- throttle plate question
- h22a open deck or closed deck?
- b20 swap
- can you take off the cc controller on the steering wheel? 92-96
- What kind of Lip Kit will fit a 92 prelude
- h22a4 missfire...
- Build on a budget? ($2000)
- 3rd Gen Prelude issues
- Doing H22a4 Rebuild... Cylinder Walls Scarred
- NITROUS (how big of a shot??)
- anyone bother to clean out the head?
- NITROUS(how big of a shot can I take?)
- warm/hot day start issues?
- Brake problems (abs)
- dynoed and tunned today
- New o2 sensor but still getting code 1
- h2b turbo water temp help Searched
- my 1991 h22a swap
- obd0 or obd1?
- 5G Prelude with F and H parts..what works?
- Will a JDM H22a crank work in a 97 SH Block?
- Identifiying TYPE S cams vs stock
- 5th gen JDM Fog lights...
- What goes here? Pic inside
- VAFC memory loss problem
- h beam vs. i beams
- oil pump leak...
- How do I remove the wheel hub?
- Anyone recognize this blocked off plug by the intake mani?
- need help doing a h22a type-S swap to 92 prelude si
- Prelude A/C nighmare-- long read but please give some advice!!!
- what is a good cat converter to use
- Problem with sleeving h22
- F20B Dizzy replacement...
- What 5th gen bumper is this?
- Any real difference between Mishimoto and Koyo radiators
- Need help with my 92 f22 prelude!
- Smog specifications for cali!!!
- H22 spring / ret. Cam profile ????
- Something every Lude owner might want to know.
- Battery Isolator in 4th gen?
- Differnt Blocks?
- obd2 h22
- 92 prelude s Need Help
- Questions - 01 PreLude
- NEED HELP! 93 prelude si H22a wont start
- damage crank pulley
- Custom Transmission Gearing Review
- Will CEL light up if Auto ECU is used on manual tranny?
- h22 type S pistons help
- colour code
- knock sensor
- HELP!!!!! 5th gen prelude with blown engine i want to rebuild. NEED SUGGESTIONS!
- alternator ?
- Where is my fast idle valve?
- insurance on a prelude
- Tightening clutch
- Prelude/H-series Transmission Codes and Ratios master-list
- egr valve on h22
- Tein s-tech and agx
- 93 bb4 4ws acting up
- Rebuild or Replace?
- vtec question
- h22a and h22 usdm
- Question about rpm sensor
- weak wiper
- H22 Build
- location of IACV
- 92 4 wheel steering? h22
- Accord Rims fit onto a Prelude
- I need an engine...
- Throttle body question
- Right kind of oils
- yes another conversion problem (EGR)
- replacing oil pan NEED HELP!
- what is needed? h23-h22?
- balance shaft removal kit pics??
- Performance Headers
- h22 with h23 manual tensioner
- have a question on hasport mounts h22 into sol
- Just finish cleaning headlights, amazing result with lot of pics...
- Final Drive
- Converting an external coil harness to fit into an internal h22a
- no vtec
- h22a vtec pressure switch HELP!!!!
- Prelude starts then dies...
- Turbo ?'s on frm h22a block? Bored with h2b want more power. Pro help only!!!
- Will a 93 prelude wheels fit a 99 integra?
- H22a Oem Parts
- transmission differences
- 4th Generation Prelude Type R Front Lip
- best obd1 ecu for h22
- Stalling coming off high RPM (skunk2 Intake)
- from H23 to JDM H22
- Prelude has been sitting all winter, what should I do before I start it?
- Is it ok to use USDM ECU on JDM TYPE S motor?
- Fuel Pump?
- DIY For Front rotors/pads?
- questions on swapping parts / dealing with insurance
- Serious problems with h22a4
- tien springs
- tein ss coilovers
- 97 Prelude sat for three months and now will not start
- Body kits
- '96 'Lude H23A JDM swap Head-Scratcher.....
- Anyone get a projector headlight system with HID 5th gen?
- crank+no start.
- anyone know what wires these are?
- i need to remove my dashboard. its urgent. can someone give advice PLEASE.
- ok i ran into a problem on my h22 swap into del sol
- Problem I need help diagnosing
- Transmission problem, please help
- loose metal noise in front suspension
- where can i find...
- headlights
- Code 67
- 2000 Prelude Transmission Problem??
- turn singal/ steering wheel not locking
- WTB random prelude parts
- Steering Rack Issues.....
- vacuum lines
- Thinking about this prelude
- DC header question
- the best head setup?
- jdm fog lights
- prelude stereo help
- stock compression ratio for h22a1?
- Cylinder Head Gasket for Honda Prelude 1981
- crack position sensor- distributor help
- 5th gen. turns off randomly while driving
- Switchin from OBD2 to OBD1 advice?
- Help with wiring JDM headlights 4th gen
- Ball Joint?
- New Prelude Questions
- Need some help opinions on which wheel bearings to get for my 5lug swapped 4th gen--
- s2k install i searched
- 3rd gen motor swap problem
- H22a Missfire, all new ignition system
- H22 timging belt Autotensioner Adjuster Bearing?
- Driver side motor mount.
- Turbo Prelude 4
- 1997 Built Prelude
- 1997 all motor build
- Oh! Frick! I think I installed my HG incorrectly?
- help with the belt and gasket.
- Climate control/heater doesn't work (5th gen)
- 92 Si - won't start, sat for 2 yrs - aftermarket sec (Lojack?)
- clutch on the mind
- Disabling Fuel Pump?
- Problems after brake job...
- Denso Universal or OE fit?
- Powerslot plus kit + other brake options
- Crank Pulley Bolt Rotation
- Little Help needed
- how strong are stock prelude (92)axels?
- center consule...
- SRS Issues
- Transmission problem!!!
- so am I screwed?
- H22 in 94 Accord oil leak!!HELP!
- manifold photo indentification
- ABS computer unplugged?
- couple 4th gen questions
- High Idle when cold but I removed the FITV
- Converting a H22a dizzy to external?
- h23 head
- Acceleration Question
- hondata s100
- Can You run a 99 prelude on a p28 ecu? With jumper harness and such
- 18" Rims on a 5th Gen
- My 5th Gen has a slight delay when accelerating!
- Bad Valve Tap
- oil leaking h22a
- ba8 stock to jdm bb4 turbo build!!!!!!!!
- Driver Side Bulkhead Ground
- h22 swap
- ac help
- Sticky valve
- 3rd Gen JDM Prelude
- H3 hid conversion
- Replacing Clutch Master Cylander - Tricks from experience?
- Map sensor wiring
- Some more high Comp. ?
- H22A4 head work: suggestions
- Black paint or other coating on inside of oil pan
- How to replace Brake Master Cylinder?
- cams for 99 prelude
- losing power
- p0441
- Passenger Side Door Window not functioning
- 5th gen swap q's. F20B ? or H23A vtec ?
- Alternator
- Turbo H22
- does the color of a wire remain constant throught the whole car?
- Clearance with +1mm valves on H22
- b18c swap
- can anyone identify this wire?
- hondata p28 with 4ws 4th gen?
- 1992 prelude vtec
- Tein HA VS. Tein Flex
- H22 W/ Chipped P72 Ecu Help !
- FAQ: How to determine tranny gear ratios without counting teeth.
- F20b-ottle, feelings and concerns.
- Side Blinkers
- 1/2 size radiator for 4th gen
- H23A1 Intake Manifold / Throttle Body Restriction
- Mahle pistons.
- H23A VTEC (blue top) running on H22A4 ecu?
- Low cylinder compression
- AC bracket-pump-block compatibility between 4g and 5g
- h22a swap with h22a4 sh ecu...has anyone got it to work?
- Timing Belt Problem...PLease Help H23 Vtec
- ECU Pin D21 and D22 - Oxygen senor Code 1
- lsd
- 2nd gen cooling fan
- car shakes when driving
- h23 crankshaft
- how can i tell what tranny i have without tag
- gt30r on stock internals
- How much are h22a dohc usdm motors worth/aka whats the going rate on them?
- h23 shakes car at idel in stationary position
- Push in clutch and car dies
- Loosing Patience Having problems Bleeding Clutch
- Turbo..
- Seafoam=amazing
- suspension Problem?
- Wiring Harness
- retrofitting a 5th gen prelude
- Loosing Patience with Dealership Parts dept. - Majestic Honda or other source better?
- Idle question?
- H22A4 crankshaft imperfections
- 96 JDM H22A Distro Options
- is this a jdm auto tranny? how do i know??
- oil pump with sensor question
- sh trans in a base
- 4th gen fogs??
- 90 Si 4WS HELP!!!
- Wiper Switch
- what other auto tranny will fit mt 5th gen?
- F22 In Prelude With No Problems?
- H23A dohc vtec?
- Question about Helms when removing trans
- power steeing???
- H22 distributor switch from obd2b to obd1
- Forbidden Short Shifter for 4th gen?
- H23VTEC build gone bad
- Clutch components-looking for solution
- 94 prelude v-tec idle issue
- 5th gen. lights dont work. HELP?
- 2 Questions: fouled O2 sensor and diagnostics
