PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 [247] 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. TANABE SUPER HYPER MEDALLION
  2. How do you take off a shift boot for 5th gen Prelude??
  3. Tire recommendations?
  4. Ok guys selling my fifth gen for a fourth possibly. Need to know what this cars jun power is capabl
  5. New prelude owner
  6. shipping a head and block
  7. 5th gen prelude
  8. Same old problem... (Long post)
  9. vafc problem or hi flow carsound cat???
  10. 84-87 Chrome Parts
  11. NGK ignition wires
  12. Which Car
  13. Question for those of you with JDM Fogs
  14. question bout jacks
  15. Video of me Auto-Xing
  16. How bad it this??
  17. 4th gen hid ideas + opinions?
  18. colder plugs for higher compression?
  19. Tranny Problems
  20. People who had their springs from the clutch disk fall out.
  21. Need Pics Of Timing Belt Side Of H22!
  22. Cooling plate for the lude
  23. Couple Things FS/FT.
  24. Tranny Mount
  25. SAFCII Wiring for bb2
  26. 4 th gen h22 turbo harsh shift engagement
  27. Friends wants to turbo his lude...
  28. intake manifold choice
  29. Opinions on this set up - 2.3 H22
  30. obd1 slips?
  31. What is wrong with Unorthodox Racing (UR) crank pulleys ?
  32. 87 lude motor?
  33. Problem with Tach...needle reads 3000Rpm and doing 80mph in 5th gear (4th gen SI)
  34. Prelude maintenance
  35. H23 ECU Pin Out Please Help (SEARECHED)
  36. Smoke from Valve cover breather???
  37. Top Speed??
  38. will 5th gen abs sensors work with a 4th gen?
  39. what is a good price to pay for a h22a lsd tranny?
  40. Can i talk this dealer down to 10k cash? Link with details, and pics of car inside.
  41. how to reset ECU on the 5th gen lude?
  42. Upgraded Fuel Pump, Do I Need a VAFC or Adj. FPR?
  43. Speedo ?
  44. High Idle H22
  45. What can I do to a stock 97 intake manifold
  46. PRELUDE FINAL DRIVE
  47. P39 ECU
  48. SUB install..
  49. what are ways to tell? What are block differences in jdm and usdm h22a shortblocks?
  50. how to identify a h22a LSD tranny
  51. 87 prelude si question
  52. jdm h22 swap...is this normal?! help! pics
  53. Spun Bearing on H23a
  54. Lock assembly in steering column
  55. h23 turbo valvetrain
  56. radiator question..
  57. why did you guys ended up driving a 4th gen?
  58. screwed again. possible vacuum leak
  59. Where can i find a 92-96 spoon upper rear tie bar????
  60. What are some symptoms of bent valves?
  61. Prelude Swap
  62. DSDSF
  63. Best header for boost? Mugen?
  64. Confused about using forged pistons in h22
  65. oem decals
  66. Wheres the timing mark on this fidenza...
  67. where can i get replacement ball joints?
  68. Spoiler Fade...how can i restore its shine?
  69. Squishy Brakes
  70. 5th gen Shock Knock - How do you fix it?
  71. Help me guys, I can't find....
  72. 3rd gen A/C compressor question
  73. Calling out all Honda know-it-alls!!!
  74. Prelude Pics
  75. testing if stuff is busted
  76. lug pattren
  77. 5th gen prelude optional body kit
  78. Whats the tension or slack for the H22 timing belt?
  79. Wiper Arm??
  80. new catalytic converter
  81. Injector removal/install?
  82. Can a h23 turbo pass a emmission test?
  83. opinions on auto tensioner replacement
  84. How would 15"x6" wheels do on a prelude?
  85. Zeal Function, Buddy Club coilovers for 4th gen.
  86. Narrowban O2 sensor hookup
  87. Well it's official: Head Gasket
  88. Having E Brake light problem
  89. h22a wiring qustions (already searched)
  90. Removing/Installing Crank Pulley.....who's done it?
  91. What's the wire hanging from the back of my roof headliner??
  92. 92-96 Prelude Strut Bar *Searched*
  93. question about the sport shift tranny
  94. 5th Gen: SH or base model exhaust...whats the difference?
  95. timing belt/ auto tensioner
  96. 97 and up prelude knock sensor is it 2 wire?
  97. H22a swap
  98. Another turn signal problem!
  99. Spring Question
  100. help with vibration when in reverse!
  101. i need a little suggestions
  102. 4th gen prelude concept car interior pic (repost?)
  103. hey guys i need help
  104. 97 Prelude Trans swap- Auto to 5 speed
  105. Any junkyards with a 5th gen in it around you guys?
  106. Door Connector Pin Removal?
  107. GsR or vtec prelude...no bias comments plzz
  108. car will not start
  109. cruise control
  110. Can i use a 97+ helms on an h22a1
  111. Good place to purchase h22?
  112. windshield wiper relay
  113. Buying 5th gen Prelude
  114. VTEC pressure wire gauge.
  115. Will the h22a4 SH head fit the base model
  116. any one using mustang throttlebodies on the r 2.2?
  117. is there any thing wrong with the Vtec in a prelude???
  118. ANYONe in the BAY AREA?
  119. 5th Gen Automatic Information
  120. Interior Question: Rear Deck Metal Loops (covered in plastic)
  121. Clutch problem
  122. 85 2.0 Carb Need new engine
  123. no more trial user! please :(
  124. engine won't idle right
  125. which one is better SH or the base model
  126. Ordered from HondaAutomotiveParts.com, feedback....
  127. The beast is overheating....
  128. What's the safe boost for stock?
  129. 5th gen prelude SH suspension
  130. Prelude news....
  131. Tire size recommendation/check
  132. Who does tuning in the Greenville, SC area????
  133. Recommend me a good All Season tire for a 99 Prelude
  134. I have come to the prelude world!
  135. CAR IDLES HIGH
  136. What model should I get S or SH
  137. How to stop my antena from working??
  138. Replacement for the Lude
  139. SAFC/SAFC II universal?
  140. 1 realIn need of gasket kit IGA any good
  141. new 1/8th mile slip ....H22 turbo hatch with full interior 8.05 @ 10 psi
  142. how to get EGR valve off...?
  143. need help asap engine problems
  144. what engine for 88 lude
  145. fitting a Greddy header to a 5th gen
  146. Crower H23 cams are done!
  147. Can CAI and Headers cause problems with the oxygen sensor?
  148. Car Troubles.. any idea?
  149. Best ECU/program to use on H22a?
  150. What spec T3/T04e should I get?
  151. compression test results.....weird?
  152. WTB: M2F4 Transmission
  153. do all honda 5 bolt wheels have the same spacing?
  154. Size of nut when adjusting valves...
  155. 95 Accord wheels on a 88 Lude
  156. 92-96 Prelude JDM One Piece Headlights
  157. Is 10mm ign. wires too big?
  158. coilovers; skunk2 or GC?
  159. Racing Sparco NT-R's 17x7 norcal
  160. K&N filter fxxked up my lude
  161. steering lag...?
  162. Fog Light problems??
  163. FS: h23 & h22 internals and parts
  164. What a good looking quiet muffler?
  165. threw code 12
  166. reasons for voltage regulator going out?
  167. cheap way to build
  168. oil pressure problem
  169. how to check codes?
  170. Having probs with drivers side JDM low beam....
  171. power steering to manual rack
  172. water pump failure?
  173. 5th gen blues... car does't start...but i bet you never heard of THIS reason!
  174. AnR Header Vs. Mugen
  175. H22 or H23 Prelude
  176. 5zigen Twin Mode Clutch
  177. expert advice please
  178. Venom 400
  179. Targa Top prelude
  180. Any one heard of Microtech?
  181. Maintance and Tune up
  182. got some KYB's for sale
  183. Stock heat sheild w/ aftermarket header. (h22a)
  184. Honda Challenge
  185. prelude 4ws swap
  186. Camber Kit for SH
  187. Double check me.....oil pressure gauge/sender install
  188. fuel filter
  189. Centrifugal SC for h23
  190. 1986 Prelude 2.0Si Turbo Manifold
  191. Built-in oil cooler
  192. Exhaust manifold-Exhaust system
  193. Door is open, keys are out of ignition, car is still beeping?!
  194. 4ws problems
  195. do i want the obd2 bypass on while tuning the vafc and how about after the dyno tuning?
  196. max CR on type-S pistons before melting them? (all motor)
  197. any other dynos of smsp headers?? isnt anyone cursious???
  198. h22a engine wiring harness
  199. Calculating Compression.....Head Volume of Prelude?
  200. how to tell it is an SH
  201. 4th gen 3 gauge pillar pods....
  202. ECU location in 99 prelude?
  203. EVAC wire/conector colors (b16a2 swap in 93 EG)
  204. Hit And Run
  205. Where to find Honda Crankshaft tool.....
  206. (PIC REQUEST) rims on cbm
  207. Brake caliper problems
  208. LSD Question
  209. where do you guys find these drawings
  210. just failed smog test
  211. What does it mean if your turbo glows red?
  212. Every one Please Help !! Check Engine Light On After VAFC II Installed.
  213. window issues.. passengerside
  214. Emergency brake
  215. sportshift tranny got problem, please help.
  216. Installing Ground Wire Kit
  217. knocking problem on 2000 prelude, need help...
  218. S2000 pistons on H22 blocks
  219. V-afc wiring diagrams
  220. auto tranny gone and got f#ck by warranty people!!!!!!!!
  221. help, h22a compression numbers
  222. quick ? about tranny
  223. how to install msd on h22a4 EG?
  224. GARAGE SALE!!! Selling off H22 parts, Turbo parts and more - Mod Approved
  225. jackson racing supercharger on a 4th gen
  226. What does the new AutoTensioner kit bring? ASAP!
  227. 2nd gen light problem
  228. How good are this coilovers?
  229. Adjusting secondaries?
  230. for all you 4th gen lovers like myself!! hahah :-)
  231. H22a4 Mis-shift ***HELP***
  232. Need pic of Fresco Blue Pearl 4th gen with CF hood
  233. Indiglo gauges
  234. RS Type V-tec controller
  235. Is this the cam seal that always leaks?
  236. rattle that consistently happens at about 2800 rpm
  237. 4th Gen Transmission Fluid Flush
  238. White Smoke
  239. Wheel/ Offset question for '98 Prelude
  240. Can I use these injectors on my lude?
  241. 5th gen with 15inch wheels
  242. Lighter Power Fuse
  243. pressure plate to flywheel
  244. Doing the bottom end:
  245. iab question for p28 h22?
  246. Drag3 Fuel Pump On My Nitrous Prelude?
  247. why am i still a trial user?
  248. tanabe sway bars
  249. whats the c/r on h22a1? help
  250. Damn Ticking at Idle, valve adj done many times, lma's fine...
