View Full Version : Honda Prelude
- Honing frm
- Neone know if there is a difference between main clearances between h23a1 and h23a3?
- 2nd gear poping out
- 2001 ECU error code??
- H22 + Turbo. Good or Bad Idea?
- shifter & cables, adjust ?
- Got new timing belt. Now timing is off!
- my prelude
- Cold air intakes and water
- help wire an h23 into accord
- Aftermarket wheel on an SH
- What knock sensors are the same?
- Replacement Question
- Serious VTEC Problem..
- gen5 Headlights
- What all can you remove after blocking off EGR
- stock lsd question
- MAJOR HELP PLEASE?!?!?
- tranny oil
- i need some technical help
- STUCK Crank Pulley
- dead prelude sh...need help!
- Idling/Driving Problems
- Prelude Short Shifters????? (Any suggestions????)
- help wanted, help NEEDED!?!?
- OS Type S Pistons...
- Tanabe SM questions
- Explicit Speed Header + Prelude = ?
- manual tensioner question
- ATTS HELP!!! please! and thank you! (Revi .. please, i beg you, read this !)
- H22a4 in a 97 Acura CL
- 4th gen evap canister?
- PCV valve?
- Clutch / Drive Train Mystery BB6 Need Ideas?!
- too low?
- H22 rods
- i ran a 14.512
- Stupid question, but i need help.
- why is my car running like a piece of....help me please
- missing gasket between brake booster and master cylinder? Is there one?
- 4th Gen Lude Question
- Why you don't drive on a Suspended License....Poor Prelude
- h23 motor does it come out the bottom or top?
- code 22 vtec pressure switch need help
- h22a vs h22a4
- egr pics?
- Honda BLueprinted Engines???
- Euro-R 5th. gear
- swap Traction Control into an EDM lude
- Power Window failure
- zip tieing tranny cables?
- Wiring diagrams for the turn signals
- Warm up Misfiring Problems
- manifold question
- Car suddenly has a clutch problem, semi-grinding gears, stalls at lights.
- i am think building a h23 turbo what do u guys think
- LF Tuner NC/SC
- RAD SPRAY WHAT !
- f22 crank in a h22a
- does a h23 have a knock sensor??
- how do u take off the oil cooler on a h22
- Emergency help needed. Oil leak behind filter. Selling car tomarow!
- Cool air Carbs... (random question thats been on my mind)
- Is the reading on SFC vtec controller on rpm is accurate?
- wondering if theres anyway i can look at a prelude adn see if its got the h22 from the looks of the
- Question about Intake-coupler & bracket.-HELP!!!
- Rota C10's on Silver 5th gen??
- --h23 vtec--
- EL Cluster in 92? How?
- anybody have exploded view for vaccum lines... choking idle again..
- f22a non vtec swap question
- Noobzorz to Hondas/ ecu question
- ****PULLEY HELP****
- Updates on my H23...
- New BB6 SH owner suspension question.
- EXHAUST HELP
- Making a auto into a manual 97-01
- shifter help
- Car wont start first time when engine cold
- Major oil leak behind oil filter pedestal
- Where can i order a Hytech Header?
- Crank Pulley Removal Tool
- Climate Control Problem
- 4th gen prelude cluster.
- What would cause my engine to do this----
- 4th Gen doors... Are they all the same?
- A lesson for all car people... input requested.
- messed up my car tonight.. what did i do?
- Something leak on the oilfilter.
- where is the ecu located in a 95 vtec prelude?
- 01 Prelude Swaps?
- CF Hood & Spoiler
- a/f gauge install
- help i have a crazy idle problem!
- What is the Green Key Light mean?
- OBD2 P72 on H22?
- Bonnet (Hood) catch doesn't lock shut..
- RLZ IM
- Greddy E-manage Ultimate
- Car wont start in cold weather (searched)
- Modifying h22 Intake Manifold
- Newbie to the prelude
- Typical Skunk Stage 1 gains ?
- Euro r manifold
- subs in an 01
- springs
- How do you dyno and tune a car with automatic transmission?
- problems with h22
- 16x7 with 45 or 40 offset?
- headlight problems
- Help on H23vtec
- Head wear ?
- 2.5 inch collector mod on DC ceramic header
- Crankshaft
- Head studs and main studs ...one time use ??
- Prelude type s pistons
- Quick Question: Diffference between USDM and JDM side skirts for 4th gen?
- camshaft question?
- D4 Light Flashing; Speedo is out on a 4th Gen H23
- Brake Caliper Clicking?
- Settings on SFC Vtec controller.
- Lets gather some info on doing a v6 swap into the prelude.....
- rod length questions
- axel help
- where to put my ballasts
- Greddy header. To mod or not to mod???
- can hardly see the tach/mph during the day
- H22A in a 3rd gen
- H22a Tranny, I need help on this one!
- starter motor "skips" in -30 degree weather
- Kaaz Cusco Quaife 1.5 Way LSD
- reusing old valves?
- AEM CAI vs V2 ? (searched)
- Type-S - Euro-R : Wheres the Difference?
- Type R lip from the Integra.. A hard fit?
- Wierd "relay clicking" sound when using clutch..
- Would a h22a4 block work with a h22a head?
- Spoon front strut bar length for BB4?
- Increase size of exhaust?
- aftermarket pistons
- Fitting aftermarket steeringwheel to a 4th gen?
- Rear Caliper Problem,Please help!!!
- crankshaft question
- Optima Battery *Searched*
- H22 Injector Sizes?
- something sticking in Carburetor?
- exhaust pipe welds broke!
- No Vtec.. has my solenoid gone bad on my H22???
- WTF wires.. They're all over.. And unplugged.. *pics*
- h22 horse power
- H22a4 injector picture request
- timing belt problem
- What are you using?
- Looking for 98' OEM Tail Lights.......
- Sputtering under 3k rpm's
- anyone want to trade there stock p/s pulley for aem?
- injectors question
- Are these wheels any good?
- f22a turbo
- Valve angle in F and H series head?
- Car doesnt start but works when push start?
- HELP! Vibration after a gearbox change.
- Price Check on 1998 Honda Prelude Type SH
- oil cooler o-ring replacement problems
- Fidanza Clutch
- D2 suspension: whats your thoughts?
- h22 camshafts?
- Troube with coversion(wont start)!!!!!!
- 01 prelude brake light and battery light?
- will 235/60/15's fit the 5th gen?
- I need honda radio code
- Car hard to start and little slugish,, after I put gas.
- gaskets after sleeves and porting??
- fluidamper or ati damper
- Tranny lock-up solenoid... where to start
- DC headers
- Thanks
- wiseco pistons
- ib spec rods
- 1998 honda prelude SH speakers?
- help with a very odd ignition startup sound..
- Neighbor Selling- Good Deal?
- Squeak when letting out clutch?
- GReddy exhaust
- 1988 preoude with a 2.0Si....im wantin more motor...
- 89 OCTANE in a 2001 PRELUDE...HELP!
- overheating problem
- K&N filters
- CV Joints?
- oil leak leading to baaad sound out of motor
- low power in low rpm, vtec not working... NO CEL
- Will Spoon N1 axleback work with Megan midpiping?
- Any one running 16x7.5 +45mm 225/45/16?
- Headstuds
- Check Engine light and V-Tec
- virginia exhaust regulations?
- Brake questions ?
- inconsistent knocking, PLEASE HELP!
- Sleeving - smogg legal?
- h23 crank in h22a4 block
- Taking off front bumper
- Mobil1 non-sinthetic oil?
- Place to sell used Axles? core?
- front sway bar
- little problem
- my blackk ludeeee
- Chnged my headlight assembly and now only my brights are on.
- trouble taking driver side axle/half shaft off
- climate control not working.. eletrical?
- nitrous ? 3rd gen lude with h22 55 shot zex kit
- turbonator
- what is the part number for the corner lights on the 4th gen..
- Brakes Problem
- My hand made balancer shaft eliminator kit link inside
- 5th gen prelude gas mileage
- injector cel
- my prelude steup
- Strange engine noise!?!?! need some help guys...
- How to remove P/S searched 98vtecs thread
- Annoying and unusual tps problem
- Interior/Exterior Thermometer
- Telling a base prelude from SH model?
- Which muffler should I get????
- does anyone own a Phantom Grip LSD, and what do you think about it?
- balancer shaft damage
- How do you take off the PS pulley
- Valve cover gasket leak...AGAIN!!!
- belt problem
- I just fell in love with weber carbs...
- engine swap
- could this deal with the timing?
- Painting my Car
- Where do this go?
- unknown block pieces
- can&how hard is it to put a v-tec in a 88 prelude
- 97 prelude front end swap
- 5 gen question
- downshifting problems
- clunk noise when clutch is released
- Timing belt broke, winter beater, intereference engine?
- How to Clean Head?
- How to remove 5th gen cluster and where is the SRS bulb
- weird noise? axle?
- 1999 Prelude...rotating tires
- Question about gas mileage
- huge decesion need some advice
- Dash lights
- Headlight problems
- Lf: used fully assembled sleeved H22 short block
- Does anyone know anything about the prelude 2007 meet ?
