PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 [162] 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. TEIN ride problems in 5th ge
  2. New hp method makes 210hp rsx go to 201? And other cars too?
  3. Anyone know all the cell codes from 1-50?
  4. How is 5Zigen Fireball full Cat-Back Exhaust???
  5. Tranny Question: Shifting without clutch...should I replace my tranny fluid?
  6. Engine Swap for 89 Prelude-What will fit?
  7. the SHOP got my car into an ACCIDENT what should i do?
  8. Break Lamp
  9. Abbreviations
  10. what does the engine light tell me?!?!?!-HELP!!1!!!!
  11. stripped philips head.
  12. boring cylinders?
  13. AXLES ??? what kind can i use?
  14. FCUK!!! Why can't people drive in a parking lot? Blue-Green 4th gen owners, step up...
  15. how do you do engine swap?
  16. New car?
  17. CarbonFiber H22 Manifold update
  18. Gas Mileage (searched)
  19. Tuning options...
  20. 5th gen transmission swap>? base to sh tranny? (searched)
  21. the timing
  22. 5th gen transmission swap>? base to sh tranny? (searched)
  23. 4th gen prelude rear bumber, causing too much drag?
  24. 5th gen transmission swap>? base to sh tranny? (searched)
  25. 4th gen cluster
  26. Need muffler. Which brand do you recommend?
  27. WEIRED noise comming from intake?????
  28. SRS light on, no wreck.
  29. going to the bay area this weekend, hoping to come home with a 5th gen!
  30. SRS light on dash...
  31. Coolant hose for intake question
  32. Really hard to shift -stiff- tranny on 01 base
  33. Intermittent power loss when A.C is on
  34. 5th gen transmission swap>? base to sh tranny? (searched)
  35. Old school-I know, but how many 2gens on the board?
  36. changed flywheel but forgot where TDC was
  37. h22 tranny
  38. All Droned out
  39. h22 sleeve removal
  40. accord typr r lip
  41. can rsx pistons be put in h22
  42. how to check for tdc
  43. pinging sound on start up
  44. Another Suspension thread (search down)
  45. oil light
  46. O2 Sensor Extension for my f22a-h22a swap.
  47. 4th gen Prelude quesiton
  48. just fixed my surging idle on 90 prelude...easy fix
  49. My car sounds like a damn turkey...
  50. Something burning?
  51. Spark plugs too big
  52. data link connector?
  53. squeeking sound in my trunk 98 honda prelude base
  54. how much does the h22 block worth
  55. valve cover bolts/studs
  56. which tranny ?
  57. Flat top valves...
  58. will H22 or B16/18 swap in 3rd generation??
  59. Starting probelm!!
  60. quick help... compression test #'s
  61. projector headlights
  62. 4th gen swap question
  63. K&N cone filter sucking in hot air, retrofit it inside the stock air box?
  64. Problem with new shift knob.
  65. 1990 prelude airbags?
  66. skunk2 manifold on h23vtec?
  67. code16 after 6500RPM - little help.
  68. strange noise when decel (searched)
  69. wanted, cf moon roof
  70. ignitor unit in dizzy = ECM?
  71. Blacked out euros
  72. CODE 43: fixing issues !!!!
  73. is the shock blown?
  74. suspension
  75. need help with my prelude
  76. Arai valve seals vs. NOK
  77. Painting engine bay red
  78. my virgin h22 swap
  79. Ski rack on a lude?
  80. radiator??
  81. crank question
  82. h22 long block
  83. Got Thermal?
  84. h22/h23 ???
  85. I can use this crankshaft with new bolt ?? **Pics**
  86. Honda MTF vs. GM Syncromesh
  87. Having trouble shifting at WOT
  88. H23 ecu
  89. direct fit a-pillar w/ gauge pods
  90. Need Wiring Diagram For a H23 to H22 Swap!!
  91. Prelude Car Club?
  92. apexi exhaust
  93. vafcII just installed, questions inside!!!!!
  94. pgm fi relay help please
  95. 17 whp and 11lbs tq from h22 to f22 crank/rod change
  96. What is it?
  97. forbidden short shifter
  98. removing bitch bolt to change t-belt
  99. 93 prelude 4ws + DC low tie bar? WHAT THE F**K?
  100. How do you adjust jdm prelude headlights
  101. suspension and nitrous advice
  102. wich tranny?
  103. 2nd gen prelude charging problem
  104. h22 pistons
  105. What do you think happened?
  106. Timing Belt Question.
  107. brake swap clarification
  108. painting stock lip
  109. jdm or domestic?
  110. Car Wont start after its been running for more than 30 secs.
  111. 1 piece header?????
  112. building cylinder head :)
  113. 4th gen jdm headlights
  114. Lowering my lude
  115. Tailights acting weird with new alarm.
  116. Crankshaft pulley bolt thread size?
  117. Sudden motor noise.
  118. idle problem
  119. Parking/Dash lights out.... Dimmer Switch?
  120. DID YOU KNOW............regarding Hondata s300
  121. timing question
  122. Quick question, did gen 4 ludes come with OEM alarm?
  123. tranny ques?
  124. i broke something, what is it?
  125. 89 Prelude---Headlights or Tailights??
  126. Anyone know how high i can rev???
  127. Carb'd H22/H23 - anyone done it?
  128. 4th gen Lude messed up... Need some help
  129. climate control
  130. 2point6...Help Please...
  131. 3rd gen ludes
  132. need help i sucked up some water tonight
  133. quick question
  134. JUN vs Skunk2
  135. What do you think is causing this hesitation problem?
  136. starting problems on my h22
  137. skunk2 intake manifold
  138. Need help with 1988 Prelude Exhaust -- What do I pick?
  139. Nitrous and preludes (searched)
  140. 5th gen Canadian Prelude Importing & Details/Differences
  141. Paint job ideas
  142. rc injector problem
  143. Want to make $$; Help me swap 23 motor; NYC area.
  144. Trunk Type SH Sticker
  145. Clarify a tranny question for me please...
  146. Carbon Hood Bubbling?
  147. I have a few questions. Can someone help?
  148. Remote start .....stalling question =(
  149. Short question: wwrs kit installation
  150. Distributor/Spark Plug Wire Timing Probelm
  151. What do you guys think.
  152. Are these problems related?
  153. need help choosing car. One or the other(Prelude)
  154. 4thgen prelude retrofit.... 56K OH CHIT!!
  155. base 97 lude manual trand keeps dying and wont start
  156. Going from an ITR to a prelude.......question
  157. vtec components
  158. Trans is trashed. Value of car?
  159. Lucas oil stabilizer
  160. Distributor housing/Camshalf
  161. Need a JDM h22a Thermostat
  162. VTEC wont engage???
  163. How many cc's, sotck H22 head
  164. Differences between JDM H22A and USDM H22A4...?
  165. Will upsizing the wheels/tires mess up the ATTS?
  166. balancer belt removal
  167. 4th gen retrofit
  168. Broken Crank?
  169. Rough Idle
  170. Weird Electrical Problem With Tail Lights
  171. Srs Light BB6 Prelude 1997
  172. Prelude got broken in
  173. 97 manual non-sh lude wont turn off and keeps dying
  174. Prelude S/Si hybrid won't run
  175. what is a blue valve cover h22
  176. RSX seats in a 4th gen
  177. erratic idle problem
  178. Prelude Websites
  179. RS-R or WS2???
  180. H23 Mods?
  181. Will the Final Drive from an automatic transmission fit a manual?? (if so hell yea)
  182. Which Motor Setup is Best?
  183. what the 1/4 times on superchaged lude 92-96
  184. Custom Exhaust
  185. superchargerd prelude throttlebody??
  186. oil/tranny/something LEAK
  187. code (72) cylinder 2 misfire
  188. F22A gears into an H22A Tranny... no one has ever really said yes/no
  189. SH knob on 4th gen? (searched)
  190. Hondata or AEM
  191. Exhaust sound clip
  192. priceing
  193. Surging Idle
  194. jdm h23 valve cover *searched dead pics*
  195. Clutch problem -no pedal pressure. Help me please
  196. how much for engine swap?
  197. will it break?
  198. Engine Replacement Opinions
  199. Idle problems
  200. '85 Prelude running / starting problems / gas leak
  201. rs-r exmag....gt or normal
  202. 1992 4ws.. swapping h22a... which ecu
  203. brake swap clarification
  204. BASE vs SH rear bumper...
  205. Oil Pan Leak. Suggestions?
  206. Tap tap sound
  207. 5th Gen Prelude
  208. car jumps, car hiccups, car sputters at high rpms
  209. Knock sensor to retared timing?
  210. Prelude trans question ?
  211. F20B into a Prelude
  212. sh or base wheels
  213. intake question
  214. electrical problem, cant figure it out
  215. Need Measurement for Cam Lobe
  216. Air Bypass Valve
  217. H22 Acura CL~Issues
  218. winshield defroster not working
  219. aftermarket axles
  220. air fuel gauge hook-up
  221. Turbo Information...?
  222. running p14 on an H22
  223. is this ok
  224. ViS r33 FRONT BUMPER LIP?
  225. What's the best bolt-ons?
  226. Okay how freaking wierd is this
  227. Prelude dyno
  228. oil leak from valve cover gasket
  229. Need help figuring out a Knock in the front suspension
  230. turbo kit..1700$
  231. turbokit..1700$
  232. Type S Tranny?
  233. JDM Transmission TOOTH COUNT
  234. Best Header for a S/C lude??
  235. cylinder 2 misfire
  236. failed inspection
  237. Is This Overhaul Labor Too Much?
  238. What size TB should I get?
  239. switching all lights over to LED..
  240. h22 Fuel Pressure Question
  241. Help!!
  242. Place that sell type s pistons with rings new?
  243. Modify or swap engines
  244. 95 lude or 95 300zx twin turbo
  245. H22a4 to obd1
  246. 2.5" exhaust vs. 3" for an N/A setup...
  247. MSD coil on a JDM H22
  248. Rear Quarter Panel Rust on 4th Gen
  249. Anyone a registered member with Preludeonline.com?
  250. VTEC solenoid screen cleaning... help
