light switch ?
  99. does flexpipe size matter?
  100. performance fuel pump make a difference?
  101. apex'i power intake
  102. O2 sensor question?
  103. intake does it matter
  104. 99 prelude -- clutch to the floor
  105. Clutch Problems
  106. crank bearings....
  107. i have a 95 prelude i need help!
  108. 5th gen header
  109. Your opinions & thoughts: Power Enterprise Timing Belts
  110. those blue condoms on the bulbs in the switches...
  111. help having problem puttin on timing belt?
  112. HELP!!ntb
  113. 5th Gen. SS gear ratios
  114. ?accord tranny
  115. blown H23
  116. best RPM 2 take off of?!?
  117. lets find out why you can burn oil!!!!!!!!!!!!!
  118. JDM Prelude headlight casing how to repair crack & seal
  119. IAC causing ATTS light to come on accrding to dealership
  120. no power in vtec?
  121. coil over issues...
  122. End of the line for my powertrain?
  123. I need a pic from a Helm's manual. 94-96 dash wire harness
  124. H22 intake manifold
  125. 5th Gens and Rotas
  126. Info Request: 98+ prelude Helms specs
  127. vtec oil pressure switch ( need help )
  128. Prelude 4th gen JDM Headlights! Took apart..... Need info.. What Sealant 2 use??
  129. Electric water pump question.
  130. vtec issues...
  131. I need a guide to removing an h22a head (searched and nothing) I NEED HELP!
  132. Over-haul Kit
  133. prelude automatic lsd tranny??? help some one.
  134. Smoking Problem - New to the board
  135. ECU Codes
  136. race shops in San Diego
  137. H22A LSD HOUSING VS. H23/H22 NON-LSD HOUSING
  138. OEM crank info needed
  139. Would a SR20DET fit in a 2nd gen prelude?
  140. I need help converting neon light
  141. can someone look at this pic and give me advice on what i should do....
  142. accord rims on a prelude?
  143. ITBs, pros and cons?
  144. factory ignition timing
  145. Removing pinstripes
  146. Weight Redux
  147. how to REMOVE ths shift knob for a 97' honda prelude
  148. prelude hop ups and sugestions
  149. 97SH changing front wheel bearing
  150. european foglights???
  151. Oil leak from valve cover air inlet (where the breather sits)
  152. VTEC HELP
  153. flexpipe problem...
  154. oem battery
  155. vtec problem
  156. tranny problems / reverse not working
  157. DSM Turbo Project
  158. Amsoil
  159. Piston-valve clearance
  160. Hawker Genesis G16EP review
  161. timing belt cover
  162. will koni's work with tein springs?
  163. help my timing balncer belt snap? does it damn any thing?
  164. Rebuilt Tranny
  165. Polishing stock lude wheels
  166. Little help here...
  167. Stock lude wheels swap
  168. different exhaust manifold on sr-v
  169. DYI valve cover paint procedure
  170. High HC on my lude fail smog help please
  171. Why are ludes so heavy?
  172. Hey Guys, just wanted to drop in and show what that this forum helped and contributed in the buildup
  173. check engine light popped on and then off.
  174. EGR Valve
  175. How can I identify if a h22a engine at a breakers is 'closed deck' and JDM
  176. instrument cluster / speed sensor compatibility ???
  177. h22 swap problem
  178. What a night!
  179. How much brake fluid for a full flush?
  180. how many types of leathers did the 4th gen have?
  181. very weird p13 prob
  182. LUDE S SPECS ???
  183. SR??
  184. steering wheel vibration
  185. Passenger area air conditioning leakage?
  186. Pre-swap
  187. Heatshield Prelude 98
  188. h22a swap soon, which parts should be replaced?
  189. What Intercooler Are You Guys Running?
  190. Can anyone in RHD Land get their hands on a 4G Electrical Manual?
  191. 345cc injectors?
  192. HELP WITH O2 CENSOR!!!!
  193. Fuel Rail Advantages?
  194. VAFC HELP!!
  195. Taking OEM intake resonator box out. Need help ASAP
  196. Anyone have an oil pressure gauge? I want to compare pressure.
  197. built jdm h22a t70/80: teflon oil treatment affecting oil pressure? turbo wont spool?
  198. before and after work?
  199. surging idle fixed
  200. Majestic Turbo Offerings
  201. vacuum system
  202. 1997 AUTO PRELUDE OR 2000 5SP Accord coupe sohc vtec?
  203. need diagram of 96 prelude ecu to installed vtec controller
  204. NGK wire : 4 or 5 wires? ASAP
  205. RE:prelude build up
  206. Maximum Timing advance of a P13 ECU ?
  207. lude owners between the years of 97-00 read this
  208. 1997 Preldue SH. Blown engine.
  209. 96 prelude 320-340 n/a hp build up
  210. it died!!!
  211. For those with BOTH VAFC and RSM
  212. F22 manual tranny to a h22?
  213. F22A? F22B?
  214. Please Look Need Help with 86 Dual Carb Prelude
  215. post pics of ur aftermarket radiator and or fan systems u got on ur prelude
  216. Steering boot, I'm lost
  217. Big mistake.. possible rod knock.. Need some opinions and suggestions.
  218. Is it okay to use Synthetic gear oil?
  219. skunk2 coilover install...what springs in front/back??
  220. cold start valve!!!!???
  221. tranny problems
  222. problems after swap!!!!
  223. Seatbelt problem
  224. i will probly have around 2000-2500 to spend
  225. Where can I get a new distributor cap from?
  226. might have found my idel problem
  227. What's your VTEC engagement set at?
  228. h22/h23 interchangle manifolds?
  229. Fuel Cutoff help
  230. 'lude almost killed me last night - help?
  231. How to test out my 2 problems. Plz help!
  232. What do you guys think of this lude?
  233. Prelude 98 vtir service manual
  234. steering wheel with airbag
  235. 95 Prelude lowering issues
  236. Outrageously ridiculous question.
  237. Computer Chip problem?
  238. How To Tell H22 Intake and Exhaust Cams Apart?
  239. Honda Alarm Manual... settings ect.
  240. Check engine help please?!?!!?!?!?!?
  241. shifter gives off shock
  242. Motor mounts
  243. 3rd gen engine swap suggestions?
  244. what comes with the jdm fogs 4th gen
  245. JDM BB6 Prelude TYPE S Lip - Any pictures and advise?
  246. Crower VS. Skunk2
  247. 97-02 prelude struts on a 92-96 prelude
  248. Greddy Exhaust?
  249. Got a couple baseline runs in.
  250. Stock grounding locations??? how many and where?
