View Full Version : Honda Prelude
- Quad throttles.
- H22 TearDown HELP!
- LOUD squeal
- Lost compression in cyl # 3
- 93 Si, Removing Intake Manifold Problems *searched extensively
- thoughts on JDM
- Normal Oil Pressure in the Block, 2PSI Oil Pressure in the Head
- Help my prelude has power.... nothing no windows sunroof radio gauges!!!
- Unsteadly idle problem after swap....
- prelude tranny loud noise
- Help Cant Post My Pics Of My car In Thread
- oil pump sensor...?
- Car shuts off! Bad gas? Need help ASAP.
- Came back from a smog station today in CA
- tranny swap (atuo to manual) have a lot of ?'s
- Another Hard question. Can u Answer?
- h22a1 piston rings
- H22A Head Install
- tranny swap gone wrong
- Cycl 1 misfire
- Should I buy?
- 94 center console in 93 prelude
- MPH Gauge
- auto obd2 to auto jdm obd1 tranny swap help!
- clutch issue
- (4th gen) any good pics of front bumper removal around?
- Installed Skunk2 Coilover Sleeves W/ KYB AGX Shocks
- 96 Prelude Build Thread
- three important questions
- Should I buy it?
- Prelude 91 B20A9
- Timing belt slider
- Please help! 93 vtec won't start
- Skunk 2 Pro IM
- no prime
- Weird Idle with A/C on?
- 4th & 5th Gen spring the same?
- Individual Throttle Bodies
- F22a1 Headers
- INFO: 5G Bulb Sizes
- INFO: 4G Bulb Sizes
- Really easy quick question
- Steering Rack Knocking Noise
- interior help
- Intake manifold / egr
- Stupid question about upper ball joint
- h22 manifold question?
- injectors
- h22 swap ecu question
- 94 accord suspension on 01 prelude?
- Impressive 800+ HP
- engine shut off itself while driving, what's the problem?
- crower stroker kit
- Will 04 TSX Wheels fit my 5th gen?
- Got a problem with bogging while driving and shaking of car
- misfire?
- for the turboed 5 gen prelude guys i have a ?
- Prelude SH destinctions
- Very difficult to shift into gear!
- Quick ECU Swap Question
- fuel rail
- NRG hub install no horn?
- Can i get some help
- IS there any how to's
- Diff Bearings for H gearboxes
- 4th gen ABS codes
- Hi I'm new (and do you think this is a good deal?)
- Stupid OKC Streets
- where to buy a new motor
- Problems with 01 prelude. Help!
- SRS light on, reset but is still present.
- Which suspension for 1991 BA4 Prelude?
- 1990 Prelude w/ 4WS and Tiptronic Shifting - HELP! *PICS*
- REMOVING THE CRANKSHAFT PULLEY...???
- Could a bad control module cause no fuel no spark???
- Spark plug HELP!
- Dumbass! - Poured a half cup of antifreeze into my engine before I realized.
- 1988 Honda Prelude Horn/Brake Lights ?
- looking for alternator belt same length as prelude but...
- Overheating at stops
- Coolant Leak Issue?
- difference between h22 and h23 valves?
- MPG check for you guys.....Hows your car really running
- stabilizer bar
- Transmission Stuck won't come off........
- OmG Motor
- Lowering Suggestion
- H22A with 3200 rev limiter
- h22 prelude swap
- 96 prelude
- iacv
- axles
- Engine Compartment drops further down a couple of inches once car is on jackstands
- engine swap question
- Dash removal
- misfiring on all cylinders....
- What part is this?
- Main Relay
- Transmission Speed Chart
- Need expert's advice. tranny or clutch issue
- H22 head skim
- Quick Question: Master Cylinder Replacement - Is there 2 pushrod seals?
- apexi ws2 question
- Tranny!!!
- radiator ?
- cel
- installed new CD deck, now no headlights/turn signals/brakelights; help!
- OBD1 H22A4 Idle issues...
- Changing headgasket Question
- prelude smoking bad
- F22B Head Gasket
- Electrical problem- 5th gen; Blinkers, horn, Cruise, power window, brake lights
- 3rd Gen Preludes
- Valve Lash
- issues after h22 swap
- H22a4 no spark no fuel need advice please!!!
- Question about oil...
- 93 H22a fuel supply malfunction #43 + symptoms
- short shifters
- whats the difference
- header help
- shifting into 4th gear question
- New to site
- Template for sidemarkers
- 92' lude h23 fan switch question
- where can i find a mugen front bumper
- 12v on the engine block when starting? Help!
- Press gas to start
- CEL, O2 Sensor
- how can i get water spots off my windows
- p13 obd1 jdm h22a throwing code 42???
- K Swap in a Prelude?
- just finished my h22 swap, idle question
- Help with Prelude Problems.
- resistor box question
- clutch switch
- need a link
- dashboard lights dont work
- PCV: Issue & Q
- h22a4 camshaft question!!!!
- H23A1 Crankshaft Pulley on H22A1 motor...?
- Prelude 2.2 calipers?
- Firing Order
- Throwing my h22 in a hatch what will I need?
- Help! Blown Valve Maybe? Help!
- For those that have fittings welded on valve cover for Oil-Catch can setups. H22
- not so simple obd 1 conversion
- Clutch wont engage??
- h22a4 rocker arm torque sequence?
- 98 prelude wont start..help
- 3rd gen prelude questions help.
- straight pipe
- Problem with power locks and window
- ECU code 1... O2 sensor... what is wrong?
- 5th gen JRSC blower install removal tip
- CHIPPED P28
- if timing is off at the crank by 1-2 teeth could that cause the car not to start?
- is it "bad" to put on aftermarket header on stock exhaust
- Manual transmission swap question
- install manual fan switch
- Quick and Easy H23a vs F22a
- P5P vs P5M intake manifold?
- h22 clutch kit question
- JDM motor in a US car?
- H22 gt35r??What will I need..
- JDM gauge cluster Q (not wiring)
- Finished engine swap, few questions
- Universal Resonators
- 5th Gear Grind After Gear & Synchro Replacement
- 01 Trans Problem
- H22a..need to borrow a P13 for 10 minutes Santa rosa CA area
- H22 gasket kit question
- Going from a 92 to a 01
- My engine get hot then is stop runing??
- jdm h22 problems ( code 36 )
- a dumb question about p13 help please
- Somebodys on the prowl for my lude...
- SH to JDM
- 93 prelude clutch bleeding question
- jumer harness obd2a to obd1 automatic
- oil light doesn't light up
- Timing belt change question
- Car wont turn over
- Help ecu wiring harness question
- Timing belt change, now complete loss of power
- Need your opinion
- help with power steering seal
- how do i visually check my lower ball joint?
- Sunroof off track please help
- Probe rods w/ Euro-R Pistons and Mahle Qs
- NO POWER??
- Low Voltage at the injector clips!!
- Steering Rack Boot - Part Number
- Can't Get my Damn VC Off
- what intake is this
- HELP: rear main seal leaking again.........
- h23 intake manifold aftermarket?
- Accord VSS sensor compatible?
- TRANNY PROBLEM!!!!! HELP!!!!
- Rebuild a honda prelude VTI (EUDM) to a H22a Type S (JDM)
- Need immobilizer info to legalize swap
- Koni Yellow shocks + Ground Control coilovers from 1994-2001 Integra
- New Project
- head rebuild time
- how can i get rid of water spots on my car
- how can i get rid of my antenna but still have a clear radio
- shaved bay and tuck almost done
- ? About Dry Starting
- Will H23A1 Crankshaft Pulley fit on H22A1 motor.....
- Majestic Honda sells 2 different oil filters, Allied Signal and Toyo Roki. Which one?
- I Give UP
- No Cold Air
- will skunk2 intake mani for h22a prelude work on h23a vtec blue top??
- unknown/unmarked h22 header. can you identify?
- manual tensioner adjustment and question about one bolt
- buying a prelude
- ecm tuning, and fueling issues
- Switching to the Prelude S Braking System
- Axels, quick answer
- 92 prelude motor options
- Wiring Harness
- 97 prelude smoking
- Looking for h23 parts
- squeaking coming from engine?
- Critique my turbo setup for autocross
- H22 Help....
- how to get crank pully key out?
- Honda Prelude Type S(JDM Spec)
- Fuel pump question
- H23A1 clutch....
- type sh bogs under WOT
- Will H23A1 distributor fit onto H22A1 Motor
- BA8 hood will not open!!!
- Consumer Assistance Program (CAP) in CA for SMOG
- Please Help... T-T
- Prelude Wont Start
- F20B Help Car Runs Like Crap!
- A few questions...
- where is a good place to buy performance parts?
- 70mm IM with 66mm TB?
- CODE 14
- H22 FULLY BUILT HELP
- engine bracket mount help!
- H23 External Dizzy wiring (switching back)
- FICV and IACV
- engine mount help
- h22 engine
- ac question
- HELP!!! Exhaust Leak??
- jdm swap issues
