PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. help help .... BAD cv axle on driverside and no one can find the part i need!
  2. Password:Jdm side marker light template
  3. h23a cam ??????????
  4. Hood Help
  5. What to do 91 prelude.
  6. manual tranny fluid level?
  7. (m2a4)5th gear grind
  8. 1993 Honda Prelude SR-VTEC Track Built Race Ready FOR SALE (ugly duckling)
  9. 93 si intake question
  10. dead starter or battery.
  11. Wtb skunk 2 h22 intake manifold
  12. Information on H22 Type S camshafts
  13. trany problem H22a
  14. '01 SH Evaluation and Mod information...needed
  15. H22/H23/F-series Manual Tranny Synchros the same?
  16. H22 damaga- cross posting
  17. Just another turbo'd lude
  18. Intermittent ATTS light
  19. Black oil after fresh build.
  20. Help with 94' Honda Prelude
  21. D light is flashing
  22. Header effects on A/F
  23. 92 prelude with transmission problem
  24. who knows how much mid sleeve installion cost
  25. 50 shot on my h23!!!?
  26. How to fix permanet ecu error codes
  27. SH and base steering wheel the same ?
  28. Accord 3.0 Throttle Body on Prelude 2.2
  29. Power Window Problem
  30. Mystery hose under the car
  31. 5th gen rear lip & strut bar on 4th gen?
  32. trunk problem
  33. throwin codes i dony know
  34. radio driving me nuts
  35. Need Help with my 3rd Gen Prelude
  36. 5th gen lude suspension on 4th gen
  37. Please help check engine light back!!!!
  38. Turbo car .. Which trans ? .. M2L5 (longer geared) vs. M2A4 (shorter geared)
  39. No Spark, No gas. WTF?
  40. 96 honda prelude abs light
  41. 1993 prelude running ruff, BAD ECU?
  42. Oil Leak Hot spots
  43. Suspension Noise....help?
  44. Drivers Side Outer Axle
  45. Anyone with polished SH rims?
  46. tapping, chatter noise
  47. Grounding Points?
  48. DRL indicator, ABS, Brake Light and Battery Light Comes On.. Help!
  49. 5G Prelude on Hype R wheels?
  50. Fuel pump maybe going bad?
  51. F20B ecm Help
  52. 5th Gen. Rear Lower Ball Joints
  53. What is the best stock downpipe for H22 (obd1 or obd2)
  54. 96 Prelude obd2-obd1...can't find obd2 p13
  55. H22a1 and H22a4 Rod bearing difference?
  56. Advice on build my motor
  57. estimate of hp
  58. Links to a good battery relocation write-up
  59. Noisy and little power in Vtec
  60. B21A1 Honda Prelude Si?
  61. 5th Gen Halo Wiring
  62. B18 In a 4th Gen Lude?
  63. starting a build on an h22
  64. 93 lude si with h22 swap= dash issues
  65. S3 gear selector lights blinks randomly in 1989 SI
  66. Any one know where to get mugen parts
  67. Electrical malfunction
  68. help 91 prelude 2.1 si no spark or fuel
  69. h23 to dohc f22 Q's
  70. Distributor help: 98 h22, need opinions
  71. Red Key for 5G - does it mess anything up?
  72. Engine noise?
  73. Bogs down when warm.
  74. 4th gen rotors and pads
  75. no heat!
  76. mugen bumper?
  77. skunk 2 springs?
  78. replaced knock sensor and code 23 is back
  79. brackets?
  80. Need some picture : Apex spring and KYB AGX 5th gen
  81. Head Gasket Thickness effecting Compression on H-series
  82. How to: Install your wwrs lip kit 5gen
  83. Mk.4 Prelude EL Dials dimming help
  84. 92-97 & 98 up Main Bearings
  85. 13" wheels????
  86. Where to find this Rear Lip?
  87. '96 prelude fogs
  88. nitrous Q's and A's(searched)
  89. setting timing w/aftermarket flywheel
  90. What kind of rims are these
  91. Power Steering Pressure Hose...
  92. h22a1 with h22a4 intake manifold Questions
  93. H.I.D.fogs?
  94. Strange H23 VTEC build- engine builders chime in!
  95. Help with camshaft selection
  96. Lower Ball Joint
  97. best ecu
  98. prelude misfiring
  99. difference between SH and base headers
  100. boosted preludes any probloms?
  101. can 99 lude fit 225's?
  102. lude running lean
  103. is someone know MFactory race flywheel ?
  104. prelude tras bad or whats wrong
  105. Turbo Charging the H22, help please
  106. Help please! h22a4 tranny problem!!!
  107. obd-2 Crank Postion Sensor, 1 or 2 sensors ?
  108. Aftermarket thermal fan switch question!
  109. Front motor mount question!
  110. Rear lip
  111. tire size....
  112. 95 Prelude...A/C not working...
  113. Clutch problem
  114. Economical way to make IABs open sooner?
  115. cold air intake
  116. where is the obd2 port on a 98?
  117. intermittent brake failure
  118. 400-500 rpm idle
  119. Ran over a pot hole
  120. distributor help??
  121. clutch questions...
  122. What tires do you use?
  123. Question on the mind
  124. Rear view mirrors - from other cars?
  125. code 4 and 8
  126. 5th gen lowering springs on 4th gen?
  127. jdm h22a boggingg
  128. anyone have auto shift cable
  129. 92 prelude no start!!!
  130. Breaking in engine after build, suggestions please!
  131. hondata s200
  132. can i use a started out of a base model prelude for my type sh
  133. How would I convert an automatic Prelude to Stick Shift?
  134. Axles, H23/F22 trans in 5G Base.
  135. Code 22
  136. please help, nasty winding noise from engine bay
  137. 5th gen head gasket
  138. Cooling issues...
  139. How big can the stock mani TB opening go???
  140. Auto Transmission Filter
  141. center console electrical;
  142. H23A1 Not running with out foot on pedal??? please help
  143. WTB 5th gen auto(tragic)
  144. Manual tensioner problem
  145. Roof spoiler
  146. rear mud flaps?
  147. No A/C
  148. IAT sensor modifiying on 5th gen
  149. tranny bomb
  150. Starting Issue, Please Respond all mastertech/honda techs
  151. 5th Gen SH calipers on a 4th gen si ?
  152. which engine do i have????
  153. Name Brand Turbos
  154. Need parts/installation help
  155. Short Shifter
  156. how much do you think my prelude is worth?
  157. damn cel codes....what are they?
  158. 97 Prelude-Strange Noise While Driving
  159. havin headlight problems!!?
  160. gas gauge wont work on 4th gen prelude...
  161. Tokico Illumina Coilover kit
  162. IAB diaphragm slow to open/close
  163. Bleeding coolant-bleeder bolt
  164. Pic Request: Painted Stock 5th Gen Calipers
  165. 94-96 console ashtray
  166. Euro-R IM Needed parts to finish swap.
  167. EVO front brakes swap
  168. How to take the spring out
  169. Radiator fan won't turn on...
  170. skunk2 pro series IM injector style
  171. s2000 airbag help
  172. idle problems and more
  173. 4bidden Short Shifter 5th gen ?
  174. h22a swap issues!
  175. PnP and EGR
  176. whats missing on this list?
  177. please help....
  178. problem after timing belt change
  179. injector issue
  180. M2B4 lsd tranny help...
  181. Electrical Issues
  182. CEL dim help
  183. anybody know where to buy?
  184. Need help quick: 01 fuse box diagram
  185. new to the game, many questions...99 prelude SH
  186. cant get my headlights 2 work?
  187. Stock Head H22 Cams
  188. couple questions about the 5th gen no2
  189. H22 Flywheel Peep Hole
  190. changing brake pads
  191. windshield strip for 92?
  192. H23 4G Si dropout into a 5G?
  193. Do not buy from ebay member: christinesparts786
  194. EL gauge cluster problem
  195. ok i know the bashing is gonna come so just do it. tranny woes....
  196. overheating issue. help!!
  197. I have a question about my h22 tranny
  198. h23vtec swap problems
  199. will the f22 tranny fit on the h22a4 motor
  200. Compression messed up ~`NEED HELP PLEASE`~
  201. 3rd Gear Tranny Grinding
  202. sprint springs
  203. 5th gen h22 in 4th gen obdII
  204. Radiator fan Won't Turn Off
  205. why does my prelude make a screeching sound when i start it?
  206. Two new problems plus the same old ones
  207. which clutch should i get please need fast re:
  208. 01 Prelude - Audio Help
  209. j32 bb6 go time
  210. Those that done H23A1 to H22 swap ?
  211. new guy
  212. how do i know if my 93 prelude h23a1 is pre wired for vtec?
  213. where to buy?
  214. Exhaust problem
  215. IACV problem
  216. Cam shaft messure stock or aftermarket can u tell by the lobe?
  217. Air/Fuel
  218. mugen replica sides 5th gen
  219. New paint (Super Marine Blue Pearl)
  220. walbro 255 fuel pumps interchangeable?
  221. Odd condition. Missing.
  222. 4gen prelude with supercharger
  223. part numbers
  224. Car dies on stop
  225. Engine grind
  226. would itr cams fit?
  227. 1990 Starter Bolts
  228. Header comparison
  229. New H22 Tri-Y Header Tested w/ Dynos!!!
  230. mods: search is down again
  231. 94 prelude si harness question
  232. Camber???
  233. Tire balance?
  234. USDM H22a4 Vs. JDM H22a4
  235. Honda Prelude Turbo
  236. Cheapest place to buy OEM lip for 5th Gen
  237. Speed sensor oil lines???? on h22a
  238. Tranny Swap???
  239. bore limits and type s
  240. question on GC coilover sleeve kit
  241. heat wrap my header so clutch wont slip??
  242. can someone post a pic of the skunk2 EGR mount kit installed
  243. intake air temperature sensor
  244. Pulled motor. Looking for any advice on my parts list
  245. h22 turbo valve size
  246. Can i see that????
  247. Manifold Skunk2 Vs Manifold Euro-R
  248. When I brake it feels like my brakes have a bump
  249. Problems with brake rotors and replacing lug studs
  250. anyone familiar with
