View Full Version : Honda Prelude
- Prelude Synchro
- Clutch for a 1989 prelude.
- Looking for pics of 92-96 Prelude with Progress springs
- 5th Gen owners with OBD 1, running a P13 ECU?
- Pnp and complete new valve trane on a lude...
- wheel size poll
- Camber kit install problems...
- H22 vs. H23 Tranny
- OT: Todd and Mike, We support you all the way!
- is the mugen kit (4th gen) built with headlight covers?
- Golden Eagle block(h23) help please
- ordering rims, which offset to get?
- is there a difference between obd1 and obd2 ecu for prelude?
- i gotta question for u prelude guys...
- Valve clearance Prelude SI '94 II
- going to get a 92-96 prelude..which model?
- 1992 Prelude (4ws) to JDM H22a (HELP)
- I know this doesn't belong here, but cut me some slack guys...
- H22A Engine weight?
- Cam gears install....
- highest compression ratio on closed deck H22?
- Its that time again (auto-x pics)
- clutchmaster flywheel w piolot bearing??
- Walboro Fuel Pump
- replacing a wheel stud..??
- WTB::: sh sides and rear in premium pearl white?? Anyone have them lyin around?
- injector size reccomendation
- Does Honda (or aftermarket) make a seal/ gasket kit that comes with all the rebuild stuff??
- Smoothing out the lude.
- oh crap....knock knock...whos there...i dont know....
- JDM B20 FS.. Wondering if anyone would be Interested?
- Coil-Over question
- I NEED ALL Parts to Make H23(Vtec) and to build motor up
- Does a Y2k prelude use resistors for the injectors?
- Does anyone know
- Nitto 450 vs. Toyo FZ4??? QUICK... tell me which is better
- crankshaft pulley bolt?
- 94 lude problems?
- Wheel weight question
- Car won't start after motor swap! Please help me out. Car has been out for a month!
- Accord Euro R parts...
- anyone live in northern cali that is sellin their lude?
- Anyone in here a Honda certified mechanic, or equivalent?
- 4g/5g Springs
- body kits galore... pleaze post pics of 5th gens with body kits
- i finally made it to the dyno
- FS: custom fiberglass 4g sub enclosure
- Windshield wiper arm stripped!! How do I fix it?
- P72 plug n play in prelude?
- car dont wanna start
- What kind of power on a 8psi H23?
- SS lude question...
- Could somebody please help me out
- Does Samco make hoses for h23's?
- Suspension Question
- Hiro lip for 4th Gen??
- Anyone one have additional info on Type S and Sir?
- 5FT Gen CF Greddy Lip Without The Logo
- Need a wiring diagram for an 88 prelude(stereo)
- Open deck or closed
- Which is better?
- Yokohama A520 qeustion
- Anyone know what lip this is for the 4th Gen?
- Need H23 Head!!!
- b17 crank in a b16a
- WTB: 4g. prelude exhaust
- who should I go through to get parts to rebuild engine?
- can someone CARFAX my car?
- Injectors needed.......
- Weight of stock 92-96 lude?
- cheapest but best way to lower?
- LUDESLEEP <---------------- sell me stuff!
- crank shaft help
- Oversized valves
- User info...
- fs tien upper pillowball mounts 92+
- Hey guys, I'm looking for someone who has aftermarket sideskirts they want to get rid of...
- Stiffer motor mounts
- Stay with Tanbe's Coilvoers or Koni with Ground Control ? ( I want stiffer ride)
- Bought my JDM climate control...woohoo!
- WTT. 1991 Manual Accord Ex trans for H22 or H23 trans.
- best wheel..
- H22 Trannies
- Desperate Search!!!!!!!!!
- Carsound high flow cat..
- 4th gen stuff for sale..
- just finished my turbo kit
- turning off VTEC
- Putting Out Feelers: Looking For Trade For mY lude
- Brake Parts Groupbuy
- post pics of 5g with OEM or type S front lips
- HP limits of stock H22.
- Need Helms Manual lookup!!asap
- USDM H22A4 <---> JDM H22A ( crank sensor )
- Whats the compression suppose to be on built h23???
- Gude Cams?
- NX ?
- high idle problem
- P/S line question on h22a
- Auto to Manual tensioner, search isn't working.....need directions! ;)
- wtb: oem headlights bb6 lude
- Need suspension bushings for 3rd gen
- wheel camber
- whats it worth???
- best all around model?????
- Starting problems..
- front grill
- nr gauges???
- Need Suspension Help
- Bedding in Pads
- Koni yellows (Defective)???
- Crower regrinds for h23
- Axxis Ultimate Pads
- where can i get one of those things under the cdplayer?
- Alright listen here todd 94....I like it in the bunghole
- Koni Yellows (confused)...need help quick
- 4th gen EL gauge cluster, is this one?
- Quad carbs in the 5th gen...
- New to board -- Question about 97 Prelude...
- any body selling s wing for 5th gen black (97)
- timing belt
- prelude S B20a3 pistons
- Is this a good buy>?
- E Brake Light Coming On...PLEASE HELP!
- Who said preludes are slow? New best ET :)
- Crankshaft Bearing
- Any shops? Resleeving
- Pics of 4G. exhaust setups
- 87/88 Bodykit
- Does anyone have a wiring diagram for 3g Preludes online?
- looking for prelude cluster
- Why 92+ Octane?
- stock exhaust diameter (2001)
- might replace front bumper, thinking of mugen (style)
- 4th gen SPOON IMITATION LIP..... ebay?!?!
- h23 f max turbo kit for sale
- New Prelude Driver
- Distributor Squeeking?
- Removed power steering belt....
- f-max turbo kit ? where from
- Need a 4g Helms manual, or shop manual.
- Need Help w/ lowering my GF's Prelude
- whats my horse
- How do I take out the Corner Lense?? (4th gen)
- sagaprelude: post pics of your car please
- nuespeed bar ???
- compression ratio of B20A5?
- looking for stock 4th gen lights
- prelude drinking oil
- Help cannot shift
- WTB New oil pump/water pump
- euro R manifold question
- oil pressure problem? built h23 turbo
- I need help figuring out what is wrong with my car please.
- 93 Prelude timing belt breaks while driving.
- invader bodykit
- wheres the cheapest place 2 get this helms?
- 3 wires for vtec
- Help please!
- 4th Gen Hood HURRY
- H22 ECU Codes 34 and 36? What the hell are these?
- Can I swap a 98 Type SH H22 into my 92 Lude Si??
- Shift Light wiring, where to hook up rpm signal?
- ECU codes, what are these codes?
- Drilling/Tapping Block for Gauges
- CAI Design Question
- what ever happened to prelude meets in knoxville tn??
- predlude 93 AEM CAI
- MUGEN style body kits for 5th gen... i need a urethane one
- HARD CORE tech question... H22a Tranny related, Please HELP
- just a quick question
- Value Sports bodykit for bb6
- H22A Intake Manifold
- Getting insurance $ for wheels....what should I get???
- chassis code for JDM Prelude Type S/SiR??
- Bad Day At the Track
- 88 Prelude Si - Worth it?
- off set for a prelude 5th gen
- :( sad day at the dyno (dyno pic)
- reccomended tires??
- Official Thread on T-Shirts for the Prelude. Need everyone to post in here.
- how many here run the H22 w/ their IAB open all the time?
- New ROTA SUBZERO's...Help on what tires and tire size to get......
- Pics of My 5Gen Lude finally..
- sprayin the f22b
- 4th gen shortshifter
- fuel problems
- 4th Gen Interior Sale With PICS
- Tire size questions:)
- f*ckin ricers are spreading....
- Torque Specs needed!!
- whats next?
- 5th gen lude brake question...
- H22A 02 Sensor Help
- I hate my brakes!
- ODBII H22 head on an ODBI JDM H22 block
- Gates belt # for no A/C on 4th gen?
- Best Suspension Set Up for 5th Gen
- Some questions about the H22A head for port & polish job...
- V-AFC settings on 99 BB6 jdm H22a
- Clutch Talk
- Funny smell from my car.
- Got into an accident in the Prelude tonight....*pics*
- 5 lug conversion on a 4th gen
- Major problems
- what to do to a h22 to keep up with the new Evo and STi?
- 4th gen lude turbo
- WTF happend to my oil pan?
- Vtec Problems???????
- exhaust weight..
- F22 DOHC bolt ons? Can I use H23s?
- got a few toys in today that you guys might like...
- b20
- timing belt tensioner
- quick question... about 1/4 time of 92 prelude with a newer vtec prelude engine swap?
- JDM 4G Tanabe Sustec Suspension?
- ***My Old baby and my NEW BABY!!
- DC 4th gen header fit on a 5th gen?
- Good plugs to run with nitrous
- 2001 prelude wheel pattern (thanks )
- Attn: KMS Luder
- golden eagel make intake manifold for the h23
- Whats the difference between....
- 3g engine swaps...
- Fuel cut-off
- OMFG nobody ever order from group5motorsports
- A/C question
- F22 DOHC or back with the H23?
- need to hit 8k
- F22 or back with the H23?
- Fidanza Or JUN Ultra Lightweight Flywheels
- JDM Type S Piston
- JDM Piston stats
- what is the OD piping size of DC header or Hotshot header (h22a)
- Wanted information on Twin turbo on a 4 Cylinder.
- H23 ecu
- any one of you have a Random Tech cat converter on your 5g lude?
- FS: H22 Skunk2 Adjustable Cam Gears
- Exhaust
- check engine light
- people are so dumb!
- Dyno results.
- just got home from the track
- Can anyone vouch for PreIudeSI????
- Measurements on ARP head studs...help
- QUICK>>Diagnose my timing belt problem--sways side to side and....
- silencer??
- Anyone Who Has Replaced their 6 X9 Sub in a 4th Gen Please Help
- lude v.s. rsx-s
