PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Intake Manifold???
  2. Need Some Advise For Fuel Not Getting To My Engine
  3. need help deciding between these two
  4. Info on 1994 Prelude
  5. 90' Prelude Si 2.1L DOHC Header?
  6. WTB 5th Gen Prelude Carbon Fiber Trunk Lid
  7. jrsc reliabitly issues?
  8. Dented Camp1320 Header
  9. h22 swap mounts
  10. Plz HELP me choose!!!Between these Two!!!!
  11. 1999 prelude SH ?s
  12. Would anyone be interested in going 169mph
  13. offsets
  14. Mods for h22a
  15. 1998 Honda Prelude
  16. Speaker positioning
  17. Other drive train setups?
  18. Rota wheels?
  19. Best place for water-temp sensor
  20. Surging idle!! help
  21. Upper Rad Hose Diameter (4th Gen)
  22. Turboing My H22
  23. i need details
  24. Going insane
  25. car just dies
  26. H22 95 prelude Slow REV and running rich
  27. Does the H22A4 have ATTS transmission?
  28. **Unsure about loss of torque in low gears**
  29. Found Some Info on our preludes, Check it out!
  30. Prelude Door Lock Actuator
  31. help anyone! new master/slave cylinder?
  32. spark plug preference?
  33. I'm not a prelude owner but I'm desperate....
  34. socal meet?
  35. Help
  36. 2 problems... one solution?
  37. want 6 speed for h22a, who can help me?
  38. 4th gen h22a clutch problem
  39. DRL light
  40. Stock prelude vtec 14.6 1/4 mile
  41. Just bought a pair of leds
  42. New help finding wheels for my racecar.
  43. Which piggyback would you get?
  44. wrist pin removal
  45. Oem m2b4 lsd into m2f4 with mfactory fd...possible?
  46. Changed clutch, now car won't start. WTF!
  47. Something Wrong and making me mad please help
  48. Emissions HELP
  49. Explanation Needed about Wheel Offset
  50. sweet h23a!!!
  51. Changing Headlights
  52. headlight wiring question
  53. 93 prelude h22 swap
  54. Aftermarket seats in a 4th gen
  55. climate control?
  56. 4th gen control arm bushings
  57. problem with new 70mm throttle body and tps sensor
  58. bore size info
  59. Turbo question
  60. no vtec no cel
  61. Picture of 4th gen lude with Sportmax 501
  62. timing marks
  63. password jdm
  64. Will rims and tires fit?
  65. Problems with my f22
  66. Vtec is back
  67. new to honda!
  68. foggy headlights?
  69. throttle surging
  70. jdm h22a swap complete (few questions)
  71. help with compression ratio
  72. 94 lude.. is the black box next to my ecu my tcu?
  73. BB6 lower control arms
  74. H22 AEM cam gears.....
  75. h22 operating temp idle
  76. Is this h22 head ok to use ?
  77. Quick o2 sensor question...
  78. 4th gen Thermostat Problem
  79. Strange sound from the back of the car
  80. 97-01 prelude engine problem
  81. Shifter Cables
  82. Blox magnetic drain plugs
  83. How good are oem axels
  84. Anyone running without the front motor mount?
  85. Honda Prelude - Engine Misfire
  86. Rear Tie Bar
  87. built short block
  88. jdm H22 rev and speed limiter
  89. Euro-r vs Type S cams???
  90. threadstone performance ic piping
  91. Swapping in a H22 Built Racing Engine... Any ideas?
  92. 97-01 Prelude control arms
  93. Door lock issues need suggestion
  94. Knock Sensor problems...again
  95. 92 lude w h22 and no CC? help
  96. which helms manual is best?
  97. Rough Idle Any Ideas?
  98. H22a4 soon want to rebuild
  99. 91 prelude questions
  100. will most h22 parts work on h23vtec
  101. H23 vtec, need Bin help
  102. car shakes when sitting still
  103. h22a injectors - different markings?
  104. National prelude meet
  105. H22 trans Q: need help ASAP
  106. Where's all the 3rd gen owners?
  107. power steering woes in aws land....help
  108. Oil Leak..
  109. Can a T2T4 LSD Unit Fit in a M2F4 Tranny?
  110. Prelude acting weird
  111. Rough idle Any ideas?
  112. Help!! Omg!!
  113. whats this worth??
  114. Rosko Racing IACV Relocation Kit (Install and Feedback)
  115. where to check CEL
  116. H to B PLate?
  117. cam help
  118. is there a stock map sensor
  119. VTEC Solenoid
  120. Need Help With ECU??? 94 Lude f22a
  121. H22a Idle Air Control Valve
  122. When I jump the service connector I get nothing
  123. E-brake light??????
  124. burnt clutch?
  125. BB6 lower control arms
  126. knock sensor
  127. need help lost of power
  128. yet another
  129. Front Spoon Strut Bar.
  130. 5 lug
  131. Convert Injen short ram air intake to full cai
  132. Oil Sending unit on SH
  133. vtec solenoid\switch housing gasket?!?!?
  134. Please help... clutch issue?
  135. Replaced VSS and still no speedo and D4 blinking????
  136. Will my 94 lude (f22a) run with fried ecu???
  137. Can I use F22 head gasket on H22 engine
  138. new headers..
  139. Exhaust Purchase Warning
  140. Alternator pully trouble
  141. flapper mod
  142. Starter spins but no start. Need a few tips. Searched
  143. Water Pump Bleed Holes Leaking
  144. Prudz 4G N20 87.25mm 11.5 comp Build
  145. tranny issues!!!
  146. Prelude door skin?
  147. Oil leak solved
  148. h22 balancer shaft question
  149. Franknstien vs G23 vs F-Bomb
  150. turn signal issues(not stupid)
  151. water leak
  152. Metal Rattling Sound
  153. What do you all think of this header?
  154. How many teeth are on H22 VSS gear?
  155. 99 Prelude EGR Valve problem
  156. auto2manual help
  157. ????S2k steering wheel????
  158. auto to manual help
  159. easy way to get wire pins out of a plug
  160. Need help on H22 starter fuse
  161. knocking noise when i turn the wheel?
  162. headlight bulbs keep burning out all the time.
  163. tuning after this
  164. problems with my CF hood & my idle
  165. new to boards
  166. Broke Timing Belt on F22B
  167. How to have FRM honed
  168. fast idle screw/Does this happen to anyone else.
  169. Gear grinding
  170. Strange clanging/ringing sound from front left side of engine bay
  171. Boosting the prelude. What to do with power steering cooler?
  172. head bolts...
  173. Quick question reguarding axles and half shafts
  174. will egr valve from H22a1 fit newer H22a4 engine?
  175. obd2 to obd1 distributor and ecu
  176. DTC Issues, help?
  177. H22 Cam intall help
  178. 2009 Tri-State NY/NJ/PA Meet
  179. f22b dohc
  180. 10k rpm h23?
  181. Oil Suggestions For H22A4
  182. Back seat
  183. Aws
  184. Need help! h22 tranny
  185. K-Mac camber kit / upper ball joint on SH
  186. Strang power lagging.. H22a
  187. BG Color codes on 4th gens come inside help please....
  188. may 3, 2009 Auto SHOW
  189. HELP! 5th gen. SH, control arm question
  190. ITBs + filtering?
  191. h23 bouncy idle
  192. H22 vtec vs. H23
  193. H22 or H23 pistons in an F23
  194. Was cruise control optional on 93-96 VTEC preludes?
  195. Failing injector cause cylinder damage??
  196. stock h22 rod strength?
  197. Foglight fuse breaks instantly
  198. SHOW is done, time for GO......h22 questions...
  199. 5th Gen Suspension
  200. radius rod removal
  201. 5th Gen radiator support replacement
  202. quick Question! Please Answer!
  203. Custom Prelude
  204. 5 lug conversion help
  205. Oil light on after new valve cover gasket
  206. 5th gen. seats in a 4th gen.
  207. pistons
  208. oil leak
  209. Can i run my 98 lude with a jdm h22a with a stock p72?
  210. H22 Help, Need experts! SOLVED!!!!!!!!
  211. OBX 02 sensor
  212. Has anyone dealt with....?
  213. Can I save this h22a1 head
  214. Yes another bouncing Idle with a twist
  215. head bolts
  216. Official H23a Vtec Info?
  217. help
  218. 2001 Honda Prelude HR to JDM H22 SIR motor swap ?
  219. 2001 prelude SH to JDM H22 SIR swap????
  220. A few build questions.
  221. How much oil does a normal H22A burn?
  222. Request ONLY links or Emails to/of h23 working basemaps please!
  223. h23 to h22 swap problems
  224. timing belt - pulley
  225. 5th gen noise starting in 1st gear
  226. Question about size wheels fitment
  227. length of wires to run OP switch and soleniod??
  228. Apexi Neo Question.
  229. SS shifter bushings
  230. Euro-R I.M. on Type-S motor question???
  231. 4th gen deletion
  232. Jdm motor swap in 5th gen
  233. brand new clutch slipping
  234. rebuilding a h22a4
  235. Serious Problem Any Ideas?
  236. Universal guage pods
  237. eliminating balance shafts
  238. DSM Injectors
  239. Hot tanking and FRM (question)
  240. Best way to increase hp/tq for under $500 (5th gen)?
  241. How not to build your H22 (blown engine motor)
  242. ultimate intake manifold
  243. some simple questions
  244. Timing belt tooth counts h22a1 vs h22a4
  245. eBay: Search Honda Prelude Parts= 0 results
  246. Brake Lamp issue!!
  247. 93 Prelude Si won't start more info inside
  248. trans doing weird things
  249. rear speakers 92 prelude
  250. Prelude info!
