PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Trying to shop around before spring
  2. H23a1 auto swap to H22A1 5 spd have ?'s
  3. Door problem?
  4. Timing crankshaft 89 Prelude 2.0
  5. BLEW IT UP
  6. Calling ALL Honda Experts! Mechanics, Transmission Specialist, Electronics
  7. Replaced starter, now have fuel and spark, but will not crank.
  8. Power Steering Doesnt Work After H22 Swap
  9. Increasing Visibility at Night
  10. trying to start off on the right foot
  11. What is all needed? My F22 is gone :(
  12. PRELUDE SH SUSPENSION
  13. Japanese Prelude H22 Red Top
  14. Car will not START after sugar in tank
  15. Plastidip
  16. Send Me Your Engine Serial Number
  17. break light switch
  18. help me out with pricing my car
  19. Power windows not working
  20. popping out of gear....
  21. vtec OP switch
  22. Cam Question
  23. F/S Prelude F2 function & forum type 2 suspension 92-01
  24. I need help!please?
  25. Evo x mr wheels
  26. Lower Control Arms
  27. Prelude Acceleration Problem
  28. Just a quick question - PLEASE help!
  29. clutch or trans?
  30. ABS code for 96 Prelude Si
  31. h23 exhaust question
  32. h22a bisimoto cam gears
  33. swaps
  34. 97 prelude dies when warm/when clutch is engaged
  35. new to the scene
  36. BB2 Dash A/C/Heater Switches.
  37. 92 prelude si (for sale)
  38. For those that have added new pins to ecu's...
  39. Jdm rear bumper
  40. engine rat-tat-tat
  41. coilovers 91 prelude
  42. Belt Squeak
  43. FS: JDM BB6 Wing
  44. Rear lower balljoint 5th gen
  45. Sudden Death – I Think I have an ignition problem
  46. 4th Gen Prelude Fuel Pump install?
  47. REMOVING AXLE FROM KNUCKLE. DO I NEED TO RELEASE THE PRESSURE ON TEIN SPRING B4?
  48. Diagnose this lude *video*
  49. 215/40/17 do I need to worry about flaring?
  50. idling issues. 92 lude
  51. 1994 honda prelude problems.
  52. Heavy rain,big puddle of water in rear floor o.O?, random rough idleing, now CEL
  53. Engine Swap Help!!!
  54. H23 dizzy wiring help
  55. Tool for removing lower balljoint on '92-96 Prelude
  56. ecu reset
  57. Need Help! Trans problem
  58. TESTING WATERS: 94 FROST WHITE SI
  59. springs and retainers.
  60. Please HELP!!! Removal of front lower balljoints on 92 prelude using correct tools.
  61. Exhaust manifold question with JDM h22 motor.
  62. VTEC Brake Conversion 92 Prelude 4WS Questions
  63. dash lights out!!
  64. 97 prelude Sh Motor Problem!!
  65. idle problems
  66. cf trunk with or without oem spoiler
  67. im for f22a1
  68. prelude wont rev up
  69. Lowering an SH
  70. is it possible to
  71. new to honda tech
  72. lightweight rims
  73. Prelude Lip
  74. Electric Supercharger???
  75. How to install pins directly into the ECU harness ?
  76. Help with a hose....can't figure out where it goes.
  77. will 3rd gen prelude seats fit into eg ?
  78. hey
  79. H22 cnc'd plenum spacer and custom intakes
  80. dual walbro?
  81. Power Steering Lines (H22 vs. H23)
  82. Blue Smoke!!! need advice asap
  83. Poor traction turbo, change tire size/rim size? Any other options
  84. no compression in all cylinders
  85. ATTS not working?
  86. H22 head gasket
  87. Ebay Coilover Fix?
  88. H22a or H22a1 rocker arm wanted for hardness testing
  89. Oil Light problems PLZ HELP!!
  90. I swear looking at my manual is pointless at times.
  91. Pressure plate has broken straps...
  92. F20b....N/A or Boost?
  93. wheel hub
  94. H22a(5speed) and F20b(auto/tiptronic) interchangeable?
  95. How wire up reverse lights switch
  96. were can i sell my peakboost ramhorn manifold
  97. Hail damage and black stuff problem
  98. H22A Strength vs B-series
  99. h22a swap....are these two parts the same?
  100. Where is the vss located
  101. MAP sensor???
  102. clutch issues
  103. H22a1 timing belt tensioner questions
  104. 92 ecu help for f22-h23 swap
  105. What kind of head is this?
  106. Oil consumption issue
  107. Rotor Swap
  108. H22 timing belt lower cover.. how to remove?!
  109. 2000 Prelude
  110. 4th Gen, Bpi flowstack/K&N filter on a CAI ?
  111. Overheating
  112. Prelude Idleing funny
  113. what this cel code
  114. fuel supply problem
  115. 2000 prelude window moldings
  116. Sohc solenoid on h22?
  117. 1996 Prelude Radiator replacement steps?
  118. Cylinder 1 misfire
  119. **WANTED** 4th gen black hood!!!!
  120. 94 Prelude Alarm Install
  121. h22 spool valve
  122. My ABS Doesnt Work
  123. Rough Idle
  124. NEED AC delete belt - 6 rib.
  125. Jumping RPM Guage
  126. Prelude died at a light, then turned on 1 hr later
  127. HELP!!! Cant keep H22 running
  128. em racing bb6 c-pillar bar into bb4!?!
  129. upper control arm
  130. hmmmm h23 head f22 block
  131. Long term is not compensating.
  132. 98 Prelude has trouble starting in cold weather.
  133. headgasket
  134. opinion on lude intakes?
  135. I have a 92 prelude automatic and want to install h22
  136. LCD TV?!?!
  137. My Vtec..
  138. Is 100km/h@3000 rpm in 5th sounds like stock gearing for 4gen?
  139. carbon fiber trunk badly oxidized on edges tried many options
  140. Clutch Master Cylinder
  141. :(
  142. Hard wiring the Heater Switch.
  143. ..:: WANTED TO BUY ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Oct/Nov 2010
  144. ..::: FOR SALE ONLY :::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Dec 2010
  145. '97 Prelude's odometer light dims from time to time?
  146. What size are euro r h22A fuel injectors?
  147. H22 Timing Belt Tensioner Gave Out
  148. 1988 prelude s questions
  149. Checking Clutch?
  150. Wobbly crank pulley
  151. lowering my lude...
  152. obd1 jdm h22a odd misfire rpm needle goes crazy
  153. car dies while driving
  154. Will this ECU get the car started?
  155. VTEC Woes, oh man.
  156. h22 not starting?
  157. New to honda-tech
  158. Intake resonator removal
  159. bb2 h22a1 swap trade for 96 ls jdm b20 vtec swap??
  160. CAI 4th gen on 5th gen
  161. no vtec....=(
  162. 94 Prelude S H22 Swap Ideas And Questions
  163. Function and form coils
  164. F22 Gargling, Not starting?!?!
  165. Prelude is making noise when I accelerate
  166. Burning Oil
  167. Cold start
  168. H22A idles at high rpm? (video)
  169. Part # for fuel rail spacer
  170. need help
  171. Help. Battery light comes on when vtec hits.
  172. Blown out ECU
  173. Oil i'n radiator!!??!!?!
  174. h22 or f20b? which tranny should i get?
  175. H22 Feel's Header
  176. transmission question
  177. H22a4 turbo build questions
  178. H22 throttle body
  179. 17x8 50 offset wheels for a 5th gen prelude
  180. Rack and pinion
  181. Fuel pressure regulator soleoind question?
  182. Need some quick help
  183. JDM H22A OBDII Swap - No Spark?
  184. buying a 92 lude 300 yes or no
  185. 93 Prelude F20
  186. HOW TO REMOVE BOLT FROM HARMONIC BALANCER PULLEY
  187. How do I remove the harmonic balancer bolt?
  188. h22a no vtec power..
  189. Tint Upper Half Of stock 5th gen Tail lights instead of lower(red portion)
  190. turn off cel
  191. vtec not working right???
  192. h22a4 oil leak prob.
  193. 5th gen prelude front wheel bearing socket size??
  194. "Ebay" turbo kits
  195. Hey questions about Battery relocation.
  196. Bought gen 4 lude cheap with h22a having issues
  197. Rear balance shaft seized...
  198. 4th gen getting some love on a video game site
  199. H22A heater hose location
  200. Stock h22 build
  201. 4th gen engine swap
  202. Blower motor resistor location on a 99 Prelude?
  203. 2 base sh rims with tires
  204. water pump leaking coolant?
  205. Stupid H22 Timing Belt Tensioner!!!!!
  206. Door locks going nuts, goes on and off randomly
  207. 4th gen for 5th trade?
  208. new here
  209. scaed to prime oil pump
  210. Just bought a prelude
  211. IACV and FICV help
  212. Fixing a Gen 4 Prelude
  213. Which Ingalls camber kit for 2-2.5 inch drop on prelude
  214. HELP with 0-60 times in different gears
  215. 3rd gen prelude
  216. 98 prelude dies at idle please help me!!
  217. Is there ANY difference between SH model upper stream 02 sensor with the Base model??
  218. 4g all weather floor mats
  219. Leaking coolant =[
  220. H22a Help
  221. In need of bb4 jdm fog lights!
  222. idle,vtec, and speed gauge problem please HELP!!!!
  223. 95 prelude H22A1 to H22A engine Problem
  224. 98 prelude blows white smoke on takeoff
  225. reverse indiglo gauge install
  226. No Power in Driverīs door help!!! 5th gen.
  227. H22 Valve Adjusting?
  228. 97 sh prelude f22 transmission can it be done
  229. will a 31x12x4 intercooler fit a 5th gen prelude
  230. Oil light flash
  231. Prelude Sunroof
  232. primary 02
  233. 4040 Proportioning valve for 92 SI
  234. 92 prelude headlight problem
  235. looking for headers
  236. h22a4 vtec
  237. Transmission Help - New Prelude Owner
  238. jdm cluster to a 5th gen base usdm prelude
  239. Prelude/Accord Lips
  240. Sunroof conversion
  241. 91 Honda Prelude B20A- Rough Idle, Wont Rev Past 3000K
  242. Project ALL MOTOR: because racecar
  243. CAD drawings?
  244. removing timing belt pulley to change woodruff key
  245. What are the symptoms of a bad pressure plate?
  246. Door light switch
  247. acl bearing question
  248. help
  249. Need feedback on forsale 2001 prelude, good buy?
  250. Sloppy Steering
