PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. high end header?
  2. Proper way to wire the 3rd LED brake light?
  3. Power steering grease....?
  4. which intake will fit?
  5. Best place(s) to buy new/used H22 motors?
  6. Rear shocks changed and still swerving severely.
  7. Power Door Locks 92 S' swapped with 95 Si Doors
  8. Short shift kit
  9. which camber kit to go with tein ss coilovers?
  10. problem with ebay headlights
  11. Do I need new valve seals? What else??
  12. Problem: Code 15(Ignition Output Signal)
  13. H22A4 sparkplug/wire issue
  14. rear main seal
  15. 91 Prelude Guages and Tailight problems
  16. H23VTEC build
  17. Rear suspension on 93 prelude HELP
  18. Gas Gauge issues help.... Can't get 15 gallons out of my tank
  19. Mushy gears.....Whats the problem??
  20. 94 prelude spark&fuel&air... wont crank
  21. 98 type sh abs acting oddly
  22. stroked h22 turbo selecetion
  23. after motor swap engine wont start
  24. Need electrical help on my 94 prelude!!
  25. 93 prelude wont start after being driven
  26. skunk 2 I.M and aem fuel rail prob.
  27. Holy gas mileage...
  28. 1994 Lude Eletrical probelem Help!
  29. thermal valve problem?
  30. chirped bone stock h23!
  31. deleting a/c need help with belt
  32. 94 prelude tach problem
  33. code 9 problem after putting a built head on
  34. tire/rim problems
  35. 93 Prelude gas tank
  36. GReddy Evo2 Cat-back Exhaust - Acceleration video
  37. Photos and video of mine
  38. where do collision repair shops get there parts?
  39. Unusual trouble with '95 Prelude
  40. H22a Hesitation Problem
  41. Pr3lude down. ;(
  42. H22A4 Problem
  43. Need help with car problem!
  44. Help me out! :D
  45. which ecu should i use
  46. IAB assistance
  47. 4th gen JTC short shifter issue (pics)
  48. 96 obd2 h23a1 swap for a obd2 h23a
  49. 96 si non vtec prewired for vtec?
  50. h23a hydro to manual tension swap
  51. 93 prelude si alternator wont stay tight
  52. flooding motor with gas
  53. 98 prelude lighting problem
  54. Timing Belt Noise?
  55. 1991 Honda Prelude Noise
  56. 5sp transmision does not want to go into gear
  57. For what it's worth, Non-VTEC owners---GUDE
  58. basic crankshaft question..
  59. Function Form Not Low Enough
  60. H23 Prelude Overheating
  61. 93 4ws
  62. Header question
  63. AC Problems
  64. Any 2nd Gen Prelude NASA or SCCA Racers Out There?
  65. WILL THESE WHEELS FIT MY 5TH GEN WITHOUT SPACERS??
  66. Brake pads, yellowstuff or hp plus?
  67. Injector questions...
  68. 1991 Honda Prelude A/C doesn't blow cold.
  69. What Honda Should i get?
  70. valve cover
  71. FYI something 4th gen I ran across the other day
  72. 01 Prelude SH ATTS light on
  73. 97 Prelude H22A4 Type S pistons???
  74. Got a Quick Question i hope?
  75. alignment specs (to those who autocross/road race)
  76. 96 H23 to H22A4 Nightmare. Need QUICK help!
  77. h22a and h22a1
  78. Electrical snags
  79. H23a Vtec Swap... or H22a4 rebuild w/goodies?
  80. question about oem sideskirts
  81. New H22A - Ate a timing belt
  82. Pics of My first HPDE at Homestead Track
  83. 5mt prelude tranny fluid suggestions?
  84. Effects of a Valve adjustment if done wrong
  85. 5th Gen, Loose Shifter no 1st or reverse PT.2
  86. Suggest me a crank pulley
  87. Heating & Cooling
  88. Swapping 5th gen dash into a 4th gen?
  89. Still no spark...looking to buy wire harness
  90. 5th gen.. running a little different, and wont start right when engine cold.
  91. h22a4 into 4th gen
  92. DIY fixes that cost nothing (Free Repairs)
  93. anyone have interior?
  94. I need fuel pump help
  95. BB1 4ws issues
  96. 90 Prelude si
  97. Which cap for TD-60u distributor?
  98. swaybars and lower control arms ?
  99. 5th Gen Prelude - Intermediate Half Shaft - Bent
  100. Reuse mahle pistonrings in new block?
  101. HELP/ADVICE 95 PRELUDE QUESTION
  102. no Vtec
  103. My 1990 Prelude won't start... can you help?
  104. cooling system/temp sensor help...
  105. 60mph to 0 in 1.2 seconds
  106. jdm h22 race questions
  107. axle question
  108. 95 Prelude Speedo Incorrect
  109. Need to find ASAP
  110. Obd2-obd1 conversion question
  111. 4th Gen Prelude Green Interior????
  112. 91 honda prelude
  113. New Prelude project owner. Just saying hi and getting some ideas.
  114. looking for a dashboard!
  115. One more forum can't hurt... Hello!
  116. Coolant sensor plug(s)? ? ?
  117. B20 rebuild or gaskets
  118. iacv issue
  119. 92 Prelude Electrical Problems
  120. 5th gen clutch pedal?
  121. How do you remove the climate control unit?
  122. spare key? learn key?
  123. Which cold air intake is good for my 93 lude?
  124. suspension help!!!
  125. 1993 sr prelude axel issue
  126. Need Help Deciding with Turbo Prelude- H23vtec or H22/F22
  127. PLEASE HELP CLUTCH PROBLEM!!
  128. having a problem with bb6
  129. gauge cluster lights not working properly
  130. Will this distributer setup work?
  131. A custom clutch line?
  132. Exhaust/Injector Help
  133. 93 Prelude steering rack question
  134. 5th gen....
  135. Obd2 p13 ecu h22
  136. Identify H22 Cams
  137. 99 Prelude Sh. Cylinder 2 misfire.
  138. Clicking sound in 88 Prelude transaxle
  139. IACV wtf.
  140. Blah.. i cant tell how fast im going....
  141. a good header for slammed preludes??
  142. Still a swerving problem with 1993 prelude? Help please
  143. Prelude Vtec Calipers leaking from fully closed bleeder screws.
  144. Slow build of Black 92 Si 5spd
  145. Head Light Malfunction, Please help
  146. 92-96 prelude interior
  147. possible trade for my prelude
  148. JDM T2T4 tranny
  149. h22a4 block with a2 head?
  150. 2000 prelude cel still on
  151. Injector Marking Help
  152. Need advice on 93 Prelude
  153. help! misfire
  154. name that part
  155. H22a Turbo - intermittent oil pressure light
  156. Best way to troubleshoot real clunk?
  157. what size injectors to use??
  158. Car idling funny, jerking hard when changing gears\letting off throttle :( d16y8
  159. looking for a climate control write up yes ive searched
  160. civic swapped jdm h22a
  161. N/A rebuild - what headgasket?
  162. bb4-bb6 question
  163. rear passenger seatbelt leaks after rain!!!
  164. New JDM H22A Problem. Help!
  165. JDM H22A Engine noise
  166. weird tapping h22
  167. 94 lude idle prob
  168. Clunk/Tapping noise at sweet spot in clutch. What is it?
  169. question for all of you with vented hoods
  170. TEIN HA question....height adjustment
  171. Idel Issue???
  172. h22a1 auto tensioner
  173. New Car..What you guys think?
  174. Got a set of 92 shocks,what other cars can they fit on??
  175. H22A S-Spec Info
  176. looking for a good 3in exhaust
  177. 5 lug swap
  178. f22b DOHC parts issues
  179. ► WANTED TO BUY ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Jun/July 2011
  180. ► FOR SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Jun/July 2011
  181. 96 Prelude Crank sensor issues
  182. 93 prelude SI killswitch
  183. just another mp1a ? easy help?!
  184. 2k idle need help
  185. 90-97 accord spring/coilovers
  186. h22a type s
  187. Moan-buzzing sound on start up. Help!
  188. 4th Gen with JDM H22 trap speeds?
  189. km/h to mph converter box location
  190. M2A4 non LSD and M2B4 with LSD
  191. how much horse power can a stock h22a4 block handle
  192. Fast Oil Burning
  193. 97 5th Gen Loose Shifter no 1st or reverse
  194. Who wants to earn a $grand, help!
  195. Loud metal sounding grind / squeek w/ steering and susp
  196. 2001 Prelude.. idles wild.. need help
  197. 1991 Vehicle Sensor PLZ HELP..
  198. Autotechnic vs golden eagle intake manifolds
  199. new 5th gen, questions
  200. dashboard removal
  201. Lost Keys, New immobilizer?
  202. 2000 prelude
  203. help vafc2???
  204. Where to buy fuel injectors?!?!
  205. High Flow Cat and/or Test Pipe Questions...
  206. Please Help! slow to start/power loss
  207. rpm goes up EG h22a turbo
  208. 3rd Gen Prelude balljoints
  209. H22A Auto :(
  210. Gearbox Trouble
  211. What clutch do u recommend
  212. 95 vtec h22a running to rich
  213. 4th gen ECT guage
  214. F22 catback on H22 downpipe
  215. Passenger side headlights not coming on
  216. stock H22 sleeves
  217. 95 h23 not running right
  218. any fabrication for accord lip
  219. Stereo 5th gen. WTF
  220. front motor mount
  221. Not Understanding ABS Codes
  222. ARP Head Studs Question
  223. Valve cover specific questions
  224. 4th gen to 5th gen front subframe/steering rack swap (w/ pics)
  225. Some one help me Asap please
  226. Should rear tires lock: Hand Break
  227. Another ball joint question on 93 prelude
  228. crank bolt issues
  229. 97 prelude- head problem
  230. h22 TDC not lining up pefectly
  231. auto tensioner oil or brake fluid? HELP
  232. 4th gen spyder side skirt install help...
  233. HID kits....
  234. Distributor questions
  235. yay
  236. Suspension confirmation
  237. intermittent no start
  238. Fixed fuel line, now won't start.
  239. Pistons back in my block question.
  240. Idle Problems with my 97 SH!!! HELP!!
  241. 5th Gen won't start
  242. 1993 Honda prelude JDM h22A vtec front lower ball joints
  243. 4th gen OEM alarm system manual
  244. What lube for sunroof tracks?
  245. Prelude V ABS problem
  246. h22 swap question(s)
  247. Unique Problems... ECU, Stalling, Idle, etc...
  248. h22a1 burning massive oil and failed smog....looking for advice
  249. h22 Intake Manifold question
  250. Any1 know the torque specs for an H22A flexplate?
