PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 [170] 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 92-96 VIS R33 front bumper lip
  2. What size slick for 5th gen. Lude
  3. can't find the transmisison thread
  4. Finally got a prelude
  5. 1997 Lude havin probs!!! HELP!
  6. Type SH shifter boot. Direct fit in 4th gen?
  7. best place to buy quaife diff
  8. what size r f22a1 injecters?????
  9. quick clutch questions (picture)
  10. Shifting Problems
  11. Are TI retainers really necessary....
  12. fuel relay or solenoid not working...help
  13. Tie rod question
  14. ??What tranny fliud??
  15. Writeup or any help requested :)
  16. 1999 type SH--> I Don't want atts anymore.
  17. 195/55/15 to 195/60/15 Tire question
  18. 93 Honda Prelude H22 worked fast
  19. 5th gen wings west rs or oem lip kit paint job cost? (searched)
  20. Tire noise? or what?
  21. 5th gen radiator?
  22. can i use ANY H22 block?
  23. 4th gen F22 auto to jdm h22 5spd conversion info
  24. auto trans help
  25. Heated seats...anybody got 'em? What year, model, etc.
  26. No Fuel, what to do?
  27. How do you remove the corner signal to change a burned out bulb
  28. h22 rebuild questions
  29. NOOB question. I'm gonna get flamed for this, I'm sure...
  30. tranny wont go in gear when car is on
  31. Raising Coolant boiling point
  32. Anyone ever had their aftermarket cams worked on?
  33. strange idle problem
  34. Techno R (mugen rep.)
  35. Sorry, another wheel/tire size question
  36. H23 blue top VTEC?
  37. Spindals for 3rd gen vtech
  38. 97-01 prelude timing reading
  39. Wheel Alignment Problem
  40. Mugen Exhaust, Full Catback for 5th Gen
  41. Looking for a '96 or newer Prelude
  42. mugen 5th gen suspension
  43. C.V. Boot replacement difficulty?
  44. Megan Racing products
  45. nitrous(searched)
  46. H22 engine F22 Type-s tranny T3/To4e Wich clutch & fly to use
  47. High pitch howling noise?
  48. stalls as soon as it reaches operating temp? please help!!!
  49. 91 prelude
  50. 4WS code 7 long 1 short I searched
  51. Short shifter
  52. type s valve springs
  53. will not start hot
  54. thermostat
  55. G23 nonVTEC hybrid engine for sale on Fleabay!!! or is it?!? lol
  56. will a sh tranny fit
  57. Another tire size question
  58. Integra Radiator almost the same as Lude Radiator
  59. Anyone know where to get carbon fiber front lip~?
  60. bb6 type s strut bar........
  61. Worth the buy???
  62. What's this thing...
  63. Need help with euro r manifold swap.
  64. good site for parts
  65. Horrible crash...looking at options
  66. tweeter mount
  67. OBX/MOROSO oil pan on a 5th gen SH?
  68. ...Very Frustrating... Breaking Bolts Trying to put the Cam Holders On...
  69. 94 jdm h22a. crank bearings???
  70. crankshaft pulley help
  71. Apexi WS2 catback question!
  72. cant get the stock flywheel off help
  73. Coolant Bypass Questions, CAI and Header wrap. I am gonna Dyno
  74. H22a4 SH Block into a 4th gen...
  75. just got a monster tach
  76. Tire size for Prelude with 17x7.5's
  77. Very very loud knocking noise
  78. recaro seats in a lude. what parts?
  79. InJen or AEM V2 CAI???
  80. Tein S-tech Springs on a 97 Prelude
  81. What is 4WS?
  82. PCD alteration wheel adapters
  83. speedo needle bulb replacement??
  84. Timing belt came loose!!
  85. I am looking for Advan RG gold rims for my 2001 prelude.
  86. How much boost can she take captain?!?!?
  87. M2B4 axles oil seals???
  88. More Torque??
  89. Intake Manifold skunk2 ?? euro R ? or venom ? or w.e
  90. Starting modifications???
  91. Idle problem
  92. Prelude Front & Rear Top Hats the same??
  93. exhaust off center?
  94. need help on tire size
  95. problem! oil in Plugs!?
  96. need help identifying the side skirts and rear lip on this 4th gen lude...
  97. h22 pistons in h23(i searched alot)
  98. CarDomain page, post yer cardomain links
  99. Completed T-belt replacement...misfire now...?
  100. OT: cheapest place for k&n filters?
  101. Prelude Performance Ignition
  102. Car won't start, help please!
  103. Stock Injectors
  104. throttle body
  105. BIG Problem (and im stumped)
  106. NEED HELP! obd2 to obd1 conversion on 97 honda prelude with OBD1 H22A
  107. H22a4 Intake Complete Manifold - OBD1 Compatible?
  108. Skunk 2 Exhuast???
  109. Which Intake is THE best??
  110. ECU smog passable???????
  111. Give me some advice~
  112. Car feels slow when hot.
  113. VAFCII - pressure psi/kpa...in Hg intake manifold negative
  114. H22 Type S in a Teg??
  115. Changing my fuel filter, should I do anything else?
  116. Egr help..bolt stuck
  117. Water Pump/Timing Belt Parts List help
  118. 5th gen smoked turn signals
  119. Knock sensor plug snipped. How do I replace it?
  120. boring the h22
  121. yet another failed h22 hydro tensioner
  122. geting a prelude
  123. Cheap audiobahn stuff
  124. qestion!
  125. Question
  126. Valve Noise??
  127. h23 flywheel on h22 motor ????
  128. Jumping fire?
  129. Would you get a exhaust???
  130. Fuel Rail Help
  131. Adjustable Cam Gears, Help??
  132. Please, i need help with a cluster situation
  133. Alarm install
  134. Precision 1000cc injector fitment?
  135. Took out the IAB's, JB welded the two outside holes...i have a problem
  136. Another Prelude failing emissions testing...HELP!
  137. Prelude BB6 JDM Visors
  138. NEED HELP FAST!!!!!!
  139. HELP!!! Knuckle ABS and non ABS
  140. 94 VTEC shudders hard during acceleration and deceleration
  141. Wierd Idle On New Built Motor?
  142. tranny conversion
  143. info on putting an H22 head on an H23 block
  144. 92-96 Prelude Door Panels Wanted!
  145. What kind of gas mileage (actual) does the Prelude SH get?
  146. jdm h22 w/ lsd tranny
  147. normal #'s?
  148. **Pic Request** 97-01 SH Header
  149. Clutch Pedal Height - Aftermarket Master Cylinder
  150. sticky throttle
  151. type s swap
  152. 70mm TB too big?
  153. new header... new sound
  154. VAFC to a non vtec car
  155. Urgent help, oil pan fit all 92-01 h22 vtec?
  156. bucking at low rpms.....help!?!
  157. a/c
  158. Searched for Ohio Prelude Site... where is it?
  159. fuel filter?
  160. Opinion: Got repairs, how much did I get taken?
  161. Fuel pump no signal, need help
  162. h23 vtec hybrid(searched)
  163. Pic request.. ITR wheels on a 4th gen.
  164. Im tottally lost
  165. Engine Damper
  166. Compairing Sizes 205/55/15 vrs 225/50/15
  167. SRS light
  168. Goodyear Belts
  169. honing question
  170. Dohc vtec Emblem
  171. Problem with passenger power window
  172. VTEC Head Question (I don't like to search)
  173. Dyno
  174. Car wont rev past 5500 rpm
  175. ES motor mounts installed
  176. FS: 5th gen MUGEN wing w/ LED
  177. moon cuts
  178. Which Front Lip/Bumper?
  179. Exhaust!
  180. help with engine swap
  181. h22a1 bearing color question...
  182. does anyone out do h22 trannys
  183. 92 prelude piping
  184. dash and parking lights dont work...
  185. junk yard trip. but i need more
  186. CEL After some backfires!!!!?????
  187. Can i Run a 125shot safely on my h22a4?
  188. Oil Pressure light when Cornering
  189. Fluctuation of RPM due to loose AC belt
  190. I have a question
  191. Solo Performance Short Shifter
  192. D16 In a Mazda 323 hatch...Possible?
  193. alternatives to the 94-95 accord rear lip and ww
  194. installing my new headunit
  195. JDM LSD Tranny
  196. How does this sound?
  197. alarm question...
  198. H22a Euro R swap into 5th gen help
  199. Prelude DRAG RACERS....what wheels do you run?
  200. Prelude A/C Icing Up
  201. Do you think its worth selling?
  202. seized crank bolt?
  203. Recommended octane for 1996 Prelude S (sohc)?
  204. Any Seals to replace when changing timing belt/water pump?
  205. My car still in limp mode!!
  206. 5th gen. gas mileage
  207. TPS voltage question
  208. HELP! what kind of headers should in get?
  209. a "different" idle problem
  210. 98 Lude non-SH headers....
  211. There's something leaking out of the front passenger side of my 5th gen...
  212. Clutch!
  213. Requesting Rota Grid's on Prelude
  214. Fuel rail adapter
  215. TPS Question--- What would this be the cause of?
  216. installing new headunnit
  217. 92 2.3L Blown?? Swap?
  218. carpet
  219. Cat-back or muffler?
  220. Help! Looking for neuspeed springs for me prelude!
  221. DIY: 4TH Gen Prelude H23A1 AC & Alternator Belt Install
  222. 4th gen Prelude: H23a1 to H22A JDM motor Swap questions.
  223. intake vacuum box
  224. obd2 to obd1 using a h22a jdm motor in a obd2 car already search heeelllpp
  225. Where are the RMF'ers?
  226. White film over my cluster?? what is it or how to get it off???
  227. Did a compression test
  228. knocking noise i cant figure it out
  229. Prelude Fuel Pump or Other?
  230. Knock Sensor - lots of open ended threads
  231. Coolant temp senders - how many are there?
  232. 4th gen ecu
  233. Can someone post up a pic of a 3rd gen Si engine?
  234. need HELP! im doing a auto to manual swap on my prelude
  235. Got Dyno'd at Tempest but my numbers seem low
  236. should i replace tensioner at my 90k timing belt change on my h22?
  237. dent in rims
  238. Noises, huming coming from somehwere
  239. Need a good Head gasket
  240. 2001 Prelude Base Clutch repair???
  241. VTEC Oil Pressure ECU Trickery? (Euro-R in 92 Prelude P13 ECU)
  242. first gear redline @ 30 mph? si lude 95
  243. 93 prelude valve spring replacment
  244. Burning Oil
  245. DIY: 4TH Gen Prelude H23A1 Power Steering Belt Install
  246. need suspensions set up ideas
  247. vtec not engaging
  248. HEY PRECORD96
  249. I can't afford to fix my cv boot...
  250. I noobed it! - Mishifted - 9000RPM - JDM H22A - Options?
