PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 [235] 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Quick Tranny question for lude gurus
  2. whp and wtq for stock h22a4
  3. 86 Prelude Si on Crx Springs?
  4. 6spd.
  5. H23 TURBO MANIFOLD?
  6. ? about axle peices...
  7. 4WS light always on :(
  8. Clutch/Transmission problem?
  9. Turbo 4th Gen prelude
  10. 97 lude...what is lug pattern?
  11. What kinds of Air Mods do i do to my 01 prelude
  12. Skunk2 Intake Manifold is out at last
  13. Euro Accord R engine swap
  14. Power Enterprise or Greddy or Stock Timing Belt - Which is the best for the money?
  15. Friends car got jacked, how easy is a 5th gen??
  16. mod chips
  17. Wiring for a Prelude
  18. where does this vacuum line go?
  19. My 2nd gear busted, any idea???
  20. mugen
  21. mugen
  22. Whats with the ugly ALTERNATOR wrap?
  23. Differences in JDM H23 vs. USDM H23
  24. fuel regulator
  25. pistons labor?
  26. Tein Installed- Few Q's
  27. droppeed my f22code 8???
  28. Quick question: How many wires are hooked up to the H22 EGR
  29. neg camber with drop **URGENT**
  30. 87 prelude...SWAP
  31. best Turbo kit for 98 SH
  32. H22a type-s pistons/cams
  33. Can Somebody Please Help me?
  34. CEL, no VTEC, and no Code-- HELP! (searched already)
  35. do honda replacement brake pads contain asbestos?
  36. 88 Prelude Auto to Manual
  37. Radio mounting brackets
  38. Just bought a ecu fast question
  39. 1986 Prelude Questions!!!
  40. 91 SI i need a header having trouble finding one for decent price (any help) tried searching
  41. Consequence of not using an EGR
  42. hit a curb some input pleaseee
  43. Workshop Manual '93 model
  44. bilstein...recommended?
  45. Rear Brakes
  46. CF Hoods
  47. -- H4 bulb question --
  48. Smoke inside cylinder head???
  49. Software and Adapter kit for jacking a laptop into a 95 prelude computer.
  50. Finally Dyno'd the new Motor!!!
  51. how to fix synchro?
  52. VTEC controler
  53. H22 JDM Swap
  54. Lude smokey on vtec.
  55. Full advance on timing only 14 deg. .... 1 tooth off on t-belt??
  56. recommended alignment shops in san jose/bay area
  57. ***CEL help***
  58. JRSC and AEM EMS
  59. Info on the 3G Si's
  60. tried everything... i have no vtec
  61. MSD Digital SCI +
  62. H22 Swap Help
  63. Is there any point in building up a stock 4th gen type s motor?
  64. Is there a difference between the USDM and JDM p13's?
  65. Labor on clutch?
  66. BEst Site to buy 1 Tokico shock
  67. Digital Dash short or ECU problem?
  68. How much power can I expect??? over 300whp or not...
  69. Possible head milled too far for tensioner to take up slack??
  70. loud muffler?
  71. Heres my dyno FINALLY and the curse.......
  72. b20a5
  73. HELP PLEASE on a swap
  74. ABS problems
  75. 1988 Honda Prelude Si 4WS
  76. Did you all read the stickied thread at the top of the forum??
  77. h23 camshaft
  78. Fan
  79. Tires???
  80. Clutch suggestion?!?!?!
  81. __::::MUST Read. The Future of this site and forum::::__
  82. Is It possible to take out the atts?
  83. FEA analysis on various strut tower bars
  84. Clutch adjustment possible? 1989 Si
  85. 90 prelude si exhuast!
  86. what how much power out of 6psi on a prelude h22a jdm ?
  87. Modifications/Replacement of OEM intake manifold?
  88. exhaust/header question
  89. I need to ask a ? about using legend rotors on my 4th gen vtec lude?
  90. How much does a stock H22a flywheel weigh and the best lightweight fw for a H22a
  91. need help for n/a prelude. idling and cel...
  92. how to fix TPS code!!!!
  93. VTEC controllers
  94. 4th gen sound sys?
  95. Short Shifters
  96. H22a studders????
  97. 98sh buildup...
  98. P13 OBD1 on a 2000 Lude... will it work?
  99. need some serious help
  100. I HAVE A TRANNY QUESTION?
  101. Gauge face help.
  102. blue smoke burning oil
  103. h23 block w/ h22 rods and pistons
  104. HELPPPPPPPPPPP!!!!!!!!!!!!
  105. Boost is Boost Right???
  106. knock sensor; 5th to 4th gen
  107. 4th gen HID Questions ??
  108. My battery and break light come on at the same time and go off? 5th gen
  109. what oil do u run ?
  110. camera
  111. prelude exhaust
  112. 700 HC running rich u think???what can i do
  113. Help me Bleed my clutch:
  114. Idle Problem.. Please Help
  115. Best Short throw for 5th gen??
  116. Last minute question.. Stage 1 with stock Valve train or Stage 2 more gains
  117. any difference between JDM and USDM intake manifolds? ghetto euro-r?
  118. troubleshooting
  119. which CAMS to go with
  120. prelude exhaust sounds
  121. could use a few ideas
  122. which tranny
  123. Removing Alternator From 89 2.0si? Need help ASAP!
  124. help me i fear the worse
  125. H23A engine
  126. New overseas member - Need help with swap
  127. ATTS Fluid..
  128. h22 vtec engaging but no power
  129. What would not enough backpressure do to the motor?
  130. dc sports dtm exhaust
  131. please recommend mods for a 97 prelude
  132. Performace gains from turbo kit on H22?
  133. covert h23a non v-tec to JDM h22 vtec
  134. Springs q...
  135. Prelude 2.0i F20A4 > which header? which catback?
  136. h22 and h23 rods are interchangable.
  137. Rod/stroke ratio on a h22?
  138. Braking power!!!!!
  139. H22 head breathing better?
  140. ATTS or NOT?
  141. Remove carpet
  142. VAFC 2 wiring instrucions.
  143. help me to decide if I should keep the prelude or sell it
  144. Short Shift adapters
  145. did anyone buy the focus 4-1 sh 97-00 header in ebay???
  146. Newbie prelude help
  147. MAP Sensor getting wet?
  148. MSD question...
  149. Timing Belt question....Decked h23 block.
  150. H22a1 sleeves
  151. Hello from the New Guy
  152. New to preludes
  153. clutch problem, need help!!!!!!
  154. piston on n/a
  155. ground control spring ratings?
  156. GM Syncromesh
  157. Whos hit 12's or below in a 4th/5th gen?
  158. H22 into 88 prelude Si
  159. searched but no luck, help........
  160. Moroso Oil Pan Installation (factory studs)
  161. heres a ? motor runs with no pump
  162. Pulley bolt access
  163. Quick ?'s
  164. I cant find a helms anywhere
  165. Torn Dust Boot On TEIN SS
  166. what kind of mods would i have to do to get a h23a1-a4 to fit in a 1988 honda prelude?
  167. What kind of OBD-I ecu would you suggest? What are ECU differences?
  168. What is the best ..........?
  169. Cleaning the Vtec Seleniod
  170. help regulator or not
  171. Prelude-sized rims (steelies)? OEM Sized?
  172. Ticking noise
  173. 95 h22 sleeving question
  174. Homeless Plug.
  175. Drain coolant for short ram intake?
  176. I'm new at this...and dammit I need answers.
  177. H22a4 head versus H22a Jdm head
  178. Part Numbers for Synchros
  179. If you like Trouble shooting....
  180. Hondata +VAFC?
  181. boost gauge
  182. prelude turns off... HELP!!!
  183. Engine light
  184. Compression ratio with H23 block, Type S pistons and H22 head?
  185. Passenger axle keeps popping out.
  186. what fuel management should i go with?
  187. what size slick should i run on a 5th gen lude?
  188. neuspeed headers?
  189. WTF... Is this correct...
  190. Manual tensioner conversion info is back up
  191. VTEC "holding back"
  192. Direct port nitrous
  193. Need Help Please
  194. better oil pan for h series
  195. someone with a 4th gen helm's...
  196. flywheel...
  197. Timing adjustments
  198. how much does your lude weigh?
  199. trouble starting f22a
  200. will this work, f22a crank, h22a rods
  201. will this work?
  202. nos instead of turbo
  203. H22 OIL LEAK!! WHERE IS IT COMING FROM?
  204. Motor Mount Bolt Broke
  205. time to change plugs
  206. ES Oval tone?
  207. I wanna run 14 psi. Whats a good set up?
  208. Aluminum Block
  209. Radiator ?
  210. Everyone who runs an H22, but is using a different ECU....Check-in Here
  211. Powerfolding Mirrors
  212. DRAG Turbo kit
  213. Which guage cluster??
  214. Timing Belt
  215. I used 10W-30 motor oil in my tranny, is this bad??
  216. 98 Base prelude ecu and VAFC2
  217. accord springs on a prelude
  218. H22A4 Rods vs. Eagle Weight wise
  219. 1992-1996 Prelude Radiator
  220. The final piece of the puzzle is here (Hytech header pics)
  221. In a Jam-- Need help...
  222. Who has consistantly taken an H23 bottom end to around 7800?
  223. h22 manual tbelt tensioner conversion
  224. reverse rice indiglos
  225. can i still boost my 97 lude....?
  226. CEL h22a 4 and 9
  227. Getting Horn to work with Momo Steering wheel
  228. Fog Lights
  229. Camber and Toe on last gen. Prelude
  230. Anyone have ZEAL suspension for their prelude? Function B6 or anything else??
  231. taking off tranny??
  232. starter problem fixable???
  233. boost problems narrowed down
  234. swap question?????
  235. which fuel managent is better?
  236. Distributer caps
  237. Shaking Lude
  238. civic with an h22.... do i need a fuel pump
  239. Camber kit?
  240. What is a 2nd Gen. Prelude good for? Please Help..
  241. Grinding gears shifting into 3rd.
  242. Prelude 97-01 stock rim specs? Tire upgrade information?
  243. does my car have gears?
  244. Brake pads
  245. p13 ecu on a 97 Prelude Sh Problems
  246. stock spring rates
  247. neuspeed header...
  248. CEL: Swapped ecu's and it went away. BAD IDEA?
  249. Engine year
  250. tranny??
