View Full Version : Honda Prelude
- GS-R manifold on a Type-SH?
- poisoned prelude
- question: '90 prelud w/b20a5 wants to race...
- f23 dohc vtec
- Look If You Have An OEM Lip Kit!
- where/what is the speedo converter
- what's a good clutch for a jrsc setup?
- Anyone have a speed delimiter in their car? fields/hks/apexi
- help! my car won't shift!
- Hondata s300 on 5th gen prelude?
- Engine oil flush
- After tranny fluid flush......
- Stock Pedal Question
- What are the colors for the (TPS) throttle position sensor
- JDM H22 EG 3 in. Exhaust
- just a wanted to know info on a H22
- General question to who can vouch for and is sure about the H22 motor
- changing stock rear brake pads on 5th gen
- BIG problem. Need help
- How do get condensation out?
- H22a4 spec S pistons
- Light weight flywheel
- Leaking clutch master cylinder?
- When using a big brake kit ....
- timing belt
- 93 si parts
- fidanza flywheel Q's
- 4th gen clutches: XTD + Exedy?
- Big Brake kit Q's
- puttering...kinda
- Not my IAC valve!!
- Strut bar ???
- Compression
- Need help diagnosing problem
- Need headlight, fender, door, etc
- Starting issues i need help asap!!!
- custom front upper strut bar
- Cooling Fans dont turn on
- Will 86-89 Accord springs fit '86 Lude?
- anyone want to do my headlight retrofit?
- 93 lude runs eratic
- Have I found an easy place to instally an autometer water temp sender?
- is a jdm p13 ecu better or a usdm p13? or doesn't matter. thank you
- Quiet Exhaust?
- stereo system in 5th gen preludes
- Adjusting Vavles?
- Quaife LSD Install (searched)
- mugen header and crower stage 2 cams
- JDM retrofits
- 5th Gen Exhaust Sound Clips
- *EDM Rear Fogs Pics.....
- Chip relocation of Auto ECU to 5spd ecu
- Where is the IAC valve located?!!!!!!!!!!!
- Questions on installing cams
- Does this dyno look right?
- Where is the IACV located?
- custom exhaust with what muffler?
- Kinda Rough Idle when turning Headlights or Heater Fan "off"!
- obd1 or 2 for H22A?
- biggest bang for your 2000 bucks
- A couple questions about CV boots
- Compression check on a H22a?
- how to disable honda stock car alarm?
- RMF header + what exhaust
- H23 rods the same as F22
- H22 Integra that was mated by me
- About to Replace Shocks/Springs
- Miss in my race motor
- All H/F Series Hybrid Motors and CR Thread
- Transsmision?
- H23A2 90mm bore
- Would I have any problems using this suspension setup for a bb6 TypeSH
- 1998 Prelude alarm, how does one disable it so i can put the battery back in?
- aftermarket projector headlights with HID
- downshifting
- water pumps
- lude jumps outta R
- f22 manual tensioner on an h22.
- Auto to Manual Tensioner Conversion
- do manufactured Si taillights exist for lude or are they mod only
- prospeed-performance ecu
- H23 vs h22 rods
- need help i have weird shifter problem on my 5th gen
- OT: Pic Request, already tried the A/C thread with no luck
- Prelude Type S camshafts on OEM valvetrain?
- Suspension accord/prelude
- rod/piston combo on NA engine
- 92-95 H22A MT into 88 prelude w/2.0 carb MT, are they the same motor mounts?
- Putting Tranny fluid in H22 tranny?
- WTB: REAR SH DECK LID
- Good camshafts for turbo setup at 7psi?
- My H22A Acura Integra
- emissions
- Differences between 4th and 5th gen H22?
- check light on!!!!
- stupid question but how many quarts of oil go in a H22?
- need some info on some chips please
- 2.25 piping with es muffler?
- How many quarts of transmission fluid go in a H22 tranny?
- Where can i find this Front Lip
- HUGE POLL: HELP! In dire need! ALL PRELUDE GURUS! swap dedline feb 1st 2006
- Car dies when I stop- SEARCHED
- 92 prelude auto si. did jdm h22 swap 6 months ago, just now did the 5 speed swap. red lines @6200 an
- springs or coil overs
- Creative Gauge Mounting
- what kinda bulb is in the jdm 5th fog lights?
- sqeaking everytime I go over bumps?
- SH, ATTS light is on?
- 93 Si--->96 Si Gauges
- BAD surging idle....I SEARCHED
- Apexi WS? or Greddy SP2? which one would you prefer?
- what wheel size and tire are you running on your 5th gen?
- 86preludeB16
- IACV Valve cleaning what to use ?
- motor debate
- tranny fluid chnage
- Front End - Control Arms, Sway Bar...Hit a curb.. :(
- What does "true coilovers" mean?
- Hondata S300
- winter all motor setup
- Your opinion on this strut/spring combo please...
- hey, question???
- oil housing o-ring leak?
- Power window not working
- installed Delta cam 272 grind in H23 non-vtec
- factory prelude cd changer?
- Adjuster Screw on TB
- Hondata question?
- H22A Cylinder Honing.
- Wife wants a 97+ Lude
- knock sensor code
- Help! I'm having Tons of trouble located a bottom end
- apex n1 catback
- 93 lude si problem
- 93 parts
- All lights but no start!
- searched and searched (h22a vs. f22a1+boost)
- cold engine
- vavles and vavle spring what brand is best...???
- 4th gen
- autometer shift light install???
- obdII ------> obdI
- idle problem
- What could be causing this mess?
- Turbo Charged h22a. What Oil Grade do you use.
- Turbo H22a problem????????????????
- Should I get adjustable cam gears? (searched)
- Question about shifter cables???
- Broken Ignition.. HELP
- Finally got tuned (PICS)
- hey
- Will These Fit?
- Bad clutch?
- vtec...oil pressure
- Wheels for a Prelude
- ATTS ECU
- Misaligned shifter
- B18C1 in a Prelude??
- EBAY Headers, YAY Or NAY??
- auto to manual timing belt tensioner
- motor swap help f22 to h23
- Integra Type R vs Prelude 5th Gen
- 93 lude si timing belt and tensioner problem
- Clutch question - 95 Prelude S.
- HELP BRAKE LIGHT
- battery light stays on
- Supercharger Prelude
- 92-96 SI header on a 92 S Prelude?
- anyone has painted their rims? i need advice please
- Replacing Stock Antenna in a 94 Prelude.
- Fixing Shock Knock
- 97 prelude EGR valve ?!?
- O2 signal wire question
- o2 sensor or knock???
- had an opps, clutch
- OIL PRESSURE. how to check? HELP
- h22 bogging @ low rpm
- h22 OEM DOWNPIPE for 4th gen
- Idled up and down
- OIL LIGHT LAMP ON?? ON JUST INSTALLED H22 JDM
- Idle surge - another cause discovered.
- interior question
- p72,p28,p30,hondata,unberdata
- 5th gen prelude leather seats
- How to use inductive timing light?? HELP
- Custom Header questions
- Which o2 sensor???
- Projector Headlights
- How many miles can i get on a 97-01 Lude?
- H22 auto to manual conversion?
- Quick rotor question
- need help buying new rotors
- Are Jun cams the best N/A cams for the H22?
- Not my IAC valve??
- help!!, removing the low beam bulbs
- Coil Overs
- What is this thing?
- Power Steering fluid
- Window not operating after door swap
- Hondata s300
- Help with brake lamp light on dashboard...
- need oem cat converter in good cond.
- Wheres the official H22 Header thread???
- Odd Steering Vibration
- Who here has ever used a Field SFC-VTEC controller?
- skunk2 valves
- H1 Bulbs keep blowing out
- h22 exhaust problem
- I need transmission help!! Please!!
- too soft help
- 5th heatshield in 4th would it work??
- inspection help!! obd NO???
- stainless lines install
- nuts for exhaust manifold
- Oil pump failure?
- Fire!!!
- Brake fluid/and brake bleeding
- brake pads
- battery
- v-afc
- spring rates
- h23 crank pulley
- 4th gen with moonroof?
- Clutch going, need referrals for good shops
- Skunk2 upper control arm+camber kit replacement for us preluders!!!!
- will h22 or h23 oil pan fit on f22a1 motor?
- What springs to get?
- anyone know how much it costs to equip the base model 97 prelude with atts
- tire size for 16s....
- pics of different steering wheel for preludes
- Need help for relocating mirror switch
- prelude speaker question
- rpm droppin...
- 5th Gen Prelude Oil leak?
- quick question please help
- h22 ignition coil position help
- PCV valve!!!
- How do i remove a jackson racing supercharger belt
- Pic Request red 5th genners
- 2000 wiring info for rear speakers
- pic request - crank pulley and plastics behind it
- what next on the 99 lude
- 2000 Prelude sh bring up Misfire Code 74
- Will the AIB from a B18 work on a H22?
- I have a question/need alot of help
- Never ending idle/jumpy in gear problem
- generation differences
- H22 Headers with 2.5" collector: DC VS Greaddy
- break calipers
- WTF check engine code P0141
