View Full Version : Honda Prelude
- 01 Prelude headlights
- adjusting valves
- Can an ODB2 ECU work on ODBI cars??
- Swapping a 94+ console into my 93
- we should have a sticky about the national meet
- Motor mounts in 97 prelude
- Any one change a wheel stud?
- JDM 5th gen bonnet/scoop ?
- Anybody know where to find a TURBO KIT for a 96' H23 non-vtec prelude!
- Needs opion on first car... lets give him the right one!
- has anyone actually done the 23-Vtec setup?
- P13
- Help!
- Afternoon Drive Turned for the Worse!
- Weird hesitation @ around 5,200 rpms...
- who HAS a Mugen wing on their 5th gen
- h22 a head
- JDM Fog Quest...
- JUN Stage 3 Cams
- trouble codes
- JDM Tranny on UDSM H22A?
- need some help with a clutch...
- what can i do?
- H22 with NOS
- OT: Anybody with a 5th gen need an exhaust?
- 92-96 prelude headlights
- WTB: 4th gen stock shift knob
- help??
- ¿Going turbo?
- does anybody know what brand this is???
- Honda FP cars!
- Cheap, reliable source for H3C bulbs for your 5th gen JDM fog lamps...
- bro got screwed... kinda OT
- weird noise between shifts (4g automatic)
- I think I've figured out the best drop-in NA cams for the H22A.
- "hum" noise when driving forward Prelude 2001
- hotshot header
- prelude headlights
- 72,000 miles: Should I get timing belt & water pump replaced?
- 93 vtec all motor timeslips for u all!
- whats the diffrence between?????
- WTB: 1st Gen Lude 5 speed transmission
- catchcan???
- NA Gods help please
- Catch can in a 5th Gen Prelude
- Will these rims fit my car??
- Possible tranny problem
- 92 JDM H22A Vtec: 96 Octane/5W/30 Non Synthetic recommended by Honda...
- Question about buying type s pistons
- who makes a replica Mugen wing for the 5th gen??
- 5th Gen Automatic Trannys
- JDM h22a Thermostat
- h23a1 trany code?
- RENO, Nevada Meet
- Type S engine?
- H22A4 in 92 SI, Which front bracket to use?
- Prelude Performance
- Honing FRM sleeves.... Service Bulletin SB618958 #18939
- lokking for new websites
- JDM Type S Gauge Cluster *MINT*
- how much can a pair of 96 lude seats go for?
- How much do's it cost to boost
- H22a swap?
- Thermostat Questions....
- Custom catback questions
- prelude info
- How Do I Remove The Headlights on a 4th Gen?
- What Belt does a 94" H22 need with PwrStr taken off????
- FS: 01 Prelude with 7,600 miles!
- '87 Prelude Si- FOR SALE CHEAP!
- difference between rods?
- FS: 17x7 Wheels and a couple good tires
- Prelude SH injectors ratings ( did search )
- NorthWest Prelude Club (LUDEConduct)
- My ride is LOWERED!!! = )
- start a car with busted timing belt
- Prelude w/ 18"
- 92-96 altezzaz dirt cheap
- Headlight turn signal help req'd
- Honda Parts & Accessories
- problem wiht my prelude need ur help!
- mechanics
- 00 Prelude Burning oil
- homie wrecked prelude today - 56k beware
- 4th Gen Weight Distribution??
- just installed the JDM headlights
- Amber turn signal lenses for 4th gen?
- short shifter
- Check out my lude........tell me what u think
- hotshot header...
- should i get Koni shocks??
- H23 Manual Tensioner on H22A, what timing belt?
- What size rims fit good on a 92 prelude si.....
- What is cheaper....
- best exhaust for 90 prelude
- Jackson Racing Superchargers no good?
- People who changed their clutch master and slave cylinders. I need your help
- Best All Motor H22A cams - specs included
- Can I fit 13's over stock-sized '96 prelude VTEC brakes?
- Fuel Line upgrade?
- Lug nut problem
- valves
- 88-91 sideskirts
- Prelude 4th gen caricature
- shops in pa???
- Need a good hi-flow but quiet exhaust
- 3rd gen 2.0 si with a 4th gen 2.3 si ecu???
- where can i buy a shop book for the lude
- h23 converstion
- ARP Head Studs worth it in my setup?
- need header suggestions
- rims from a 2000 gs-r fit on a 92 prelude?
- 4th gen's Rejoice! Spoon CF Chin Spoiler Replica
- Will i ever figure out what tranny i have???? someone has to know!
- Japanese Performance mag - Ludes
- hp in a 97prelude would be?
- PROFEC-B controller...
- Turbo Question
- HELP with wings west air dam! 92-96 wings west "rs" front lip
- can i tap into oil feed on the head of my h22?
- Is my powersteering going bad?? Causing my 4WS light to come on??
- just a quick question
- damn prelude gearing
- 4TH GEN VTEC, Power steering problem
- OptAuto.com
- best oil weight for h22
- wheel width??
- that time for new tires..
- 92-96 JDM headlights
- Good News/Bad News
- Peak HP & Peak Torque
- Tranny ratio/slick sizing question for my prelude (link to drag racing forum)....
- average price for h22 manual tranny.....
- meet in tampa!!
- 4thgen rear mudflaps
- BB1 Mugen Front
- Turbo kit...
- Small CV boot leak
- what tranny for a B20
- intercooler fitment
- cam shafts
- need Iceman intake CARB EO number!
- ANY LUDERS IN AZ, or around the ASU area?
- If you were buying 4th Gen or 5th Gen VTEC
- CF Trunk just arrived!
- n00b, just saying hi.
- About how much do you change your oil?
- Need Help Quick
- header gasket for DC headers. Buy new or stock work?
- Brake Question?? Help Please
- 1/4 times
- Fuel line question
- water in spark plug holes
- Super chips !!!!!!!
- hub removal...
- Idle adjustment screw, screwing itself in?!?!?!?
- new upper control arm ball joints greased?
- Shift Lights
- Car pics from Japan
- leaky tranny???
- Bay Area Meet is STILL on!!!
- Wanna be Racer. (pic 56k?)
- 4th Gen Prelude Corner Lights
- HID's Installed! (Hella 7500K) So damn blue!!!
- My cousin picking up a lude..see if you guy can help
- Lube job for 3rd gen
- Diffusers
- TEIN sus
- Who has boosted H series with F22 tranny?
- Leather seats.
- Tranny warantee????????
- question about prelude seats
- P13 ecu chips.. which is better? pros? cons?
- Need help ASAP...cxode 43(fuel supply)...what to do now?
- Quick Flywheel Q...
- sway bars and strut bars
- Jrsc Owners...
- Nitrous Question? 70 Dry and 75 Wet
- Happen to find this...
- 97 Prelude offset
- Apex'i VAFC???
- h22a - Best underdrive Crank pulley ?????
- Is Greddy a good a exhaust?
- Any one selling OEM Add on kit for 97+ prelude
- the 97 preludes did they come in any funky green colors???
- Silvia 15 or Type R Headlamps
- mugen header
- Is This Bad?????
- need your knowledge
- Those of you with Boosted H22
- Torque Converter Article from Import Tuner mag...
- horse numbers for a n/a lude?
- oil pan gasket
- Since I lowered my car the inside of my tires are wearing what can I do?
- knock sensor LED?
- Dyno charts for stock H22a's...
- 4WS question
- fast and the furious 2 trailer...
- 96 prelude H23 to H22A engine swap
- Spark plug temp for JDM H22
- f22b swap
- My future setup
- More stupid Turn signal problems.. NEED HELP!!!
- Finishing Touches on 93 Vtec
- noise coming from the engine!!!
- boosted ludes, clutch question?
- chipping problem
- Valve adjustment
- 97 and 98 brake rotors vs 99 to 2001 brake rotors
- Pics after a wash
- to those w/ blk housing JDM headlights...
- this is for the moderators...
- JDM H4/H1 Harness
- how to get rid of orange bulb in tailights??
- SHOCK knock!
- Anyone have a stock rear bumepr they'd like to sell?
- Clutch recommendations for my planned driving
- OT: but members corner is closed.........
- Exhaust rattle??
- Jdm Headlights installed
- H22 pistons in H23...
- Ground Controls on Koni Adjustables... GOOD SETUP???
- fuse for ecu reset
- Stromung Exhausts
- Remove rear seats?
- OEM parts and diagrams
- Balance shafts eliminated!
- 450 turbo h22
- Auto SS to 5spd Manual Tranny swap w/ LSD
- price of sleeving block
- H22a Downipe from 97-01 does it fit 92-95 or not ????
- All H series knock senors the same
- UPS was here!
- Spraying
- Does anyone have the APEXI world sport exhaust on their fifth gen?
- Wiring help for VTEC
- New pictures...
- used online parts store?
- 96 Prelude SI SE mods
- headlight query
- 4th gen dash
- Tranny questions
- whats the difference between 97 and up h22 VTEC motors and their earlier counter parts.....
- Searching For 92 Lude Headlights
- Heater and Radiator Question
- For those who have bought an aftermarket header for 4gen Vtec
- anyone have any extra exhaust valves?
- Huge problems with car
- help all mechanics
- FS: Prelude Tranny. LSD, CM Stage 3, Jun FW, Custom Final Drive
