PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 [199] 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Best header for price?
  2. How should i drop my car?
  3. H22 is stamped....B B A B what are my options?
  4. How to: Remove A/C compressor
  5. lowering
  6. 97 Prelude headlight eyelids
  7. altornator belt help
  8. new starter
  9. Worst Prelud Ever
  10. b&m fuel pressure for a h23?? which one..
  11. fuel problem/ help
  12. Traction in snow
  13. annnnnnoying pedal clunking
  14. Newbie Driver....help
  15. No spark in JDM h22
  16. question about CF hoods
  17. Wheel wobbles like hell...bad for any parts..like bearings or anything?
  18. Rough idle, shaking on a 3rd gen
  19. What your think of this turbo kit???
  20. rings did seat with no honeing.!!...
  21. Couple questions..
  22. is it bad to have no fast idle?
  23. AFC HACK
  24. Prelude
  25. going to buy 93 lude for $600 but......
  26. All my oil dissapeared!!!
  27. Fourth Gen Rear Caliper stuck... what to do?
  28. Radiator fan not workin
  29. ATTS Questions
  30. In response to mgags7 about polishing intake manifolds and intake ports..
  31. 3rd Gen Rough Idle
  32. 5th Gen Interior
  33. is swaaping my motor out worth it?
  34. What to shop by for SE...
  35. need help with part #
  36. RC 550 injectors
  37. G-Tech ss For Auto????
  38. Sh 4th gen lude?
  39. Ignition switch
  40. Weird Engine Noise ... Video Included .... Help!!!
  41. h22 problems
  42. pulling wheel hub 97 SH
  43. 1994 Prelude S, stock need upgrade advice :)
  44. H22A1 1992 Lude?
  45. Bad acceleration
  46. projector headlights
  47. LSD
  48. prelude curse continues: car stalling, idle surging slightly
  49. gauges HELP 92 prelude si 4ws
  50. h22a auto gearing
  51. HELP how do you put on a timing belt on a h22 motor?????
  52. toy model prelude.
  53. who got their present early? i did and it sucks
  54. Suspension creaky...?
  55. first one to say it!!!
  56. 2.5" Exhaust system?
  57. HELP !!!
  58. Euro R Intake Manifold
  59. couple Qs about euro r h22 manifold
  60. Thermo can go?
  61. How to hook up a tach in a 95 prelude
  62. how to remove front bumper 5th gen
  63. can i run a walbro 255 HP until....
  64. Which HID kit to buy?
  65. pluggin car in, but 2 plugs?
  66. putting tranny back in.... HELP
  67. any body have pics of itb on a h22
  68. quick question about 5th gen
  69. Setting up a turbo on a 92 lude
  70. HELP!! Car idles at 3000!
  71. will a lil water in the intake mess up my motor
  72. Anybody selling B16 headers??? Honda SI 1999
  73. Luder's i need your opinions...
  74. whats wrong with mi tranny!spits 2nd gear!!
  75. Replacement Radiator for a 5G Prelude?
  76. FS - Neuspeed Sport Springs 97-01 Prelude...Less than 1,000 miles!
  77. Final Swap Pics: H22A4 to JDM H22A (OBD-II)
  78. timing tensioner
  79. A HORROR STORY!
  80. Performed Swap - Engine will not start!?
  81. Valve Cover Gasket install / parts?
  82. Is this my FITV?
  83. how to flush the power steering fluid...
  84. help me quick
  85. HID HELP
  86. car wont idle
  87. Fog Lights
  88. idle problem
  89. help me with my boost controller problem!
  90. 00 prelude Fender question
  91. distributor/timing issue with jdm f22b swap in 92 prelude S
  92. SPOON Sports!!!
  93. how do i stop that annoying bleep?
  94. how should i do this¿
  95. skunk2 crank
  96. neuspeed short shifter
  97. H23 block compatable w/H22 tranny?
  98. oil leak
  99. what power steering fluid should i use
  100. Anyone know where I can get one of these???
  101. Questions about Spoon header
  102. H22 Valves?
  103. spark rods ??
  104. tuning guide?
  105. Timing Belt Problem :(
  106. H22 Tranny... HELP
  107. blue wire that runs through fire wall with cruise control cable?
  108. oil question
  109. ecu and knock sensor question
  110. blue wire that runs beside auctator cable in a 1992 honda preludesi with 4ws
  111. OBD2 H22 w/ OBD2 96-97 Accord Ex ECU?
  112. question about modding apexi ws
  113. where is the idle control valve and what does it look like?
  114. lowering my SH
  115. passenger side window!
  116. yellow H22 injectors? peak and hold?
  117. is it ok to run this?
  118. cel 7 and 17
  119. full 4th gen mugen body kit
  120. Rode vtec for about 3 miles.....
  121. Why cant I become a member???
  122. 1991 Honda PRelude Si 4ws
  123. i have a h22 head and h23 block what timing belt do i need
  124. if u put a h22 head on a h23 block which HEAD GASKET do u use the h22 or the h23
  125. 4th gen, making fog lights stay on when high beams are on?
  126. starter problem?
  127. Skunk 2 Intake Manifold.....on 2000 Prelude......How to install????
  128. Tightening up E-brake?
  129. IACV??
  130. ABS light??
  131. 5th gen sycro's
  132. Static electricity...
  133. what controls fast idle?
  134. electrical probs please help
  135. Need help (timing belt install)
  136. Hondata
  137. 97 prelude h22 into 93 prelude si
  138. Jackson Racing VTEC, EMS, fuel ressure reg and MORE
  139. Ebay Cat Converter
  140. how do you tightning belts?
  141. clutch install... HELP
  142. i may be dumb for asking this but...
  143. NewB saying what's up.
  144. best block
  145. quick brake question
  146. ignition help - k reg jdm prelude 2.2 vtec si
  147. Need map sensor for 1990 prelude si 2.05L
  148. Neuspeed strut bar install QUICK QUESTION!
  149. 3rd Gen Bodykit
  150. HID kits fit any good???
  151. sway bar question
  152. What type of transmission fluid is best for a 01 SS Prelude? (did a search already buuut)
  153. Shifty Lowering of car :
  154. idle valve
  155. Jun camshaft stage 3 with springs and retainers, reliability?
  156. Can a JDM OBD2 ECU work on USDM 98Prelude?
  157. 93 prelude syncros
  158. opinions on modded Sh vs modded base
  159. Should i juice it up?
  160. light problem
  161. Need info on 2.4-2.6 H motor.
  162. Xenon HID conversion
  163. what does the H23 timing conversion!!
  164. Prelude wheels
  165. quick question about TB
  166. Transmission problem 5spd JDM
  167. First-time poster? Please play this training video
  168. 4Bidden Short Shifter
  169. Oem calipers
  170. Where To Find Plastic Bolts For Front Bumper
  171. clutch problems
  172. Differnce on Prelude?
  173. O2 Sensor on Cat
  174. 00 Prelude h22a Motor Trouble
  175. The Official Bogging and Hesitation Thread
  176. Dash lights fade with aftermarket guages
  177. Won't start. Heavy Fuel Smell.
  178. h22a sleeves
  179. shooting black smoke
  180. After Market fly wheel timing mark
  181. taking headlight assembly out??
  182. To anyone who has compared a gsr and sh...
  183. Crank/TDC Sensor Problem
  184. installing an S2000 gauge cluster???
  185. Squealing after timing belt replacement
  186. Flow Insufficiency - 2000 lude
  187. Sould I buy this TURBO KIT????
  188. Wheel hub going out....
  189. VAFC HELP
  190. AEM pullies belt size??
  191. 300 to change a clutch?
  192. Steering wheel hub adapter for 93' with 4WS?
  193. Winter Disaster , Oil hole
  194. Prelude Part Name?!! Picture
  195. anyone using this intercooler?
  196. Engine Hesitation and Vtech Not Kicking In
  197. '88 heater never warms up
  198. knockin noise
  199. Hondas Only junkyard... any good??
  200. if u put a h22 head on a h23 block which HEAD GASKET do u use the h22 or the h23 help
  201. if u put a h22 head on a h23 block help
  202. prelude weight loss...?
  203. honda prelude models?
  204. help! please
  205. NEED HELP REALLY QUICK!
  206. 18" rims
  207. Air Filter on Tb
  208. Pulled Cel code#6 #70 and D25
  209. very noisy valve ticking upon first start up....
  210. taking out compressor.
  211. 300whp
  212. Prelude + Nitrous =???
  213. engine weak when lights and music is on.
  214. new wheels for 5th gen???
  215. control arm problems
  216. Good brake upgrade
  217. "Rage" SS header from Kteller....awsome...
  218. factory cd player not working
  219. H22 Help!!!!!!!!!!!!!!!!!
  220. 93lude manifold or injectors problem help!
  221. extra little mods
  222. BAD idle!!
  223. tensioner spring
  224. LOOKING FOR A GOOD EXHAUST...HELP!!!!
  225. S2K seats into 5th Gen??
  226. little help? 97 auto ( =/ ) prelude
  227. a little tiny part wasted hours!
  228. Average Cost of Replacing SH Clutch??
  229. cold start stall
  230. valves clicking noise, 215, 185, 220, 230 compression
  231. s200
  232. Knock sensor issues...
  233. Pic of 4thGen lude with eiback sportline springs
  234. H22 intake manifold
  235. Boost controller install
  236. H22A4 SWAP: NEED HELP
  237. vafc for sh?
  238. block heater
  239. anyone have a built h22 turbo??
  240. NON-Pop Prelude Headlights
  241. Anyone actually use one of the EBay tast pipe/high flow cats without the O2 sim. and not get a CEL??
  242. racingheart c2 rims
  243. Hoodpins
  244. sunroof visor
  245. first time building an H22... I need help!!!
  246. OTS ground control spring rates wrong?
  247. toe links for prelude
  248. 5th Gen Stock Seat Question...
  249. mobil 1 10w30
  250. What is this open tube on the top of the tranny for?
