View Full Version : Honda Prelude
- what engine comes in the preludes
- need help after pulling 4ws code...
- Neuspeed Sport Spring Install
- so my gas light went on about 30 miles ago. Nearest cheap gas station is 10 miles away.
- AC / Alternator belt tension (5th gen)
- removal of abs 4th gen
- Compeition Flywheel for H22 any good?
- blacktrax ecs
- Accord rear lip
- 95-96 VTEC front map light compatible w/ 92-94 models?
- 88 Prelude Si
- anyone know how many quarts of tranny fluid a M2b4 tranny take?
- Searching for a couple 3rd Gen parts (not found in SEARCH)
- f22 tensioner swap?
- Best Header for Bolt-Ons Only :: Already Searched
- ecm questions
- Hondata S300 Questions?
- sorry this is vague, but what should I do??
- Best prelude in the prelude pics section
- AEM intake
- Headlight Power Supply *need answear ASAP*
- i need to get a h22 crank pulley stock
- where can u find the hiro lip??
- removing butterfly from Intame manifold good or bad?
- what is ATTS?
- Steering shakes between 90-110 kph
- never heard of this problem...
- Can I use 4th generation conversion on a 5th generation vehicle?
- For 5th gens: what is the diff between a Type-S and Type-SH ?
- fuel filter
- AEM V2 intake
- FIBER RE-INFORCED sleves h22a
- wiring vtec on a p28...
- ***Speed Shop Grand Opening Event*** Orlando, Fl.
- Help... vacuum leak
- can i remove the secondary box under the h22 IM?
- Just did a baseline run today...need opinions...
- help with electrical problem!
- Brembo blank Rotors ?
- Clutch booster or clutch master clyinder problem
- Map Sensor differnce on 93 h22a1 vs. 94 h23a ASAP!
- How to install Piston rings?
- h22a swap
- Dc2R Seats in 99 Lude?
- f22 h23 franken honda
- aem tru time cam gears vs. skunk2 cam gears
- which lip - accord 95 type R or accord 95 Mugen style
- Prelude NOx Too High
- wheel hop!!!!!
- Need a Knock Sensor--Trade VTEC Solenoid for it
- High RPM at 74 mph on highway (5th gen lude)
- engine vibrations = bad balance shafts???
- 5th Gen Paint Color
- raditor support housing
- f22b distributor
- reputable site ? http://www.customautotrim.com/
- Reinstalling Head tips and pointers also Rear Balance Shaft Question
- Noob question: common problem with 4th gen prelude
- Loud Knocking noise
- transmission question, help please
- H22A Compression 180/270/270/180, What is up?
- can the starter bend valves?
- F22 Vtec
- something slipping ?
- tornado exhuast
- oil pump?
- getting into reverse is getting diffiult
- Octane requirement of stock 95 H22A1
- Knocking/thumping in engine bay petal area
- higher speed power loss
- Has Anyone tried this Mod? Would this work for my idle issues?
- anyone have pics of a 5th gen with a targa top or even a 4th gen
- 93 lude question
- Cobalt Lude uber rare??????
- crank nose bolt
- Ignition column problem.......wtf? (searched)
- WTB: The following things below all for a H22
- PCV Valve: Do I need an OEM one?
- change up for a 1995 civic dx
- Type-S Piston Installation (Honing and Boring)
- Sisters 95 Prelude SE having tranny problems, could use advice
- Please Help!
- shuddering when I first start pulling out of the driveway
- which headlight bulb fits on a 99 prelude
- supercharging my lude
- Will an F22 bottem end work with a h22a head?
- FS: Greddy E-manage
- KONIG TRAFFIX
- sportline-pro kit mix
- New timing belt - change also the pulleys?
- Does anyone have a link or info on how to pull the OEM head unit in a 5th gen?
- Service engine light. Will not reset HELP!!!
- stock or skunk2
- relocating 4WS computer 4 rear upper strut bar
- came across a 3rd gen prelude Si today.
- where are all the prelude?
- 97-98 / 99-01 Color Difference
- Engine problems
- Door doesnt look!
- 1g DSM Turbo Prelude problems
- no v-tec and 6500 rev limit
- Anyone have a pic of their 4th Gen with racing seats installed?
- squeeking while accelerating
- oil pump replacement...how to?
- 89 Prelude engine swap...need help
- is there any way to check your oil pump
- Price to pay for obd2 prelude swap
- Installing konis, what else can I upgrade/replace??
- f20/h22 oil pump (searched already)
- what heads are sompatiable with a b20a3 block
- Will 15" wheels fit with NSX calipers on stock rotors?
- Tightening belts
- Installed new FD gears LSD, and more. (pics) (review)
- motor shoping
- Converting to Alcohol
- Socket size for the oil pressure sender?
- h23 motor ?
- push button start
- TPS info needed
- 92 Master Window Switch Problem!
- Pressure steering hose on 91 B20A1
- changing timing belt and water pump
- 4th Gen/5th Gen Brake Question
- 92 prelude lowering or coils
- turbo kit for h23?
- Whats your preferance on engines?????
- electrical a/f control... i hope someone knows their circuits
- h22 mounting question...
- RS-R Down Springs....Whos running them??? I've Searched.
- auto shifting
- 1/4 mile 4th gen h22
- 15) Ignition Output Signal - Missing or defective ignition output signal ????? need help
- tie rod ?
- Accord rear lip
- Fidanza short shifter adaptor for bb6?
- Pic Request!!
- would i blow the bottom end out of my 93 prelude si if i stuck a h22 head on it?
- what performance chip?
- removing the mmud flaps
- hey guys need some help..if u could
- LOOKING FOR 94-96 CABLE LINKAGE
- 99 prelude vs 02 rsx-s
- ecu location in 92 prelude
- what is a really clean looking body kit???
- Distributor
- Quick H23/F22 Question
- please post pics of your 5th gen Prelude with Roll bar/Roll cage/Harness Bar?
- tein or eibach
- base mod or SH mod
- highway stalling 60+ mph
- No ABS on the Prelude S series?
- Do i have to upgrade my injectors?
- post if you have a 5th gen with no p/s or abs
- Need help to make my prelude light.
- 97 Prelude won't always start
- G4 big brake kit
- Tanabe DTM? searched
- skunk2 TB
- any h22a or f22b specialist here?(about the hybride engine)
- Spitfire plugs are bad on jdm h22A
- what do you guys think?
- Nitrous Kit
- 4ws problems please help!
- Extending O2 sensor wires?
- Interesting Transmission Problem, Lost Three Gears. Any Ideas?
- MF10 0n a 5th gen?
- 1992 prelude si 4ws????????
- jacobs nitrous mastermind
- upgrades to my prelude?
- Trick to Install Accessory Belts?
- Any 5th gens running Ksport coilovers??
- for sale
- 3rd gen, check engine light
- automatic transmission, want to swap to manual transmission
- thermo housing ground
- best intake for my car
- Slicks
- who has a v-afc
- Gauge cluster, tail lights, day time running lights, and fogs dont work.
- wont turn over
- do you have to completely remove the axle to get intermediate shaft out
- VTEC Controller
- another "car won't start" thread. i need help
- 95 JDM H22A Fuel Pressure???
- rad hoses for h22 civic EG
- Nos + Vafc how to make it work?
- moonroof rattle...
- Camshaft Question
- searched, can't find anything.. sway bars that work w/ 4ws
- half rad install
- Best spark plugs, wires?
- Which black paint to get?
- Anyone running this ?
- MTF Refill
- megan exhaust
- h23 mated with f22 tranny
- Chamber or Straight flow design?
- World Sport modification
- Running your Prelude on Alternative Fuel..
- replacing headlight bulbs
- Lexus headlights
- H22a1 complete harness shifter cables stock mounts
- RSR Catback Installed.......Worth Every Penny. 5thGen
- the mother of all break jobs
- Injectors for Turbo lude
- Turn signal not working on left side! Help Me!
- apexi ws cat-back, worth it for mild steel?
- which exhaust is best for my prelude
- AC belt question
- B-series combos... already searched
- carbon fiber hood?
- Any overseas guys have Honda's TSC ???
- What is the next step?
- Right size rims
- how wide can I go on rims on a 5th gen?
- electrical problem need help???
- anyone know the proper clutch pedal engagement point and free play on 97 prelude?
- what offset to go with when buying MF10 17x7 for a 5th gen?
- f22b ngk wires
- 98 prelude car bog
- Rota Slipstreams on a 97 prelude?
- OEM fornt lip?
- whats the diffrence
- Stange power loss?
- tech question. brake lamp?
- Help understanding shifter
- Anyone want/need a set of stock 4th gen springs and dampers?(NOT A FOR SALE POST!!!)
- Exhaust no cat ?
- P14 question
- Why you shouldn't buy eBay CF Hoods..... :( Pics coming soon
- Gas gauge not working
- 1997 Prelude Projectors
- Any sugestions on wheels
- clutch weight variation?
- ecu code 1259 vtec
- Opinions on tire size
- a/c removal
- low tech brake light question - please help
- 92 prelude cold idle problem
- pte gt35-61s for h22?
- Whats a good clutch - I searched !!
- Apexi ws2 and power intake?
- Need advise on which car to keep!!!!
- Knock sensor trouble. *searched*
- Azure bluegreen or britany bluegreen??
- ignition (recall parts just replaced)
- Instructions for installing greddy turbo??
- Test pipe difference with a turbo car?
- Hondata Head gasket for boosting any good?
- difference in dash wire harness between base and SH?
