PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Rear main seal leak
  2. bad compression?
  3. good setup for H23 vtec?
  4. What is a H22A1 motor running stock?
  5. Drag Equips on my 5th gen prelude?
  6. H22A Rebuild
  7. cost of f22 tranny?
  8. 4th gen JDM headlight owners....little help. =P
  9. H2B swap into a prelude?
  10. Honda Prelude 01-97 o2 sensor
  11. Runs upside down?
  12. Apex-i Turbo Timer - A/F values?
  13. Standard or low tension rings?
  14. need help!! please
  15. Exhaust wrap?
  16. H22a transmission cooler.
  17. Post your catch can setups
  18. 2001 prelude a or b
  19. Noisy as hell....
  20. upper balljoint replacement...
  21. Problem with the auto-tensioner adjuster nut
  22. Is the lighting relay the same as the headlight relay?
  23. oem lip kit
  24. Engine motor swap '01 Prelude SH to '99 Prelude base
  25. Automatic shift kit
  26. phearable.net ecu??
  27. 2007 H series Clutch Poll
  28. M2B4 Tranny larger than others, Which axles?
  29. Sluggish
  30. Air Conditioning problem
  31. H23 clutch and shift cable ?s
  32. fan questions did search
  33. Unsprung clutch
  34. Manifold Welding?
  35. h22 swap in sohc 93 lude please come look im so pissed need help
  36. Stock Headunit Code
  37. Problem With H23 Stock Headers
  38. Fuel pressure
  39. kteller header
  40. clutch feeling funny after installed.
  41. Engine Lift
  42. are engine harnesses interchangeable between series?
  43. Is this compatible?
  44. h22 versus h23
  45. Inspecting crank and rod bearings...... how should they look
  46. Brake Pad question
  47. Ignition switch problem ?
  48. Interior/parking lights wont light up.
  49. Degreesing tranny housing?
  50. 5th gen SH header
  51. Clogged fuel return line
  52. please analyze my custom suspension setup and tell me if I'm doing anything wrong
  53. vtec misfiring..
  54. wtb rear view mirror
  55. anyone know what this is?
  56. will this do?
  57. test pipe =backpressure??
  58. Prelude oil pan Bolts....always seeping.
  59. Where can I find Nordic Mist Metallic spray paint? 5th Generation Prelude
  60. 1992 JDM Lude, Original Dizzy No ?
  61. '93 Prelude for SALE
  62. Backfiring?
  63. oil in intercooler?
  64. VTEC timing belt tension (with autotensioner)
  65. Stock FPR's questions
  66. 4th gen steering wheel
  67. Need help identifying a part
  68. performance Radiator
  69. Spoon Sports Strut Bar 3rd gen/4th gen
  70. need help with fuel problem
  71. Lower Timing Cover bolts
  72. Who is running stock axles with over/near 300whp?
  73. IACV
  74. Stroker Kit/Turbo build
  75. Question: Can a 4th gen prelude use a 5th gen prelude power steering pump & hoses?
  76. noob question: how to make my shifter shorter?
  77. which shift boot fits my 5th gen prelude?
  78. prelude oem color?
  79. H22 oil pump
  80. small question. (did search for sure)
  81. Help with decision making on Prelude purchase.
  82. A/F Gauge (reads....sometimes?)
  83. Altenator ?s
  84. Low Beams Do Not Work, BUT High Beams Do Work
  85. lenso vpd wheels?????
  86. question about suspension
  87. help: REAR SPEAKER REMOVAL
  88. 2001 prelude tranny
  89. blue smoke on jsm motor!
  90. power chamber passwordjdm
  91. Starter motor / Alternator wiring.
  92. 97-01 Prelude 4-2-1 Header
  93. How do you remove the locknut under the alternator?
  94. Spark Plugs
  95. 'clunk' noise in rear end
  96. 4G63 cam angle sensor on a H22A?
  97. Tanabe GF210 Springs
  98. Suspension setups on 5gens
  99. gas milage help
  100. Stock keeper broken on a h22T??
  101. 91 Prelude
  102. Mugen thermostat/fan swich
  103. People with ABS on 4th gen
  104. so will this work?
  105. JDM Power Folding Mirrors
  106. h22 headers
  107. h22 and h23 head same injectors and cam gears?
  108. h22 oil pan baffling
  109. Turbo and fuel system
  110. Is it just me....
  111. throttle sticking
  112. Type-RS BOV Adjustment?
  113. Prelude Bolt On
  114. New Exhaust/cat - UK suppliers
  115. H22 aftermarket Timing Belt Auto Tensioner ?? Toda?? Anyone?
  116. Synthetic Oil (Mobil 1)
  117. Synthetic oil
  118. Need suggestions/advice
  119. anyone got skunk2 pro series stage 1 cams dyno graphs (H22A)
  120. hssa internal coil distributor
  121. 84 Prelude will not start
  122. lower ball joints
  123. H22 NA build Info needed
  124. Changing fuel filter
  125. Any way to fix this front end damaged? =(
  126. Sorry for such a noob question!!!
  127. fuel pump location? under back seat?
  128. Looking for new clutch and flywheel
  129. WHAT CAMS FOR MY EK H22?
  130. pistons options?
  131. Something Snapped
  132. Strange Question for 5th Gen Owners
  133. 4 CEL Codes, Need Help!!
  134. DeftRacing vs Seibon CF Hood
  135. H22a transmission
  136. i need chiped ecu
  137. anyone using 16x7.5 rims on 5th gen?
  138. electrical problem(s) Yay!!!!on1!!1!
  139. installed brand new clutch. dosn't work! WTF?
  140. Sparktec Motorsports international orders
  141. 4gen Rearview mirror (picture request)
  142. My 91 Si 4ws.... build started 9-12-07 ......... tons of pictures.
  143. Burning Oil
  144. Buying the right ECU for JDM h22a
  145. flywheel options?h22
  146. valet key no start car??
  147. autotranny problem
  148. trunk light on all the time.
  149. armrest options for my 92 prelude
  150. gold series pistons --any good??
  151. Idle problems...I need a refresher
  152. 5th gen surging?
  153. Idle Pissing me off!!!!!
  154. Need to know why....
  155. bolt in timing cover
  156. Auto To Sick Conversion
  157. please help me to where these parts go.
  158. take a look at my intake manifold
  159. CYP cel after advancing exhaust cam +1
  160. QUESTION-blinker/foglight
  161. Help Weird AT stock bb6 redlining at 8500 vtec kicking hard
  162. Aftermarket honda parts
  163. coilovers
  164. h22 oem type s oversized pistons.... how much are they worth?
  165. HYPERFLEX POLYURETHANE KIT FROM ENERGY
  166. How to Remove: SRS+AC Stuff on the interior
  167. Type SH ecu vs base ecu
  168. bfg dr's fitment?
  169. Nowhere to be found.
  170. 91 prelude SI
  171. Help with my engine transplant please
  172. trying to choose pistons endyn or cp pistons? turbo application.
  173. how do you install blaster ss coil
  174. Brake Problem.
  175. h22a1 to jdm h22a
  176. H22A IAB's Question/idea.
  177. exhaust question
  178. no spark or fuel
  179. H22 chipped ECU
  180. Whats the best fluids?
  181. looking to do a prelude h22 swap, questions about OBD and other problems
  182. test pipe
  183. Using a 90-93 Accord F22a1 tranny in a 92-96 Prelude
  184. accord lip on 4th gen
  185. 5th gen with roof rack?
  186. oil pump
  187. Base vs SH
  188. turbo h22a
  189. Type-SH engine but looking for a regular h22 motor
  190. Seizing brakes
  191. 3rd gen ecu codes
  192. Bringing sexy back... I mean the Accord out of retirement
  193. Throttle Body related maintenance- DIY write-up
  194. Max Speed Per Gear
  195. 5-lug conversion
  196. new ride set n i got questions...
  197. quick oil pan question
  198. what is ya opinion on crower cam shaft?
  199. under hood strut tower bushing??
  200. greddy ti-c
  201. **Searched** E-bay Throttle bodies???
  202. are all the h23 motor mounts same as h22
  203. H22 timing belt question.
  204. greddy header
  205. Apex'i HP gains
  206. removal M2U4 trans problem
  207. I need ball joints..
  208. is it possible to make a h23a vtec?
  209. Removing stock exhaust manifold with rusted bolts
  210. H22 Long Block Automatic...how can you tell
  211. FS: '92-'01 Ground Control Coilovers
  212. tuning specialists
  213. g22 hybrid no vtec?
  214. H22 spun bearing?
  215. What is the part number?? For...
  216. Someone with a 1988 prelude 2.0 si 4ws or similar
  217. Prelude Key Fob
  218. Missing CEL connector...
  219. BB6 Instrument Cluster Fuse?
  220. iac? still no clue
  221. cai installed and now strange idle
  222. Is a 4th Gen prelude header identical to 5th Gen?
  223. fog light mod
  224. JDM H22A from HMO motors. A issue/question
  225. JDM ECU
  226. fuel line to short for swap.....
  227. Tachometer Dead "Searched"
  228. Reasonable price for BB6
  229. h22 fine, sputters, dead
  230. Front ends shakes
  231. Valve Stem Oil Seals
  232. 4th Gen Lude Pic Request: Black lude. Rims: Sportmax 002 & Black Rota Slips
  233. 4WS computer
  234. need help with rear brakes
  235. 5th Gen Hesitation/Bogging Solution
  236. 92 Prelude Si with an interesting story
  237. Suspension Clunking/Squeeking... '97 Type-SH...
  238. Which OEM spring is longer/taller? Front or rear? 98 Prelude SH
  239. What does it mean?
  240. Flashing Oil Lamp Light
  241. Not running good after Cold air and exhaust upgrade.
  242. h and b series fuel rail are they the same
  243. SURGING H23A1
  244. ATTS Help Please
  245. ANY ONE HAVE THIS BOLT (AEM FUEL RAIL)
  246. IS IT WORTH FIXING UP A 97 HONDA PRELUDE (AUTOMATIC)
  247. Prelude.... forum?
  248. Stainless Braided Brake Lines, 4g
  249. Crankshaft Nut Question!
  250. Top Speed Limiter HELP!!!
