View Full Version : Honda Prelude
- b20a5 in a 91 prelude si
- o2 sensor same for 00prelude @ 99civic?
- cold air diameter
- just bought 94 prelude si need exhaust help
- squeaky noises
- 22Need Help Fast Prelude Wont Start
- Do all models have airbags?
- I searched for it and all i got was the #'s for an h23, I need an H22a, .. help please
- Need Help WIth 99 Lude O2 Sensors
- ?> Can I use my H23 injectors on my H22 Swap?
- What Brand Tires and Sizes to get.
- Motor purchase?
- 92-96 Prelude OEM foglight question
- Question about Prelude Wheels
- Mugen wins at Mid-Ohio!
- I/E cam clearance spec?
- Switch ECU's? Potential benifits
- Philips 4300k HID kit, on sale!!!
- No boost aaaarghhh!!!!
- Engine making tapping noises
- Prelude rims
- Help!! How to take paint off a CF hood
- More POWER
- firewall
- H22A4 injectors conversion in a swap
- Moroso crank pully tool...will it fit H23
- 94 Prelude Si making noises while turning. Help please!
- need help instaling lowering coilovers.........fast.....
- Custom ECU work
- emergency: Need EGR valve for 98 prelude up base model. can it be fix or clean?
- H22 VTEC Gears in a H23 NON-VTEC Tranny
- neuspeed n2 header... anybody tried it??
- Mugen MF 10s finally got them..
- Balancer shaft vibrating?
- Looking at a '93 Prelude Si in Chicago
- Since this seems to be the place to show off headers...
- Sleeving the H22A1
- Check out Sept. GRM...
- Well the Skunk 2 Intake Mani for the SOHC is now out.. H22 next??
- HEADER and SPRINGS swap
- about timing gears, bent valves, and compression
- Kinda Off Topic: The Prelude just got a sister ;)
- Fluidyne Radiator Question
- crank pulley wobbling???
- 3rd gear problems
- Thinking of getting a prelude, 92-95??
- HP Racing 5th Gen Header on 4th Gen?
- h23 tps sensor question??
- Revhard stage II installed...
- sleeves and pistons. machining?
- Balance Shaft Removal
- Lowering Heights
- skunk 2 cam gears vs AEM cam gears(poll)
- koni yellow questionz
- turbo reliability?
- Wearing in clutch
- is there a 4th gen prelude 4ws??????
- 94 Prelude Si Makes Racking noise when turning the streeing wheel...Please HELP!!!
- antenna mast removal
- h22a1 manual into prelude f22 automatic
- how to take shocks/struts off?????
- my coils on my coilover sleeves are stuck! what to do?
- Engine help needed.
- what to do with 4th gen Si?
- H23 Compression Test numbers
- Passenger side window switch.
- Help w/ TDC - changing my timing belt right now
- Dimming of lights when idled
- 5th gen o2 sensor wiring
- UR or AEM Pullies???
- tire tech help
- Throttle bodies.
- rubbing
- Elkins911 1/4 Mile: UPDATE :
- Engine Swap???
- Mallory hyfire IV and MSD blaster coil ss install write up
- anyone with HPs?
- gasket problems?
- about valves and timing,....
- 5th gear Grinds!! what do i do?
- vtec kick in sooner
- OBDII to OBDI beneficial?
- VTEC is very very weak
- Just bought a 1990 Prelude Si.
- 12 seconds
- computer?
- Lost reverse
- Automatic H22 same as 5speed H22 ???
- Big problem with Golden Eagle Oil Sandwich Adapter
- Car not running right!
- Where to get parts in the UK?
- How to put turn signals into this bumper?
- maximum bore on a resleeved H22
- what is the MOST you can mill an h22 head, and how to calulate the increase in compression
- Todd Weld
- removing 5th gen paneling?
- 97 prelude acting VERY weird
- shocks/springs
- h23 header
- Differences between USDM and JDM (non-TypeS) H22 cams?
- S Coupe and swappage
- 97 , AEM CAI (1/4??)
- Difference
- Does the A20 have potential?-
- Side markers for 5 gen
- got ez ?
- leaking floorboards
- Type-S header
- JDM One Pieces
- b21 Vtec
- Good sleaves for n h22
- Are H22 and F23 crank pulley interchangable?
- Max wheel size on 4WS?
- piston to valve clearances
- 1/4 mile traps.
- Je Pistons Releasing new pistons for h22a? No sleeves required.
- Question about Headers
- has anyone tried this?
- h1 harness
- Stock Piston Ring End Gap?
- stock exhaust diameter V.S. Greddy Evo diameter
- First time in the Prelude Forum, whatcha think?
- OK> Keeping all the lude people updated!!!!! H22 Swap!
- Typical Friday at the shop....
- Rim opinions...
- FS: 93 Prelude Wheels w/ almost New tires
- 93 lude $4500 obo (jdm h22a vtec)
- Anyone know a good site to buy H.I.D. kits from?
- 99 lude
- how much is my ride worth???
- boosting.....leaking oil, please help
- Wanting to buy: Prelude. Need help
- wiring jdm headlights
- Fidanza Info for you fidanza owners:)
- ?'s about h22 head gasket
- What types of shocks/springs work with SH?
- just got exhaust, help with install
- need help finding exhaust for h23
- FS 4th gen interior
- eagle rod power handling?
- i need a obd2 p13 pinout wiring diagram
- NEED TO SELL
- h23 oil squirter install
- A/C Compressor
- Acura CL swap
- How much would a shell cost
- Headers
- Type S engine swap
- help im a jackass Car and fueling with my 4th gen hybrid? a putting noise getting on nerves
- diff. ring gear question
- Cooling fan won't shut off, wassup? & WTB H23 5 speed (5th synchros out)
- Type S 5th Gen Prelude
- Installing msd blaster ss coil
- Prelude 92-96 POD>? Ok, I gotta ask> Where do you find one?
- Edmonton Prelude Club - Install Day & BBQ
- Power Steering Pump
- Insulate the Intake?
- Suspension set up question
- ABS Brake bleeding
- Need h22/h23 manifold...
- Coil-over install
- How wide are the stock 5th gen rims?
- wtb: need a h22a auto prelude tcu
- Paint the exterior for ? $$$
- Do I have a LSD
- Which Springs???
- Custom NOS dry system
- is it true that HID's are going to become illegal?(tried searching)(and sorry its off topic!)
- Car runs like crap! Cant idle, nitrous sucks....arg!
- S2000 Antenna conversion on 4th gen Prelude?
- Supercharged H23??
- MSD Wires
- *Posted with permission* :::::Upcoming Gainesville Prelude Meet:::::
- power locks
- Hand brake warning Light
- SOMETHINGS F-ED UP with my car.
- I'm bored: how much would it cost to customize doors ?
- Fidanza flywheel
- H22A or H23?!?!
- OEM foglights.
- A Case of Transmission Mis-identity...
- I'm Looking for a JDM Type S Intake
- rads
- Official Alarm Install On 4th Gens
- Need advise ASAP!
- 3rd Generation Prelude help?
- Looking for 95 prelude SI helms service manual
- Where to put hood pins?
- Atts: boosting....
- My prelude got hit,parting out
- Prelude Headlight Bulbs
- Response from skunk about h22 manifold.
- 4th or 5th gen prelude??
- Alarm install for 4th Gens
- 4th gen Exhuast comparo?
- V-AFC important!
- Low Gas Light..How to test?
- prelude
- Removing Front Bumper on 92-96?
- new to forums please help??
- would 19 inch c2's rub?
- Why does my car feel MUCH SLOWER after installing my AEM CAI...
- oil light problem
- I need measurments
- turbonetics turbo ....
- Please help! Replacing water pump on 88 prelude
- info needed on h23 to h22 swap
- Ebay Camber Kits - any good?
- blance shaft thought....possibly talked about before?
- CF Lip for 5th gen.
- Are the h22 and h23 DOHC prelude headers the same????
- straight pipe exhaust
- powerd steering fluid Problems
- Headlight Eyebrows???
- H23 burning/losing oil?!
- h23 questions/problems
- how to put a timeing belt on a h23a? like line up the marks an stuff chilton SUCKS
- Fidanza 11lb vs 8lb?
- PreludeForum.com <--- Guess who the admin is? APRIL of the deceased HPOA
- Wuzupper>? New > Kewl site>95 prelude here
- installed front springs...problems with the rear
- Replacement bulbs. Need help.
- need help bad
- Weird sound coming from engine during low rpms...Help app.
- OMG PRELUDE TYPE R (ebay fun)
- Need help Installing tach in a 99 prelude?
- I have a couple of questions pretty stupid of me to ask and all bout fuel system.
- Testing Ignitor?
- Does rim size matter?
- new...looking for a lude...
- Scheduled maintenance on lude?
- h23/h22 head components interchangable???
- New to Prelude forum and have some questions...
- what would happen if you installed your balance shafts w/out the bearing?!
- 93 si prelude / h22 install, whats needed ?
- Rear Bumper
- **** Best INTAKE for 4th GEN PRELUDE??
- anyone goin to Dallas this weekend for NHRA
- need advice on setup for boost
- What exhaust should i get?
- stupid question
- Intermediate Shaft questions
- Are they the same ones?
- ? on installing p13
- e-brake light triggering abs light
- *********ep civic guy w/ a question for all you prelude guys.******
- Rattle on the way down... any ideas?
- is the H23 closed or open deck?
- exhaust flow rates
- What do you guys think of this little tool?
