View Full Version : Honda Prelude
- ECT Fan switch sensor and the Coolant Temp sensor
- Which clutch is recommended?
- Side marker Install wiring help
- i just bought A 98 NEED your help please
- How To: Swap Out Your Motor
- Oil viscosity question.
- windshield washer
- Antenna Removal/installation
- Crank Case MOD
- 99 Prelude SH with problems.
- Radius rods interchangeable?
- WELD wheels
- SAGGING BUMPER
- Which Tranny is MP1A?
- Wheel bearing roaring
- Need help with Clunk from front end!
- Right turn signal dont work and its not the bulb(Help!!!!!!!1
- car dies in neutral????
- H22a crankshaft
- will BB6 5Lug Suspension work on 92-95 civic
- Pulley Help.
- which exhaust looks better on our car?
- what kind of oil to use on my 92 prelude
- Prelude Tranny.
- quick question!
- AEM Cam Gear Install on 5th gen
- Best gaskets for the money
- this gasket...
- I sprayed Carb Cleaner through the Coolant Loop on my IACV
- Banjo Bolt from Mr. Gasket Fuel Rail Broke. Where can I get a replacement?
- head swap
- More ECU problems P72 P75 P06 Chipped Crapping out?
- caliper pin stuck
- need help with tdc p1399 200 prelude v-tec (base)
- Help with speed sensor problem
- question about my 88 prelude?? didnt put it in classics cause it aint lol
- Accord Lip
- wire tuck on a 5h gen how to and any problems after
- Apexi GT Spec Exhaust System
- H22a Oil Cooler Lines
- Selling my prelude (not a WTB thread)
- Distributor is really hot
- EDM parts info?
- my car wont idle
- h23 block won't turn over
- Oil Cooler Leak and... Probably Head Gasket
- Stiffer Exhaust Hangers?
- another emblem ?
- transmission problems
- Jerky Throttle
- Front sway bar bushings?
- Who makes h22 pistons 88 mm and hogh compression?
- Can get Rear Brake Calibers off! I also need help getting Rotors off front and rear!
- code 6 on my 1993 h22a... ect but i dont know what to do...i lost my Vtec... ect can be the cause?
- Camber kit poll..........Which is the best for my 95 SI?
- <~~~IAT question...need help~~~>
- IACV compatibility?
- Question for slammed ludes, breaking axles
- civic si steering wheel
- 87 Octane in the 5th gen?
- Scraping so much i feel like a lowrider...
- MFactory Oil Catch Can Group Buy (MOD Approved)
- need help with 88 lude, pretty rough, need quality info-not hanes our chiltons
- jdm h22a swap in a 97 prelude sh
- IAT question...need help
- Skunk 2 cams h22a
- how do i remove the crank from my h22?
- My battery light always appears and my revolution is not good ,my alternator is charging good and my
- 1991 NSX brakes on prelude 1997 will it fit?
- installing bellows kit onto rack and pinion?
- h22a tranny question?
- need axle help
- prelude help
- Check Engine light is on. I smell fumes.
- Exhaust/emission question
- compression loss???
- 4th gen. radiator fan stays on after car is off?
- mods for prelude???
- 94 vtec prelude timing belt install?
- Tachometer is dead
- Need help picking springs...
- Weird speedometer issue accompanied by motor surge
- Paint job opinions...
- HKS Sport Exhaust
- 90 prelude sputters
- oil leak fixed?
- need a close-up picture, searched allready
- 97 lude wont starts need help
- ECU wiring help
- Need two rear quarter panels...
- axle installation
- s2000 steering wheel in 5th gen//loose?
- Help findout what size socket i need!
- good idea or bad?
- transmission question
- HELP IS IT THE EXHAUST OR THROTTLE BODY
- JDM longblock/shortblock question
- 93 Prelude 4WS revving at idle problem
- i think its my radiator fan, wont start unless car is off.
- I have a F22b DOHC and have a bunch of questions. PLEASE HELP!!!!
- Shifter / Gear Selector Leaking
- question about changing wheel studs?
- tranny question
- Some Turbo Questions??
- 92-96 Honda Prelude Factory Options List
- ECU--Vtec Problem??
- Injectors?
- where is the best place
- exhaust question
- *2000 prelude front bumper reflectors*
- 94 prelude crankshaft pully bolt removal
- valve cover gaskets or lube
- 93-96 header vs. 97-01 header
- VSS Question
- Weird ECU Problems
- H23A not A1, where does it come from?...
- vibrant performance Exhaust (Opinions)
- Build threads. The Rules.
- my RPM needle is bouncing like crazy....why????help plzz...
- Manual Swap from old accord.
- Dizzy help
- Oil smell through vents at idle?
- H22 cams n bottom end
- H23 HEADGASKET HELP
- tie rod or axle problems?
- JRSC engine build
- Skunk 2 lowering springs?
- h22 to ek, harness trouble
- Door Chime?
- Looking for a 5th Gen prelude?
- Has anybody ever dissambled the ABS-Pump?
- Help! My Car Won't Go Into Gear
- ECU
- Ingalls Cmaber Kit #35720
- Bouncing Idle at cold start.
- Which 6.5" Speakers for my 5th gen?
- rc injector install
- turbo instructions
- How To Relocate Battery n 4th Gen
- Need Rmf header installed pics please
- Transmission help please!!
- Do I have a Stolen engine...?
- few questions regarding a engine swap.
- 4th gen OBD1 Prelude ABS(4-2 or 2-4) and CEL(10,12,14) codes
- immobilizer bypass help
- piggy back info
- Place to buy an engine
- I need wheel fitment data - Enkei RPF1 on a 5Gen
- 15x8 wheels ... what offset to run ?
- head lights
- lip
- H23 ALL MOTOR BUILD PLEASE HELP!
- Power Steering issues.....foam
- eBay Oil Catch Can?
- H23 internals max power
- how close to the end is it????
- removing cruise control
- help
- OEM clutch issues on '93 Si.
- Mods Please Help
- What is diameter of stock exhaust piping on a 92-96 prelude vtec vs s model
- making my prelude '97 obd1.
- hello
- ATTS PROBLEMS
- 97 prelude Test pipe and catback install
- N/A H22a Port and Polish, where is a good one?
- Doing a valve set on my 98' What are the measurements
- want opinion on crank pulley
- swaping out tb ? and tunning?
- H22 LSD
- I just got my Tein Flex in and my EDFC unit for the fronts says an EE
- Can i run B-series cam gears on H series?
- 2001 Prelude odd ignition assembly problem
- Burning Oil
- Whats Your WHP?
- anyone strip the threads for the slave cylinder?
- suspension problems! need help asap!!!
- need advice thrown rod?????
- IACV: code 14 w/ new p13, but not w/ p28 + uberdata???
- 98'SH Leather Seats question
- VTEC problem *SEaRCheD*
- 98' prelude help!
- Airbag / fuel pump
- EGR Vacuum Control Valve and Solenoid H22
- car overheating?
- Speedometer problems help
- 94 prelude help...!
- trunk spring removal
- quiet 3" muffler?
- how do i fix my RPM???
- F22/H23 Intake Hybrid Fuel Rail?
- more hp
- tach needle not moving, use to bounce sometimes but worked fine....possible ignitor aka igniter ?
- dc sports header piping?
- H22A OIL PUMP PLEASE HELP!?
- Oil cooler leaking, Please help!
- Black leather / red stitched interior.
- where is the oil pressure sensor (turbo)
- Brakes rubbing
- H22 with h23 crankshaft OR h23vtec
- Same partial throttle issues...
- 01 Prelude revs itself
- tensioner questions??????????????/
- Question: IACV for H23 same as IACV for H22A4 ?
- Vlang29's H23VTEC Rebuild
- Koyo radiators
- which exhaust to choose
- start up hesitation
- Best exhaust?
- 5th gen JDM bumper supports
- spark and fuel but not running
- Side view mirrors the same?
- Catalytic Converter.. needed... three way connection
- 91 prelude performance
- LoveFab h22 header
- header, body question
- pictures of your slammed 5th gen
- 01 Honda Prelude SH idle/misfire problem please help
- Coolant Fan question
- Unhooked Connectors...
- drag/street spring rates (searched)
- 5 lug swap. big brake kit.
- tein flex coilovers
- Bad Thermostat??
- Grinding
- Prelude Heating up issues?? Help
- Turbo Exhaust
- CAR is reading over Heated! :mad:
- G23 Motor
- PLEASE HELP H22 PROBLEMS
- dumb 4th gen questions ,searching didnt help me.
- 99 prelude brake light help
- In the market for a 5th Gen Finally!!!
- Labor for motor/manual swap
- removing powersteering cooler
- 4th gen turbo people help
- rmf header, civic/prelude
- shops in SO CAL that cone hone FRM sleeves
- f22 header o2 sensor extension question?
- H22A HELP!!!
- Wheres the Legend caliper canversion write up?
- Car turns off when i brake
- 92 h23 speed sensor
- ECU cut off switch, better than fuel?
- Ecu chipping...
- 5th gen mugen rears on a 4th gen
- Manual door locks won't lock.
- HELP!!! AEM TRU TIME GEAR MIXUP
- Need help with H22A Motors...
- Rim hub rings
