PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 [242] 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. what exactly is a vfac?
  2. best clutch for my turbo prelude
  3. 5th Gen Tranny-Cold Weather Question
  4. b series throttle body on h series intake manifold
  5. Type S Piston .25 OS part number
  6. where to look??
  7. Looking to Stiffen up 4th gen suspension and lower
  8. WTF?
  9. 5th gen with factory wheels tire size question...
  10. H22 Engine codes?
  11. yo, how much money?
  12. disabling the EGR system - possible?
  13. which injectors
  14. Looking For a 95 Si dash Cluster (Need tach And Speedo assembly)
  15. Ratling header
  16. CEL #6 an #20 on p13 ECU question
  17. Help with h22!! Someone that TRUELY knows about this...
  18. Modified DC or Greddy Headers
  19. best ecu for use on a h22a4 p28, p72 or p13
  20. Problem with my prelude
  21. H23 TIMING, How the heck do you do it? Ive tried everything
  22. 4TH GEN Lowering
  23. H22 Computer problems
  24. Exhaust switching
  25. F-max, Drag, Greddy???
  26. The Time Has Come To Sell My Lude. Please Look.Mod Approved.
  27. **building F20B, need some help on some info**
  28. manual tensioner conversion part numbers
  29. Strut Bar on 4WS
  30. *****H23 stripped crank pulley internal threads can i drill and tap it?, any suggestions or experien
  31. Where can I find H22 block
  32. how easy is it to replace an oil cooler gasket? (92si)
  33. advice on remote starter / car alarm for my 98 SH.
  34. People who have used acl bearings please HELP
  35. Brake Change
  36. ECU HELP!!!
  37. Injector questions...jdm, usdm, and ecu
  38. 4th Gen Magazine Articles -Back by request
  39. hondata experts p72 question
  40. what would be fair price??
  41. aftermarket fuel pump & fuel pressure regulator help
  42. new act clutch, what to do about flywheel
  43. necessity of valvetrain upgrades
  44. Clutch Feeling
  45. F22 series engines
  46. HELP REAR TOE!!!
  47. Saenz Performance 4.364 Final Drive
  48. Where to get universal rails for a 4th gen prelude?
  49. Brake question for 92 S
  50. Nitrous Express Ntercooler Kit or a 30 Wet Shot
  51. clutches and flywheel suggestion's (accord hybrid)
  52. 5th gen side skirts
  53. 2000 prelude nitrous
  54. 5th Gen Shifting
  55. Intermediate shaft removal 4th Gen
  56. Brake Line Problem
  57. Oil Pressure Specs?
  58. question on the slave cylinder...
  59. Info
  60. Greddy e-manage
  61. do i have to run premium?
  62. Check engine light, how do you code it?
  63. high compression and nos
  64. Is my Dream Practical?
  65. S&S Headers or Pacesetters for an 86 Prelude SI A20
  66. OEM Spring rates
  67. re-occuring bad spark plug issues...
  68. What would you do with $2500
  69. thinking about lowering my 91 prelude... need advice
  70. B-Series plug wire cover?
  71. Simple question
  72. Gauge-Type Wideband UEGO Controller
  73. some info needed
  74. JDM one pieces install help
  75. 93 F22 to H22AJDM Distributor
  76. swap options or ideas
  77. problem with my prelude
  78. trying to jump for cel
  79. H23 massive oil leak from waterpump crank pulley area?
  80. Knock sensor question
  81. Prelude GTP front lip, and "whale tail" spoiler help?
  82. prelude help
  83. 5th Gen RollCage
  84. Raxles or Enjo axles?
  85. Prelude wont rev pass 6500 rpm help
  86. ride quality w/aftermarket coilovers and shocks
  87. Second VTEC???
  88. question regarding ecu
  89. color of ignition wire
  90. FWD - RWD ?
  91. which throttle body for Golden Eagle Intake Manifold
  92. h22 on f22 tranny?
  93. JUNKYARD TURBO
  94. 4th Gen Airbag reinstallation
  95. magic h23 tranny??
  96. Tokico Suspension
  97. Oil Pump O-Ring... WTF??
  98. HELP!!! I DROP THE LOCKNUT DOWN THE PORTS!
  99. dissplacement calculator---- how much to bore H22
  100. SH header wont fit H22---------- are they different
  101. Someone actually did this..B16 in Prelude...
  102. What the hell can it be?!
  103. gauage swap??
  104. Who says you can't boost a stock H22???
  105. rroom inside the dash? :updated:
  106. stock prelude h22 and h23
  107. tranny problem 88 prelude
  108. 5th gen Prelude lug pattern????
  109. msd ignition install on h22
  110. h22 w/ ACT flywheel
  111. Bad gas...What to do?
  112. Cooling system upgrades, what options do I have?
  113. Mugen wing...
  114. amber bumper lights??
  115. VSS compatability
  116. 92 h22 intake manifold????
  117. 2000 honda prelude nitrous express
  118. Installing an intake on a 96 lude
  119. h22 shifting problems???? Helppp Please!!!
  120. Dry sump Oil systems
  121. ? about the 97s and the 98+
  122. Cant start car after distributor got wet
  123. DIfference between prelude sh and regualr prelude?
  124. 911 HELP 1988 Honda Prelude Electrical Drain problem!!!!!!!!!!!!
  125. BORED AND STROKED!
  126. Best place to buy greddy headers
  127. Wondering what people got there SAFC/VAFC set at for their turbo lude
  128. High output alternator for 4th generation H22A?
  129. How much of a NX express shot for a strong running f22a1?
  130. Throttle position sensor
  131. battery relocation
  132. h22a idle problem
  133. Greddy Turbo kits Owners
  134. the rest of my p.s. story...
  135. question for yOu HIGH horsepower prelude owners
  136. Need help with a website
  137. h22a4 recalls?
  138. SH owners!! clutch question
  139. Transmission problems. HELP!
  140. 1/2 vtec...
  141. hi, new here
  142. turbo charge or supercharge my h22???
  143. Lowering caused alignment problem
  144. What whp yo have seen H22 putt down?
  145. jdm cams usdm cams
  146. Type SH diagnostic
  147. new ht member
  148. PCV VALVE CLOGGED NOW OUTRAGEOUS LEAK!!!
  149. H22a and SH Atts tranny
  150. h26a1 question again
  151. Auto to Manual Tensioner on H23 VTEC...Belt Doesn't Fit!
  152. Which 5th Generation and Why?
  153. Bolts on the Tranny side of the block.
  154. Fmax Turbo kit Gaskets -Bolts
  155. h22a final drive in f22??
  156. Will these rims fit?
  157. Can you Estimate the Value on this stuff, I have no idea...
  158. checked the check engine light 61
  159. h22 turbo or supercharger???
  160. need help with cam gears at TDC
  161. Block Guard (Now or Never)
  162. Nitrous for H22
  163. My 4th Gen SRV
  164. k20a in a 92-96??
  165. Knock sensor pin out needed!
  166. OEM seals and moldings
  167. Pls Help...! H22a Turbo or Supercharge.....? pls help.....
  168. 92-96 Prelude Speakers... What are the sizes??
  169. Am I getting overcharged for this intake?
  170. 95 PRELUDE ECU WIRING DIAGRAM NEEDED!
  171. Will overall diameter be the same?
  172. Searching for information on Prelude/Accord Manual transmissions
  173. help: my idle is surging.
  174. H22 hatch. She's finally roadworthy! (pics)
  175. Strange ABS problem
  176. leaking power steering fluid...
  177. h26a1??????
  178. O-Ring In Head and Bottom Of Motor (Oil Girdle)?
  179. fuel rail compatible ?!
  180. ECU questions, and jumper information....
  181. Car's dying while warm up...
  182. Wheel Weight
  183. yeah will the jdm 95 vtec prelude gauge cluster fit on my 92 prelude
  184. need some info about New Jersy
  185. Upcoming Dyno Session
  186. Exedy Clutches
  187. spark plug gaskets
  188. Help!!! Cant start my car!
  189. What's this and can I take it out?
  190. 314 whp on H22 turbo
  191. Bulb Question
  192. drag gen 4 turbo kit for 5th gen sh
  193. Cricket in the exaust
  194. My boosted lude... Turbo selection question
  195. RWD Turbo H22, 5th gen.
  196. vtec is one or two stage on a 97 lude
  197. SOcal heds equipment?!?
  198. 90K Service
  199. turbo spark plug questions what size?
  200. Header question??
  201. Speedometer cable replacement in 89 Prelude - Help
  202. BatterY HELP!
  203. JDM Motors
  204. jdm motor, does it have a oil switch???
  205. Camera mounting on a 4thGen.....
  206. Clutch gurus: Help needed please
  207. what happened to the roof plug?
  208. ANY1 SELLING BLACK LEATHER SEATZ FOR A 99 PRELUDE
  209. Prelude Type-S tranny
  210. ford mustang throttle body
  211. can 97 h22 distributor fit 94 h22
  212. puttin new honda emblem on my 4th gen lude....
  213. greddy certificate..
  214. what kind of engine stand?
  215. Integra LS (B18B) in a 1989 Prelude (B20A5)
  216. Digital Custer Help
  217. sor so that the honda computer will read itford throttle body
  218. 5Gen turbo misfire issues ?? maybe fuel?
  219. where to get prelude Fuel pump?
  220. consume too much oil...
  221. rpm jumping at 1500 to 2000 rpm
  222. black smoke
  223. If you have an Auto-starter *Read This* (repair advice also needed)
  224. ATTS: hose on top of the atts.
  225. Could this problem be the distributor?
  226. removing air bags...
  227. How can I tell if I have 345cc Prelude Injectors???
  228. crower stage 3's and lma's ??
  229. 98 Turbo SH issues -
  230. racing wheels
  231. 85 Prelude Radiator
  232. is this a good deal
  233. ????????
  234. how do you know if its real type s cams or not ?
  235. will 01 prelude jdm type s header fit on 1993 h22a 4th gen lude?
  236. 5th gen prelude interior light color is?
  237. h23a1 to f22a6, how to??
  238. GReddy SS Header come with Gasket?
  239. 5th gen and 4th gen H&R's?
  240. auto to manual tensioner, can i remove this??
  241. need help from you prelude gurus .......Head stamp & what they mean....
  242. How do you reset the check enging light?
  243. motor swap gone bad
  244. Some new Clutch Kit don't need to be break in, True/False?
  245. Help! What is the Average Clutch Installation Labor?
  246. bolt b torque specs
  247. drop height
  248. Tire Size Question
  249. Fastest All Motor 5th gen
  250. Jrsc Vs. Greddy Turbo for 98 base
