View Full Version : Honda Prelude
- little holes in the balance shaft that flow oil? Consequence of removing shaft or belt?
- Starting Problems...
- Throttle Body spacers
- I laughed when they shot Old Yeller, and cheered when the Titantic sank...
- nsx stock wheels on 99 lude
- aftermarket throttle body opinions
- 92-95 oem Genuine Honda Prelude oxygen sensor!
- I need an h22a crankshaft in good condition.
- Reluctor on the distributor
- Battery relocation kit....advantage???
- Right rear caliper sticking
- new engine skipping.....
- Transmission problem on auto prelude....HELP PLEASE.
- Fiber Images CF hood
- New catalytic converter?
- suspension setup
- Can my friend boost his SH?
- FYI: Stock Parts for Sale
- Major if any diff between 97-01 H22A Type-s VS. H22A
- Any One Interested In Power Enterprise Super Strong Timing Belts for your H22a?
- ***TURBO prelude ??? GURUs please***
- Water pump interchange -able?
- has anyone attempted to use a F22 differential in an H22 trans?
- clifford alarm
- AEM cai install
- Wires
- Few new questions
- will these tires fit...
- tranny recall?!
- anybody got a carfax account?
- jrsc+strut bar
- 5th gen axles
- What's up with imitation mufflers??
- Installing Clutch next weekend.
- 4th Gen Axle Replacement. Can I do it myself??
- ALARM question about IGNITION wires...
- Which Cat-Back System???
- Is there anyway a non bolt on Greddy Exaust that Came off another Honda Not Aprelude
- Would I need rods + bearings for this setup?
- valve timing
- VA/DC/MD Prelude Meet November 24th - Tysons II
- FS: any full body kit, u get free carbon fiber hood, 400$
- My first Lude
- how to install a prodrive oil pump gear
- Oil Seal question??? PART# ID
- Making my car more reliable!?
- OK guys where did u get your turbo manifolds..
- Please Read!!!!! Big Question!!!!
- Brake line compatibility> Prelude/Accord
- Gas tank capicity
- Very interesting info... Forged crank and rods in later H22A4s?
- 3g surging idle fix - check this before you spend money!
- TWM individual throtle bodies any good???
- shorter shift lever = shorter shift throw..... need a quick answer!!
- 4g Exhast.. HKS good or no?
- h22a HEADER which is best for Normally Aspirated all out (MUGEN or GREDDY)??
- thinner head gasket on H22....anyone know about them?
- JDM H22A Engine Swap Questions
- Iron coated forged pistons.....
- 4th gen malfunctioning power door locks
- my camshaft doesn't look right...
- Help Needed
- AC Controls Removal on 95 Prelude. Need help
- what would you CUSTOm paint your lude
- piecing out a 1988 honda prelude 2.0si
- dc shortshifter problem
- more power?
- valve lash specs for 94 prelude vtec???
- "LIMITED" battery warranty
- b18c5 in prelude
- New Pics...
- Pics from Roosevelt Mall meet
- Drop the BS and give me facts: Re-sleeving FRM block necessary for forged pistons?
- JDM Fog Lights?
- Ch3ck 0ut thi5 m4d lud3 y0!
- Best 5th Gen Color? P O L L
- AEM big brake kit..anyone used??
- Damn South Carolina representing...
- H23 Rebuild
- MaxRev H-series turbo manifold and downpipe.
- 15" Wheels with 2" drop
- squeaking when i reverse
- Prelude Paint codes
- WTB crower stage h22a cams.
- BEST valve springs for h22a. crower EIBACH, skunk2 etc etc.
- Wheel theft in NYC, please help!
- jdm lights
- I'm back, but not going to live here again just yet... a few rules...
- any spring/coilover recommendation??
- cant reply to FS/FT? Not to disrespect but are there any other sites?
- Apex'i VAFC measurments
- cams???
- PRELUDE N/A THEORY: Destroking my H23 VTEC with F20B
- Here is a quiz question: 97 vs. 98 H22A4 intermediate "aka half" shaft.......
- the OFFICIAL TURBO Prelude thread!!!
- h23 bottom
- How much boost can a stock prelude engine take?
- No Clue
- Columbus, Ohio H-T Meet
- just got a new prelude, please help
- Oil change
- For the boosted H22's.....
- Ok, guys, we have known each other long enough...
- ok, once again.... suspension
- Drag intercooler install ahahah bolt on my ass!
- Where to get VALUE wing.
- Odd Noise
- A guy I know is going to Japan..what should I have him get me??
- words from JE themselves: YOU DON'T NEED TO SLEAVE (WTF?!)
- Intake Manifold Problem...help!
- 6400rpm??? huh????
- Prelude sites
- Which One?
- Jun Hood?
- I need pics of Spoon bars (rear)
- Can anyone help me out with TURBO
- Import Virgin ...needs a few good men to skool me on my 97 'Lude :)
- Slightly OT, but Prelude related :)
- Xenon Gas lights.
- Turbo Kits
- Excedy clutches?
- THIS IS NOT a forsale forum
- hybrid h22 tranny?
- Flapper valve for secondary runners
- custom turbo piping
- Need engine for 89 Si
- Water in trunk/backseat, continued.
- Field Vtec controller problems
- I need to buy a Spoon H22. Where do I go to order it online????
- conversions
- anyone wanna sell their oem front lip?
- Headlight + Taillight Removal
- How to tell if your tranny is LSD...?
- what's stock bore on an H22A... 87mm?
- H22 Tranny??
- ? for autox experts about cams..
- how to install new speedometer gauges?
- installing intake ?
- Help w/ Engine Whirring
- specs, setups, and run-down on h-series vtec motors.
- rattling
- H22A exhaust camshaft broke in 4 pieces!
- JDM Foglight question.
- JDM H22a cams same as USDM H22a cams?
- strengthened timing belts, and auto tensioner ?
- skunk2 H22A gears
- My turbo kit ask me questions
- turbo accessories
- weird clicking noise???
- 2000 Prelude ecu
- help on clay bar..
- JDM Headlights
- headlight wont turn on
- Need quick advice! Buying tires today! (5th gen)
- Getting a turbo need help
- burned 1 quart in 800 miles, blamed on drving style...
- V-AFC Question
- good rear strut tower brace?
- What Engines can i bolt to my tranny??
- carbon fiber lip group buy for 4th gen.... you want one?
- top end build up
- Installed exhaust - how do I fix the rattle?
- Sensor of my 3rd gen
- Turbo question
- Turbo Question?
- Brake master cylinder help???
- Bulb installation??
- H22 ecu
- Grinding Sounds
- I'm looking for a JDM P13, anybody got one???
- so I hydrolocked my motor today...
- Trans Problems
- water temp sensor placement 93 vtec....
- the tein ss's are ordered..anyone have them here?
- This sound about right?
- c/f lip for 4th gen 'Lude
- 3rd gen si 4ws parts car in MA... $200 plus towing takes it
- Type-S and stock ring gap...
- type s pistons???
- Anyone make aftermarket gearsets?
- ok ok heres pics i got new wing so dont wanna hear it...
- New to 'Ludes, need swap help
- is the h23 the biggest 4cylinder engine honda has?
- oil question on H22????
- Oil dipstick didn't register any oil when I last changed it...
- NOPI Gallery and etc.
- question!!
- Where's the fuse for "LED" fuel gauge on 93 lude?
- LONG ISLAND meet Saturday Oct 26th. 8pm WHO IS going?
- Forged pistons in stock H22 sleeve...
- Brake Fluid.
- 5th Gen Ram Air System
- Ignitor or coil problems?
- Help with launch?
- worth getting stock my '98 H22a tuned?
- Need help with H22a4 problem
- Anyone ever make break ducts on 5th gen?
- Skunk2 Stage 2 cams
- differences between oem 2001 body styles
- testing waters how much would this be worth
- vafc settings for h22
- Anyone have a S2k TB on their Lude?
- Boosting and Spraying.......
- Massive Headers?
- Crank, Cam Gears, and Underdrive
- SportShift transmission fluid change/preventive mod
- freeing up extra hp without doing anything mechanically..
- 5th gen with wheels pics?
- How do I pass Smog TEST ONLY CENTER
- question about rota wheel
- Where are they?
- HELP ME! I am thinking of selling my lude!
- catch can location?
- H22a running real bad. What can the problem be?
- H22 Tranny On H23 Motor
- So Cal Meet.... please COME!!
- How am I supposed to decide on an exhaust??
- header with 2.5 inch collector
- FS: 4th Gen H-series parts
- skunk2's
- Auto-Tensioner Failure
- Has anyone turboed a type SH?
- Hey H22a Guys! real quick, what color bearings??
- autometer temp for h22
- Anyone running Crower Stage 3 Cams??
- 4th Gen prelude fmax style intercooler piping..lets see pics.
- H22A with gas and spark but won't start
- New to boards, 3rd gen h22a swap
- Grease Opinions
- H-T meet for NC, SC, VA maybe in Charlotte NC
- AEM EMS or hondata ?
- Anyone know a web site for OEM paint in a spray can?
- Honda Prelude VTEC SE ?
- help on removing valve cover and prepping it for spray..
- besides valve cover, what else is safe to paint??
- 4th gen vs 5th gen.......... suspension
- my car just died
- Injector Size
- Would this work?
- Anyone have a BBK 70mm throttle body on their lude?
- All motor or FI H22A4 prelude?
- Throw-out bearing in need of greasing....
- WTB: 91 Prelude hood, fender, pass side headlight!!!! :)
- help me w/ launching an SS lude
- I need turbo???
- H22 gearing
- idle adj on h22a4
- Radiator or Thermostat???
- Interior
- H22a fuel cut at 6500rpms, VTEC, but no CEL codes!
