View Full Version : Honda Prelude
- Prelude Power Steering Problem
- problem w/ arp head studs
- Shift adapter?
- Tech Heads, help me get this motor timed right.
- An H22 VTEC Head On An H23?
- Wiring on H22a
- Underbody neon led lights???
- cylinder head info
- cold engine problem
- oil pressure problem
- help on bosch 02 sensor install (yes, i've searched.. nothing concrete)
- AEM Fuel Rail from B18 fit on H22?
- H22 in "Limp Mode" but no codes
- Will dropping my 4th gen lude 1.5" cause any drastic chamber problems?
- My lude is running wierd or my brain is slow today Please help.
- HELP WITH ECU CODE 17 FOR 94 2.2 vtec Prelude
- h22 head?
- shortened shocks.
- stupid question.....prelude bolt pattern
- Low idle w/ Sudden Stalling / Burning Oil on 4th gen?
- The Quest for ultimate power
- need input!!
- im planning on buying a v-afc vtec controller,is it worth buying it?
- what cams are better type s cams or skunk2 stage 1 cams??
- BOv not activating
- H22 acting weird
- Kamikaze header coating...
- please read
- Need help taking off front, rear, sides 92 lude
- Fuel Pressure Adjustment
- What is a good ajustable control arm.
- difference between h22z1 and h22a4
- Help needed -> rear lower ball joint
- Pistons.....
- Help!! Need JDM H22 pistons!!
- Exhaust Advice Req,
- 3rd Gen Paint Codes
- Oaks Racing Prelude now @ 664 whp 136mph Trap speed
- help with the alarm system
- my buddy needs help people that have put a new valve cover on plez help
- Im not RICH kids, sooooo chipped p13 OR VAFCII? PLEASE!
- engine running problem
- parts list request..
- Test Pipe
- Apexi Power FC on prelude
- how do I get my front bumper off?
- 91 Honda Prelude looking for proformance is turbo a good idea?
- AEM underdrive pulley kit ?
- 1988 B20A5 into a Civic hatchback
- engines!!!
- superchargers?
- gona be racing the car soon, what should i tune up and check up on
- H23 vs. H22 Injectors . How do tell them apart ?
- prelude 88 parts
- my H22 acting weird
- 4th Gen. Steering Wheel Removal
- Whats the best way to lower a 93 prelude.
- first time timing belt change
- Wheels and Tires for 94 Prelude Si
- Starting problem on 4th Gen 93
- dyno question????
- wuz up
- P13 ECU Tuning w/ VAFC n' Chip
- right front upper control arm
- compression numbers ?
- h22 ?
- h22 w/ titanium connecting rods?
- Guage cluster problems
- question about crower
- Lowering 92 Si. Camber kit?
- Need the part number for the JDM Type-S valve cover
- FAST HELP!!!! Door poppers
- Help! Smoke with a new turbo?
- chattery noise from engine bay... i think ive narrowed it down
- Need help with g22 probelm
- H22a4 going into a 1992 Prelude with F22 in it already.
- problems with the turbo prelude
- tapping noises?? hydraulic lift?
- Wiring H23 for VTEC
- head swap - car will not stay on, steam coming from exhaust
- high flow cat
- abs warning light after strange noise.
- why do I have water in my floor board????????
- 'Excessive heat to catalytic convertor'
- Problem getting the lude started
- 4th gen, what is that sensor/solonoid on the fire wall?
- Starting problem...
- Adjusting the clutch pedal.
- H23 to H22 Sensors
- timing belt tensioner common?
- what do you guys think sc300 with 2jzgte swap or prelude h22 euro swap?
- is it possible?
- where to buy hondata
- How much $ to convert to power locks?
- h23 with h22 pistons and head
- check light code???
- Why is my rev limiter kicking in at 6200 and i have no v-tec?
- wide body r34 kit help needed greatly
- Tubro Prelude questions
- h23 valve covers
- moving the redline up...or back...whatever
- Fool the SRS?
- Skunk2 Exhaust fitment
- Dynoed... opinions welcomed.
- 94 vtec erratic tach operation
- wheel fitment question
- i have a p14 usdm ecu any one want to trade for a p13 ecu?
- 6 speed on a H22?
- Purchasing a 97-01 Prelude
- Need a 97-01 Lude in the Raleigh Area
- Turbo H22er's - what turbo do you have/what power/what psi
- 88 prelude parts FS
- turbo exhast question for OBD2
- Please help me...! I really dont know what to do.....
- Max ignition timing off a stock H22 @ WOT @ 7500rpms?
- H22 spring and retainer differences
- Pulling H23 out. Wire harness question
- Installed VAFC II in my 95 lude vti-r having problems
- e-brake
- help me figure out this noise please
- installed head w/o dowel pins (woops)
- weird knocking
- Breather question.
- How do you get "base" ignition timing on a '96 Prelude VTEC?
- buyin a lude
- H23 Pistons and Rods...
- H22a AT p13 ecu with 5speed trans
- Oil pan similarities
- High flow catalytic converter
- Problem starting car
- alternator
- Are 92+ and 97+ suspension interchangable?
- clutch chirping
- Twin Turbo Prelude???
- WHATS THE BEST???
- All kinds of clunking a in 2001 Base
- gas problem on my h22 hybrid
- Just got my alignment done
- Need some tech advice >
- fire from exhaust
- 4th Gen Rear Bumper Removal help.
- How to Tell Cams apart?
- Throttle Problem
- New fuel pump and stainless steel lines
- strut bar ?????????????????s
- 89 Lude
- how much boost do u guys think i can run on a stock h22
- ~~~ Trouble Replacing Back Brakes ~~~
- y wont my prelude rev up as fast as it did
- Hear a knock noise when I turn left..
- im looking for a p13 ecu for my h22a1 prelude does anyone have one for sale or know a place that sel
- vtec solenoid
- SRS Airbag light
- 91 octane reduced my performance...
- Remove Airbag
- oil smell
- Greddy Header
- Oil sandwich adapter for turbo feed line
- damn Just got hit'N'run'd low speed rear ended :-(
- Please Help!
- h23a1 main bearing help?
- retail price?
- f22 intake manifold h23
- h22a1 vs. h22a4
- Transmissions
- ECU PINOUT
- ....one question?
- Where does the H22 originate?
- what is this ??? H22a + 6 speed tranny ???
- Orange front turn signals...
- SS Brake line swap on 4th Gen...
- best 92-96 lude taillight opinions and cat exhaust install estimated time of completion
- Converting from 93 to 94 console...
- h22 over heating in a hatchback
- wut is the best turbo 4 a h22
- best turbo?
- turbo vs supercharger
- how to get 300 hp
- i neep a price on my motor
- rebuild
- JRSC question need help quick
- jumpy arse speedo
- take out rear seat
- H22a1 timing
- TAKING OFF WEIGHT
- And some of you thought Corey's engine was built before!
- Strange VTEC problem
- Stiff changing gears
- i got an h22 vtec that i want to put in my 90 prelude si
- erratic idling when a/c is on
- Recirculating Muffler
- Need help with a 1990 Prelude Si!!
- ACT clutch/fly break in period
- road race prelude 4th gen
- Would a spoon chip be worth the time?
- header/ test pipe??
- What would a dry shot of nos do?
- Where would you start on a stock h23a to get better performance?
- CEL Code 9: New Dist, or just replace rotor and cap?
- How would you beef a h23a in a 93 prelude
- h22/h23
- Looking for wiring diagrams for 92-95 for the ECu pin outs
- Other Car Comparable to a Prelude?
- Type S Pistons.... question
- 11.8 sec 1/4 mile for a N/A H22 Prelude: Is this true??
- 5th Gen Header question ?
- What is considered perfect compression for a JDM H23A DOHC VTEC???
- Accord Type R gearbox
- EXHAUST QUESTION
- timing belt snaped !!
- 1st post, Tranny trouble?
- h22t euro r manifold???
- dsm turboing...
- 89 prelude si I NEED BIGGER pistons? ANY IDEAS
- H22 RD DYNO stroker kit
- 3rd gen preludes lets see them
- New clutch install problems
- Dented oil pan
- car wont rev past 6800
- got the engine in... and theres a few problems (of course). oil pressure, dead miss...
- What does it mean when my "MAINTANCE REQUIRED" Light in the guage cluster turn from GREEN to YELLOW?
- 92 prelude, right front wheel seems to be locking up
- UR crank pulley
- What the hell? Engine problem majora?
- Knock Sensor, How vital is it in my H22?
- knuckles from salvage yard
- 89 Prelude s acceleration/idle problems
- h23 cams?????????????
- On my 98 Prelude radio/CD dont work, need code!!!
- F22a1 or H23 boosted
- Turbo Problem with my black 93 VTEC turbo'd h22a1 lude
- 5TH gen prelude cat and exhaust specs..
- Can someone tell me about my joints?
- port and polish or aftermarket
- seat pressure skunk2 springs
- H23 normal operating temperature
- tranny just blew - 5th Gen Lude
- replacing e-brake cable?
- Golden Eagle proudly introduces its H23a Intake Manifold
- injen intake prelude sh
- H23 custom turbo setup Q's
- no cat run very rich??
- would a craked coil be a reason I'm running too rich?
- 4th gen lude plastic "spoon style" lips??
- question from a new guy
- VTEC Hesitation
- Is a h23a spoon chip worth the extra revs?
- Steering Wheel Pulstates at 60mph
- Does anyone know a lot on 2000 Preludes?
- 4th gen prelude questions!
