View Full Version : Honda Prelude
- Problem with brakes?!
- Supercharging a F20A
- emissions woes
- VTEC Motor Problem
- Craftsman Valve Spring Compressor --- Can't get it to work. Any tips ?
- Which Strut bar will fit with JRSC
- Tranny Troubles...
- f22 turbo
- 92-93 Prelude ABS unit - Difference in Vtec vs. Non Vtec???
- need help
- any tricks to getting the fuel pump filter lower in the gas tank?
- is the tranny going?
- 92 with 204xxx. sugestions?
- intake resonator
- wat prelude gen. is better
- side marker (search couldnt fine the thread)
- Greddy evo2 or sp2!!!
- In-car from Hyperfest 2007, #117 H1 Prelude
- Are preludes stolen?
- anyone who has access to harness/connectors for 4G non-EL cluster
- changed wheel bearing today
- rear brake squeak, bearing?
- Balljoint Press
- vtec/engine problems have searched plz help
- prelude seats
- rim ?
- which crank i got???
- Will I pass smog in ca with current mods?...
- Quarter glass removal?
- ABS
- hopeful fix for sluggish startup
- 4th genner's in Cali, take a looK !
- Need help with h23a1 stalling while driving down the road
- is this a real exedy clutch.
- head gasket question
- what way do i install my clutch?
- How Much
- quick alignment ?
- A/C By-pass Belt Size H23
- Honda Prelude 1997-2001 2.3
- clutch causing awful noise
- Where can i get this
- Reading ECU
- cooling fan on all the time
- Weapon R 2.5" collector header..Any experience??
- Weird rev bounce at part-throttle launch....
- Any really knowledgeable honda enthusiasts nearby
- type s prelude 217hp wtf?
- Looking for what to do next if you could help that would be great.
- high comp pistons?
- HELP with Weight Reduction???????
- PRELUDE SH HELP !!!!! PLEASE ASAP
- 99 prelude question?
- gas pedal sensitivity
- tachometer on a/c hole driver side?
- i need this part...anyone?
- h23 EcU
- throttle body hoses
- need help finding an old thread
- Custom Exhaust Any suggestions?
- Please I need to know the difference between an H23A1 and H23A3..
- shift linkage
- Venom pcm module
- how to ohm out injectors and harness?
- Installing remote fan switch.. searched already
- What are these parts?
- engine bay shave
- Well this is my last resort cause know one seems to know how its done. jus seein if theres some good
- spoon mirrors on 4th gens
- Need help on swaping from H23a1 to H22a1
- Slwo turn over
- transmission problem. Not going into gear
- my h23 prelude
- Euro-R Piston rings and Bearings
- H22a Mounts in EF $$$$$$$$
- slave-mission
- Rear brake rotors wont come off!!
- Anyone getting knock w/ low grade gas on an H22?
- friends prelude stalling NEED HELP!!!!!!
- interior light problem
- upgrading my lude
- leaded vs unleaded
- Smoke coming out of exhaust when hitting V-TEC. Is this Normal?
- NO MORE EMISSIONS! :)
- I don't know anything about my prelude. Noob Question.
- butterfly valves
- Can I Use an Oxygen Sensor from an h22 or h23 on My F22
- 94 4WS how rare
- Transmission case will not bolt back up to engine
- Code 15 ( no ignition output)
- blown head gasket?
- vtec solenoid
- Dropping Gas Tank
- intake manifold. me being an idiot,
- pics of how to move the gas temp gauges
- Please help me find axle needed, just did a auto to manual conversion
- 86 prelude transmission problems
- how to bore TB
- ? car vents smell of exhaust ?
- NEED HELP FAST!!!!!!!!!!!!
- h23a (vtec) & (non vtec) swaps
- Egr code 12 (searched already)
- 5th Gen Tail light Question
- Flywheel Question
- Need quick info on what i need to convert from SH motor to JDM H22A motor
- removing jdm speed limiter
- What would cause my car to run rich?
- PLX install
- WTB: 97+ prelude bracket for power steering
- hoses on TB
- whats the purpose of the resonator and intake control diaphram (controled by solinoid)?
- prelude h2b trans?
- Crazy Heater Control Panel only works intermittantly?!
- Turbo help
- problem with k-sport coilover fitment , front legs, help!!!!
- f22 parts?
- hitting sound??
- Coilovers on eBay
- Prelude questions
- Bore 20 over or sleeve the block?
- guages and lights help!!!
- 1999 Prelude engine block Non SH
- WTB: ATTS left oil pressure sensor
- 95 honda prelude vtec 1/8 and 1/4 times...and questions.
- Pic Request
- will a 15inch rim fit on a 5th gen?
- I got CEL and ATTS light - code -... Please Help (Searched)
- Smoke
- How long do shocks last?
- what wires to i tap into to install kill switches in my 92 lude?
- Turbonetics H22 Turbo Kit, CARB Exempt?
- ATTS HELP
- need help and fast. dont have much time.
- E85 Tune on the way, Stay tuned for results!
- Street Legal Turbo for Prelude SH?
- FM Shortshifter Install: A few questions
- Horn does not work
- AC Quit working
- Getting custom exhaust ... diameter question
- ATTS Control Unit - Unknown failure
- prelude stock ecu unable to tune?
- Turbo H22A4 Prelude is sputtering??? Need HELP!
- Can XTD stage 3 clutch cause Problems
- HElP: Prelude type SH why is the atts light is on..
- anyone in chicago area know of a machine shop?
- sh tranny's
- Golden Eagle intake manifold
- JDM H22a Swap-Getting fuel to rail but injectors won't fire.
- some questions...
- JFYI.......Aem intakes suck.....
- rad cap for 5th gen? 1.1?
- fs: norcal-98 prelude parts
- VTEC model with 2WS
- timing belt!
- Can't change gears
- Acura will not start
- 93 lude hasnt run for a year
- If I upgrade the calipers on a 4-th gen SI to the VTEC or 5-th gen ones can I still use the stock wh
- NTK O2 sensor differences 24042 & 24169
- Sqeaky suspension
- Spark Plug Preference??
- is this safe?
- Prelude A/C
- Recent Topic That Someone Posted?
- Water Pump
- Engine idle's drops below 1000rpm and even cuts off
- 4th Gen & 5th Gen Rear Brake Calipers, The Same?
- PCV Valve = bad idle?
- Why is the lude so unpopular?
- Car DRINKING clutch fluid!!
- I havent posted in here in a long time.
- Aftermarket Steering Wheel Installation
- Plugs + wires
- GENUINE HONDA PRODUCTS
- Removing Front Mount
- FT: 5th GEN. mugen rear aprons
- Alternator belt squeak
- so I was driving my prelude and..
- H22A transmission
- ABS ATTS Lights always on?
- carb help needed
- Are A/F ratios affect by gear?
- What lip kit?
- Black as a.... well u pick one that wont offend
- h22a4 crank in h22a1
- Power Antenna Replacement help
- need help with new car
- Grinding clutch in neutral when clutch is released(already searched)
- I need help changing my tranny fluid...
- 92 si jdm h22a swap!!!! using stock wiring harness, soidering? motor going in this weekend
- True NooB with Mod questions...NEED HELP
- h22 vtec swicth over
- HOW DID THIS HAPPENED?
- Installing new valves
- f20b sohc vs. dohc
- Header design article
- help!! car wont go in reverse!!
- Prelude Headers
- International freight - lude parts
- what to do with the 93 lude
- HELP! marking TDC on my Fidanza Flywheel
- Twin Loop Muffler
- Aftermarket lower control arms for 97-01 prelude(help cant find any)
- 1993 Prelude Vtec
- JDM F22B DOHC, mpg?
- Where can I find.....
- I need a turbo manual for my h22a
- Tuning an SH
- HELP! need f20b crank!
- Radiator? Condensor?
- does anyone know anything about steeing columns
- Euro R tb and Port matched Euro R Manifold. How big of a bore?
- Car wont start!!! what can it be!!! HELP!!!
- problems changing clutch, need your help....
- a tech qustion for ya nerds (genius'). At WOT would anybody know CFM of 2.3L
- HONDA NAVIGATION SYSTEM
- need help bad with my sh tranny!!!!!!
- Electric window jammed
- 2nd and 3rd-Tranny
- Bolt Pattern
- Coil Frying and some Ignition Discussion
- Report Posts while I am gone.
- weight of a prelude
- belt help
- Can i run 100% water?
- Good Deal On Prelude?
- Nite-shades
- External Coil
- Radiator hose Size question, Will paypal you CASH.
- my a/c smells funny
- I need some help with my project.
- Camp1320 header h22
- vtec grind metalic sound?
- JDM red door panels?
- Balljoint issues
- KMS high flow oil pump
- H22a in 98 civic ex bogging out
- clutch pedal is on the ground
- steering column problem
- O2 sensor question NEED help
- a little help with my SH suspension (searched)
- h23 and h22 axle question
- h23 Ecu question?
- high flow muffler for turbo prelude
- turbo h23 tranny ?
- Where do you buy your parts?
- H23 fuel rail
- springs for KYB AGX
- Official Nitrous-Prelude 1/4 mile & Dyno thread......
- does mugen bumper come with the grill?????
