View Full Version : Honda Prelude
- need help with a swap .
- BLOWN MOTOR!!!!!!!! EXPERIENCED ADVICE NEEDED!!!!!
- Which master cyclinder to swap
- Exhaust route to left side.
- Bad steering return
- oil in knock sensor plug
- Headbolts?
- 92-96 prelude bearings
- axle axle
- License plate relocator
- HELP! VAFC install killed my car! =(
- valvecover color codes
- Help! Diagnose my car issues.
- distributor question
- What's everybody running suspension wise?
- 92 prelude 5 speed phoenix-tempe area $3000 obo
- anyone work at a body shop and can do an estimate?
- idle quesiton
- Flex pipe Leaking
- F22B1 in 92 Prelude?
- tein s techs
- Is 3500 rpm to high for Prelude 98 in 5th gear
- CKP sensor
- Camp1320 Header install on 5th gen
- h23 turbo mount
- Best Motor Mount Kit???
- Colder weather and brake light sensor
- 84 prelude issues..Please help
- a/f gauge
- fuel pressure is high am running to rich here
- can i build an h23 vtec like if it was an h22 like for allmotor
- engine running like crap after swap attempt
- Searching for Prelude 2.0Si Leather Wrap Steering Wheel BB4?
- Suggestions!!!!
- Oil leak only when car runs?
- no spark on 2000 prelude
- Kimini finally on the dyno
- my 1985 prelude with a 86 motor
- 4th gen oil pan gasket
- cold start woes...
- Any traction bars out for a 5th gen lude?
- JUN reprogramed computer (p14)
- clutch installation questions
- just converted from auto to manual, ECU swap?
- 1993 Honda Prelude Vtec is running really shakey, and won't rev over 3500?
- H22a4 compression for FI
- Carbing
- Need some help figuring some engine bay stuff
- Need help!! Pulled too hard on axel how can i reconnect it?
- My lude sounds like a helicopter at 30mph, and vehicle shakes.
- oil pan question
- Cant figure where this leak coming from
- White Smoke! HELP!
- can I start engine without axles installed?
- OEM tune up question.. 5th gen
- cruise control issues
- BB6 Front/front crossmember/subframe question... Base:Type-SH...
- suspension help
- my first prelude!!!!!!!
- Car won't go into gear- need confirmation
- heres a fun one...
- F23 block & H23 head. Trying to rebuild an OEM daily driver motor. Please offer input.
- what year accord rear OEM lip works on a 93 lude?
- h22 pistons in h23 head/block
- ? about honing in spec but glazed cylinders with new rings
- Mugen Fan Switch and Thermostat
- will the 4th gen prelude h22 drag gen 4 turbo kit fit on the 5th gen prelude?
- Quick question about ap2 rims....
- real exedy?
- OBDII Scanner.. Under $200
- 4th gen and 5th gen exhaust
- New rear quarters
- clutch engagement
- Carb Cleaner EGR
- Gauges
- Breather Install Question
- Will it fit. Headers
- prelude springs
- Cold Start Almost about to die....
- Electric aerial connection?
- what brand camber kits do you have on your 5th gen?
- your suggestions to clean up combustion chamber/piston carbon
- FS: 92-96 Prelude Forbidden Motorsports True Short Shifter
- Another wierd Power steering/electrical issue?
- Replacing radius rod bushing
- Crank Angle Sensor
- Blue Dash Gauges on a 4th gen
- camp1320 picture on 5th gen
- Which relay controls lights at night?
- Need For Resonator box with jdm type-s intake
- 4ws sticker on trunk
- s2000 shocks and struts
- my bb4 h22 turbo build with pics.. custom fab work
- Timing Belt play??????
- Cheap Strut Bars
- car not revvin right...
- Rubbing sound and the car is loud as hell, plz help. (read me)
- Plate Lights Question
- how often do you guys change fluids?
- midwest tuners?
- 4th gen gas warning light tested
- 88 prelude si speratic idle?
- Hard Shifting From 1st to 2nd
- not lookin good. what is this part??? help
- sunroof
- Air in power steering fluid!
- What do you think of this suspension setup.
- Rear Bumper Rubbing after New Wheels and Tires
- anyone
- Trying to find a part for my lude.
- fuel system?
- Prelude Radio Error?
- Prelude SH
- looking for crower maxi-light rods
- Simple power steering?
- need help with p13
- JDM Type S into 4 gen- any attempts so far?
- <>How to put a SH block with a BASE TRANNY?<>
- Air Breathers
- car is missing ?'s fuel pressure or other problem
- Foamy oil...coolant ???
- 96 to 99 prelude engine swap
- Fuel Injectors running too rich quick fix?
- Anyone know if ground control coils fit base+sh or just one?
- Motor Mount Question
- wings west body
- 4thgen H22 Shoft shifters?
- WTS H22a4
- NGK wideband meter, anyone uning one?
- anyone know of any tuners in indiana?
- h22 vtec controller or chipped ECU?
- Strange Problem
- Got my exhaust and intake valves mixed
- Difference in H22a1 and H22a?
- Innovative Motor Mounts: Question regarding hardness...
- Having trouble with Alternator mounting bolts.
- C-pillar bar Harness bar
- Aftermarket Strut for TYPE SH
- anyone know a good rear lip for back bumper for a 93 lude
- Is it possible to do a Manual to Auto tranny swap?? 2000 Type SH
- clutch question?
- JDM fog light bulb question...
- anyone have experience with the kaizenspeed BALANCE SHAFT ELIMINATORS kit?
- Power window issue
- I need help!
- noob question...
- what exactly is a wideband o2 sensor? (searched)
- What size belt will I need if I am not using an A/C compressor?
- h22A W/ F20 TRANS...starter question
- Rear upper strut bar ??
- backseats!!!
- need help doin Timing please help!
- Energy Suspension Motor mounts ???????
- anybody have pics of the Seibon TJ stly lip kit on a 5th gen?
- p13?
- Need help finding member. Whos lude is this? (move if needed)
- any idea where to find the "Motegi" badge?
- underdrive crank pulley
- knock sensor question
- crower or skunk 2 cams
- BPI flowstack
- turbo H23A1 with H22 head
- questions about rebuilding my h23a1
- it's time to play NAME! THAT! LIP!
- 91 prelude engine swap?
- possible to check cylinder compression with motor out of car?
- intake manifold problems?
- Prelude stock fuel injectors
- good deal or not?
- h22 on 5 psi
- whats better for u guys on 5th gen - type sh or normal on the 97
- VTEC problems
- Clutchmasters Flywheel Problem
- I just filled my 4g prelude and it cost me $95!
- h23 to h22 swap question
- Prelude Noob help
- Low offset Rims
- 1st Shakedown pass at Houston Raceway Park- Timeslip
- What is this?
- p5p ecu question....
- worth it?
- 25 CELs?
- valves ticking
- will any knock sensor work?
- Finding Oil and Transmission Oil Leak
- Camshaft recommendations
- Slow leak in winter tires
- h22 + h23?
- p13 auto or manual
- 2000 Prelude problem
- H22A grooved crankshaft?
- Turbo Application on F20A4
- price on 2000 honda prelude?
- idle problem after valve adjustment!
- 5th gen prelude springs in 4th gen???
- {searched} would like to know....
- Prelude durabilty
- am i checking timing right?
- how to remove shift boot and shift knob
- timing belt wear in period?
- TEIN S TECH SPRINGS question
- 4th gen crash in Russia
- electircal problem?!?
- my 93 lude will run for 2 min then cut off. need help
- ANYBODY EVER SEEN ONE OF THESE????
- Cat-Back for 88-91 Preludes
- Wall near the fusebox...
- Tips On Turboing My H22A
- fuel filter
- atts light
- Intake Manifolds
- Exhaust Cam Bolt Came Loose - Now H22 Lacks Power and Dies
- Bad Altenator, Funny Idol????
- full race h22 question?
- Damn Spark plug wire keeps popping ouT!?
- My new 1992 Prelude Si---need suggestions
- Tires for the new Slips?
- Removing the battery with hondata or other programable ecu's
- Power Steering removal....
- My Honda Prelude 1992 will always start first go but when i turn it off it wont start
- new to game 5th gen trying to go all motor any tips
- Engine Problem, 92 prelude with F22b
- 5th gen front passenger brake hard line? is there an easier way?
- jdm f22b tranny or 2001 h22 tranny to a obd1 H22A1
- torn cv boots
- oil lines
- marker, dash and tail lights
- ok Prelude type R??
- Why is the H22 better than the H23 engine.
- more tranny problems
- vteccrossover
- quick ecu question
- Any one been to the BAR in Huntington Beach?
- buying a prelude..
- ProjectBB6's Fall/Winter Project
- h22a3?
- Who has bought from Hmotorsonline?
- vtec pressure switch sensor
- WRITE-UP/RESOURCE THREAD: 5th gen auto to 5spd SWAP
- 1989 honda prelude starts but quits when engine warms up
- Question on B20 motor
- brakes...recomendations?
- h22a1 vs. h22a4 short blocks
- h23a1 smoking. Did test, now need input.
- Fuel injectors, duty cycle and how not to look like an idiot. **please read**
- How much boost can a H22 take?
- putting my car back to stock
- Weird Problem
- Does anyone know?
