PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 [169] 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Differences between USDM h22 head and type-S head?
  2. difficult to install starter
  3. What is this anamoly indicative of?
  4. hmotorsonline....any engine mile warranties?
  5. slipping ?
  6. new wires, and plugs
  7. Clutch Masters Flywheel timing marks?
  8. 2001 vtec swap into 1992
  9. Weird Vibration on H22
  10. A/C climate control panel lights
  11. 5th gen dash harness
  12. clutch problem?
  13. compression and leakdown test... how much?
  14. Aftermarket Radio Install for 2001
  15. I need help with my 88 prelude
  16. 97 prelude bulbs
  17. sleeper exhust?
  18. Need some help on suspension kit.
  19. 02 sensor voltage....
  20. Keys got stolen, need help about immobilizer
  21. Low whistle sound when AC and lights are on.
  22. Turb kits for 5th Gen
  23. Amping the stock 5th gen front speakers...
  24. Looking to clarify a few things...
  25. Dent resistant material - ........what do you think?
  26. h22 compression question??
  27. 4th gen Header ??
  28. help Im a newb about to get ripped off
  29. Need Help gaining HP
  30. my 97 honda prelude won't go into gear anymore. HELP!
  31. differences in ecu's
  32. H22A Type -S swap HELP>>>>>>
  33. is my 95 Luda P12 Ecu Chippable?
  34. Eagle ESP rods on a H22a4 - NEED .866" pins help>>>>>!!!!
  35. vis mugen replica kit 5th gen
  36. Air vent & A/C odor...
  37. oil change
  38. Topic: going with out A/C any risks ?
  39. Couple problemos, vtec not engaging, oiled up clutch fix? (nice pictures :)
  40. four wheel steering?
  41. Toyo vs Bridgestone for Prelude?
  42. clutch
  43. is the mechanic bs'ing me??
  44. H23 Head Removal??? help
  45. compressed shock by hand, is it bad or good??
  46. DOT Approved Headers?
  47. lowering the prelude
  48. H22a has a knocking soundHELP!!!
  49. What kind of Tranny? whats the number?
  50. i have a question on reabuilding a H22A4?
  51. Power mirror dont work
  52. JDM H23 HEAD ?
  53. accord kit
  54. OEM Rim width specs Prelude SE 5 stars
  55. The official how-to remove my abs thread...
  56. Hydrolock
  57. Need help finding a deck plate...
  58. Smoke / tick @ startup
  59. 12:1 Compression pistons - non forged
  60. Info about putting a H22 into my 92 Prelude Si (what do I need, etc)
  61. type-s hood
  62. Eagle H22 rod question?
  63. searched, but can't find thread
  64. Lowering shocks to match springs?
  65. The "Where Can I get" this thread.
  66. ? about intakemanifold on my N/A
  67. heat wrap / header wrap on intake
  68. Engine rebuilding or new engine.
  69. Will 225/50-15 Tires on 15x7 40 offset rims rub on non-lowered 4th Gen?
  70. Removing air bag from steering wheel?
  71. Custom endlinks....
  72. Diagram for 97-01 oem intake system
  73. Quick question....
  74. 1990 honda prelude rod bearing replacement problems
  75. Recently bought 92 lude... few questions...
  76. Wanted: JDM Door sills
  77. Any Progress on Solid Rear Mount or Traction Bars anyone?
  78. VTEC help
  79. Who makes final drive gears for Preludes
  80. Prelude wont start
  81. Header results + motor failure = teh sad
  82. Specifications on 1988 Honda Prelude 2.0 SI 5 Speed 4WS
  83. price dif - custom vs namebrand cams
  84. exhaust question
  85. Sony Xplod 12" subs
  86. sorry search is down, will 97-01 H22 header fit on 92-96 head?
  87. 97-01 prelude final drive
  88. 98 h22a4 oil leaking when hot, not cold around flywheel cover
  89. building an h22 for high boost. help
  90. someone please help.... car wont idol...
  91. Adjusting ignition timing.
  92. removing hub.....HOW????please help
  93. Black housing headlights
  94. pictures of 1.7 f and 1.5 drop
  95. car sat while i painted it now runs like crap
  96. ****Torque Specs on Stock H23 rod Bolts anyone??????
  97. password jdm intake in 4th gen
  98. car cuts out between 2 and 3 thousand
  99. balance shaft question (searched already)
  100. Four wheel drive/ All wheel drive prelude??
  101. Fuel pressure test
  102. yahoo group
  103. custom liscense plate for the lude!>
  104. Steering arm problem
  105. 1984 Prelude. Is there an aftermarket for me?
  106. solid motor mounts found... kinda
  107. 250+ NA hp?
  108. Want to Rebuild my H22???
  109. HELP turn signals WHONT FIT IN MUGEN BEMPER
  110. quick wheel question
  111. DC vs. Apex WS2
  112. 4WS problem
  113. So my car is leaning to the front right...
  114. Oem valve cover
  115. Storing a car for the winter
  116. skunk2 lowering springs 4th gen - pic request
  117. Rear view mirror I can get it back on dang
  118. Will an 97 block work in a 01 prelude?
  119. 3rd Gen Door Hinge Compatability
  120. car keeps stalling HELP!
  121. front door speaker size in a 97 lude?
  122. trial user?
  123. RSX oem wheels & H&R sport springs
  124. Right hand drive parts
  125. Rebuilt H22A
  126. 97 up prelude side markers...
  127. Good suspension setup? yes/no?
  128. f22 header?
  129. Some questions about a 4th gen
  130. fidanza short shifter...anyone?
  131. Stock fuel pressure on h22?
  132. anyone have jdm foglights on their BB4?
  133. i have a few problems.. please help me
  134. getting those engine temps. down
  135. 92-96 prelude-nsx/legend brake caliper upgrade?
  136. rear speakers 4th gen, rod it the way?
  137. Can't Decide
  138. Underdrive pulley question
  139. How to pull off Horse Shoe clip thingies on tranny holding cables in place?
  140. 4th Gen Corner Lights
  141. Sleeving the block (H22) which sleeves?
  142. Another H22 Problem. Searched but to no avail. NO POWER.
  143. Something is wrong with the header, making weird sound
  144. blown shocks??
  145. skunk2 exaust??? on a 5gen ??
  146. Selling my H22A1...
  147. I looked, but couldn't find...paint codes/color names for 4th gens.
  148. Upper ball-joint woes...
  149. 4th Gen Brake Lamp
  150. How tall are you 5th gen Lude drivers?
  151. Oil Light flickering
  152. just bought car, accidently put octane 87 in it, what should i do?
  153. 93 accord tranny on a h23a prelude si
  154. How much hp to achieve 12's in 5th gen prelude??
  155. 4th gen top hats
  156. Did a compression test on my Jdm H22 , Whatda think.
  157. Short! :(
  158. Engine choaking when starting up every morning?
  159. Short Shift Kits for 5th Generation Preludes
  160. 5th gen overheating damage? (searched)
  161. i've got the basics whats the next big na horse power gain
  162. recent dyno of my h22
  163. Power Steering nut - thread pitch???
  164. prelude trunk strut
  165. Starting Problem!!!!!!!
  166. Right Side Drive '95 JDM Honda Prelude
  167. Any reason to keep old main bearings?
  168. 4th gen prelude front lips?
  169. Just got a 88 lude with b20a3.
  170. Need Helpful Suggestions w/Idle Surge. JDM H22A Motor Swap into 94 Accord
  171. 3rd Gen Lude- Fog Lamp Part Number?
  172. vented 4th gen hood?
  173. 4th Gen Front Seats
  174. How to Install.....Buddy Club Earthing Ground Kit???
  175. What makes the cat rumble?
  176. timing belt tricks???
  177. Do all 5th gens come with the P R E L U D E emblem?
  178. Tokico HP Shocks and Springs
  179. Help me with HID kit
  180. random technology cats.?
  181. APEXI VTEC CONTROLLER VAFC2?
  182. ABS light on in Prelude
  183. need to know which wires to jump, to make D4 to go to (P)Park from a auto to manual conversion prelu
  184. It could only happen to me....
  185. gauges. automatic/manual
  186. Suspension question
  187. O.E.M. lugs exact specs prelude
  188. Reset ABS warning light
  189. Six Sigma Racing (DTR-Fab) H22A Header Recieved!
  190. Help! Car is idling very low.
  191. Lost all oil, but no oil light?
  192. SPOON Header?
  193. automatic to manual conversion prelude si
  194. F20B into 93 Si?
  195. Collector mod
  196. 5G "A" Pipe Replacement Options? [Exhaust Flex Pipe]
  197. BRAND NEW IN BOX AEM (POLISH) COLD AIR FOR SALE
  198. Replaced Immobilizer, now no fuel?
  199. tail lights
  200. Motor mount replacement questions for 94 vtec
  201. crankshaft/timing belt/engine valve help
  202. I need help deciding on..........
  203. need new pistons :(
  204. check engine light
  205. poping noise and pop feeling in clutch pedal
  206. Cleaning inside of muffler...?
  207. i think i just lost 30k miles!
  208. Mk1 auto Prelude EX - misses badly under load, worse when cold
  209. Cold Air Intake
  210. f22a to jdm h22a
  211. How to tell the difference of a USDM and JDM p13 ecu for 93-95 vtec?
  212. Getting my engine rebuild, what other parts worthwhile?
  213. A/C question
  214. RPM's drop when AC is on or put into gear.
  215. Searched: What brand short shifter for 95 civic coupe w/ h22
  216. Question: H22 wont start after balance shaft belt pops off
  217. rebuilding a usdm h22
  218. just finish Droping in jdm h22a and converting it to manual in 97 honda prelude now need HELP!!
  219. h23 conrod into h22a1
  220. H22A swap in 89 Prelude
  221. There is no difference between the Lude SH 97-01 and the Non-SH w/Exhaust right?
  222. findaza flywheel to light for reliability?
  223. h22 swap into 4th gen prelude questions
  224. 95 h22 head(JDM) swap in 97h22a4
  225. center speaker doesnt work 95 SI vtec
  226. anyone know what kind of header this is??
  227. Need help with swap h22..frustrating
  228. Power loss (searched)
  229. best vafc???
  230. H22a4 with Type S pistons - Q's HELP!!!
  231. Another tire size question....
  232. clutch release bearing / spring thing diagram HELP!!!!!
  233. driver side door is stuck shut, wont unlock, what to do
  234. carbon fiber hood
  235. Common 5th gen problems ?
  236. Inner tie rod ends
  237. SH tranny on base block adapter thing
  238. Anyone have a How to?? on installing an alternator on a 97 lude????
  239. Searched all over, can't find it...how much coolant does my 4th gen take?
  240. Anti glare side mirrors?
  241. smoke from vents?
  242. 4th gen audio --> the window is the enemy
  243. 97+ 5spd Prelude shifter/cables assembly the same as 90+Accord and 92-96 Preludes?
  244. JDM Front & Rear Lip
  245. quife LSD, 4th gen and 5th gen same model?
  246. Body Parts/ repair options?
  247. What are the specs for JDM 97+ H22 engines?
  248. Prelude ECU
  249. Intake manifold, 4th gen
  250. I need some Brake experts, not getting pressure
