- 98 vs 00 tranny
- will 2lb/rim more make THAT big of a difference?
- obd2-obd1 egr cel. using a skunk2 harness?
- check light on at 50k miles????
- injector size
- 4g prelude i/h/e combo
- en car won't start.........need help or opinions.......
- s-afc 97 prelude
- Check engine light on. CODE 45???
- Electric supercharger??
- specs on switch for fog lights
- 4th Gen bumper removal?
- valve cover gasket and parts install
- what next
- Prelude rear window wiper
- reverse lock-out
- Brake light comes on when shifting fast??
- Black Housing 1 Piece Headlights, good price...
- 3M Windo-Weld = Good
- dash warning lights
- Need h22 help
- stock axles
- 92-96 VS 97-01
- Drilled or Slotted Rotors????
- h22a gonna be boosted ???
- what year is this prelude and how can you tell?
- Shoudl i replace balance shaft bearings
- gude products
- Gearing issue?
- 92 si rpm ????????
- What to do
- where can i get an lsd
- Valve Adjustment Specs
- Trouble when turning - Help
- H22 catch can?
- how are H&R's?
- Searching for an engine...
- what gear do you use when dyno-tuning?
- worth my time?
- Fuel pump whistle
- I really need a helms!!!
- 6th Gen Lude ??
- nooB ?
- DC Sports Header 93-96 vs. 97+
- Skunk 2 Intake Manifold
- prelude motor mounts
- H22a4 block identification
- mugen twin loop
- Basic bolt ons and...
- Unknown sensor on h22a
- My 1986 1.8L prelude wont run???
- do SOHC headers fit H22's?
- installin camshafts, autozone castrol lube ok??
- Throttle body & JRSC
- broken o2 sensor?
- ATTS - 5Gen Lude Turbo
- JRSC Intercooler
- Limited Slip Differential
- prelude wont start?
- what to do?
- -?INJECTORS?-
- AWD PRELUDE?
- is there a differnt between auto and manuals cam lobes for h22a
- For everyone who is running JRSC
- What do I need to rev my h22a1 to 8k??
- 5th gen front seats in a 4th gen
- P13 ecu chip stock
- does anyone know where i can get all the parts for a turbo
- what is this part???
- Injen RD intake?
- Stupid Question!
- Rear View Mirror on 99 Lude
- How Much Boost w/ 9.3:1 OEM Pistons?
- Clearing out the amber from the taillight?
- Girdle?
- Auto vs. Manual H22/H23.. block differences?
- Gas light gone out?
- 4th Gen Front lip
- Would you trust this short shifter?
- anyone know how to fix a cup holder?
- what happened to the 5th gen short shifter thread?
- Back from the dyno with the jrsc 4th gen
- C&R Radiator fan install
- I have a small problem wit my lude any one else have this problem?
- What Always Turns on the Radiator Fan?
- honest opinion
- h22 turbo manifold on a f22?
- Idle Air Control Valve throwing CEL in Euro R ( H22a ) Swap. HELP!
- What rear toe kit for my 93 Lude?
- Apexi super intake
- Did type S motors have bigger LMAs to accept the bigger lift of the Type S cams?
- POssible Radiator Leak
- Apexi AVCR (posted in the "forced induction" section w/ no reply)
- euro r manifold install.
- Where can i find....
- center console
- 5th gen lude sunroof fit on 4th??
- engine ticking and um...
- bullfrog upgrade
- Bolt pattern and offset.
- removing catalyic converter
- Pinging Noise ran low on oil (Please HelP)
- How Far is Too Low?
- cat back
- Help plz... Got my tach, but not sure on wiring... Thanks!
- which pistons in an A4 block?
- changed timing belt: now idle dies down after reving
- 1994 Prelude S help
- Should i retard my ignition?
- "JDM h23a blue top vtec" anyone know about this engine
- this clutch good for the money
- lsd
- Any suggestions for quieter tires?
- Prelude Performance, & General Observation
- Changing 4th Gen Prelude Shift Boot
- distributor question
- H23 1/4 mile times???
- oil leak from valve cover washers
- header?
- 2000 sh 1/4 mile times STOCK
- my new, old greddy header - refurbished
- Radio Problems
- exhuast question
- somewhat stupid question....4th gen vs 5th
- cant keep it in 3rd gear?
- wanna buy a prelude...
- OBD I vs. OBD II
- Differences in the 3 versions of the SMSP header
- 4th gen making wierd clicking noise whatn turning?
- dyno tune
- JDM P13
- Dumb ?- 1988 Prelude SI/Auto. What is the small button next to the shifter? Overdrive?
- prelude front bumper
- 500 degress
- How Much Did You Pay For Your Lude?
- Guage install help!! w/link to pics
- timing marks on oil and water pump offline at TDC
- P&P Shop in SD
- Throttlebody same between h23a1 and h22a???
- 97 prelude clutch install with ATTS hints please
- ATTN: ELECTRON BLUE PEARL Prelude owners
- 92 accord steelies on lude???
- Pocket/din with lid-Anyone install this?
- How many O2 sensors does a 93 VTEC have?
- H23 Valve Cover
- diffs between h22 and h23 intake manifold
- balanace of the harmonic balancer
- camshaft caps
- help me im a newbie
- Boost level on JRSC
- Anybody using prodrive 4.7 final drive????
- Swap
- Motor mounts inserts
- 93 DOHC timing
- Are 4th and 5th gen Prelude AEM intakes close to interchangeable??
- CD player power problem
- Wiring my H22 into my 92 Si
- Prelude Stereo Problems...
- Will 89 'lude si tranny fit 89 accord lxi?
- Clutch
- H22A1 stock cam specs
- Tranny question
- Lowering a 4th Gen 4WS Lude
- size of speaker on 4th gen
- built h22a
- tire size?
- anyone use this exedy clutch
- how can i tell the difference between trannys?
- Tein or GC?
- Skunk 2 stage 2 or jun stage 3 cams?
- Question about a 99 lude headunit
- Honda Prelude Alternator 1990
- i dunno where this vacuum hose goes!!!
- Clutch slipping when warmed up
- burning oil smell still..
- Does this sound Weird To Anyone Else....?
- Hondata
- H22 Exhaust port diameter Q and more...
- Lift/duration of skunk2 stg 1's, Type-S and Crower stg 1's?
- got a brake question 4 ya
- h22 stock clutch
- Differences between... (engines)
- How to clean calipers?
- speakers removal. how?
- R1 muffler on a h22 4th gen!!!!
- greddy evo?
- 97+ prelude cold air intake for sale...cheap
- 98' prelude blowing headlight bulbs, need help
- Installing New Mirrors...Can anyone help?
- keepin ABS after doin' H22A swap on 4th gen.
- Tein coilovers
- Whats wrong with my dyno results
- who is the best shop in the bay area?
- adjust valves w/ no cams?
- 5th gen exhaust on 4th...?
- need help just bought used car.
- gas needle broke
- VAFC Question
- Prelude folding mirror diagram!!!
- Which Lowering Spring Manufacturer do you prefer?
- FS: Brand New H1 5300K HID Kit $350
- Got a quick quest about Vtec contoller
- SHOULD I KEEP AUTO TENSIONER?
- If i were to go with hondata...
- B21A1 Motor
- Funny Question...
- header question
- helms manual question
- Will F22a Dc 421 Header Fit H22a's and h23a's?
- Hondata & Atts what happens ?????????
- JRSC Quick Q
- Torque specs exhaust bolts
- H22A Tranny...
- KYB AGX Adjustable Struts or Tokico Illuminas?
- agx vs illuminas
- Dyno Day...Its Official.....Free Dyno Run....Feb 21,2004
- EF kid needing prelude questions answered please?
- Engine seems to bog down......
- Quick question about 5th gen. back seats
- Which suspension setup?
- problem takin off lower timing cover
- camber kit differences
- manual
- 93 h22 NSX brake coversion Q
- SAFC VAFC SAFC2? which should i get
- Anyone has the link for know where I can get
- Problems with air fuel meter
- 98 H22A vtec X-over too high for JDM H23 vtec?
- installing engine
- wastegate failure?
- 5th gen stuff
- washing engine...throwing a code
- 89 prelude s conversion
- WTB: 4th gen h22 header. JUN header F/S - mod approved
- Wheelie Bar
- Amp Wiring into a 98 Lude
- how much tranny fluid??
- which clutch for 215 whp exedy or act hdss
- 94 S suspension fit 95 Si?
- Auto trans swap advice
- Which company makes rotors for Honda dealers?
- 4G vtec Brembo blanks part# needed
- Hawker Battery..
- 5gen AT helps with upgrades
- CRANKSHAFT PULLEY BOLT WONT COME OFF!!
- JDM Bumper...
- dual exhaust
- 92 4WS .. HELP ME
- Apexi Exhaust
- reverse syncro
