View Full Version : Honda Prelude
- Hi there!
- Intake manifold butterflys
- 4th gen "traction bar" setup
- carbon fiber body kit
- Hood Dampers
- I just Got an 2000 Prelude Sh
- throttel body sticking CLOSED?!
- Just got a 93 prelude vtec..need help to remove radio
- 91 prelude, need help ASAP!!!!
- short throw shifter 98 h22
- Need help to identifique this chip p13z ECU
- HELP
- Coolant smoke only while warm
- F22block/H22 head, in a 4th gen.
- first time repair
- clutch adjustment??
- new clutch needed, what should i get?
- correct me if im wrong
- 2001 Honda Prelude SH
- Auto-to-manual on 4th gen.
- full carbon fiber body kit? is it real
- new motor won't start
- Help with an 89 prelude turbo
- electric window and sunroof problem on gen4
- Sucked in water, now wont start
- having issues with my 97 prelude SH
- H2B TWIN DISK TILTON FROM EVO
- Headlight Wiring
- ATTS ???????
- heater hose temp
- 99 honda prelude hid fitment problem
- What are you wiring your gauges off of
- manual tensioner question
- mugen header
- Can't figure out what wire on my ECU is the o2 signal wire for air fuel please Help
- 01 prelude HID bulbs too long?
- 93 SI wobbly right wheel
- lower ball joints
- help on 1997 prelude
- Help Shock Knock!
- Head lights issue
- 97 Prelude Base SS JRSC ?'s
- Wrong water pump?
- Need Answers
- 2 missing o2 sensors make ATTS light turn on
- Fake spoon P13 Ecu or Not ? (pics inside)
- ep3/s2k steering wheel fitment problem (pics)
- TP sensor leading to other problems?
- pressure in clutch
- itb or turbo?!
- okay i dont know what this is...
- Mark 4 JDM H22A 4WS Prelude Rear Suspension - parts required for an overhaul
- prelude tranny concern, thinking of buying
- HID / Projectors on my 4th gen
- Flat Black Prelude
- Swapping a H22A1 into a Si
- Odd Piston wear
- Fuel pressure question
- F**K Importbuilders
- checking engine for bad piston rods
- Koni Yellow differences?
- turboing a h22 prelude..
- car dies when i start it up then runs fine after
- 92 Si - How do I remove the rear/center top garnish?
- black housing headlights??
- Ignition Problem After Alarm Removal
- stuck on shocks
- Just wanted to say thanks to a great place...
- Huge oil leak!
- track car interior rewiring
- never hooked up an M2 B4...
- not sure what the problem is...
- 99 is dead again- suggestions?
- is gt35r to big
- msd ignition h22a
- Is there a drain plug on a 5th gen gas tank?? I've got 4 year old gas in my tank.
- What is this connector for?
- OBD2 Distributor install question...
- 93 Si auto trans problems
- After putting some gaz car won't start
- what kind of gains with these mods and a ecu tune do you think I could get
- "Brake Light" in guage cluster
- Car died last night in the middle of the road. More details inside ...
- What did I do?? Clutch pedal has no compression...
- JDM Bumper Support
- So i burn oil and i have white smoke coming out my exhaust
- Prelude S and Si
- East Coast Racing-BOOOOOO
- Thinking about a 97 Prelude I found
- What is the purpose of the metal ring for the flywheel?
- How can I tell apart a 93-96 vtec from a base.
- Partially deployed airbag? WTF?
- Help! Asap!
- 98 Prelude upgrades?
- Poor mans LoJack = Zoom Bak
- Technical question on Tach Signal - 93 Lude
- Throttle cable tight, no slack
- Greddy Header on SH
- Adam's 4th gen Riced out Restoration
- USDM 5th gen fogs
- question about h22a distributor
- Clutch Info.
- Type SH Header Gasket.
- Intake rubber seal cracked...where to purchase?
- is there a way i can tell if i have a type s h22a?
- Vacuum lines
- jdm parts heaven!!!!!!!!!!!!!!
- problem with my front 2 rims.
- simota aeroform 2 Intake
- Please Help me
- Compressing slave cylinder? Plus other slave questions...
- Replacing steering knuckle
- bolt on stock h23 oil cooler
- Needed: '91 Prelude cigarette lighter
- 1992 prelude convert to manual
- VSS Problem
- USDM Fogs + HIDs
- Car won't start
- My Supercharged H23
- How to check for bent valves.
- weight reduction
- Stretched tires...
- MTF refill
- underdrive pulleys for 98 SI
- H23 and H22 crank pulley bolt
- Easiest way to install headlights
- wiring v tec on a 92. $5.00 for the right asnwer!
- Suggestions for whining whirring engine?
- prelude stanley fog lights?
- idle problem. i know another thread on this.
- stupid second gear question
- do acura TL type-s rims fit on the 5th gen
- @@@@ Help Pirate choose the next F23-based Winter build @@@@
- H22 Ebay Header
- Need one persons help
- Brake rotors and calipers
- E-brake light on my display cluster stays on when really cold outside
- vacuum lines??
- Annoying Vibration
- Oxygen sensor voltage 93' V-tec
- Oxygen sensor voltage 93' Prelude V-tec
- h22a4 head and h22a block???
- What are these 2 random pieces left over? [pics] Also, intake mani support bracket question...
- 98 honda prelude swap with h23a3...help
- help clutch stopped working on my 98 lude are all h22a and f22 clutches the same spline and size
- Prelude nine spoke wheel direction
- No service connector!! H22A obdII to I conversion Retime dizzy????
- ABS light wont show when i turn the key to on? is that a problem??
- modified oem H22 intake manifold
- Announcement: EVERYONE PLEASE READ
- Balancer shaft seal Q..
- Heater not working
- Changed thermostat, now spedo and tach are acting funny
- At the last part. Balancer belt and TDC
- Air intake
- Looking to do a swap..
- Oil cooler question
- Starter question!
- How the h3ll do you route wires through the bulkhead?
- where is the vtec oil pressure switch on an h22a
- f23 bloch h22 head
- 95 electrical problems
- 4th gen....w/ broken door lock...
- Engine Builders please help with bearing clearences
- Theres Gotta Be A Away
- ecu swap cel light
- Air/fuel ratio gauge connection? Help!
- 55 Watt HID's?
- Code 43: Fuel Supply System
- valve timing oil pressure switch.
- How many Si
- Strange intermitten humming noise
- H22 speed sensor help
- What distributors work with an H22A?
- rims!!!
- H23a and H22 difference
- Just wondering if a H22A4 head is compatible with an H22A block!
- 2000 prelude radio wiring
- G23 vs sleeved H22 for boost
- 98 prelude rear wheel drive conversion??
- I want to *gasp* make my prelude quieter!! :P
- My 93 prelude miss fires unless i'm on the gas hard. Please help
- new here: My 1993 Prelude
- M2b4 LSD shift cables?
- Car ran rough yesterday Now wont at all! Need some help to find problem!
- blown head gasket
- Summit racing fuel filters
- vss question
- why does my p13 h22a1 redline at 6500?
- bypass speedo
- Safe to use Type S cams and pistons in USDM H22???
- has anyone tried venom im for the h22a?is it worth it.opinions pls
- H22A4 into a 93 prelude?
- Clutch help
- Idle Surging testing questions
- Electric Grounding kits?
- do I need to get my ecu tuned if?
- Accord Euro R or Type S swap?
- Just installed timing belt and when I turn the motor over it slides to the edge of the tensioner...
- Doing Timing Belt, Where Does Maintenance Hole Lead?
- Skunk2 Intake Mani on 99 SH.
- Have clips and nipple that are unplugged, where do they go?
- Lowering Alignment?
- Pic Request- 5th gen with USDM Fogs.
- arrgggggg what is wrong with my car !
- dash light replacement
- H23 Megan Header info.... (JDM F22B fit)
- 4th gen speaker problem. 5th gen radio.
- Need Help with H22a swap into 92 prelude Si
- need new catalytic converter & test pipe...questions
- Clutchs
- H22a4 to type s conversion, help. Pistons P5P JO
- obd1 distributor on obd2 h22a4 swap HELP!!
- H22A4 rebuild
- I need an ecu Pinout for a 1992 f22a1 Prelude
- Quick questions for those with an OEM windshield (5th gen)
- Clutch Issues on my 2001 Prelude
- Should i buy this 89 prelude si fo $1700???
- no vtec
- no speedo no vtec
- pink wire on p13 ecu
- kyb agx's on SH
- 98 prelude with h23a3 bottom end and rest of it stock..... need help no spark but everythign turns
- new 3" collector header question
- Bumper problems
- wheel shaking and creaking when turning 4th gen. help please
- JDM H22a Swap
- (searched) acura cl wheels on 4th gen... is it even safe!?!?
- Tokico Suspension??
- Two boots ripped. Question on them.
- lowering the prelude a little
- car problems after mech looked at it
- thread pitch/size on 4th gen downpipe
- Can I get rid of my ATTS diff. Will this work and how?
- Can you hook up vtec to your horn button? If possiable how so???
- Clutch question?
- Advancing timing- Pros and Cons?
- Auto H23 prelude? How much tranny fluid?
- SE and Si
- Hey someone please read this. i need help..
- Prelude with a jdm F22, Tune up what to use?
- thinking of putting new engine in
- Lower Cover Removal for timing belt
- H22 Questions
- Have spark and fuel...still wont start
- Help finding a 99 lip
- jdm h22a thermostat
- usdm f23 5th gear into T2W4
- Overheating Problem on 91 si
- jdm p13 on usdm h22a1 redline 6500?
