PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 [171] 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. ATTS issues
  2. gauges?
  3. Valve cover gasket fixed!
  4. DarkBB4 posting: blown head gasket?
  5. Will it all go in there?
  6. h22/ h23 injectors
  7. 94 Prelude Starting problem
  8. MY DEAd h22a
  9. Quick but important H22 oil pan question
  10. 1985 GT-S Corolla with S2000 engine swap for sale
  11. Skunk2 H22 Intake Manifold Is A Bust!!!
  12. Thinking of ditching my 275hp allmotor for a turbo set up. whatcha think?
  13. Hollowed Out my Cat and now my exhaust sounds like crap
  14. Slow in the corners... :-(
  15. HI IM NEW
  16. 3rd gen prelude AC compressor problem
  17. I opened the IAC valve and some liquid squarted out!
  18. Prelude Pulley Kit Questions
  19. got my flywheel put in today... (review)
  20. stock shocks w/ coilover sleeves?
  21. Need Help! H22 Knocking! Video Footage!
  22. Is custom make cat-back exhaust 2.5 good enough at mufflershop?
  23. H23 Reddish Belts W/ Tiny Cracks
  24. How to tell if it's an LSD tranny
  25. Reassembly and break in? Tips??
  26. stalling low rpm's? sometimes?! help!
  27. Transmission jerk question
  28. 1997 PRELUDE Auto Trans. NOT starting after 12+ hours of sitting. Got spark, got fuel on 3 plugs Ple
  29. Just a couple of Q's... Header/Alt
  30. squeeking in the motor
  31. Failed emissions - Mechanic says 'intake vacuum leak'
  32. need sometin quiet
  33. NEUSPEED race springs and STOCK springs and stuff!!!
  34. Only 2 weeks and I broke my luda....dammit!
  35. h22a Ecu + Fmu + Missing Link on a f22
  36. bought another lude slightly overheating
  37. recommendations..
  38. Installed Autometer gauge..doesnt seem to work??
  39. Launching a 97 prelude!
  40. freaking exhaust problems
  41. TAS Full CF 5th Gen Lude In SuperStreet TAS
  42. gear fell off...
  43. how can you find out what year your h22 is if you dont know
  44. weak, short first gear?
  45. prelude windshield wiper
  46. need advice on an 88 prelude
  47. H22A4 oil pump
  48. 93 prelude problem?!?!
  49. Anyone know how to do a COMPRESSION and LEAK DOWN test? 97 Prelude SS
  50. banned
  51. Syncro numbers for gears on 96 Prelude VTEC
  52. 93 prelude gas cap/lid
  53. Dudes and there bikes..
  54. quick motor question
  55. Need some help
  56. Whats wrong with my car!
  57. OBD2 P72 ECU
  58. quick h22 timming question....
  59. www.moates.net
  60. Will an SI header fit on an S? (4th Gen)
  61. can an exhaust from a jdm h22a fit a usdm f22
  62. 2001 prelude (base) helms...anyone have a .PDF
  63. New Carbon Fiber H22 Intake Manifold available
  64. Motor left smoking... Sad day.
  65. How much for a H22A4 engine and tranny(US)version
  66. location of a/c drain line 89 prelude
  67. 4g speakers. someone please answer this
  68. Silencing A Very loud exhaust *searched*
  69. 3.0 v tech in prelude any way at all
  70. torque specs on exhaust header
  71. h22a4 valve adjustment...searched
  72. Im stumped - Solid compressio, no blow-by - why am I still burning oil?
  73. adjusting idle screw
  74. Cornering - E-Brake light
  75. What are possible causes for retarded timing?
  76. Hard to get into 3rd and 5th
  77. Help! Motor Swap... turning to bad. Need help!
  78. h22a1; Needs more high end power, what to do?
  79. dc low tie bar on 93 prelude si 4ws
  80. VSS - What's its purpose?
  81. help with 4th gen. part name to find replacement
  82. Air--Fuel
  83. 4th gen prelude emblem
  84. 98 base hesitating (Already searched) this might be different
  85. running temperature
  86. Anyone looking for Mugen parts or JDM parts?
  87. question on the Actice torque transfer system
  88. CV joint
  89. compressing auto tensioner
  90. How much for a H22AS type S engine and tranny
  91. 86 Si PGM-FI light
  92. Removing Emblems
  93. Engine builders....ACL Bearings for my h22
  94. 30-1010 in bb6??
  95. Type S gears in a Base prelude tranny. Possible??
  96. How tough is the paint match for Nordic Mist on a 97?
  97. Skunk2 + HG Query
  98. AEM Big Brake Kit
  99. Tanabe Sustec coilovers=super duper harsh bouncy
  100. not real, but will perform?
  101. Question about slamming a 5th gen
  102. clutch slave replacement
  103. help wit vtec jdm h22a
  104. 200 Prelude Radio Removal
  105. HELP! buying 01 prelude.... DSMcrossover
  106. lsd question?????????
  107. WWRS and Accord type-r front
  108. What is the best turbo setup for a 4th gen
  109. relay location question
  110. jdm or usdm which would you use???
  111. i wish i had vtech
  112. EGR Valve/Port Question
  113. OOO this is hotTT...
  114. Bleeding clutch problem
  115. type-s piston?
  116. 93 prelude fuel problem
  117. exhaust setup
  118. oil pressure gauge..defi or blitz?
  119. Help!! car wont start
  120. H22 Spoolin Performance Manifold
  121. AutoMeter Pro Shift Lite question
  122. Fuel vapor-lock problem?
  123. Helms manual
  124. no vtec when hot...
  125. JUN type-2R + other parts total price
  126. Intake manifold
  127. Turbo Luders
  128. water temp wont go up
  129. SHORT RAM vs CAI
  130. too Rich? bad Spark? WTF is wrong!!
  131. 89 Si, What belt to remove AC?
  132. BB What???
  133. Typ-S cams into my 94 h22a in my Accord
  134. Collector mod for a DC
  135. 4th gen gas tank anti-siphon?
  136. 4Th Gen come with a OEM alarm system? How I stop it
  137. T belt brand?
  138. # cam caps - h22
  139. tail lights? gauge lights?? PLEASE HELP
  140. problems with h22a
  141. H22 STILL sputters and spitts from exhaust??
  142. aem fuel rail
  143. WTB: OBD2 OBDII P13 ECU !!
  144. changing my sunroof to a moon roof
  145. 93 prelude fuel pump prelude
  146. compression test done...
  147. Daily Driver
  148. value of prelude shell? value with jdm h22
  149. installing a rear view
  150. 4th Gen JDM 194 side bulb replacement...Do I really ahve to drop the bumper again?
  151. rod & main bearing ?
  152. Neuspeed Anti-Sway Bar
  153. F20B injector flowrating (cc)?
  154. fan help
  155. PCV Part Number
  156. IM Gasket and Euro R IM
  157. How long will my 94 auto tranny last?
  158. h23a1 swapped h22a
  159. H22 auto tensioner failed
  160. Having problems starting my 1997 Prelude after 1+ days of not driving?? System running lean? Full in
  161. 1997 Prelude is overheating after 10 minutes!? Also, system is running lean?
  162. Do you have a 1997-2001 Prelude with a BAD TRANSMISSION? Read this! Very important!
  163. 2point6 headed for 11's... ALL MOTOR
  164. VTEC Solenoid - H22A
  165. Picture request: 5th gen with gun metal rims (preferably slipstreams)
  166. i keep seeing bb# what does that mean? newb question
  167. oil leaking onto headers..HELP!
  168. removing rear LCA prob
  169. Windshield replacement: Spend extra for OEM?
  170. High temp paint
  171. h 22 a problems
  172. Steering question
  173. Question for those who Parted out
  174. Need help guys, sad story, prelude down :( hopefully not totalled
  175. H23A1 ?!?!?!??!
  176. Bad coolant leak Mysteriously stops... HELP
  177. Mis-Fire Problems, help!?
  178. Mounting Bracets
  179. EM Racing C-Pillar Bar
  180. what clutch should i put in my prelude its turbo i look around 500-600whp
  181. fuses blown when turn signal is used..HELP!!
  182. Running rich?
  183. Leather RSX [front] seats bolt in my 98' Lude?
  184. unorthodox racing pulley belt size help
  185. can you use a h23a1 start on a h22
  186. Manual Conversion help!!!
  187. Type SH used Civic Si/NSX shift knob?
  188. M2A4 or M2B4
  189. Taking off the head
  190. 92 h23 ecu code
  191. 4th gen differences between h23 and h22? help?
  192. noob with question???
  193. aem tru power pulleys
  194. 4WS Update
  195. wierd niose from under the hood
  196. T-Pros header??? anyone heard of them?
  197. 3rd isnt grabbing... H E L P ! ! !
  198. random oil burning
  199. wanted to make sure...
  200. 4th gen lip kit help
  201. h22 to f22 5th gear swap help...
  202. need help with steering wheel please
  203. Is it LSD or not. Conversion HELP
  204. car wont start... guessing alternator problem... please take a look
  205. Car keeps stalling
  206. thinking about buying new rims...need some info
  207. Megan Header - Ebay
  208. Vibrating Crank Pully!
  209. 2001 prelude with RSX rims
  210. Someone please help me with audio!
  211. JDM P13 ECU Problem
  212. Engine/exhaust sounds different after valve adjustment (H22)...
  213. I have a short!
  214. what (if anything) to replace with timing belt/water pump for 90k?
  215. guage lights
  216. ECU??
  217. problem pulling engine & trans
  218. Problem with clutch master cylinder and Transmission ?'s
  219. code 36 on jdm P13 ecu (Traction control) how to disable??
  220. Good Alternators?
  221. Short Ram Intake vs. Cold Air
  222. CTR steering wheel
  223. Dash kit for 4th gen prelude, or just a wiring harness?
  224. 2001 prelude XM Radio Install
  225. city-lights on 92-96 prelude(bb4)
  226. how to take steerin wheel off
  227. Jun p13 ecu's (Vetec pulls very hard)?
  228. exhaust and header
  229. speaker fitment. (alpine type r); skunk2 coilovers
  230. electric supercharger?????
  231. fuel pump ?
  232. h22a4 good spot to mount external coil?
  233. Plumbing up EACV to a H22a4
  234. driving normal, punch it, hard power, no power, hard power. fuel pump?
  235. ITBs for H22A? Where?
  236. vafc 2 kpa reading
  237. White gauge faces???
  238. Brake Pads and Lines
  239. Clicking,clanking rattling noise
  240. WWRS and huge Exhuast??
  241. takin dash out
  242. Oil is not getting to the head
  243. 4th gen JDM Prelude pcd conversion???
  244. Air conditioning problem
  245. oil light blinking
  246. kyb vs koni
  247. weird switch.....
  248. Dry sump?
  249. Why does my clutch pedal vibrates a little?
  250. Dyno: SMSP vs Mugen
