PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 [216] 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. thermostat problem, right?
  2. cams for 3rd gen si w/b20a
  3. idleing problem, narrowed down to the TB
  4. you all remember my beater??? well check this... (teaser pics inside)
  5. TPS sensor question
  6. Help, EZ out use..
  7. which aftermarket gauges really help?
  8. CYP CODE IS COMING ON MY ECU ?????????
  9. Annoying Rattles
  10. Removing rust?
  11. Tein Stech Springs
  12. U2Q7 OEM LSD ->> M2A4 tranny
  13. smaller tire size = slower speed ?
  14. what is the best manual for a 91?
  15. Anyone in the North Carolina area that can work on modifiying H22's?
  16. VAFC 2= stalling motor@@@@!!! help ASAP
  17. Oil problem.
  18. Does anyone have pics of the downpipe bracket for H23->H22 swap??
  19. forgot VAFC 2 password. any way to reset?
  20. a2k5 transmission years?
  21. prelude vs. rsx type s
  22. H23 swap questions
  23. Suspension ???
  24. So I got my new JDM H22A
  25. Building for Turbo soon check my list...
  26. Are intake valves bigger than exhaust valves?
  27. 98 Prelude Amplifier Remote Wire
  28. cold idle start
  29. Uh oh... Possible water in engine.
  30. 88 prelude engine swap
  31. h22 question?
  32. fuel filter
  33. EL Digital gauges on 4th gen
  34. VTEC NOT WORKING ... H22a ..
  35. exhaust $.02
  36. v2 pic
  37. GReddy turbo kit info for 98' Prelude...
  38. Oil being forced out of cyl #4
  39. 97 Prelude SH clutch advice
  40. Engine stand bolts.
  41. I need more hp?
  42. Not tacking right can someone help
  43. B20 and B18 head
  44. Transmission fluid question.
  45. Fuel Gauge Problem
  46. h22 vtec
  47. Who's the guy from CT that wanted my 3" exhaust and misc turbo work?
  48. exhaust question
  49. ASAP: VAFC 2 help.. WIRING and color codes
  50. lip kit installation question?
  51. Conversion
  52. Worn/Blown shocks... How to tell??
  53. Crank Pully Q (2 Engines out of the car.... )
  54. 93' H22 V-TECH
  55. cruise control diagram
  56. !!!!!!!!!!!!!!!!!!P28 with H22 program!!!!!!!!!!!!!!!!!!!!
  57. DC collector mod question.
  58. at what mileage do u change the tming belt for a 5th gen?
  59. Cracked water pump?
  60. FS: Prelude 5th gen base stock exhaust
  61. JDM H22 Thermostat
  62. Turbo Questions
  63. Autometer Water Temp
  64. Which transmissions bolt up to the H22a?
  65. Installed K&N drop in filter, 5th Gen now slower..????
  66. Can anyone help me with security on my prelude?
  67. The heck is this?
  68. Lightweight Battery
  69. H22 in 91 prelude
  70. Timing belt gave out
  71. F23 97mm crank
  72. How much should I shave my head to raise compression .5?
  73. EXHAUST
  74. question on headers
  75. idle low
  76. will wires make a difference?
  77. Type S piston rings?
  78. misfiring ? need some help
  79. slepper exhaust
  80. Cost of new 01 prelude sh engin
  81. 92 Prelude Si / Hard time starting up car / Clutch Problem?
  82. Shop location in Austin, TX
  83. Anyone running 17" wheels with +42mm and 2" drop?
  84. IAT sensor trouble
  85. CEL with engine swap.please help.
  86. should i buy these cams??
  87. Quick question: where the hell does the battery ground on the 4th gen?
  88. I don't think this was posted in the prelude section at all but check this out...
  89. 91 2.0 SI need to reset computer how help
  90. 95 SRV stock Speaker System?
  91. coilovers whats a good set .
  92. VAFC Initial Settings - YES I HAVE SEARCHED!
  93. the H23 beast is almost done!
  94. coilovers on stock shocks
  95. Timing belt noise
  96. mods for the dyno
  97. almost failed smog check on 2001 stock questions
  98. upgrade from stock 5th gen to typeS?
  99. fpr setting
  100. totaled motor????
  101. Valvesprings & retainers installation
  102. timing
  103. Got myself a 93 VTEC...
  104. oil pressure and engine temp
  105. Humming/buzzing coming from alternator/pullies area
  106. Help: 41 Primary oxygen sensor heater :Help
  107. H22a Euro R ??
  108. exhaust manifold?
  109. Tanabe DF210 Springs
  110. Should I Change The Rear Brakes Also?
  111. Neuspeed Race on 92 Lude which camber kit?
  112. how do i remove a steering wheel?
  113. need help quick...
  114. what motor
  115. H23 Auto tranny upgrades?
  116. Prelude Traction Bars
  117. Painting my car... Sunroof & Rear side windows?
  118. back on the dyno.
  119. V6 Prelude
  120. is this a Good price
  121. Steering wheel boss ?
  122. newb question...
  123. Out of the Lude game
  124. AFTERMARKET DECK Dont fit stock bracket??? 94 prelude
  125. arp torque specs h22
  126. Nology Hotwires or regular wires?
  127. Overheated, pulled the head and hated it
  128. car shudders and engine cuts off at times??
  129. Does anyone have a pic of the fuel filter for a 94 2.2 vtec import prelude??
  130. Tokico Illumina's VS KYB AGX?
  131. ECU upgrades
  132. Buying a lude
  133. What number or type of spark plug do you guys use for your 92 JDM H22 ?
  134. did h22a new clutch now prob wit vtec?
  135. Buzz from indiglo gauges...
  136. Metal Frame?
  137. h23 vtec
  138. blueprinting questions
  139. fans not working
  140. Please help!!!
  141. Weird noise from Air Control
  142. Engine running hot at idle
  143. Need information about F22 JDM non-vtec
  144. need help lowerin 4ws prelude
  145. Constant 12 v source?
  146. ps&g trucks suck
  147. what is type s cams fuel pressure stock at wide open throtttle?
  148. type s cams probelm?
  149. H23 Vtec to SH tranny??
  150. throwing error 36 from 4ws system. plz help!
  151. Weird humming noise coming from engine bay, !!!!!!LOUD!!!!!! Help please
  152. Replaced TPS, Still problems.
  153. Whp Numbers anyone???
  154. sr-v ?
  155. how is dc header differetn from greddy besides the name?
  156. FI Prelude Reliablity
  157. Has n e body found a tru short shifter for 5th gen
  158. QUICK HELP spindle nut removal
  159. 35 mm offset wheels do fit!!
  160. rear speakers have a microphone?
  161. Wrong Foglights
  162. 5th gen wheels on a 4th gen?
  163. Fiberglass bond to Carbon Fiber???
  164. A/C compressor blowing fuse
  165. Nopi Nationals 2004 - Atlanta, GA
  166. 4th gen question: Anyone ever change the EL to a different color?
  167. No love for the 80's?
  168. 5th gen trubo kit on a 4th gen
  169. just bought some circuit 8's for the lude and......
  170. ~~ 1997 Prelude: Need Help w/ Brakes ~~
  171. I need help with finding John Goff aka "J B G" the scammer.
  172. LSD question
  173. check this clutch problem out.
  174. Finally Dyno Numbers from JDM Type S.
  175. Prelude Autox Setups
  176. thinking of buying a prelude some info needed
  177. best headers?
  178. Hytech or Prospeed **ordering asap**
  179. anyone change to colored bulbs in the NON EL gauge clusters?
  180. 1987 prelude choice
  181. 1st to 2nd grinds
  182. Buy Stuff?
  183. Need help modding an H22 to 250 whp
  184. vafc and vtec problem(searched)
  185. Got my JDM lights...
  186. Rattling at 3K
  187. Qustion about H22 Boosting!!!
  188. track results ( link to racing ) give me some advice
  189. which one?
  190. 5th Gear Grinding
  191. gas tank cover problems
  192. noob Type S swap question
  193. door speakers
  194. Custom exhaust ?
  195. Vtec Controller question
  196. Opinions needed, H22A New Autotensioner vs. used Manual with 125k Miles.
  197. The official Skunk2 Intake Manifold Thread
  198. MY V tECH IS NOT KICKING IN HELP
  199. antenna jdm switch
  200. Wiring Harness
  201. Looking to lose some weight!
  202. Is the p28 ecu the best choice for NA and skunk2 IM?
  203. Rubbing/Grindding noise
  204. minor clutch squeak normal?
  205. stock coil rating in the H22
  206. anyone know anything about a prelude speedchip
  207. Prelude Vs Del Sol Turbo
  208. Weather Striping Prelude
  209. lowered car tips
  210. 1/4 nightmare
  211. shift cable?
  212. Farting exhaust
  213. c v joint causing problem?
  214. Integra Vs Prelude
  215. turbo h23 plugs?
  216. LSD tranny
  217. Clutch Masters flywheel replacement disc
  218. getting my car fixed... is this to much or a good deal
  219. GM Syncro-Mesh -- opinions
  220. 98 prelude cat question
  221. soft parking brake after major service, tension?
  222. 185whp 150tq JDM H22A OBD1... bone stock with K&N filter + VTEC AFC... good or bad?
  223. JDM H22A Autotensioners
  224. Oil on outside of plugs...
  225. Where to buy black housing headlights? 97+
  226. M12 Head Bolt Pitch. WTF?????
  227. egr lift sensor
  228. I blew the seal in my new turbo...high oil pressure??
  229. Removing pins from ECU harness plugs.
  230. Clifford Alarm help?!?!
  231. reverse glow gauges help???
  232. dsm 450s in 98 sh
  233. Interior light wont turn on!! plz help!
  234. Need help from the prelude guru's.
  235. what ECU should I use?
  236. 91 Prelude 2.1 si stock bogging down; need advice...
  237. What would happen if i paired a UR alt pulley with an AEM PS Pulley?
  238. o2 simulator and egr valve removal.
  239. JDM headlight question
  240. quick question about h22a
  241. needed: help with aftermarket 2nd gen parts
  242. Distributor
  243. exhaust opinions please!
  244. thinking of doing h22 head on h23 block and going turbo is it possible ?
  245. Best setup for N/A ?
  246. Which aftermarket fuel rails work with JRSC???
  247. PO141 bank 1 sensor 2?
  248. Wheel clearance...not enough?
  249. slim radiator fans?
  250. Radar Detector
