View Full Version : Honda Prelude
- ABS standard?
- h22 manual timing belt tensioner
- Removal Of Prelude Dashboard
- h22 Auto Tensioner Timing Belt Change
- F20a4 Info
- Push Clutch=Dead Car
- Check engine light problem
- h22a 92 prelude question
- Why is this connector taken off, Please Help
- almost ready for paint
- detailed picture of alternator and powersteering placement for a h23
- Neukin H22 Turbo Manifold
- Changing LED dash lights?
- Civic Half-Rad + H22 = Need Slim Fan!!
- bad engine mount or bad axle?
- ecu wiring question
- 92 fog light switch???
- fuel filter bolts?
- How do i take the top part of the IM off
- front lower ball joints replacement??
- exhaust and chip help
- please help
- Dumb question
- Car almost dying in traffic
- Engine suggestions
- How to tell if a M2B4 has LSD?
- Koni Yellow's and S-Techs
- changing dc header back to stock h22a one
- WALBRO 255LPH FUEL PUMP WITH STOCK FUEL PRESSURE REGULATOR.
- H23 Auto to 5 speed Tranny swap
- What prelude model is this...
- Installed JDM dizzy now throws code 15?
- Ecu opinions for the JDM H22A
- euro r intake manifold from ebay
- What's the name of that thing?
- Wheel Bearing problem
- gauges
- Question On 1989 Fuel Injected Engine
- Have a coolant leak near my 1987 prelude water pump
- Where can I get injectors with the same pintle as Euro-R injectors?
- Greddy EVO 2 on 5th gen
- H23A3 vs. H23A1 ?
- Changeing ATF write up
- car trouble.......
- where is the coolant drain plug on a h22 engine
- camhaft and valve upgrade decision
- aem pulleys
- Europe Tranny Codes (need help)
- is a different throttle body worth the money??
- Car NOT Starting...please HELP
- Are there any good CO local suppliers of carbon fiber hoods?
- How do i replace the mirror on the 5th Gen Honda Prelude.
- auto-to-manual swap
- h22 in a 91 prelude
- iacv problems
- Car stalling when starting it
- strut arm and radius arm bushing on a 5th gen diff on a sh?
- Suggestions/ ideas for my DD 4th
- help
- JDM H23 Vtec
- Where is my MAP sensor?
- Clip?
- need a 21 or 22 tooth gear for a f22a1 waterpump
- Pulleys are a hassle
- alternator easy to replace?
- ET Motorsports
- pspec short shifter
- Lug nut thread type
- 5th Gen Prelude- Looking to purchase.
- HELP! My Lude Just cought on fire!
- my final plan... take a look plz..
- Redoing my suspension
- 1992 Honda Prelude si 2.3 manual
- Mfactory h22a fd 4.64 good or bad does anyone have this
- Suspension Technique lowering springs
- H&R Race Springs VS Neuspeed Race Springs
- Two of my Main bearings are out of spec. point me in the right direction
- shift boot
- need some decision help
- Quick Fuel Line Question
- prelude exhaust and intake suggestions
- Clutch Noise Question
- 3rd Gen How To: Clutch Adjustment?
- Hi luderz
- H22/H22LSD Transmission Switchover
- My God aweful experience with Drag Turbo-Kits/Blox Racing.
- Prelude 5 speed synchro problems/grinding
- fuel system
- CEL insufficient flow from EGR valve , Replaced EGR , CEL came back on Help!!
- Anyone know which header this is, just by looking at it?
- anybody intested in h22 high performanced ECU
- Porting and polishing a head
- ABS Unit, Could I remove without replacing everything?
- unorthodox crank pulley's do they work well with h22 motor's?
- high compression head gasket or removing layers off Honda OEM one ?
- '97 SH rear knuckle and spindle...same as base?
- Using stock crank pulley
- reusable thermal TB gasket
- 5th gen headlight lens?
- Dropping in new pistons
- Fox Race headers
- My H23a1 Running rich...its getting annoying
- 4th gen ABS hub. Are there diff ones?
- ? about my crank pulley
- How does this price sound for this maintenance on my 97 SH?
- Car shutting down at random
- main bearing question
- ingalls camber kit question
- ATTN: 4th Gen Owners with Koni Adjustables
- have $1600 to burn
- Question for all H22A owners
- question on h23vtec help plz........
- t Broke a rod
- Upgrades for a prelude 93'Si H23a1 engine
- custom exhaust for my prelude- whats a good muffler?
- BEWARE: MHR Performance aka Lucky Racing
- SOHC F20a swap for F22a
- 5th gen lude f20 --> H22A ODB2
- Radiator fan problem
- 93 prelude h22a bogging????
- help with f20a dohc swap
- Would you guys be interested in these gauge clusters??
- honda newb: can you convert to v-tec
- Prelude specific Drag Racing wheel/tire combo.....
- JDM Folding Mirrors 4th Gen
- JDM H22
- how to question...
- im looking for sum Side Skirts
- Speaker sizes
- H22 head markings, what are they?
- 92-96 interior carpet, black or blue
- some mods for NA all motor nitrous
- bored vid clip...launch
- looking for 240 whp
- This should work...right?
- How do you guys drive?
- Will B16A work for swap?
- Hondata with obd1 p72 on 98 lude....emissions ?
- 1998 Prelude-Base Automatic to Manual Swap Questions.
- buying 97 prelude- help please.
- Just replaced my radius rod bushings
- ignition switch?
- difference from usdm/jdm p13
- Great video explaining clutchs/flywheels and pressure plates
- JRSC question.
- which shocks 4 sport drop?
- 4th gen front end conversion to a 5th gen?
- worth it, or not?
- Rod Bearing Help! Oil Orfice Hole! New Bearings dont have them.
- reseting computer on a 97
- 4th gen S model brake line thread sizes
- H22A4 Questions
- is taking off the belt and pulley ok?
- Headlight problems
- will the stock mounts fit on racing bucket seats
- how much should I pay for this longblock
- RWD conversion, anyone?
- 4x114 to 5x114 conversion thingy any good?
- OEM Speeedometer gauge installation
- Fog light fuse keeps blowing up.
- prelude help
- Is the DC sports short shift adapter for the 5th gen just garbage
- Another Prelude accident
- FUEL FILTER ???
- honda parts
- which pulley is which
- Rebuild or replace?
- Electric Issues, Interior and Tail Lights
- reverse issues
- 92 prelude CEL
- Adjust Toe
- Equalizer /CD changer in 92-96??
- how to take out glove box in 5th gen
- manual swap done now wont start
- someone help me please timing belt trouble
- 90mm throtle body on H23 vtec?
- d16 and h23 intake's
- 3rd Gen Prelude H22 swap, Driveshafts??? help!
- wastegate spring question
- Uneven drop
- bleeding procedure S TYPE
- Will a H23 block fit directly onto an H22a head? Please read inside
- Retrofit finally done! Pics, tips, and comments.
- 1988 ba4 starting problems
- - Complete List - H/F tranny codes - gear ratios
- not too expensive project
- HOW MUCH IS AUTO TO MANUAL CONVERSION ANY EST.?? THANKS
- Need help installing my jdm bb6 fog lights, anyone?
- help jdm h22 swap
- H22 install in F22 prelude, please help
- Rough Idle... Now No Idle...
- squeaky noises (I think it’s coming from the rear suspension, head lights and or the front bumper)
- new guy here, need some help on getting rear glass out
- Who likes these 18's?
- 4th Gen Cursive Prelude Font
- Is there anyway to trouble shoot a MAP sensor (89 prelude SI)
- Cigarette Lighter Mod--> VW Mini "Torch"
- did anyone ever install a ecu chip from ebay?
- stalled an ecu chip they got from ebay and did anyone ever install a ecu chip from ebay?
- AC Repair Compressor > Receiver
- f22/h22
- Professional Products throttle body (only $140!?)
- 95 h22 compatible with 97 prelude
- Shifter Vibration- side to side
- Brakes Help!!
- oil leak
- H22 throttle "TPS" issue
- turbo build w/c rods
- long ram or short ram?
- Base model header on a Type-SH. 97-01 of course
- 5th Gen. Prelude Aftermarket headlight fitment w/lots of pics
- jackson racing supercharger
- usdm h22a1 syncros work for m2a4 tranny?
- clevite or acl??
- new starter...
- Problem and Questions on suspension install on 01 SH?
- JDM Type S Pistons and JDM Rods, what bearings and rings?
- HELP!!!!
- Where did YOU get it done?
- belt question
- Engine Shaking
- JDM H22A build help
- **1st** 4bidden SS review for 5th gen.....go ahead and bow down :-)
- m2b4 tranny on 2000 prelude
- How to build a High Rev Engine?
- 2.3 L h23a dohc to 2.2 L f22b dohc swap
- Leaking water inside......anyone??
- m2b4 tranny? (searched)
- What belt to use after AC removal
- Would a Celica GT4 4wd system fit on a 4th generation Prelude?
- S2000 antenna fit on 4th gen prelude?
- accord motor into prelude - anyone have one
- XTD clutch reviews
- Whats better??
- ECM QUESTION 88 PRELUDE
- Ignition Troubleshooting
- Tryin to make Prelude faster and more powerful
- Starter Rebuild
- Ractive header any good?
- Will S2000 rims fit on 98 and up prelude please help
- radiator coolent
- Stainless Steel brake lines?
- Anyone know where I can order an Apexi WS exhaust??
- Head Bolts
- idle surging
- I need a legit answer about a Pearl Paint question.
- SPARCO LOWERING SPRINGS!!!!
- JDM Type-S in a BB1 - problems?
- where to buy greddy exhaust?
- just bought 5th gen... MPG question?
