View Full Version : Honda Prelude
- crank pulley bolt
- Smog Help in SoCal
- salvage title
- Prelude t34s3r!
- Need advice: Friend got a ticket for having a JDM F22B motor (illegal)
- 4gen e-brake
- f22 frankenstein
- broken egr valve = crazy idle?
- is this offset possible?
- 1989 Prelude SI
- I need a good cheap header/DP for my H22A
- Prelude Antenna...
- Prelude injectors
- anti-sway bars on 4th gen
- If you want to keep the WTB/FS threads READ THIS.
- H23 Vtec Swap?
- Prelude stalling
- Replacing axle... ran into alot of problems... please help, i have to get it in by tomorrow afternoo
- Torque Specs?
- 4 to 1 header for 5th gens??
- 95 prelude... slick size
- Need a couple dimensions of an H22 flywheel...
- coil caught on fire today!
- 92 prelude type s compression
- Drag Radials on lude
- radiator direct fitment on 4th gen
- Crank Pulley came loose, now car won't start!!! Please HELP!!
- 4x114.3 wheels
- Starting problems
- 89' Prelude SI
- Transmission gurus - High pitch noise when clutch not pressed in -help-
- How to correct speedometer.
- oil in the spark plugs
- How can you test bad inner cv joints
- msd 6a car keeps bogging and popping?
- purpose of after market steering wheel
- h22a type s
- Tire size on S2000 wheels
- is there a way to keep an amber blinker after tail light mod?
- swapped H22. cranks but wont start. fuel pump not priming. help!! *searched and did everything*
- H23VTEC Turbo build with tech by ludesleep
- Electrical problem
- who was going to buy my h23 parts? lost you phone number
- obd2b to obd2 HELP!!
- Starting problems. Done everything except jump start the starter solenoid.
- LOud Exhaust
- Clutch clicking when engaging
- Starter Problems.....
- 5th gen swap question
- Nitrous Bore ? Also JUN head ok for nitrous ?
- Safe to shim PS pulley?
- New built motor... please help
- ignition pull?
- is normal to run rich with the stock p13 ecu is doing 10:1 AFR
- H22A, built head, power?
- o2 sensor prob
- Clutch not engaging (new clutch)
- turbo car overheats when ac is on at a stop????????? help!!!!
- Cel code 23, knock sensor... possible for sensor to bust in half?
- hondata s3000 vs. AEM ems
- DC Sports Strut Bar Bolts
- Picture Request: WWRS front lip with Accord rear and/or sides
- brake light on in the dash
- Changing Fuel Pump
- LSD vs. ATTS
- Weird symptoms before oil change
- stock timming??
- after crowerII install idle sometimes has trouble catching itself when put in neutral.
- Ebay Turbo Kit
- Need stock H22A1 Rods (pressed wrist pin style)
- 4th Gen Fuel Feed Steel Hard Line Diameter
- sticky clutch solutions?
- my check engine light is on in my 92 prelude
- knockling sound on driver side when i turn right
- throwing a CEL 17 VSS after fixing CEL 23 KNOCK and changing oil - speedo works what could this be?
- megan racing header for si come with a flex pipe?
- Bouncing idle then stalls at stop
- Will This Benefit My H22?
- to those with accord type r style lips
- prelude problem
- best motor for 88 prelude si? To smog or not to smog?
- 4th gen interior swap
- Apexi Exhaust
- Header gaskets question.
- Exterior Side Rear Window Trim- How to replace??? 5th gen
- H22 power rating 5th gen
- does anyone knows how much it would cost to ship a tranny??
- so i'm replacing my busted H23 with another H23
- How many ft lbs of torque for engine mount bolts?
- Low "E" pitch sound coming from the front
- Help about starting to race.
- Is there a difference in exhaust systems for the different model preludes
- civic intake on h23a1 prelude
- What motor is this?
- jdm H22 swap issue
- Accident
- 4th Gen ABS Question
- headlight accents
- accelerator hiccup
- 1997 prelude Tranny Problems
- 1989 Prelude
- Cruise control doesn't work
- How To: Remove P/S on a 5th Gen
- prelude shooting fire
- dsm 440cc injectors?
- sounds kind of stupid
- Prelude Sh radiator
- h22 ignitor no power?
- ? about the f22b
- new clutch and/or flywheel?
- Question about the new Prelude (oil cooler)
- engine noise
- Socal shop that can perform manual tensioner swap 5th gen
- still a noob can't get in contact with bb6-213
- DYNO results US vs other countries
- aem intake bracket
- Replacing axle, how true is this GUIDE to the 5th Gen Prelude?
- euro r intake manifold
- Noise when accelerating?
- my friends prelude
- what is the h22 header made of?
- 4th gen window visor thingies
- 4th gen APEXi world sport exhaust length question.
- One Thing After Another ... D@MN IT!
- Rethreading H22 tranny bolt holes
- stripped head bolt
- !!!!!!NEED GAUGE HELP STAT!!!!!!
- satin silver paint
- Fluid for helping 2nd/3rd/5th gear grind?
- wheel not centered 5th gen?
- stereo mount
- D4 flashing on a H23 (92)
- Replacement B-Pipe
- 1989 Prelude SI
- 509whp/387tq stock h23 bottom end, stock h22 top end
- Why dosnt my H22A have a KnOcK SeNsOr??
- Question About Oil Change
- 450 DSM injector question an timming
- Seats for a 4th Gen
- blew tranny ?
- wheels vibrate during acceleration help
- Type R shift boot on a 5th gen.....Problems
- 4th gen retrofit
- Timing belt (auto tensioner)
- studder then CEL
- starter or ignition problem.....
- Battery Light??
- cams-prelude type s VS. crower stage 1
- knock sensor on 94 h22a swap??
- DC Sports H22A Headers - Collector Sizes?
- What does SH stand for?
- Speedometer and Odometer not working
- is there any way to fix weak rear brakes?
- Question bout engine swap
- h22 or f20b
- H22 hesitating at lower rpm's...getting worse, PLEASE HELP!
- 88-91 Prelude 4 wire O2 sensor conversion.
- h22 Piston Removal???
- How low is the WS2 exhaust for 97-01?
- Dash board parking brake light problem.
- need help on parking brakes
- Another fix another problem (Boosted Prelude)
- Would this fit on an H22 ?
- Muffler ?
- What throttle body to use with Euro-R IM?
- cold air intakesould files
- Prelude & Accord Engines the Same?
- 5th gen DIY's
- engine wont turn over.
- 4th gen : F22a1 / F20A4 ( euro ) camshaft
- Help Request - Koni Shock Install
- Resonator on old exhaust or buy a twin loop
- vss or gauge cluster....
- H22 Mounts for 88-91 Preludes
- what the best chip?
- What Happens At 40 mph?
- I need LESS rotation!!
- Honda Newb
- Cooling Fan Question; 5th Gen Prelude
- HOW TO: Charging your A/C air conditioner conditioning system at home. (crosslink)
- misaligned balance shaft - loud squeel - HELP
- indiglo gauges
- What's the highest springs I can get besides Eibach Pro Kit? 5th gen
- another overheating thread
- Piston Size on 98
- after crower II's trying to find expected hp, could it be the air/fuel tune?
- Centrifugal Supercharger for prelude(h22)?
- Power Problems (91 lude si)
- Is this thing even worth it?
- im new and buying a prelude
- boosted lude - overheating when a/c is on
- Just install tranny, shift very rough, did I get rip off?
- where are you guys buying your OEM LSD trans from!?
- Need opinions on a product . . .
- Very good main relay DIY link
- I'm gonna shoot myself in the face......
- wtf?!?!?! what dizzy is this??
- Opinions
- ECU
- help! dyno tune went wrong
- Compression + Thinner Head-gasket issue...Feedback Appreciated
- starting problem
- Colorado Preludes!!
- Want to run nitrous.... few questions/concerns?
- vtech head on h23!!! opinion
- HELP Help help...cant get belt over the gears because of the auto tensioner
- S2S2 vs Crower stg2's ?
- Starts, stalls and no start: weird problem
- Noth Alabama Ludes - Calling all Preludes in the area
- H23 Vtec - Mahle Gold series pistons... CR questions??
- 4th gen sideview mirrors fit on the 5th gen?
- b16 trans in a 5th gen lude. Will it work?
- Getting tranny cryoed and rebuilt
- A Little OT: John D's Prelude Timeline (56k:Warning Comp Will Explode)
- AEM dry flow filter Vs APEIi dry flow filter
- 4th gen ITR headlight conversion
- sh models
- h22 turbo
- h23 external coil dizzy...can I use my f22 external coil???
- 92 Si 5 speed, Rough clutch engagement
- Prelude factory spring rates?
- How much to replace valve seals?
- my car cranks but wont start! *searched* HELP!!
- broken ripped shifter bushing - what to do?
- Prelude on boost problems, now running hondata
- spring question
- Golden Eagle sleeved H22A4 block *pictures*
- is there a crank fluctuation sensor ?
- usdm p13 vs. jdm p13
- 98 SH running rich, need help.
- 99-01 Prelude Grill
- H22 running lean? picture of spark plug.
- why am i not getting injector pulse????
- prelude window switch
- passenger side tire shaking under accelaration
- Weird noise from timing belt. Recording included
- H22a swap.. need basemap for new p28
- blue smoke
- speed govoner
- Help needed plz... Prelude + Deer + L200 + tape measure???
- Type S piston questions
- Anyone disabled the dimmer circuit on the headlights?
- TPS sensor problem
- should i go turbo or stick with n/a?
- Prelude Helm Manual
- my right headlight keeps goin out
- 96 'lude obd2 f22 to obd1 h22 swap questions
- f22 tranny for better gas milage?
- BlackTrax intake manifold vs Euro R
- cleaning 02 sensor?? replace??
