View Full Version : Honda Prelude
- h22a need help
- Please Help! H22 intake manifold ????
- H22 swap help
- what its worth??? h22
- strange problem with my door locks and door handles ( already searched with no luck )
- over heating trouble. need help please
- Cammed h22 flyby vid and a question
- Help, headlights stopped working
- Problems with 1st gear,Jerky/Bucking
- Best Spark Plug semi-built H22
- What's Missing in these pictures?
- headers
- Carbon Build up
- My p13 doesnt like my h22a
- Denso or NGK?
- rota rb
- pros/cons h22a vs b-series with vtec
- Smashed thrust washer H22
- whats between your head and block?
- Odd cooling system problem...
- *** H22a4 Motor with a jdm p13 ecu... cel 21, but vtec still works ***
- My parking lights and cluster won't come on
- The Prelude Curse - Spun bearing v3.0
- Light Preassure Turbo Type S
- Manual tensioner weakening?
- 97 Prelude suspension upgrade
- 97 Prelude replacement carpet
- Prelude/Accord engine
- Engine is broke
- How To: 5g VIN Decoder Ring
- just a teaser!!!!!!!
- modding my new 97 Prelude
- Shaving the prelude H22 valve cover??
- Do i need a new battery or what?? HELP!
- Broken wheel studs
- start up trouble
- What's with this oil cooler?
- quick question about injectors
- hickups
- 97-01 prelude master cylinder?
- skunk2 tb help needed!!!!
- Dynodays in socal?
- going nitrous, do I need to mess with timing?
- HID problem help!!
- Prelude stopping on its own
- Is there damage done to the engine after I washed the bay?
- 4WS Swap in to non 4WS help
- Apexi N1 catback with...?
- How does the Main Relay Work
- Building an H22A.......
- Heavy vibraion after swap..Balancer shafts out of time?
- How does the starter work
- Car is running Like CRAP! HELP
- engine swap
- hard spots on flywheel
- engine swap
- E-85 Conversion 99 prelude
- H22A4 Shredded timing belt
- o2 sensor/catalytic converter/ ???????
- Throttle Body question
- H22 Turbo build questions!!
- changing o2 sensor bank 1 sensor 1
- I think im almost done. Please help.
- Which ECU?
- Could i run a p28 with an F22 sc non vtec
- P28 - f22a sohc non-vtec?
- obd2 h22 in obd1 prelude
- S/C'd H23 prelude and i got questions.
- headlights
- JDM - USDM H22a distributor bearing
- NEED HELP .....well advise
- G23 in 5th gen prelude...
- FAQ added- $20 H/F Balance shaft removal
- F20 Transmission sent with H22 Swap!!
- I need h22 pros! horrible bogging, need help asap!!
- whats the thinnest oil sandwich adaptor
- Cruise control removal
- injector wires
- car stalls on me!!!
- 92 prelude headswap.
- 92 prelude auto trani question
- idle surging
- what distr. on h22 swap in 92 si??
- 2000 Honda Prelude SH Supercharged
- horse power
- Eastern, PA King of Prussia Meet 5/03/2009
- HELP! 4th gen gets a 99 SH Motor need harness and ECU
- Collector size
- Valve Spring install height
- Installing new valves
- main relay fix?
- Skunk 2 Stage II cams on stock valvetrain?
- b series tranny
- How ro replace VTEC pressure switch (Solenoid)
- help w/ h23 to h22 swap
- h22 w/ no ac compressor:how to do so?//does h23 harness have knock iab on it?
- 2001 prelude ebay camber kit junk?
- 2k to 3k hesitation SOLVED!!!
- Can anybody tell me where the other end of this is wired to
- vtec sub-harness for h23 help
- Misc hoses on H22 (M2A4) gearbox *PIC*
- 92 Prelude bent valves question??
- distributor swaps on H22A?
- Prelude halo projector headlights
- will an OBD1 PO6 ECU fit a 94 prelude?
- 5th Gen with random miss fires
- Prlude gearbox problems
- F20 manifold advice needed
- H23a1 head
- First post: Lost 5th gear w/new clutch-HELP!
- H23a1 Timing Questions
- Custom turbo manifold
- Please help! i have a question. f22a to f22b
- 01 prelude Coilovers?
- 94 prelude turnsignals?
- V6? Or Not?
- h23 block h22 head questions
- SH vs base spring perch
- h22a1 IM fitment on h22a4
- Replacement mounts for 95 lude
- h22a crank question
- tricky question? 96 jdm motor
- Steering Problem When Aggressively Turning Wheel Left-Right
- 5th gen. Mugen exhaust in 4th gen.
- can a f20b fit into a 95 honda prelude si??
- suspension bushing options
- 98 Prelude Power Steering Pump HELP
- How to tell if my h22a4 was Turbo
- ??Auto or man. Block??
- motor wont run on idle after cams installed............help..........
- Cam Oil Seal leak near gear side install Q
- base or sh?
- Direct fit Cali proofCatalytic Converter
- Need help installing intake
- 4th gen trans will bolt into a 5th gen prelude?
- OBD1 to OBD2 or OBD2 to OBD1?
- Pic Request: 5th gen with slipstreams.
- jdm h22a idling is fine except when..
- H23 to H22 swap ?'s
- Main bearing and ConRod bearing measurments
- Anyone using this cold air intake?
- Help me choose good suspension setup
- What should i start to do first on my 93 prelude vtec?
- Got my lude tuned today
- leaking master cylinder
- VSS Removal/Installation problems
- what oil?
- lound ticking noise coming from engine h22a4
- Whats a good Sway bars and tie bar setup?
- Rear drivers side camber issue
- h22a type s valvetrain
- 235/40/17 for road racing
- VAFC help
- Compression Test
- JDM F22B piston rings?
- Need help with oem prelude radio/cdplayer
- 99 honda prelude driver side window issues
- Window Motor Failure?
- Help Identifying Wire Harness (4th Gen)
- prelude w/ 2008 17' HFP rims request
- h22a swap, power???
- hit and run.
- Thoughts on D2 Suspension?
- starting air valve?
- little farther on H22 rebuild... still some issues
- ac turns on and off....
- Ticking noise from inside the car
- nox emisions is really high
- help swapping 92si -h22a
- Low compression...need suggestions
- Double-checking parts required for SH ATTS to Base Conversion
- 93 prelude converting to digital dash cluster
- ac compressor type
- H22a4 Swap from Basic H22a
- Serious H22 cooling issues
- Honda Prelude 1997 Airbox
- h22a1 head gasket
- h22 powered 85 prelude
- WTB Intake and Throttle Body
- H22 Experts Help
- 99 prelude wiper problem
- n00b. new to forum.
- Broke two timing belt tensioners in under 800 miles..97 lude
- using accord for auto to manual swap?
- Engine wont start
- low rpm
- Tranny Question
- Anyone ever tried rebuilding M2A4?
- wiring problem with front drivers side turn signal...
- Best exhuast for ma 93 Lude si?
- P13 or P28?
- What would it take?
- Delete please
- radio code?
- HELP: weird rpm and vtec problem
- Timing advance question.
- Car shut down. Fly wheel shifted out of site!
- Auto tranny slipping after fluid change...
- installing bosch 1000c injectors on H22???
- new to the forum
- Does an h22 ecu plug into a Civc?
- JDM headlights
- 94 Prelude wandering like crazy!
- Interior clock issue
- Help! Alarm won't turn off!
- 98 Honda prelude won't start! Hope I can get some help!!!
- honda prelude 89 si 2.0, problem starting the car
- 92 F22A1 head swap H22
- what oil filter to bump pressure slightly?
- How do I hook up vtec on H22 swap
- 99 prelude stereo advice
- CEL code 9
- F20(S2000) Crank Pulley
- h23a1 head with F22B block
- difference in pe width? how important?
- cost to replace a clutxh
- 3rd Gen Cluster Wiring
- Traction Bars ???
- running leaning and random misfires
- H23a Motor
- Anyone running magnaflow spun cat?
- 4ws code 20
- H22 Build
- throttle response wheel/cam
- Help my car won't stop.
- Question on intake control selenoid valve.
- compression test is good or bad
- WHAT HAPPEND To THE DIY BALL JOINT write up????
- 5 gen front wheel bearing diy
- 92 Engine Swap Problem
- Need help fast
- Do all h23 intake manifolds have dual runners?
- oil cooler inlet hose size
- Taking apart h23 block
- h22 all motor throttle body.
- extremely loud exhaust
- weird idling?
- Low Idle after warm up
- How-to: Retrieve CEL, ATTS, ABS and 4WS DTC's
- havin trouble with my radiator fan need help!
- h22a4 rebuild. main & rod bearing colors..?
- ATTS light
- Unable to tune the ignition timing to required mark on F20a (=F22a)
- purge tank...
- Getting a 97 base
- tuning necessary?
- Engine Hiccups at idle but rpm is stable
- code 43?
- 97 Prelude in dying need of help!!
- Quick Question: Are 4th Gen headlight bulbs H4??
